Думаю 2х74 SAS+controller куда интереснее и лучше чем один Раптор 150GB SATAI за 5200р.
Интересна какая будет скорость массива, только боюсь не упрется ли в ограничение шины PCI-Ex1 256mb\sec ?
_________________ Тезка Геннадия Андреича Зюганова. За него и голосовал!
"-The MAX3 RC series represents Fujitsu's current high-performance professional hard drive family. It spins at 15,000 RPM and offers capacity points of 36 GB, 74 GB and 147 GB. Fujitsu says its read seek times are 3.3 ms and write seeks are 3.8 ms. All drives carry 16 MB buffer memory and utilize a SAS interface. Fujitsu implements FDB motors (Fluid Dynamic Bearing) and an on-the-fly ECC (Error Correcting Code). The temperature operating range is 5°C to 55°C (41°F to 131°F); the drives require 11.5 W idle power. This drive provides up to 93 MB/s data transfer rates and average access times of 5.7 ms."
А в выводах в конце-
"The clear performance winner is Seagate's new Cheetah 15K.5 at 300 GB. With a 128 MB/s maximum transfer speed and an amazing minimum transfer rate of 73 MB/s, it is the fastest hard drive ever. But the drive suffers from relatively long access times of 6.6 ms. For I/O-intensive applications, the 2.5" Savvio 15K.1, also by Seagate, is a much better choice.(!) We measured a 5.5 ms average access time, while its transfer rates of up to 104 MB/s are not bad either, which is the second best result after the Cheetah 15K.5."
И после- сводная таблица, но там просто данные изготовителя о дисках...
Я что-то где-то проглядел или где?
_____________________________________________________________________
ЗЫ:
Интервью с Andrew Batty, sales and marketing director at Fujitsu Europe
и комментарии Hubbert Smith, Western Digital's enterprise marketing director на тему-
"SAS or enterprise SATA drives?" WD says eSATA, Fujitsu says SAS:
http://www.techworld.com/storage/featur ... ureid=1973 и ещё обзор Raptor, если кому интересно:
http://www.storagereview.com/articles/2 ... page=0%2C0 (всё нарыл в обсуждении статьи на Tom`s)
9 Странная какая-то фраза, eSata это внешний вариант интерфейса вообще-то, и спутать его с enterprise SATA drives могут только журналисты:)
Да и вообще тут или/или быть не может, у них предназначение совершенно разное - корпоративные SATA диски используют в компах на основе десктопного железа, а SAS это уже для рабочих станций и серверов.
Статус: Не в сети Регистрация: 20.06.2006 Откуда: Воронеж
Вопрос может и ламерский, но задам: стоит ли брать бэушный контроллер, может ли с ним быть что-то не так или на него не влияет эксплуатация? Имеется в виду, что контроллер рабочий на 100%.
_________________ Aut vincere, aut mori. - Победа или смерть
Статус: Не в сети Регистрация: 26.08.2005 Откуда: 34
ИМХО это самое оптимальное, железка проверенная, а цена ниже магазинной - дёшево и сердито
_________________ Очень давно не обновлял инфу в профиле.
Раз у него отдельные порты - какие могут быть проблемы?
Меня просто насторожило в описании совместимость указана только с контроллерами промайс Добавлено спустя 14 минут, 11 секунд Кабель такой нужен:
mSASx4 (SFF-8087) to SATA (4)x1 with sideband (SFF-8448) #77 ?
Статус: Не в сети Регистрация: 01.03.2005 Откуда: Москва, СПб
Provider Если возьмешь ритейл вариант адаптека, то этот кабель будет в комплекте. Им же подключается корзина, а корзина имеет уже собственные хвосты кабеля 8482 для подключения винтов.
Но нужна ли тебе эта конструкция? может проще взять OEM вариант контроллер (тоже хорошо упакован, просто без цветастой глянцевой коробки), который дешевле на 1000 р. и без кабеля. И отдельно купить SFF-8087 to SFF-8482 Multi-lane Internal SAS/SATA Cable за 1500 р. для непосредственного подключения винтов?
Корзина - это, конечно, эффектно, но за ее цену, сдается мне, ты можешь взять лишний винт на 147 гб. ИМХО проще винты вдвинуть просто в корпус.
Статус: Не в сети Регистрация: 19.12.2005 Откуда: НН Фото: 69
Helium Контроллер я уже купил и с ним был кабель, но если брать эту корзину, то этого кабеля просто банально не хватит до нее...
В стандартой корзине уже тесно, даже если выкинуть три 80ки. Да и хотелось бы видеть какую-нить индикацию работы этих сас дисков, кроме той что есть на контроллере... Добавлено спустя 2 минуты, 5 секунд
Я расчитываю брать винты меньшего обьема ~76 гб Кст корзина эта у нас стоит всего 3650 р.
LAV48 Так получается, что дешевле Адаптека 2405 ничего нет? Пока что поставлю один хард, а затем докуплю другой. Или с учётом этого есть что попроще, но и качество должно не страдать. Просто интересны и другие модели, кроме Адаптека, посмотрю на Ебэе в продаже.
Добавлено спустя 3 минуты, 30 секунд А по корзинам, что отсюда посоветуете http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=212&zenid=8d18840f4eb07fad17c3dacb104defcb И ещё интересует, а корзина глушит винты или она просто для крепления?
Статус: Не в сети Регистрация: 16.07.2008 Откуда: г. Таганрог
Куда ж еще дешевле? Кэш 128, поддержка уровней raid урезана насколько это возможно, 4 порта... Главное что это контроллер а не адаптер А зачем вам винты глушить? У меня стоял hitachi 15K300 73Gb, объективно он лишь ненамного громче 7.2К максторов...
Хотя старые сказийные контроллеры имели 64 Мб sdram памяти и pentium 100 на борту , т.е. дешевле теоретически можно
Red Light мне просто интересно узнать смысл корзины, что она собой представляет: просто вместилище для дисков или она выполняет и функции шумоподавления. Добавлено спустя 1 минуту, 17 секунд А в дуэле Велоцераптор-Сас, Сас победит?
15к однозначно, да и 10 тысячники САСы всёж не просто так денег стоят.
zergrus13 По этим корзинам ничего не скажу,они все разные А вообще корзинки предназначены больше для хотсвапа, для дома я бы посоветовал зажать харды аллюминиевыми радиаторами
