Не могу отправить посчитанные задания на сервер. Уже четвертую делаю, а предыдущие не отправляются.
Выглядит примерно так.
[16:02:01] Completed 247500 out of 250000 steps (99%) [16:11:08] Completed 250000 out of 250000 steps (100%) [16:11:10] DynamicWrapper: Finished Work Unit: sleep=10000 [16:11:20] [16:11:20] Finished Work Unit: [16:11:20] - Reading up to 21204144 from "work/wudata_00.trr": Read 21204144 [16:11:21] trr file hash check passed. [16:11:21] - Reading up to 27699936 from "work/wudata_00.xtc": Read 27699936 [16:11:23] xtc file hash check passed. [16:11:23] edr file hash check passed. [16:11:23] logfile size: 181224 [16:11:23] Leaving Run [16:11:25] - Writing 49230056 bytes of core data to disk... [16:11:25] ... Done. [16:11:36] - Shutting down core [16:11:36] [16:11:36] Folding@home Core Shutdown: FINISHED_UNIT [16:14:44] CoreStatus = 64 (100) [16:14:44] Unit 0 finished with 78 percent of time to deadline remaining. [16:14:44] Updated performance fraction: 0.762756 [16:14:44] Sending work to server [16:14:44] - Already sending work [16:14:44] Trying to send all finished work units [16:14:44] - Already sending work [16:14:44] - Already sending work [16:14:44] - Already sending work [16:14:44] + Sent 0 of 3 completed units to the server [16:14:44] - Preparing to get new work unit... [16:14:44] + Attempting to get work packet [16:14:44] - Will indicate memory of 2004 MB [16:14:44] - Connecting to assignment server [16:14:44] Connecting to http://assign.stanford.edu:8080/ [16:14:54] Posted data. [16:14:54] Initial: 43AB; - Successful: assigned to (171.67.108.24). [16:14:54] + News From Folding@Home: Welcome to Folding@Home [16:14:54] Loaded queue successfully. [16:14:54] Connecting to http://171.67.108.24:8080/ [16:15:03] Posted data. [16:15:03] Initial: 0000; - Receiving payload (expected size: 4838625) [16:41:22] - Downloaded at ~2 kB/s [16:41:22] - Averaged speed for that direction ~5 kB/s [16:41:22] + Received work. [16:41:22] Trying to send all finished work units [16:41:22] - Already sending work [16:41:22] - Already sending work [16:41:22] - Already sending work [16:41:22] + Sent 0 of 3 completed units to the server [16:41:22] + Closed connections [16:41:22] [16:41:22] + Processing work unit [16:41:22] Core required: FahCore_a2.exe [16:41:22] Core found. [16:41:24] Working on Unit 01 [June 4 16:41:24] [16:41:24] + Working ... [16:41:24] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 01 -np 4 -checkpoint 15 -forceasm -verbose -lifeline 5368 -version 602'
[16:41:24] [16:41:24] *------------------------------* [16:41:24] Folding@Home Gromacs SMP Core [16:41:24] Version 2.07 (Sun Apr 19 14:51:09 PDT 2009) [16:41:24] [16:41:24] Preparing to commence simulation [16:41:24] - Ensuring status. Please wait. [16:41:25] Called DecompressByteArray: compressed_data_size=4838113 data_size=24028541, decompressed_data_size=24028541 diff=0 [16:41:25] - Digital signature verified [16:41:25] [16:41:25] Project: 2671 (Run 36, Clone 67, Gen 42) [16:41:25] [16:41:25] Assembly optimizations on if available. [16:41:25] Entering M.D. [16:41:32] Multi-core optimizations on [16:41:35] .D. [16:41:42] Multi-core optimizations on [16:41:44] Completed 0 out of 250000 steps (0%) [16:50:51] Completed 2500 out of 250000 steps (1%)
Черт. уже дедлайн для первой сделаной, но не посланной жабы, прошел. Даже не представляю куда копать. Даже комп грузанул. Вроде все нормально было до 2 числа. Добавлено спустя 1 час, 25 минут, 12 секунд В процессе выполнения пытается отправлять, но не получается:
[07:57:48] Completed 242500 out of 250000 steps (97%) [08:00:29] - Couldn't send HTTP request to server [08:00:29] + Could not connect to Work Server (results) [08:00:29] (171.67.108.24:8080) [08:00:29] - Error: Could not transmit unit 00 (completed June 4) to work server. [08:00:29] - 1 failed uploads of this unit. [08:00:29] Keeping unit 00 in queue.
[08:00:29] + Attempting to send results [08:00:29] - Reading file work/wuresults_08.dat from core [08:00:31] (Read 48662999 bytes from disk) [08:00:31] Connecting to http://171.67.108.24:8080/ [08:07:03] Completed 245000 out of 250000 steps (98%)
камрады,
я, конечно, понимаю, что вопрос не по теме и он и вас уже окончательно утомил, но все-таки: слышно что насчет ГПУ клиент под линукс? может какие-нить хотя бы признаки появления сего чуда намечаются?
или мабыть тупо докторам на форуме отфлудиться?
Сорри, если баян, но поиском ничего не нашлось на эту тему....
Кто-нибудь использует кластер для F@H? Если да, какой дистриб, какой софт? Если не секрет... У меня имеется 10-15 свободных десктопов, не могу понять на базе чего лучше сгородить огород? Или всё это ерунда, просто наклонировать с одного образа уже настроенных?
Статус: Не в сети Регистрация: 30.01.2006 Откуда: Химки
morten666, конечно копируй. Хотя была статья в инете, кто-то поднимал смп на четырех одноядерных компах. Но оно того не стоит.
_________________ 5 мая начинается The Chimp Challenge '2010! Присоединяйся к российской команде! Инфо: http://forums.overclockers.ru/viewtopic.php?f=21&t=351237
Lendy, ясно, спасибо. А насколько плохо, что это двухядерники? У F@H на сайте написано, что лучше всего 4-хядерными считать. Не получится быстрее, если наделать виртуальных 4-хядерников и на них запускать? Сомнительно, но вдруг...
morten666, не будет. На двух ядрах смп пойдет скорее всего. Какие двухядерники?
Eisenhorn, гпу через вайн.
Статус: Не в сети Регистрация: 03.06.2009 Откуда: Евпатория
Ребята подскажите пожалуйста. Я пользователь Linux с недавнего времени (около полугода). Пока считал только на ЦП, хотя смотрю, что на видюхе считается лучше. Но как-то боялся поставить эти CUDA драйвера. Вчера набрался смелости и поставил (оказалось не так уж и сложно, если внимательно читать факи). Пользовался FAQ http://www.overclock.net/overclock-net-folding-home-team/436453-how-gpu2-folding-linux.html, который вынесен в топик. Шаг за шагом внимательно все воспроизвел. Но при запуске выскакивает ошибка: [04:44:04] Folding@home Core Shutdown: UNSTABLE_MACHINE Вот лог:
Код:
# Windows GPU Console Edition ################################################# ###############################################################################
Система: Ubuntu 9.04 x86-64 (драйвера качал 64 бита, тулкит 32 бита - версия 2,3). Видеокарта GeForce 8800GT не разогнана. Раньше (под виндой) я на ней частенько играл. Никогда никаких проблем не возникало, работала всегда стабильно, никаких нареканий не было. А считать не хочет. Можно ли помочь моему горю?
