Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 7 из 20<  1 ... 4  5  6  7  8  9  10 ... 20  >
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 51.79 fps, 3899.26 kb/s
encoded 1442 frames, 51.91 fps, 3899.26 kb/s
encoded 1442 frames, 51.99 fps, 3899.26 kb/s
encoded 1442 frames, 51.82 fps, 3899.26 kb/s
encoded 1442 frames, 12.37 fps, 3971.91 kb/s
encoded 1442 frames, 12.41 fps, 3970.52 kb/s
encoded 1442 frames, 12.40 fps, 3971.34 kb/s
encoded 1442 frames, 12.38 fps, 3970.93 kb/s
System Details
Name Intel Core 2 Duo E8200
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8200 @ 2.66GHz
Core Stepping C0
Technology 45 nm
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Stock frequency 2666 MHz
Core Speed 3584.2 MHz
FID range 6.0x - 8.0x
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Command Rate (CR) 2T
Memory Frequency 560.0 MHz (4:5)
Memory Type DDR2
Memory Size 2048 MBytes
Channels Dual, (Symmetric)
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
Number of processors 1
Number of threads 2
Number of threads 2 (max 2)
L2 cache 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 34°C (93°F) [0x22] (System)
Temperature 1 41°C (105°F) [0x29] (CPU)
Temperature 0 54°C (129°F) [0x2E] (Core #0)
Temperature 1 56°C (132°F) [0x2C] (Core #1)
Fortuna non penis, in manus non recepi.
AMD Phenom(tm) II X4 955 Processor = 3359,9Mhz
Код:
x264 HD BENCHMARK RESULTS
Please copy/paste everything below the line into the forum post to report your data
Results for x264.exe v0.58.747
encoded 1442 frames, 68.23 fps, 3905.42 kb/s
encoded 1442 frames, 64.19 fps, 3905.42 kb/s
encoded 1442 frames, 58.25 fps, 3905.42 kb/s
encoded 1442 frames, 59.77 fps, 3905.42 kb/s
encoded 1442 frames, 17.99 fps, 3952.85 kb/s
encoded 1442 frames, 17.64 fps, 3952.85 kb/s
encoded 1442 frames, 17.62 fps, 3952.85 kb/s
encoded 1442 frames, 18.18 fps, 3952.85 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 72.84 fps, 3891.55 kb/s
encoded 1442 frames, 72.46 fps, 3891.55 kb/s
encoded 1442 frames, 71.43 fps, 3891.55 kb/s
encoded 1442 frames, 71.56 fps, 3891.55 kb/s
encoded 1442 frames, 19.43 fps, 3963.44 kb/s
encoded 1442 frames, 19.26 fps, 3963.43 kb/s
encoded 1442 frames, 19.25 fps, 3963.43 kb/s
encoded 1442 frames, 19.36 fps, 3963.43 kb/s
System Details
Name         AMD Phenom
Codename      Deneb
Specification      AMD Phenom(tm) II X4 955 Processor
Core Stepping
Technology      45 nm
Core Speed      3359.9 MHz (16.0 x 210.0 MHz)
Northbridge      ATI RD770 rev. 00
Southbridge      ATI SB700 rev. 00
CAS#         5.0
RAS# to CAS#      5
RAS# Precharge      5
Cycle Time (tRAS)   18
Command Rate      2T
Memory Frequency   420.0 MHz (1:2)
Memory Type      DDR2
Memory Size      6144 MBytes
Channels      Dual (Unganged)
Windows Version      Microsoft Windows Vista (6.1) Ultimate Edition   (Build 7600)
Voltage sensor 0   1.34 Volts [0x54] (CPU VCORE)
Number of threads   4
Number of threads   4 (max 4)
L2 cache      4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets   MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package         Socket AM2+ (940)
Package Type      0x1
Temperature sensor 0   44°C (111°F) [0x2C] (TMPIN0)
Temperature sensor 1   59°C (138°F) [0x3B] (TMPIN1)
Temperature sensor 2   80°C (175°F) [0x50] (TMPIN2)
Temperature sensor 0   56°C (131°F) [0x1BC] (core #0)
Temperature sensor 1   56°C (131°F) [0x1BC] (core #1)
Temperature sensor 3   56°C (131°F) [0x1BC] (core #3)
Temperature sensor 2   56°C (131°F) [0x1BC] (core #2)
Temperature sensor 0   52°C (125°F) [0x34] (GPU Core)
AMD Phenom II X4 955 (3570.0 MHz)
Код:
encoded 1442 frames, 69.98 fps, 3900.68 kb/s
encoded 1442 frames, 70.79 fps, 3900.68 kb/s
encoded 1442 frames, 70.87 fps, 3900.68 kb/s
encoded 1442 frames, 69.31 fps, 3901.21 kb/s
encoded 1442 frames, 21.94 fps, 3971.69 kb/s
encoded 1442 frames, 21.87 fps, 3971.52 kb/s
encoded 1442 frames, 21.73 fps, 3973.39 kb/s
encoded 1442 frames, 21.92 fps, 3971.58 kb/s
System Details
   Name         AMD Phenom II X4 955
   Codename      Deneb
   Core Stepping      RB-C2
   Technology      45 nm
   Core Speed      3570.0 MHz
Southbridge         ATI SB750 rev. 00
Memory Type         DDR2
Channels         Dual, (Unganged)
Windows Version         Microsoft Windows 7 (6.1) Ultimate Edition   (Build 7600)
Number of threads      4
   Package Type      0x1
   Temperature 0   42°C (107°F) [0x2A] (TMPIN0)
   Temperature 1   59°C (138°F) [0x3B] (TMPIN1)
   Temperature 2   80°C (175°F) [0x50] (TMPIN2)
   Temperature 0   58°C (135°F) [0x1CE] (Core #0)
   Temperature 1   58°C (135°F) [0x1CD] (Core #1)
   Temperature 2   58°C (135°F) [0x1CD] (Core #2)
   Temperature 3   58°C (135°F) [0x1CD] (Core #3)
Последний раз редактировалось Hasanov 29.12.2009 23:50, всего редактировалось 2 раз(а).
encoded 1442 frames, 100.69 fps, 3899.02 kb/s
encoded 1442 frames, 102.25 fps, 3899.02 kb/s
encoded 1442 frames, 103.86 fps, 3899.02 kb/s
encoded 1442 frames, 98.44 fps, 3899.02 kb/s
encoded 1442 frames, 38.16 fps, 3955.64 kb/s
encoded 1442 frames, 38.66 fps, 3962.46 kb/s
encoded 1442 frames, 38.74 fps, 3963.31 kb/s
encoded 1442 frames, 38.77 fps, 3958.51 kb/s
System Details
Name Intel Core i7 920
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Core Stepping C0/C1
Technology 45 nm
Core Speed 4200.2 MHz
Northbridge Intel X58 rev. 12
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Command Rate (CR) 1T
Memory Frequency 800.0 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Package (platform ID) Socket 1366 LGA (0x1)
In God We Trust
Hasanov с апгрейдом вас :beer:
WTF88 когда уже подключишь свою мощь на пользу науке? :beer:
http://audio-hi-end.livejournal.com/profile Аудиоэкспертиза - это не слух, а анализ услышанного
WTF88
У меня первая часть бенча получше, вторая похуже твоего viewtopic.php?p=6755999#p6755999, но и версии разные...
suum cuique
encoded 1442 frames, 23.22 fps, 3899.26 kb/s
encoded 1442 frames, 23.13 fps, 3899.26 kb/s
encoded 1442 frames, 25.02 fps, 3899.26 kb/s
encoded 1442 frames, 24.00 fps, 3899.26 kb/s
encoded 1442 frames, 5.77 fps, 3971.28 kb/s
encoded 1442 frames, 5.77 fps, 3970.77 kb/s
encoded 1442 frames, 5.88 fps, 3971.58 kb/s
encoded 1442 frames, 5.87 fps, 3971.50 kb/s
System Details
Name AMD Athlon 64 X2 4850e
Codename
Specification AMD Athlon(tm) Dual Core Processor 4850e
Core Stepping DH-G2
Technology 65 nm
Stock frequency 2500 MHz
Core Speed 2517.8 MHz
Northbridge AMD 780G rev. 00
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Memory Frequency 359.7 MHz (CPU/7)
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Number of threads 2
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Package Socket AM2 (940)
Temperature 0 40°C (103°F) [0x28] (TMPIN0)
Temperature 1 93°C (199°F) [0x5D] (TMPIN1)
Temperature 2 50°C (121°F) [0x32] (TMPIN2)
Temperature 0 50°C (122°F) [0x139] (Core #0)
Temperature 1 51°C (122°F) [0x13A] (Core #1)
encoded 1442 frames, 45.13 fps, 3899.26 kb/s
encoded 1442 frames, 45.20 fps, 3899.26 kb/s
encoded 1442 frames, 45.27 fps, 3899.26 kb/s
encoded 1442 frames, 43.60 fps, 3899.26 kb/s
encoded 1442 frames, 11.41 fps, 3972.04 kb/s
encoded 1442 frames, 11.41 fps, 3971.40 kb/s
encoded 1442 frames, 11.40 fps, 3971.38 kb/s
encoded 1442 frames, 11.36 fps, 3970.50 kb/s
System Details
Name Intel Core 2 Duo E8300
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8300 @ 2.83GHz
Core Stepping C0
Technology 45 nm
Stock frequency 2833 MHz
Core Speed 3315.0 MHz
FID range 6.0x - 8.5x
CAS# latency (CL) 4.0
Cycle Time (tRAS) 12
Memory Frequency 390.0 MHz (1:1)
Memory Type DDR2
Number of threads 2
Temperature 0 37°C (98°F) [0x25] (System)
Temperature 1 51°C (123°F) [0x33] (CPU)
Temperature 0 64°C (147°F) [0x24] (Core #0)
Temperature 1 59°C (138°F) [0x29] (Core #1)
Phenom II X4 925 3500Mhz NB 2500Mhz
2*2048MB DDR3 667Mhz (1333) 7-7-7-20 Unganged mode
W7 7600 x64 ENG [EAV 4.0.474 + uTorrent 2.0 17668] / x264 HD Benchmark v3.0
Код:
encoded 1442 frames, 74.55 fps, 3900.68 kb/s
encoded 1442 frames, 75.34 fps, 3900.68 kb/s
encoded 1442 frames, 74.48 fps, 3900.68 kb/s
encoded 1442 frames, 74.46 fps, 3900.68 kb/s
encoded 1442 frames, 22.51 fps, 3971.04 kb/s
encoded 1442 frames, 22.61 fps, 3970.64 kb/s
encoded 1442 frames, 22.44 fps, 3970.81 kb/s
encoded 1442 frames, 22.61 fps, 3970.63 kb/s
System Details
   Name         AMD Phenom II X4 925
   Codename      Deneb
   Specification      AMD Phenom(tm) II X4 925 Processor
   Core Stepping      RB-C2
   Technology      45 nm
   Stock frequency      2800 MHz
   Core Speed      3500.0 MHz
   FID range      5.0x - 14.0x
Cycle Time (tRAS)      20
Memory Frequency      666.7 MHz (3:8)
Memory Type         DDR3
Number of threads      4
   Package Type      0x1
   Temperature 0   34°C (93°F) [0x22] (TMPIN0)
   Temperature 1   55°C (130°F) [0x37] (TMPIN1)
   Temperature 2   79°C (174°F) [0x4F] (TMPIN2)
   Temperature 0   53°C (126°F) [0x1A5] (Core #0)
   Temperature 1   53°C (126°F) [0x1A5] (Core #1)
   Temperature 2   53°C (126°F) [0x1A5] (Core #2)
   Temperature 3   53°C (126°F) [0x1A4] (Core #3)
Ну теперь моя очередь похвастаться :oops:
encoded 1442 frames, 64.67 fps, 3899.90 kb/s
encoded 1442 frames, 64.76 fps, 3899.90 kb/s
encoded 1442 frames, 64.72 fps, 3899.90 kb/s
encoded 1442 frames, 64.54 fps, 3899.90 kb/s
encoded 1442 frames, 14.45 fps, 3971.09 kb/s
encoded 1442 frames, 14.43 fps, 3971.32 kb/s
encoded 1442 frames, 14.42 fps, 3971.75 kb/s
encoded 1442 frames, 14.42 fps, 3971.67 kb/s
System Details
Name AMD Phenom II X3 720
Codename Heka
Specification AMD Phenom(tm) II X3 720 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 3202.2 MHz
Northbridge AMD 790GX rev. 00
Cycle Time (tRAS) 24
Memory Frequency 800.6 MHz (1:4)
Memory Type DDR3
Number of threads 3
Number of threads 3 (max 3)
L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size
Package Socket AM3
Package Type 0x1
Temperature 0 18°C (64°F) [0x12] (TMPIN0)
Temperature 1 52°C (125°F) [0x34] (TMPIN1)
Temperature 2 40°C (103°F) [0x28] (TMPIN2)
Temperature 0 43°C (108°F) [0x154] (Core #0)
Temperature 1 43°C (108°F) [0x154] (Core #1)
Temperature 2 43°C (108°F) [0x154] (Core #2)
Gigabyte GA-Z77X-UD3H-WB WIFI / Intel Core i5-3570K/ 16Gb DDR3 / Sapphire R9 290X / Chieftec A-135 850W / PLEXTOR 128Gb / NZXT Tempest 410
Последний раз редактировалось CkuHXeD 30.12.2009 12:57, всего редактировалось 1 раз.
Есть предложение сравнить помимо чистого кодирования x264 еще скорость работы всей подсистемы (чипсет, память), добавив в avs скрипт обработку видео каким-то шумодавом и сложным деинтерлейсом. Например MvDegrain3 и McBob.
Вот еще :gun:
encoded 1442 frames, 37.08 fps, 3899.26 kb/s
encoded 1442 frames, 36.94 fps, 3899.26 kb/s
encoded 1442 frames, 36.86 fps, 3899.26 kb/s
encoded 1442 frames, 36.46 fps, 3899.26 kb/s
encoded 1442 frames, 9.14 fps, 3971.76 kb/s
encoded 1442 frames, 9.14 fps, 3970.99 kb/s
encoded 1442 frames, 9.06 fps, 3971.15 kb/s
encoded 1442 frames, 9.07 fps, 3970.74 kb/s
System Details
Name Intel Core 2 Duo E6550
Codename Conroe
Specification Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz
Core Stepping G0
Technology 65 nm
Stock frequency 2333 MHz
Core Speed 2800.1 MHz
FID range 6.0x - 7.0x
Cycle Time (tRAS) 10
Memory Frequency 400.0 MHz (1:1)
Memory Type DDR2
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 2 (Build 6002)
Number of threads 2
L2 cache 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Temperature 0 40°C (103°F) [0x28] (System)
Temperature 1 45°C (112°F) [0x2D] (CPU)
Temperature 0 59°C (138°F) [0x29] (Core #0)
Temperature 1 57°C (134°F) [0x2B] (Core #1)
encoded 1442 frames, 24.05 fps, 3899.26 kb/s
encoded 1442 frames, 24.17 fps, 3899.26 kb/s
encoded 1442 frames, 24.15 fps, 3899.26 kb/s
encoded 1442 frames, 24.11 fps, 3899.26 kb/s
encoded 1442 frames, 5.62 fps, 3971.70 kb/s
encoded 1442 frames, 5.62 fps, 3971.42 kb/s
encoded 1442 frames, 5.61 fps, 3971.62 kb/s
encoded 1442 frames, 5.61 fps, 3971.16 kb/s
System Details
Name Intel Pentium E2160
Codename Conroe
Specification Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
Core Stepping M0
Technology 65 nm
Stock frequency 1800 MHz
Core Speed 1800.0 MHz
FID range 6.0x - 9.0x
Northbridge Intel G41 rev. A3
Southbridge Intel 82801GB (ICH7/R) rev. A1
Memory Frequency 333.3 MHz (3:5)
Memory Type DDR2
Number of threads 2
L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
Temperature 2 47°C (116°F) [0x2F] (TMPIN2)
Temperature 0 47°C (116°F) [0x26] (Core #0)
Temperature 1 48°C (118°F) [0x25] (Core #1)
encoded 1442 frames, 28.91 fps, 3899.26 kb/s
encoded 1442 frames, 29.32 fps, 3899.26 kb/s
encoded 1442 frames, 29.84 fps, 3899.26 kb/s
encoded 1442 frames, 29.34 fps, 3899.26 kb/s
encoded 1442 frames, 7.53 fps, 3971.72 kb/s
encoded 1442 frames, 7.61 fps, 3971.61 kb/s
encoded 1442 frames, 7.77 fps, 3971.82 kb/s
encoded 1442 frames, 7.56 fps, 3971.40 kb/s
System Details
Name Intel Core 2 Duo E4300
Codename Conroe
Specification Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz
Core Stepping L2
Technology 65 nm
Core Speed 2610.1 MHz
Memory Frequency 362.5 MHz (4:5)
Memory Type DDR2
Number of threads 2
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
Temperature 0 46°C (114°F) [0x2E] (SYSTIN)
Temperature 1 42°C (107°F) [0x54] (CPUTIN)
Temperature 2 119°C (246°F) [0xEE] (AUXTIN)
Temperature 0 66°C (150°F) [0x22] (Core #0)
Temperature 1 65°C (148°F) [0x23] (Core #1)
Quad Q6600, Win 7 x64 RC7100 , 4Gb, 9800GT, 1Tb+7*750G, H2O
encoded 1442 frames, 80.24 fps, 3900.68 kb/s
encoded 1442 frames, 80.66 fps, 3900.68 kb/s
encoded 1442 frames, 80.87 fps, 3900.68 kb/s
encoded 1442 frames, 81.01 fps, 3900.68 kb/s
encoded 1442 frames, 24.77 fps, 3971.48 kb/s
encoded 1442 frames, 24.68 fps, 3973.36 kb/s
encoded 1442 frames, 24.81 fps, 3971.57 kb/s
encoded 1442 frames, 24.76 fps, 3971.35 kb/s
System Details
Name Intel Core i5 750
product System Product Name
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Specification PC3-12800
Core Stepping B1
Technology 45 nm
Core Speed 3266.4 MHz
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 05
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Command Rate 2T
Command Rate 2T
Memory Frequency 816.6 MHz (2:10)
Memory Type DDR3
Channels Dual
Number of threads 4
Number of threads 4 (max 16)
Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 50°C (121°F) [0x32] (SYSTIN)
Temperature 1 50°C (121°F) [0x64] (CPUTIN)
Temperature 2 39°C (101°F) [0x4D] (AUXTIN)
Temperature 0 48°C (118°F) [0x33] (Core #0)
Temperature 1 45°C (112°F) [0x36] (Core #1)
Temperature 2 48°C (118°F) [0x33] (Core #2)
Temperature 3 47°C (116°F) [0x34] (Core #3)
Фото: 17
encoded 1442 frames, 62.92 fps, 3899.90 kb/s
encoded 1442 frames, 63.30 fps, 3899.90 kb/s
encoded 1442 frames, 63.65 fps, 3899.90 kb/s
encoded 1442 frames, 64.03 fps, 3899.90 kb/s
encoded 1442 frames, 14.90 fps, 3971.94 kb/s
encoded 1442 frames, 14.95 fps, 3971.84 kb/s
encoded 1442 frames, 14.92 fps, 3971.09 kb/s
encoded 1442 frames, 14.95 fps, 3971.82 kb/s
System Details
Codename Heka
Core Stepping RB-C2
Technology 45 nm
Core Speed 3500.1 MHz
Northbridge AMD 790X rev. 00
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 3
Memory Frequency 416.7 MHz (3:5)
Memory Type DDR2
Number of threads 3
Package Type 0x1
Temperature 0 37°C (98°F) [0x25] (TMPIN0)
Temperature 1 47°C (116°F) [0x2F] (TMPIN1)
Temperature 2 44°C (111°F) [0x2C] (TMPIN2)
Temperature 0 38°C (100°F) [0x12F] (Core #0)
Temperature 1 38°C (100°F) [0x12F] (Core #1)
Temperature 2 38°C (100°F) [0x12F] (Core #2)
3D Mark06 (8800gts) ~16k on Win 7 x64
Последний раз редактировалось Monk0306 30.12.2009 21:21, всего редактировалось 1 раз.
encoded 1442 frames, 63.96 fps, 3901.21 kb/s
encoded 1442 frames, 64.84 fps, 3901.21 kb/s
encoded 1442 frames, 65.40 fps, 3900.43 kb/s
encoded 1442 frames, 63.10 fps, 3901.21 kb/s
encoded 1442 frames, 20.10 fps, 3971.38 kb/s
encoded 1442 frames, 19.92 fps, 3971.75 kb/s
encoded 1442 frames, 20.10 fps, 3971.45 kb/s
encoded 1442 frames, 20.12 fps, 3970.60 kb/s
System Details
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Core Stepping G0
Technology 65 nm
Stock frequency 2400 MHz
Core Speed 3249.0 MHz
Northbridge Intel P45/P43/G45/G43 rev. A2
Memory Frequency 433.2 MHz (5:6)
Memory Type DDR2
Number of threads 4
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 34°C (93°F) [0x22] (SYSTIN)
Temperature 1 44°C (110°F) [0x57] (CPUTIN)
Temperature 2 19°C (66°F) [0x26] (AUXTIN)
Temperature 1 52°C (125°F) [0x30] (Core #1)
Temperature 2 44°C (111°F) [0x38] (Core #2)
Temperature 3 45°C (112°F) [0x37] (Core #3)
encoded 1442 frames, 62.25 fps, 3904.67 kb/s
encoded 1442 frames, 62.18 fps, 3904.62 kb/s
encoded 1442 frames, 62.38 fps, 3904.67 kb/s
encoded 1442 frames, 61.71 fps, 3904.67 kb/s
encoded 1442 frames, 17.92 fps, 3952.97 kb/s
encoded 1442 frames, 17.94 fps, 3953.18 kb/s
encoded 1442 frames, 17.98 fps, 3952.97 kb/s
encoded 1442 frames, 17.96 fps, 3952.97 kb/s
encoded 1442 frames, 67.43 fps, 3889.34 kb/s
encoded 1442 frames, 67.84 fps, 3889.34 kb/s
encoded 1442 frames, 67.08 fps, 3889.34 kb/s
encoded 1442 frames, 66.85 fps, 3889.34 kb/s
encoded 1442 frames, 19.89 fps, 3962.76 kb/s
encoded 1442 frames, 19.93 fps, 3962.75 kb/s
encoded 1442 frames, 20.03 fps, 3962.75 kb/s
encoded 1442 frames, 19.98 fps, 3962.76 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3248.7 MHz (9.0 x 361.0 MHz)
Northbridge Intel P45 rev. A2
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Type DDR3
Channels Dual (Symmetric)
max VID 1.288 V
Voltage sensor 0 1.29 Volts [0xA1] (CPU VCORE)
Number of threads 4
Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 34°C (93°F) [0x22] (SYSTIN)
Temperature sensor 1 45°C (112°F) [0x5A] (CPUTIN)
Temperature sensor 2 19°C (66°F) [0x26] (AUXTIN)
Temperature sensor 0 57°C (134°F) [0x2B] (core #0)
Temperature sensor 1 54°C (129°F) [0x2E] (core #1)
Temperature sensor 2 48°C (118°F) [0x34] (core #2)
Temperature sensor 3 46°C (114°F) [0x36] (core #3)
Temperature sensor 0 52°C (124°F) [0x33] (GPU Core)
C2D Q6600-3,6 GHz Vid-1,45 - Asus P5Q-PRO - RAM (2x2 Gb +1Gb x 2)= 6 Gb-Asus ENGTX560Ti DC/2DI/1GD5 GPU-950Mhz/Mem-1025Mhz/Vcore-1.075 V
encoded 1442 frames, 56.74 fps, 3899.24 kb/s
encoded 1442 frames, 56.68 fps, 3899.26 kb/s
encoded 1442 frames, 56.57 fps, 3899.26 kb/s
encoded 1442 frames, 54.53 fps, 3899.26 kb/s
encoded 1442 frames, 13.94 fps, 3971.31 kb/s
encoded 1442 frames, 13.91 fps, 3971.60 kb/s
encoded 1442 frames, 13.93 fps, 3971.92 kb/s
encoded 1442 frames, 13.97 fps, 3971.83 kb/s
System Details
Name Intel Core 2 Duo E8400
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Core Stepping C0
Technology 45 nm
Stock frequency 3000 MHz
Core Speed 4050.1 MHz
Southbridge Intel 82801IR (ICH9R) rev. 02
Memory Frequency 600.0 MHz (3:4)
Memory Type DDR2
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 2 (Build 7600)
Number of threads 2
Temperature 0 36°C (96°F) [0x24] (SYSTIN)
Temperature 1 47°C (116°F) [0x5E] (CPUTIN)
Temperature 0 56°C (132°F) [0x2C] (Core #0)
Во дела Phenom II x3 720 на 3.2 и 3,5 считай 1 в 1 и = с Q6600 на 3,2 :spy:
encoded 1442 frames, 55.19 fps, 3900.68 kb/s
encoded 1442 frames, 55.36 fps, 3901.21 kb/s
encoded 1442 frames, 55.45 fps, 3900.68 kb/s
encoded 1442 frames, 55.90 fps, 3900.68 kb/s
encoded 1442 frames, 20.64 fps, 3970.73 kb/s
encoded 1442 frames, 20.38 fps, 3970.77 kb/s
encoded 1442 frames, 20.69 fps, 3969.05 kb/s
encoded 1442 frames, 20.83 fps, 3970.50 kb/s
System Details
Name Intel Core 2 Quad Q6700
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz
Core Stepping G0
Technology 65 nm
Core Speed 3424.5 MHz
FID range 6.0x - 10.0x
Northbridge NVIDIA nForce 650i SLI SPP rev. A2
Southbridge NVIDIA nForce 650i SLI MCP rev. A3
Memory Frequency 428.1 MHz (4:5)
Memory Type DDR2
Channels Dual
Number of threads 4
Temperature 0 60°C (139°F) [0x3C] (TMPIN0)
Temperature 1 43°C (109°F) [0x2B] (TMPIN1)
Temperature 0 70°C (157°F) [0x1E] (Core #0)
Temperature 1 71°C (159°F) [0x1D] (Core #1)
Temperature 2 65°C (148°F) [0x23] (Core #2)
Temperature 3 68°C (154°F) [0x20] (Core #3)
На завтрак снегири, на обед буженина псковская, на ужин консервы бурятские.
encoded 1442 frames, 97.84 fps, 3899.02 kb/s
encoded 1442 frames, 98.40 fps, 3899.02 kb/s
encoded 1442 frames, 97.94 fps, 3899.02 kb/s
encoded 1442 frames, 95.57 fps, 3899.02 kb/s
encoded 1442 frames, 37.64 fps, 3971.34 kb/s
encoded 1442 frames, 37.68 fps, 3971.20 kb/s
encoded 1442 frames, 37.44 fps, 3960.64 kb/s
encoded 1442 frames, 37.53 fps, 3958.24 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 4209.5 MHz
Northbridge Intel X58 rev. 13
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Memory Frequency 801.8 MHz (2:8)
Memory Type DDR3
Memory Size 12288 MBytes
Channels Triple
Number of threads 8
Temperature 1 65°C (148°F) [0x82] (CPUTIN)
Temperature 2 45°C (112°F) [0x59] (AUXTIN)
Temperature 0 77°C (170°F) [0x17] (Core #0)
Temperature 1 72°C (161°F) [0x1C] (Core #1)
Temperature 2 69°C (156°F) [0x1F] (Core #2)
Temperature 3 61°C (141°F) [0x27] (Core #3)
cron
