Статус: Не в сети Регистрация: 12.05.2005 Откуда: Poland/Germany
Нужно скомпилить прогу для Lineage2 с http://l2packetframework.250free.com/ Для работы с C1 версией там нужно сменить case. А бинарники там для С2. Может поможет кто? (там 200 кил)
here's a little source package to decrypt the lineage2 traffic from the
server to the client.
to display the hp ingame, you need to copy the d3d8.dll to the
lineage2\system folder and restart lineage2.
the application must be started before logging in.
i hope this will wake up ncsoft, so they'll finally STOP to send every
players hp to everyone.
to compile you need Microsoft Visual Studio 2003, you maybe have to
correct the paths to some libraries (IpHlp Api, WSock)
have fun.
Oh - and it works for Chronicles2 btw - to make it work under C1, you need to Change the "case 0x0e:" to "case 0x1a" in PacketProcessor.cpp
To compile you also need to set the active configuration to "console"
