Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 503 • Страница 8 из 26<  1 ... 5  6  7  8  9  10  11 ... 26  >
XP DX9 март, NV9600GT (OC) на forceware 174.53 + E4500@3000
FileVersion: Build 1.1.1.6115, хотя патч 1.2.
1280x1024 сглаживание 2х http://images.people.overclockers.ru/152478.png
дополнительные настройки графики http://images.people.overclockers.ru/152479.png
проход GPU 30fps http://images.people.overclockers.ru/152475.png
проход CPU1 27fps http://images.people.overclockers.ru/152476.png
проход CPU2 16fps http://images.people.overclockers.ru/152477.png
Фото: 95
Pentium E2160@3465(385*9)
Gpu GeCube 3850 512mb def (770/1800) XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
Custom Cvars:
sys_spec_Full = 3
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 71.95s, Average FPS: 27.80
Min FPS: 19.89 at frame 139, Max FPS: 34.93 at frame 986
Average Tri/Sec: 27381508, Tri/Frame: 985010
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 66.41s, Average FPS: 30.12
Average Tri/Sec: 29996776, Tri/Frame: 995970
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Play Time: 66.29s, Average FPS: 30.17
Min FPS: 19.89 at frame 139, Max FPS: 35.30 at frame 991
Average Tri/Sec: 30066314, Tri/Frame: 996544
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
Gpu GeCube 3850 512mb (823/2140) XP
Custom Cvars:
sys_spec_Full = 3
Play Time: 64.54s, Average FPS: 30.99
Min FPS: 20.21 at frame 155, Max FPS: 38.51 at frame 1009
Average Tri/Sec: 30515570, Tri/Frame: 984667
Play Time: 58.73s, Average FPS: 34.06
Min FPS: 20.21 at frame 155, Max FPS: 39.74 at frame 993
Average Tri/Sec: 33898208, Tri/Frame: 995373
Play Time: 58.65s, Average FPS: 34.10
Min FPS: 20.21 at frame 155, Max FPS: 40.16 at frame 1001
Average Tri/Sec: 33968364, Tri/Frame: 996050
Completed All Tests
Team_MXS
Fire - walk with me.
Е6850 475*9 = 4275 8800U@756(1992)/1188
8800GTS Без разгонов и модификаций
24.03.2008 11:10:51 -
DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
    Play Time: 59.95s, Average FPS: 33.36
    Min FPS: 22.47 at frame 159, Max FPS: 40.92 at frame 994
    Average Tri/Sec: -32434654, Tri/Frame: -972301
    Recorded/Played Tris ratio: -0.94
    Play Time: 56.51s, Average FPS: 35.39
    Min FPS: 22.47 at frame 159, Max FPS: 41.43 at frame 1005
    Average Tri/Sec: -33983388, Tri/Frame: -960138
    Recorded/Played Tris ratio: -0.95
    Min FPS: 22.47 at frame 159, Max FPS: 41.50 at frame 1009
    Average Tri/Sec: -33978576, Tri/Frame: -960006
Completed All Tests
756(2000)\1940
24.03.2008 11:19:06 -
    Play Time: 53.83s, Average FPS: 37.16
    Min FPS: 26.48 at frame 146, Max FPS: 44.39 at frame 984
    Average Tri/Sec: -36120956, Tri/Frame: -972119
    Play Time: 51.59s, Average FPS: 38.77
    Min FPS: 26.48 at frame 146, Max FPS: 44.72 at frame 983
    Average Tri/Sec: -37216716, Tri/Frame: -959932
    Play Time: 51.57s, Average FPS: 38.79
    Min FPS: 26.48 at frame 146, Max FPS: 44.92 at frame 983
    Average Tri/Sec: -37248612, Tri/Frame: -960374
Completed All Tests
850(2123)\1940
24.03.2008 11:30:49 -
    Play Time: 53.35s, Average FPS: 37.49
    Min FPS: 20.98 at frame 139, Max FPS: 45.98 at frame 994
    Average Tri/Sec: -36417884, Tri/Frame: -971508
    Play Time: 49.62s, Average FPS: 40.30
    Min FPS: 20.98 at frame 139, Max FPS: 46.16 at frame 985
    Average Tri/Sec: -38688288, Tri/Frame: -959921
    Play Time: 49.56s, Average FPS: 40.35
    Min FPS: 20.98 at frame 139, Max FPS: 46.39 at frame 982
    Average Tri/Sec: -38721848, Tri/Frame: -959606
    Recorded/Played Tris ratio: -0.96
Completed All Tests
875(2186)\1940
24.03.2008 11:37:54 -
    Play Time: 51.17s, Average FPS: 39.08
    Min FPS: 26.87 at frame 152, Max FPS: 46.91 at frame 989
    Average Tri/Sec: -37999480, Tri/Frame: -972284
    Play Time: 48.93s, Average FPS: 40.88
    Min FPS: 26.87 at frame 152, Max FPS: 47.70 at frame 1014
    Average Tri/Sec: -39252080, Tri/Frame: -960232
    Play Time: 48.88s, Average FPS: 40.92
    Min FPS: 26.87 at frame 152, Max FPS: 47.81 at frame 996
    Average Tri/Sec: -39262636, Tri/Frame: -959612
Completed All Tests
900(2248)\1940
24.03.2008 11:47:55 -
    Play Time: 51.74s, Average FPS: 38.66
    Min FPS: 23.51 at frame 141, Max FPS: 47.78 at frame 987
    Average Tri/Sec: -37561548, Tri/Frame: -971699
    Play Time: 48.00s, Average FPS: 41.67
    Min FPS: 23.51 at frame 141, Max FPS: 49.08 at frame 1004
    Average Tri/Sec: -39996676, Tri/Frame: -959899
    Play Time: 47.99s, Average FPS: 41.68
    Average Tri/Sec: -39966836, Tri/Frame: -958939
Completed All Tests
Должен признать карта очень хорошая и тихая + быстрая (почти догнала в разгоне мою 8800ультру  :o  и это карта за 8 тысяч рублей против 8800ультра за 22  :lol: тысячи я не верил своим глазам блок питания на 650 ватт даже не повышал обороты кулера с 900 до 2000 карта с максимальным разгоном и вольтмодом чипа с 1.170 до 1.440 вольта на GPU это просто фантастика.)
Проверим, что у нас получится в режиме SLI:
670(1674)\1940 SLI 8800GTS 512 G92 Стандартные настройки карт.
24.03.2008 13:34:24 -
    Play Time: 48.73s, Average FPS: 41.04
    Min FPS: 15.46 at frame 144, Max FPS: 58.66 at frame 896
    Average Tri/Sec: -29483560, Tri/Frame: -718395
    Recorded/Played Tris ratio: -1.28
    Play Time: 41.22s, Average FPS: 48.52
    Min FPS: 15.46 at frame 144, Max FPS: 60.92 at frame 61
    Average Tri/Sec: -34806108, Tri/Frame: -717333
    Play Time: 41.15s, Average FPS: 48.60
    Min FPS: 15.46 at frame 144, Max FPS: 62.20 at frame 70
    Average Tri/Sec: -34807752, Tri/Frame: -716202
Completed All Tests
И что мы видим производительность без разгона больше чем с разгоном одиночной карты до внушающих частот 900(2248)\1940 – просто полный финиш
756(2000)\1940 SLI 8800GTS 512 G92
Тут надо сделать отступление: частоты 756(2000)\1940 выбраны не просто так, именно на таких частотах (кроме памяти 2550) у меня работает моя 8800Ultra
24.03.2008 13:42:12 -
    Play Time: 46.03s, Average FPS: 43.45
    Min FPS: 27.99 at frame 1961, Max FPS: 63.08 at frame 976
    Average Tri/Sec: -31220656, Tri/Frame: -718621
    Play Time: 39.51s, Average FPS: 50.62
    Min FPS: 27.99 at frame 1961, Max FPS: 65.18 at frame 123
    Average Tri/Sec: -36312224, Tri/Frame: -717310
    Play Time: 38.83s, Average FPS: 51.51
    Min FPS: 27.99 at frame 1961, Max FPS: 66.43 at frame 111
    Average Tri/Sec: -36869400, Tri/Frame: -715764
Completed All Tests
Результаты для сравнения на 8800Ultra:
15.02.2008 12:21:36 -
    Play Time: 47.23s, Average FPS: 42.34
    Min FPS: 32.34 at frame 170, Max FPS: 50.10 at frame 979
    Average Tri/Sec: -41168000, Tri/Frame: -972271
    Play Time: 45.15s, Average FPS: 44.30
    Min FPS: 32.34 at frame 170, Max FPS: 51.86 at frame 996
    Average Tri/Sec: -42542560, Tri/Frame: -960314
    Min FPS: 32.34 at frame 170, Max FPS: 52.56 at frame 1009
    Average Tri/Sec: -42500144, Tri/Frame: -959474
Completed All Tests
850(2123)\1940 SLI 8800GTS 512 G92
24.03.2008 14:00:08 -
    Play Time: 45.24s, Average FPS: 44.21
    Min FPS: 24.83 at frame 1950, Max FPS: 62.42 at frame 859
    Average Tri/Sec: -31787392, Tri/Frame: -719048
    Recorded/Played Tris ratio: -1.27
    Play Time: 39.01s, Average FPS: 51.27
    Min FPS: 24.83 at frame 1950, Max FPS: 68.50 at frame 104
    Average Tri/Sec: -36761368, Tri/Frame: -717039
    Play Time: 39.14s, Average FPS: 51.10
    Average Tri/Sec: -36600076, Tri/Frame: -716290
Completed All Tests
В тесте прирост есть но только в игре SLI не работает !!!
9800 GX2@750(1875)/1141 E6850@3000
01.04.2008 1:42:38 -
Play Time: 87.36s, Average FPS: 22.89
Min FPS: 9.83 at frame 140, Max FPS: 28.35 at frame 977
Average Tri/Sec: -9290242, Tri/Frame: -405787
Recorded/Played Tris ratio: -2.26
Play Time: 83.24s, Average FPS: 24.03
Min FPS: 9.83 at frame 140, Max FPS: 28.96 at frame 986
Average Tri/Sec: -9593820, Tri/Frame: -399296
Recorded/Played Tris ratio: -2.30
Play Time: 83.19s, Average FPS: 24.04
Min FPS: 9.83 at frame 140, Max FPS: 29.28 at frame 994
Average Tri/Sec: -9610469, Tri/Frame: -399759
Recorded/Played Tris ratio: -2.29
Alexxx650
какой-то странный результат на 9800GX2,
Min FPS: 9.83
:shock: может с драйвером что-то не так?
Да ты прав ;) это 174.53 полночи играл с 174.74 БЕТА игра всё на мах и верихай через конфиг было 22 fps всреднем, сейчас 45 fps.
позже прогоню и выложу результаты.
Alexxx650
Ждем! Если есть возможность, прогони в 10Х!!!!!!!!!!!
На разрешении 1280х1024!
Нет, этого не будет пока DX 10 не будет мифом который можно включить на ХР ;)
Сделаю.
Добавлено спустя 34 минуты, 8 секунд
01.04.2008 13:54:22 -
Play Time: 63.99s, Average FPS: 31.25
Min FPS: 11.70 at frame 146, Max FPS: 41.92 at frame 879
Average Tri/Sec: -12696140, Tri/Frame: -406243
Play Time: 56.80s, Average FPS: 35.21
Min FPS: 11.70 at frame 146, Max FPS: 43.90 at frame 987
Average Tri/Sec: -14040198, Tri/Frame: -398737
Play Time: 56.42s, Average FPS: 35.45
Average Tri/Sec: -14102977, Tri/Frame: -397848
01.04.2008 14:02:23 -
Play Time: 53.74s, Average FPS: 37.22
Min FPS: 17.54 at frame 142, Max FPS: 52.21 at frame 948
Average Tri/Sec: -24861462, Tri/Frame: -667991
Recorded/Played Tris ratio: -1.37
Play Time: 46.63s, Average FPS: 42.89
Min FPS: 17.54 at frame 142, Max FPS: 56.86 at frame 80
Average Tri/Sec: -28386482, Tri/Frame: -661897
Recorded/Played Tris ratio: -1.38
Play Time: 45.78s, Average FPS: 43.69
Average Tri/Sec: -28863768, Tri/Frame: -660697
Recorded/Played Tris ratio: -1.39
Alexxx650
Чего-то результаты мягко говоря слабоваты. :roll:
750(1875)/1100
01.04.2008 14:10:43 -
Play Time: 50.41s, Average FPS: 39.67
Min FPS: 13.93 at frame 147, Max FPS: 57.84 at frame 927
Average Tri/Sec: -26497974, Tri/Frame: -667906
Play Time: 42.40s, Average FPS: 47.17
Min FPS: 13.93 at frame 147, Max FPS: 58.05 at frame 106
Average Tri/Sec: -31206868, Tri/Frame: -661552
Play Time: 41.60s, Average FPS: 48.08
Min FPS: 13.93 at frame 147, Max FPS: 58.67 at frame 102
Average Tri/Sec: -31790552, Tri/Frame: -661232
Alexxx650
Какие драйвера ?!
Для кого делал скрины так и не понял, там всё есть, если не охото смотреть то 174.74 БЕТА и 174.53 с подписью просто ужас …
Alexxx650
У меня например скрины не открываются. :oops:
Alexxx650 А винда XP 64 ?Минималка что-то низковата. Я видел у ребят побольше. А вот моя 8800GTX #77
Последний раз редактировалось Куба 01.04.2008 13:35, всего редактировалось 1 раз.
750(1875)/1100
01.04.2008 14:28:38 -
Play Time: 58.05s, Average FPS: 34.45
Min FPS: 17.70 at frame 138, Max FPS: 46.48 at frame 948
Average Tri/Sec: -14001242, Tri/Frame: -406412
Play Time: 51.72s, Average FPS: 38.67
Min FPS: 17.70 at frame 138, Max FPS: 49.90 at frame 981
Average Tri/Sec: -15447757, Tri/Frame: -399487
Play Time: 50.80s, Average FPS: 39.37
Average Tri/Sec: -15693703, Tri/Frame: -398609
Куба
Две страницы назад я писал
Core 2Duo E6600@2400
ASUS P5Е
8800 GTS512 без разгона
Kingston 2GB kit DDR2 1066@800 5,5,5,18
ОС - ХР SP2
в разрешение 1280х1024 при всех настройках на ВЫС. (High) с АА=0
GPU
high - 33,10/46,46/57,94
:wink:
Тут ещё сказывает, что карта в нижнем слоте в материнке, не через север идёт как обычно а через юг :( просто водоблок мешает на юге мешает поставить в первый слот
Жду 790i ;)
Можно в Кризисе записывать свои демки для последующих тестов? Если можно то какой командой?
Фото: 104
ммм
у меня на dx10 без АА И АФ все верихай
средний 36 фпс
сейчас на работе могу прийти полностью резалт скинуть
X2@3300
GTS 512 @ 800\2000\2200
DLSS RENDERING RES.->DLSS OUTPUT RES.
1440×810->1920×1080(FHD)
1920×1080->2560×1440(QHD)
2560×1440->3840×2160(UHD)
ʞɐɯ оɯ-ʞɐʞ
02.01.2003 8:15:53 - XP
Play Time: 43.20s, Average FPS: 46.30
Min FPS: 27.65 at frame 138, Max FPS: 62.74 at frame 976
Average Tri/Sec: -33265396, Tri/Frame: -718507
Play Time: 37.03s, Average FPS: 54.01
Min FPS: 27.65 at frame 138, Max FPS: 66.18 at frame 899
Average Tri/Sec: -38727028, Tri/Frame: -717078
Play Time: 36.68s, Average FPS: 54.52
Average Tri/Sec: -39032724, Tri/Frame: -715933
Completed All Tests
Сейчас этот форум просматривают: Michailovsky и гости: 13
