System Details -------------- Name AMD Athlon 64 X2 4800+ Codename Brisbane Specification AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ Core Stepping BH-G1 Technology 65 nm Stock frequency 2500 MHz Core Speed 2875.1 MHz (12.5 x 230.0 MHz)
Northbridge ATI RD770 rev. 00 Southbridge ATI SB700 rev. 00
CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 410.7 MHz (CPU/7) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7600)
max VID 1.375 V Voltage sensor 0 1.46 Volts [0x5B] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket AM2 (940)
Temperature sensor 0 41°C (105°F) [0x29] (TMPIN0) Temperature sensor 1 55°C (130°F) [0x37] (TMPIN1) Temperature sensor 2 79°C (174°F) [0x4F] (TMPIN2) Temperature sensor 0 41°C (104°F) [0x166] (core #0) Temperature sensor 1 39°C (101°F) [0x15F] (core #1) Temperature sensor 0 54°C (129°F) [0x36] (GPU Core)
max VID 0.825 V Voltage sensor 0 1.23 Volts [0x4D] (CPU VCORE) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 32 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID = 1h)
Temperature sensor 0 41°C (105°F) [0x29] (TMPIN0) Temperature sensor 1 50°C (121°F) [0x32] (TMPIN1) Temperature sensor 2 48°C (118°F) [0x30] (TMPIN2) Temperature sensor 0 72°C (161°F) [0x21] (core #0) Temperature sensor 1 68°C (154°F) [0x25] (core #1) Temperature sensor 2 68°C (154°F) [0x25] (core #2) Temperature sensor 3 68°C (154°F) [0x25] (core #3) Temperature sensor 0 49°C (120°F) [0x31] (GPU Core) Temperature sensor 0 47°C (116°F) [0x2F] (GPU Core) Temperature sensor 0 49°C (120°F) [0x31] (GPU Core)
CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 1T Memory Frequency 400.4 MHz (1:1) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric)
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
max VID 1.225 V Voltage sensor 0 1.18 Volts [0x93] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 0h)
Temperature sensor 0 40°C (103°F) [0x28] (SYSTIN) Temperature sensor 1 43°C (109°F) [0x56] (CPUTIN) Temperature sensor 2 1°C (33°F) [0x1FE] (AUXTIN) Temperature sensor 0 54°C (129°F) [0x33] (core #0) Temperature sensor 1 53°C (127°F) [0x34] (core #1) Temperature sensor 0 41°C (104°F) [0x28] (GPU Core)
CAS# 6.0 RAS# to CAS# 6 RAS# Precharge 6 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 443.9 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual (Symmetric)
Windows Version Microsoft Windows Vista (6.1) Enterprise Edition Service Pack 2 (Build 7600)
max VID 1.238 V Voltage sensor 0 1.34 Volts [0xA8] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 42°C (107°F) [0x2A] (SYSTIN) Temperature sensor 1 65°C (148°F) [0x82] (CPUTIN) Temperature sensor 2 127°C (260°F) [0xFE] (AUXTIN) Temperature sensor 0 78°C (172°F) [0x1B] (core #0) Temperature sensor 1 70°C (157°F) [0x23] (core #1) Temperature sensor 2 75°C (166°F) [0x1E] (core #2) Temperature sensor 3 72°C (161°F) [0x21] (core #3) Temperature sensor 0 40°C (103°F) [0x27] (GPU Core)
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 600.1 MHz (5:6) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric)
Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 41°C (105°F) [0x29] (System) Temperature 1 63°C (145°F) [0x3F] (CPU) Temperature 0 71°C (159°F) [0x1D] (Core #0) Temperature 1 65°C (148°F) [0x23] (Core #1) Temperature 3 69°C (156°F) [0x1F] (Core #3) Temperature 2 70°C (157°F) [0x1E] (Core #2)
System Details -------------- Name AMD Phenom Codename Deneb Specification AMD Phenom(tm) II X4 945 Processor Core Stepping Technology 45 nm Stock frequency 3000 MHz Core Speed 3750.0 MHz (15.0 x 250.0 MHz) FID range 5.0x - 15.0x
Northbridge ATI RD790 rev. 00 Southbridge ATI SB700 rev. 00
CAS# 6.0 RAS# to CAS# 6 RAS# Precharge 6 Cycle Time (tRAS) 15 Command Rate 1T Memory Frequency 666.7 MHz (3:8) Memory Type DDR3 Memory Size 4094 MBytes Channels Dual (Unganged)
max VID 1.300 V Voltage sensor 0 1.44 Volts [0x5A] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1
Temperature sensor 0 40°C (103°F) [0x28] (TMPIN0) Temperature sensor 1 54°C (129°F) [0x36] (TMPIN1) Temperature sensor 2 48°C (118°F) [0x30] (TMPIN2) Temperature sensor 0 50°C (121°F) [0x18C] (core #0) Temperature sensor 1 50°C (121°F) [0x18C] (core #1) Temperature sensor 3 50°C (121°F) [0x18C] (core #3) Temperature sensor 2 50°C (121°F) [0x18C] (core #2) Temperature sensor 0 43°C (108°F) [0x2A] (GPU Core)
System Details -------------- Name AMD Phenom II X4 940 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 940 Processor Core Stepping RB-C2 Technology 45 nm Core Speed 3612.2 MHz
Northbridge AMD 790FX rev. 00 Southbridge ATI SB750 rev. 00
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 535.1 MHz (3:8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Temperature 0 55°C (130°F) [0x37] (TMPIN0) Temperature 1 44°C (111°F) [0x2C] (TMPIN1) Temperature 2 22°C (71°F) [0x16] (TMPIN2) Temperature 0 56°C (133°F) [0x1C3] (Core #0) Temperature 1 56°C (133°F) [0x1C3] (Core #1) Temperature 2 56°C (133°F) [0x1C3] (Core #2) Temperature 3 56°C (133°F) [0x1C3] (Core #3)
_________________ Гробы разработчиков надо делать круглыми, чтоб переворачиваться было удобно!
System Details -------------- Name AMD Phenom II X3 710 Codename Heka Specification AMD Phenom(tm) II X3 710 Processor Core Stepping RB-C2 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2600 MHz Core Speed 3510.1 MHz FID range 5.0x - 13.0x
Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00
CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 14 Command Rate (CR) 2T Memory Frequency 540.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged)
Number of processors 1 Number of threads 3 L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940)
Temperature 0 39°C (101°F) [0x134] (Core #0) Temperature 1 38°C (100°F) [0x132] (Core #1) Temperature 2 38°C (100°F) [0x132] (Core #2)
CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 443.9 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric)
Windows Version Microsoft Windows 7 (6.1) Enterprise Edition Service Pack 2 (Build 7600)
Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 43°C (109°F) [0x2B] (SYSTIN) Temperature 1 57°C (134°F) [0x72] (CPUTIN) Temperature 0 69°C (156°F) [0x1F] (Core #0) Temperature 1 63°C (145°F) [0x25] (Core #1) Temperature 2 67°C (152°F) [0x21] (Core #2) Temperature 3 65°C (148°F) [0x23] (Core #3)
ещё новее
x264 HD BENCHMARK 3.01 RESULTS
Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data
Temperature 0 43°C (109°F) [0x2B] (SYSTIN) Temperature 1 63°C (145°F) [0x7E] (CPUTIN) Temperature 0 70°C (157°F) [0x1E] (Core #0) Temperature 1 63°C (145°F) [0x25] (Core #1) Temperature 2 67°C (152°F) [0x21] (Core #2) Temperature 3 65°C (148°F) [0x23] (Core #3)
System Details -------------- Name AMD K10 Codename Specification AMD Processor model unknown Core Stepping Stock frequency 2700 MHz Core Speed 3374.8 MHz (13.5 x 250.0 MHz) FID range 5.0x - 13.5x
Northbridge ATI Xpress 3200 (RD580) rev. 00 Southbridge ATI SB600 rev. 00
CAS# 6.0 RAS# to CAS# 6 RAS# Precharge 6 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 500.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Single
max VID 1.325 V Voltage sensor 0 1.34 Volts [0x54] (CPU VCORE) Number of processors 1 Number of threads 3 Number of threads 3 (max 3) L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1
Temperature sensor 0 42°C (107°F) [0x2A] (TMPIN0) Temperature sensor 1 36°C (96°F) [0x24] (TMPIN1) Temperature sensor 0 33°C (90°F) [0x104] (core #0) Temperature sensor 1 33°C (90°F) [0x104] (core #1) Temperature sensor 2 33°C (90°F) [0x104] (core #2) Temperature sensor 0 50°C (121°F) [0x32] (GPU Core)
_________________ 99% проблем с компьютером сидит в 40 см. от монитора Запчасти для смартфонов, ноутбуков, планшетов - https://tfl-shop.ru/?promo_id=48460
CAS# 5.0 RAS# to CAS# 4 RAS# Precharge 4 Cycle Time (tRAS) 8 Command Rate 2T Memory Frequency 462.5 MHz (1:2) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual (Ganged)
Voltage sensor 0 1.42 Volts [0x59] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1
Temperature sensor 0 33°C (91°F) [0x21] (TMPIN0) Temperature sensor 1 31°C (87°F) [0x1F] (TMPIN1) Temperature sensor 2 32°C (89°F) [0x20] (TMPIN2) Temperature sensor 0 43°C (109°F) [0x158] (core #0) Temperature sensor 1 43°C (109°F) [0x158] (core #1) Temperature sensor 3 43°C (109°F) [0x158] (core #3) Temperature sensor 2 43°C (108°F) [0x154] (core #2) Temperature sensor 0 36°C (96°F) [0x24] (GPU Core)
Старички ещё хоть куды. Позвоните родителям
_________________ http://audio-hi-end.livejournal.com/profile Аудиоэкспертиза - это не слух, а анализ услышанного
Заблокирован Статус: Не в сети Регистрация: 25.04.2008 Откуда: град Петра
Куба Так с открытым балконным окном и напольным вентилем, а при 1.5в на проце БП на защиту встает сразу. Под(или за) 200вт кушать начинает 3500 скрин держит, но стоит чуть подгрузить - темпа за 50гр и аут БП хиленький, но он мне нравится- ТТ TR2 W0101 550W
а так при 1.3в на 3000мгц не боится ничего, греться может до 65гр (выше просто не видел)
Последний раз редактировалось 6a3apoB 07.12.2009 20:31, всего редактировалось 2 раз(а).
max VID 0.825 V Voltage sensor 0 1.41 Volts [0x58] (CPU VCORE) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 32 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID = 1h)
Temperature sensor 0 38°C (100°F) [0x26] (TMPIN0) Temperature sensor 1 59°C (138°F) [0x3B] (TMPIN1) Temperature sensor 2 46°C (114°F) [0x2E] (TMPIN2) Temperature sensor 0 86°C (186°F) [0x13] (core #0) Temperature sensor 1 89°C (192°F) [0x10] (core #1) Temperature sensor 2 83°C (181°F) [0x16] (core #2) Temperature sensor 3 85°C (184°F) [0x14] (core #3) Temperature sensor 0 46°C (114°F) [0x2E] (GPU Core) Temperature sensor 0 45°C (112°F) [0x2D] (GPU Core) Temperature sensor 0 45°C (112°F) [0x2D] (GPU Core)
CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 480.0 MHz (5:6) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual (Symmetric)
max VID 1.225 V Voltage sensor 0 1.25 Volts [0x4E] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 0h)
Temperature sensor 0 38°C (100°F) [0x26] (TMPIN0) Temperature sensor 1 51°C (123°F) [0x33] (TMPIN1) Temperature sensor 0 69°C (156°F) [0x24] (core #0) Temperature sensor 1 67°C (152°F) [0x26] (core #1) Temperature sensor 0 41°C (105°F) [0x29] (GPU Core)
CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 800.0 MHz (2:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual
Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 36°C (96°F) [0x24] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 56°C (132°F) [0x38] (TMPIN2) Temperature 0 59°C (138°F) [0x28] (Core #0) Temperature 1 60°C (139°F) [0x27] (Core #1) Temperature 2 61°C (141°F) [0x26] (Core #2) Temperature 3 64°C (147°F) [0x23] (Core #3)
_________________ Pentium II 300/AMD Duron 700/Core 2 Duo E8400/Core i7-920/Core i5-2500k/Core i7-4790k/Core i7-10700k/AMD 9800X3D
System Details -------------- Name AMD Phenom Codename Deneb Specification AMD Phenom(tm) II X4 20 Processor(разблокированный и разогнанный AMD Phenom(tm) II X3 720) Core Stepping Technology 45 nm Core Speed 3428.2 MHz (17.0 x 201.7 MHz)
Northbridge AMD ID9601 rev. 00 Southbridge ATI SB700 rev. 00
CAS# 6.0 RAS# to CAS# 6 RAS# Precharge 6 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 537.8 MHz (3:8) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual (Unganged)
Voltage sensor 0 1.51 Volts [0xBD] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1
Temperature sensor 0 34°C (93°F) [0x22] (SYSTIN) Temperature sensor 1 50°C (121°F) [0x63] (CPUTIN) Temperature sensor 2 36°C (95°F) [0x47] (AUXTIN) Temperature sensor 0 0°C (32°F) [0x0] (core #0) Temperature sensor 1 0°C (32°F) [0x0] (core #1) Temperature sensor 2 0°C (32°F) [0x0] (core #2) Temperature sensor 3 0°C (32°F) [0x0] (core #3)
Добавлено спустя 10 минут 13 секунд: x264 HD BENCHMARK 3.0 RESULTS
System Details -------------- Name AMD Phenom II X4 Codename Deneb Specification AMD Phenom(tm) II X4 20 Processor Core Stepping RB-C2 Technology 45 nm Core Speed 3400.0 MHz
Northbridge AMD 785GX rev. 00 Southbridge ATI SB750 rev. 00
CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 533.3 MHz (3:8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged)
Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 47°C (115°F) [0x5D] (CPUTIN) Temperature 2 36°C (96°F) [0x48] (AUXTIN) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 480.0 MHz (2:3) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual, (Symmetric)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7232)
Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 54°C (129°F) [0x36] (SYSTIN) Temperature 1 113°C (235°F) [0xE2] (CPUTIN) Temperature 2 122°C (250°F) [0xF3] (AUXTIN) Temperature 0 97°C (206°F) [0x3] (Core #0) Temperature 1 96°C (204°F) [0x4] (Core #1)
_________________ Законы глобальной экономики они такие... бандеровские...
