Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 2644 • Страница 35 из 133 • <  1 ... 32  33  34  35  36  37  38 ... 133  >
Полный список STOP-ошибок Windows XP.
Изучение FAQ строго обязательно.
Не забывайте прикладывать минидампы - файл(ы) из директории Windows\Minidump
Код:
Microsoft (R) Windows Debugger  Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini071307-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700
Debug session time: Fri Jul 13 19:14:51.359 2007 (GMT+4)
System Uptime: 0 days 1:36:05.042
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck C2, {7, cd4, 2100001, 84208f88}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Unable to load image nltdi.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for nltdi.sys
*** ERROR: Module load completed but symbols could not be loaded for nltdi.sys
*** WARNING: Unable to verify timestamp for netbt.sys
*** ERROR: Module load completed but symbols could not be loaded for netbt.sys
Unable to load image srv.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for srv.sys
*** ERROR: Module load completed but symbols could not be loaded for srv.sys
unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_POOL_HEADER                               ***
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
unable to get nt!MiSessionPoolStart
unable to get nt!MiSessionPoolEnd
***    work.                                                          ***
***    work.                                                          ***
***    Type referenced: nt!_POOL_TRACKER_BIG_PAGES                    ***
Cannot get _POOL_TRACKER_BIG_PAGES type size
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
Probably caused by : nltdi.sys ( nltdi+a56 )
Followup: MachineOwner
че за файл это nltdi.sys ?
Здравствуйте, у меня часто появляется синий экран и пишется следующая ошибка: BUGCODE_USB_DRIVER
*** STOP: 0x000000FE(0x00000005, 0x862920e0,0x10b952237,0x863ddf90)
Как с этим бороться? Заранее Вам благодарен.
а у меня воще в синий экран без надписей (он не просто синий а темно синий) при разгоне что это значит
Помогите. Каждый раз после некоторого времени работы компьютера вылезает синий экран :weep: :
*** STOP: 0x0000008E (0xC0000005, 0x7103D7F5, 0xF4AA3CD0, 0x00000000)
Компьютер:
Windows XP SP2
512 МБ оперативной памяти
NVidia GeForce 5700LE 128 MB
P4P800SE
Artem14
http://www.oszone.net/display.php?id=1185 - это читали для начала ?
Вам может показаться, что я повторяюсь, но я буду распоряжаться вашими жизнями, как мне вздумается. Постарайтесь этого не забывать...
|Клан Дедов|
.Maviring Установлена ли программа NetLimiter 2.0.7.1 и OutPost на Вашем компьютере? Если да, то скорей всего они не дружат. Постараюсь поискать еще какие-нибудь результаты
Over's Beer Clan - пилот УБС -http://dedov.clan.su/
Rev@n
Читал, но там написан случай для SP1 и случай при установке Windows XP. Ни один из них мне не подходит.
Примечание: ошибки 0x00000050 и 0x0000008E в большинстве случаев указывают на неисправную RAM память.
Проверь память memtest'ом... Да и у тебя одна плашка памяти ?
Давно стало появлятся ? (может после изменения кофига компьтера)
|Клан Дедов|
Я точно не помню, но перед тем, как они стали появляться, я удалил второй виндовс...
? А как этот второй был установлен?
Artem14
А в каких именно приложениях вылетает BSOD ? И он на что-нибудь ссылается, имя файла там например.
|Зондерфюрер Штеуда| |Песчинка и камень тонут в воде одинаково|
Сначала через MS-DOS, потом в Windows.
Что удивительно, что он ни на какой фаил не ссылается, но при запуске, развёртывании какой-либо программы (иногда), либо после долгого его застоя вылетает BSOD.
Artem14
А память тестировал ?
Memtest например: http://www.overclockers.ru/files/index.shtml?dir=25 можно взять здесь.
то есть на тот же логический диск что и первый? Или у Вас два HDD?
Пытался тестировать, но он мне каждый раз выдаёт "You cannot run Memtest86+ if the system already is in protected mode."
У меня 2 HDD (устанавливал на второй)
Artem14
Скачай эту версию http://softportal.com/?id=4914.
Проверил, но ошибок не было найдено...
И сколько ты тестировал, 10 минут что-ли (минимму на 1 час поставь).
Часовая проверка ничего не дала.
Помогите устранить причину BSOD'а
:mad2: #77
В Висте вылетает частенько. В ХР не было.
"Стреляй мне в сердце, если веришь в силу смерти, только вот смотри не промахнись во избежание мести…" ©
