Blood Iron P35-T2RL features Intel® high performance chipset P35, which is based on Intel® 775 socket platform. It supports Intel®'s Core 2 Duo and Core 2 Quad/ extreme processors. For delivering the cutting edge performance, Blood Iron P35-T2RL is now ready to supports latest FSB 1333MHz. In fact, the Quad core processor is becoming a new “sweet heart” to enthusiast and power users. Hence, the FSB1333MHz support is a fundamental condition for a Quad core motherboard, particularly the upcoming 45nm process CPU.
The PCB of Blood Iron P35 T2RL has a special form factors size, 305 X 205mm, which equipped with rich features and functions. Blood Iron P35-T2RL makes use of 4-phase digital PWM to enhance the stability of power supplying. Frankly, it is still very seldom to see manufacturer puts Digital PWM onto a “reasonable price” board. The advantages of using digital PWM were generally approved by enthusiast and the industry. LANParty series is to take the lead in use of digital PWM. Then, the other brands tread in DFI's footsteps. Aside from this, you might notice that so many solid aluminum capacitors around the PWM area. DFI insists to provide user an “explosion-free” and highly stability overclocking environment. Hence, Solid aluminum capacitor is the only choice for this Blood Iron P35-T2RL.
Blood Iron P35-T2RL uses Realtek ALC882 as the audio codec. It provides 7.1 channels High-definition audio, which supports surround and Dolby-like quality audio output. Further, an S/PDIF optical out is provided too. No matter for gaming 3D audio or DVD playback purpose, Blood IronP35-T2RL's audio must certainly satisfy you.
BI P35-T2RL has a high extensibility for related devices. DFI considers user has so many gadgets or devices that needed to work with their PC. Therefore, the extensibility of a motherboard is a key point. So, it has 12 USB 2.0 ports on board. Beside, it provides 6 SATAII ports, which supports RAID 0, 1, 0+1, 5 functions for storage security and extension.
DFI made a new package design for Blood Iron P35-T2RL. It looks pretty game-oriented and tasteful, which is let users realize that DFI will continues to create a series of rock solid stability, outstanding performance and quality motherboard for hardcore gamers and overclockers. At past, high performance motherboard somehow means expansive in price. On the contrary, the boards with a reasonable price that seems to be a “semi-performance” board…DFI tried to exemplify an exception for this stereotype of users. Blood I ronP35-T2RL established a good example of a gold ratio between “cost” and “performance” .
Статус: Не в сети Регистрация: 17.02.2006 Откуда: Duisburg, NRW
Нашёл вот я 250€, и получил сабж, и собрал систему, и закрутились вентиляторы, и всё на этом... Воткнул обратно старую маму - всё работает... Ничё не понимаю.
Overclocker Чтобы рамку, процессор прижимающую, защёлкнуть, усилие мне на рычажок ну очень уж неслабое пришлось приложить, в разы сильнее давил, чем на асусе. На описанном сабже так же было?
Статус: Не в сети Регистрация: 02.06.2003 Откуда: Haifa
Cookie На описанном сабже так не было, но вообще-то у меня так было очень много раз на разных платах. Это бывает сокет такой, если ты обращал внимание, там рамка как-бы еще и процессор придавливает, так пока сокет новый, контакты пр-ра тугие и он на них ложится, бывает рычаг туго об рамку царапает. Это ерунда и не зависит от конкретной платы, может процессор еще чуть не так лег, можешь поднять его и проверить еще раз.
Статус: Не в сети Регистрация: 13.08.2006 Откуда: Москва, Россия
Статья сильная, сразу чувствуется высокий технический уровень.
Только вот эмоций слишком много, но автор в принципе человек слегка "вольтанутый", так что ему прощается.
Overclocker писал(а):
Cookie Это ерунда и не зависит от конкретной платы
Ерунда, но плата из-за этого не стартовала. Сам я ничего не исправлял, отправил обратно и через день получил рабочую маму, причём рамка защёлкнулась теперь свободно.
Приступил к исследованиям... До FSB 400 - CPU 3600/кулер боксовый - DDR2-960 разогнал с дефолтными напругами, стабильность 100%. На ФСБ 410 рестарт, если 2 ветки MemTest Pro запустить.
Пытался при ФСБ 333 поставить память на 1066, подняв на оной напряжение до 2,25В - пришлось лезть к джамперу...
http://www.psp-devices.ucoz.ru/ - Сюда постучись тады... или л.с. черкани: http://forums.overclockers.ru/profile.php?mode=viewprofile&u=97037 Биос восторг вызывает - при неизменных частотах/таймингах памяти можно либо стабильность, либо производительность заметно улучшать. Е6850 на воздухе вдруг до 4100 погнался, что на Асусе П5Б делюксе немыслимо было. Память гонится не так сильно, как на XFX 680i SLI, зато СуперПи гораздо быстрее считается. 32М прогонял с баллистикой 1200 4-4-4-11 2,7В - если б я ещё и твикать умел, то резалт бы очень даже ничё бы получилсо...
Гонял даже под спиртом)))), 4455МГц СуперПи 1М. Дроп отключается в биосе, мониторинг после этого показывает стабильно то напряжение, которое в биосе установлено; напруга на памяти проседает под нагрузкой сильно, и БП в этом точно не виноват. С последним биосом это проседание уменьшилось наполовину.
С боксовым кулером вне корпуса, на полочке стола, нормальная комнатная температура, термопастой пользуюсь исключительно жидкометалльной.
