Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 9 из 20<  1 ... 6  7  8  9  10  11  12 ... 20  >
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 34.99 fps, 3899.26 kb/s
encoded 1442 frames, 34.92 fps, 3899.26 kb/s
encoded 1442 frames, 34.61 fps, 3899.26 kb/s
encoded 1442 frames, 34.53 fps, 3899.26 kb/s
encoded 1442 frames, 8.26 fps, 3971.47 kb/s
encoded 1442 frames, 8.24 fps, 3971.17 kb/s
encoded 1442 frames, 8.22 fps, 3971.14 kb/s
encoded 1442 frames, 8.30 fps, 3971.17 kb/s
System Details
Name AMD Athlon 64 X2 6000+
Codename Windsor
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Core Stepping JH-F3
Technology 90 nm
Stock frequency 3000 MHz
Core Speed 3250.2 MHz
Northbridge ATI RD770 rev. 00
Southbridge ATI SB600 rev. 00
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 18
Command Rate (CR) 2T
Memory Frequency 406.3 MHz (CPU/8)
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7127)
Number of processors 1
Number of threads 2
Number of threads 2 (max 2)
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Package Socket AM2 (940)
Temperature 0 31°C (87°F) [0x1F] (TMPIN0)
Temperature 2 47°C (116°F) [0x2F] (TMPIN2)
Temperature 0 48°C (118°F) [0x61] (Core #0)
Temperature 1 49°C (120°F) [0x62] (Core #1)
    encoded 1442 frames, 52.65 fps, 3900.68 kb/s
    encoded 1442 frames, 53.25 fps, 3901.21 kb/s
    encoded 1442 frames, 53.28 fps, 3900.68 kb/s
    encoded 1442 frames, 53.69 fps, 3900.68 kb/s
    encoded 1442 frames, 15.37 fps, 3971.87 kb/s
    encoded 1442 frames, 15.31 fps, 3971.62 kb/s
    encoded 1442 frames, 15.36 fps, 3970.65 kb/s
    encoded 1442 frames, 15.36 fps, 3971.70 kb/s
    System Details
    Name Intel Core 2 Quad Q6600
    product System Product Name
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
    Core Stepping G0
    Technology 65 nm
    Stock frequency 2400 MHz
    Core Speed 2405.7 MHz
    FID range 6.0x - 9.0x
    Northbridge Intel X48 rev. 01
    Southbridge Intel 82801IR (ICH9R) rev. 02
    CAS# latency (CL) 7.0
    RAS# to CAS# delay (tRCD) 7
    RAS# Precharge (tRP) 7
    Cycle Time (tRAS) 20
    Command Rate (CR) 1T
    Memory Frequency 534.6 MHz (1:2)
    Memory Type DDR3
    Channels Dual, (Symmetric)
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
    Package (platform ID) Socket 775 LGA (0x4)
    Temperature 0 35°C (94°F) [0x23] (SYSTIN)
    Temperature 1 51°C (123°F) [0x66] (CPUTIN)
    Temperature 0 59°C (138°F) [0x29] (Core #0)
    Temperature 1 63°C (145°F) [0x25] (Core #1)
    Temperature 2 57°C (134°F) [0x2B] (Core #2)
    Temperature 3 59°C (138°F) [0x29] (Core #3)
sv_cheats 1
god
encoded 1442 frames, 87.91 fps, 3899.02 kb/s
encoded 1442 frames, 86.70 fps, 3899.02 kb/s
encoded 1442 frames, 87.53 fps, 3899.02 kb/s
encoded 1442 frames, 86.98 fps, 3899.02 kb/s
encoded 1442 frames, 34.88 fps, 3958.38 kb/s
encoded 1442 frames, 34.91 fps, 3965.71 kb/s
encoded 1442 frames, 34.70 fps, 3961.14 kb/s
encoded 1442 frames, 34.78 fps, 3971.51 kb/s
System Details
Name Intel Core i7 920
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Specification PC3-12800
Core Stepping C0/C1
Technology 45 nm
Stock frequency 2666 MHz
Core Speed 3779.9 MHz
Northbridge Intel X58 rev. 12
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 22
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 720.0 MHz (2:8)
Memory Type DDR3
Memory Size 6144 MBytes
Channels Triple
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 45°C (112°F) [0x2D] (SYSTIN)
Temperature 1 65°C (148°F) [0x82] (CPUTIN)
Temperature 2 15°C (58°F) [0x1D] (AUXTIN)
Temperature 0 69°C (156°F) [0x1F] (Core #0)
Temperature 1 61°C (141°F) [0x27] (Core #1)
Temperature 2 66°C (150°F) [0x22] (Core #2)
Temperature 3 60°C (139°F) [0x28] (Core #3)
Добавлено спустя 9 часов 30 минут 28 секунд:
Это разница между DDR3 1066 и 1600Mhz на Core i7 920, частота ядер стандартная.
1066
Results for x264.exe v0.58.747
encoded 1442 frames, 67.87 fps, 3904.94 kb/s
encoded 1442 frames, 67.83 fps, 3904.94 kb/s
encoded 1442 frames, 67.80 fps, 3904.94 kb/s
encoded 1442 frames, 66.50 fps, 3904.94 kb/s
encoded 1442 frames, 23.72 fps, 3974.08 kb/s
encoded 1442 frames, 23.70 fps, 3974.08 kb/s
encoded 1442 frames, 23.69 fps, 3974.08 kb/s
encoded 1442 frames, 23.52 fps, 3974.08 kb/s
1600
encoded 1442 frames, 71.25 fps, 3904.94 kb/s
encoded 1442 frames, 69.96 fps, 3904.94 kb/s
encoded 1442 frames, 69.34 fps, 3904.94 kb/s
encoded 1442 frames, 69.22 fps, 3904.94 kb/s
encoded 1442 frames, 24.11 fps, 3974.08 kb/s
encoded 1442 frames, 23.62 fps, 3974.08 kb/s
encoded 1442 frames, 23.79 fps, 3974.08 kb/s
Добавлено спустя 2 минуты 21 секунду:
Покупка дорогой быстрой памяти это лохотрон))
GA-Z77-DS3H v1, Core i5 3570K, 16Gb, GTX-560, OCZ Vertex 3 120Gb, Asus Xonar Essence ST
encoded 1442 frames, 61.81 fps, 3900.68 kb/s
encoded 1442 frames, 61.57 fps, 3900.10 kb/s
encoded 1442 frames, 61.77 fps, 3900.89 kb/s
encoded 1442 frames, 61.61 fps, 3900.10 kb/s
encoded 1442 frames, 19.17 fps, 3972.09 kb/s
encoded 1442 frames, 19.09 fps, 3970.57 kb/s
encoded 1442 frames, 19.19 fps, 3971.13 kb/s
encoded 1442 frames, 18.98 fps, 3971.77 kb/s
System Details
Name AMD Phenom II X4
Codename Deneb
Specification AMD Phenom(tm) II X4 B25 Processor
Core Stepping
Technology 45 nm
Stock frequency 2700 MHz
Core Speed 2970.0 MHz
FID range 5.0x - 13.5x
Northbridge AMD 785GX rev. 00
Southbridge ATI SB750 rev. 00
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Memory Frequency 733.3 MHz (3:10)
Memory Type DDR3
Memory Size 2048 MBytes
Channels Single
Number of threads 4
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 54°C (129°F) [0x36] (TMPIN0)
Temperature 1 36°C (96°F) [0x24] (TMPIN1)
Temperature 0 0°C (32°F) [0x0] (Core #0)
Temperature 1 0°C (32°F) [0x0] (Core #1)
Temperature 2 0°C (32°F) [0x0] (Core #2)
Temperature 3 0°C (32°F) [0x0] (Core #3)
encoded 1442 frames, 72.90 fps, 3900.68 kb/s
encoded 1442 frames, 73.89 fps, 3900.68 kb/s
encoded 1442 frames, 73.19 fps, 3900.93 kb/s
encoded 1442 frames, 73.42 fps, 3901.21 kb/s
encoded 1442 frames, 23.02 fps, 3971.82 kb/s
encoded 1442 frames, 23.05 fps, 3972.53 kb/s
encoded 1442 frames, 23.11 fps, 3970.80 kb/s
encoded 1442 frames, 23.04 fps, 3971.60 kb/s
System Details
Name Intel Core 2 Quad Q9400
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
Core Stepping R0
Technology 45 nm
Core Speed 3600.1 MHz
FID range 6.0x - 8.0x
Northbridge Intel P45/P43 rev. A3
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Memory Frequency 450.0 MHz (1:1)
Memory Type DDR2
Number of threads 4
L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Temperature 0 33°C (91°F) [0x21] (System)
Temperature 1 51°C (123°F) [0x66] (CPU)
Temperature 2 10°C (49°F) [0x13] (AUX)
Temperature 0 55°C (130°F) [0x2D] (Core #0)
Temperature 1 55°C (130°F) [0x2D] (Core #1)
Temperature 2 59°C (138°F) [0x29] (Core #2)
Temperature 3 56°C (132°F) [0x2C] (Core #3)
encoded 1442 frames, 92.87 fps, 3899.02 kb/s
encoded 1442 frames, 91.91 fps, 3899.02 kb/s
encoded 1442 frames, 91.42 fps, 3899.02 kb/s
encoded 1442 frames, 92.71 fps, 3899.02 kb/s
encoded 1442 frames, 36.61 fps, 3963.53 kb/s
encoded 1442 frames, 36.60 fps, 3961.30 kb/s
encoded 1442 frames, 36.53 fps, 3957.02 kb/s
encoded 1442 frames, 36.56 fps, 3964.34 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 3999.9 MHz
Northbridge Intel X58 rev. 13
Cycle Time (tRAS) 21
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 800.0 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 37°C (98°F) [0x25] (SYSTIN)
Temperature 1 55°C (130°F) [0x6E] (CPUTIN)
Temperature 0 66°C (150°F) [0x1F] (Core #0)
Temperature 1 56°C (132°F) [0x29] (Core #1)
Temperature 2 63°C (145°F) [0x22] (Core #2)
Temperature 3 56°C (132°F) [0x29] (Core #3)
الحب هو الخط الفاصل بين الخير والشر
encoded 1442 frames, 64.23 fps, 3901.21 kb/s
encoded 1442 frames, 64.91 fps, 3900.68 kb/s
encoded 1442 frames, 64.91 fps, 3901.21 kb/s
encoded 1442 frames, 64.33 fps, 3900.68 kb/s
encoded 1442 frames, 20.16 fps, 3970.85 kb/s
encoded 1442 frames, 20.17 fps, 3970.58 kb/s
encoded 1442 frames, 20.22 fps, 3971.40 kb/s
encoded 1442 frames, 20.15 fps, 3971.01 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000)
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Core Speed 3200.1 MHz
Northbridge Intel X38 rev. 01
Memory Frequency 400.0 MHz (1:1)
Memory Type DDR2
Number of threads 4
Temperature 0 40°C (103°F) [0x28] (System)
Temperature 1 54°C (129°F) [0x36] (CPU)
Temperature 0 66°C (150°F) [0x22] (Core #0)
Temperature 1 67°C (152°F) [0x21] (Core #1)
Temperature 3 61°C (141°F) [0x27] (Core #3)
encoded 1442 frames, 97.41 fps, 3901.21 kb/s
encoded 1442 frames, 97.35 fps, 3900.68 kb/s
encoded 1442 frames, 97.76 fps, 3900.68 kb/s
encoded 1442 frames, 97.78 fps, 3901.21 kb/s
encoded 1442 frames, 29.04 fps, 3971.88 kb/s
encoded 1442 frames, 29.06 fps, 3965.93 kb/s
encoded 1442 frames, 28.85 fps, 3971.82 kb/s
encoded 1442 frames, 29.02 fps, 3970.60 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 3800.0 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Type DDR3
Channels Triple
Number of threads 4
Number of threads 4 (max 16)
Temperature 0 42°C (107°F) [0x2A] (SYSTIN)
Temperature 1 49°C (119°F) [0x61] (CPUTIN)
Temperature 2 10°C (49°F) [0x13] (AUXTIN)
Temperature 0 58°C (136°F) [0x2A] (Core #0)
Temperature 3 55°C (130°F) [0x2D] (Core #3)
Хоршо там,где нас нет
encoded 1442 frames, 100.86 fps, 3901.65 kb/s
encoded 1442 frames, 100.75 fps, 3893.41 kb/s
encoded 1442 frames, 100.10 fps, 3887.21 kb/s
encoded 1442 frames, 100.42 fps, 3900.66 kb/s
encoded 1442 frames, 32.90 fps, 3979.22 kb/s
encoded 1442 frames, 33.44 fps, 3957.13 kb/s
encoded 1442 frames, 32.62 fps, 3956.46 kb/s
encoded 1442 frames, 32.56 fps, 3955.09 kb/s
System Details
Name Intel Core i5 750
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Core Stepping B1
Technology 45 nm
Manufacturer (ID) Apacer Technology (7F7A000000000000)
Core Speed 4337.7 MHz
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 05
Memory Frequency 650.7 MHz (2:6)
Memory Type DDR3
Channels Dual
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Number of threads 4
Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 51°C (123°F) [0x33] (SYSTIN)
Temperature 1 52°C (124°F) [0x67] (CPUTIN)
Temperature 2 36°C (95°F) [0x47] (AUXTIN)
Temperature 0 51°C (123°F) [0x30] (Core #0)
Temperature 1 48°C (118°F) [0x33] (Core #1)
Temperature 2 45°C (112°F) [0x36] (Core #2)
Temperature 3 41°C (105°F) [0x3A] (Core #3)
Если работаешь, чтобы жить — зачем убиваться на работе?
encoded 1442 frames, 69.28 fps, 3899.90 kb/s
encoded 1442 frames, 69.60 fps, 3899.90 kb/s
encoded 1442 frames, 69.55 fps, 3899.90 kb/s
encoded 1442 frames, 69.13 fps, 3899.90 kb/s
encoded 1442 frames, 15.48 fps, 3971.83 kb/s
encoded 1442 frames, 15.41 fps, 3971.89 kb/s
encoded 1442 frames, 15.43 fps, 3971.77 kb/s
encoded 1442 frames, 15.42 fps, 3970.86 kb/s
System Details
Name AMD Phenom II X3 720
Codename Heka
Specification AMD Phenom(tm) II X3 720 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 3602.1 MHz
Northbridge AMD 790GX rev. 00
Memory Frequency 667.0 MHz (3:10)
Memory Type DDR3
Channels Dual, (Unganged)
Number of threads 3
Number of threads 3 (max 3)
L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size
Package Type 0x1
Temperature 0 46°C (114°F) [0x2E] (TMPIN0)
Temperature 2 27°C (80°F) [0x1B] (TMPIN2)
Temperature 0 44°C (111°F) [0x160] (Core #0)
Temperature 1 44°C (111°F) [0x160] (Core #1)
Temperature 2 44°C (111°F) [0x160] (Core #2)
Нет предела совершенству.
encoded 1442 frames, 64.46 fps, 3901.21 kb/s
encoded 1442 frames, 65.14 fps, 3900.68 kb/s
encoded 1442 frames, 65.88 fps, 3900.68 kb/s
encoded 1442 frames, 64.15 fps, 3901.21 kb/s
encoded 1442 frames, 19.70 fps, 3971.51 kb/s
encoded 1442 frames, 19.64 fps, 3971.15 kb/s
encoded 1442 frames, 19.60 fps, 3971.95 kb/s
encoded 1442 frames, 19.64 fps, 3967.14 kb/s
System Details
Name AMD Phenom II X4 945
Codename Deneb
Specification AMD Phenom(tm) II X4 945 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 3013.1 MHz
FID range 5.0x - 15.0x
Memory Frequency 669.6 MHz (3:10)
Memory Type DDR3
Number of threads 4
Package Type 0x1
Temperature 0 43°C (109°F) [0x2B] (TMPIN0)
Temperature 1 50°C (121°F) [0x32] (TMPIN1)
Temperature 2 49°C (120°F) [0x31] (TMPIN2)
Temperature 0 45°C (112°F) [0x164] (Core #0)
Temperature 1 45°C (112°F) [0x164] (Core #1)
Temperature 3 45°C (112°F) [0x164] (Core #3)
Temperature 2 44°C (111°F) [0x163] (Core #2)
после разгона
encoded 1442 frames, 80.24 fps, 3900.68 kb/s
encoded 1442 frames, 80.39 fps, 3900.69 kb/s
encoded 1442 frames, 80.87 fps, 3901.14 kb/s
encoded 1442 frames, 81.37 fps, 3901.22 kb/s
encoded 1442 frames, 24.35 fps, 3971.72 kb/s
encoded 1442 frames, 24.34 fps, 3971.62 kb/s
encoded 1442 frames, 24.51 fps, 3970.49 kb/s
encoded 1442 frames, 24.45 fps, 3971.15 kb/s
System Details
Codename Deneb
Core Stepping RB-C2
Technology 45 nm
Core Speed 3750.0 MHz
Memory Frequency 833.3 MHz (3:10)
Memory Type DDR3
Number of threads 4
Package Type 0x1
Temperature 0 41°C (105°F) [0x29] (TMPIN0)
Temperature 1 57°C (134°F) [0x39] (TMPIN1)
Temperature 2 53°C (127°F) [0x35] (TMPIN2)
Temperature 0 50°C (122°F) [0x192] (Core #0)
Temperature 1 50°C (122°F) [0x191] (Core #1)
Temperature 2 50°C (122°F) [0x191] (Core #2)
Temperature 3 50°C (122°F) [0x191] (Core #3)
Последний раз редактировалось 123RaZoR321 18.01.2010 14:44, всего редактировалось 1 раз.
encoded 1442 frames, 57.16 fps, 3900.68 kb/s
encoded 1442 frames, 56.12 fps, 3901.21 kb/s
encoded 1442 frames, 55.62 fps, 3901.21 kb/s
encoded 1442 frames, 55.53 fps, 3901.21 kb/s
encoded 1442 frames, 19.58 fps, 3971.99 kb/s
encoded 1442 frames, 19.64 fps, 3970.73 kb/s
encoded 1442 frames, 19.68 fps, 3971.94 kb/s
encoded 1442 frames, 19.45 fps, 3971.46 kb/s
System Details
Name AMD Athlon II X4 630
Codename Propus
Specification AMD Athlon(tm) II X4 630 Processor
Core Stepping
Technology 45 nm
Stock frequency 2800 MHz
Core Speed 3360.0 MHz
FID range 5.0x - 14.0x
Northbridge AMD 790X rev. 00
Cycle Time (tRAS) 13
Memory Frequency 400.0 MHz (3:5)
Memory Type DDR2
Channels Single
Number of threads 4
Package Type 0x1
Temperature 1 54°C (129°F) [0x36] (TMPIN1)
Temperature 2 57°C (134°F) [0x39] (TMPIN2)
Temperature 0 53°C (127°F) [0x1A7] (Core #0)
Temperature 1 53°C (127°F) [0x1A7] (Core #1)
Temperature 3 53°C (127°F) [0x1A7] (Core #3)
Temperature 2 53°C (127°F) [0x1A7] (Core #2)
encoded 1442 frames, 66.51 fps, 3901.21 kb/s
encoded 1442 frames, 61.52 fps, 3900.68 kb/s
encoded 1442 frames, 60.19 fps, 3900.68 kb/s
encoded 1442 frames, 67.07 fps, 3900.68 kb/s
encoded 1442 frames, 22.20 fps, 3971.54 kb/s
encoded 1442 frames, 19.37 fps, 3971.75 kb/s
encoded 1442 frames, 22.24 fps, 3970.71 kb/s
encoded 1442 frames, 21.87 fps, 3968.33 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3615.8 MHz
Memory Frequency 452.0 MHz (1:1)
Memory Type DDR2
Memory Size 8192 MBytes
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 3 (Build 7600)
Number of threads 4
Temperature 0 34°C (93°F) [0x22] (System)
Temperature 1 55°C (130°F) [0x37] (CPU)
Temperature 1 65°C (148°F) [0x23] (Core #1)
Temperature 2 63°C (145°F) [0x25] (Core #2)
Temperature 3 66°C (150°F) [0x22] (Core #3)
encoded 1442 frames, 70.85 fps, 3900.68 kb/s
encoded 1442 frames, 71.26 fps, 3900.68 kb/s
encoded 1442 frames, 69.86 fps, 3900.68 kb/s
encoded 1442 frames, 70.16 fps, 3901.21 kb/s
encoded 1442 frames, 22.42 fps, 3970.56 kb/s
encoded 1442 frames, 22.40 fps, 3970.51 kb/s
encoded 1442 frames, 22.41 fps, 3970.54 kb/s
encoded 1442 frames, 22.52 fps, 3971.60 kb/s
System Details
Name AMD Phenom II X4 920
Codename Deneb
Specification AMD Phenom(tm) II X4 920 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 3640.3 MHz
Northbridge AMD 790FX rev. 00
Cycle Time (tRAS) 15
Memory Frequency 433.4 MHz (3:5)
Memory Type DDR2
Channels Dual, (Ganged)
Number of threads 4
Package Type 0x1
Temperature 1 35°C (94°F) [0x23] (TMPIN1)
Temperature 2 79°C (174°F) [0x4F] (TMPIN2)
Temperature 0 47°C (117°F) [0x17A] (Core #0)
Temperature 1 47°C (117°F) [0x17A] (Core #1)
Temperature 2 47°C (116°F) [0x179] (Core #2)
Temperature 3 47°C (116°F) [0x179] (Core #3)
encoded 1442 frames, 78.16 fps, 3900.68 kb/s
encoded 1442 frames, 79.62 fps, 3900.68 kb/s
encoded 1442 frames, 79.76 fps, 3901.21 kb/s
encoded 1442 frames, 79.23 fps, 3901.21 kb/s
encoded 1442 frames, 25.76 fps, 3971.64 kb/s
encoded 1442 frames, 25.67 fps, 3971.87 kb/s
encoded 1442 frames, 25.73 fps, 3971.46 kb/s
encoded 1442 frames, 25.85 fps, 3971.47 kb/s
System Details
Name Intel Core 2 Quad Q9550
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Core Stepping E0
Technology 45 nm
Stock frequency 2833 MHz
Core Speed 3995.0 MHz
FID range 6.0x - 8.5x
Northbridge Intel P45/P43/G45/G43 rev. A2
Memory Frequency 470.0 MHz (1:1)
Memory Type DDR2
Number of threads 4
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Temperature 0 36°C (96°F) [0x24] (SYSTIN)
Temperature 1 38°C (100°F) [0x4C] (CPUTIN)
Temperature 2 23°C (72°F) [0x2D] (AUXTIN)
Temperature 0 53°C (127°F) [0x2F] (Core #0)
Temperature 1 45°C (112°F) [0x37] (Core #1)
Temperature 2 47°C (116°F) [0x35] (Core #2)
Temperature 3 47°C (116°F) [0x35] (Core #3)
Core i7 2600K@4500, Gigabyte UD4B3, ОЗУ 4x2048, Palit JetStream 980, SSD Plextor PX-256M3+Raid 1Tb*2, БП 1500W,CM HAF X942, CM V10, X-Fi TitanHD
encoded 1442 frames, 65.50 fps, 3900.68 kb/s
encoded 1442 frames, 65.36 fps, 3900.68 kb/s
encoded 1442 frames, 65.27 fps, 3900.68 kb/s
encoded 1442 frames, 64.86 fps, 3901.21 kb/s
encoded 1442 frames, 20.87 fps, 3970.73 kb/s
encoded 1442 frames, 20.62 fps, 3971.80 kb/s
encoded 1442 frames, 20.65 fps, 3971.87 kb/s
encoded 1442 frames, 20.53 fps, 3971.02 kb/s
System Details
Name Intel Core 2 Quad Q6700
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz
Core Stepping G0
Technology 65 nm
Core Speed 3330.2 MHz
FID range 6.0x - 10.0x
Northbridge Intel X58 rev. 02
Memory Type
Number of threads 4
Temperature 0 48°C (118°F) [0x30] (System)
Temperature 1 53°C (127°F) [0x35] (CPU)
Temperature 0 62°C (143°F) [0x26] (Core #0)
Temperature 3 51°C (123°F) [0x31] (Core #3)
Temperature 2 54°C (129°F) [0x2E] (Core #2)
encoded 1442 frames, 83.88 fps, 3900.68 kb/s
encoded 1442 frames, 84.65 fps, 3900.68 kb/s
encoded 1442 frames, 85.51 fps, 3901.21 kb/s
encoded 1442 frames, 26.14 fps, 3973.38 kb/s
encoded 1442 frames, 26.38 fps, 3971.57 kb/s
encoded 1442 frames, 26.42 fps, 3971.73 kb/s
encoded 1442 frames, 26.34 fps, 3971.56 kb/s
System Details
Name Intel Core 2 Quad Q9505
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9505 @ 2.83GHz
Core Stepping R0
Technology 45 nm
Core Speed 3994.9 MHz
Memory Frequency 564.0 MHz (5:6)
Memory Type DDR2
Number of threads 4
Temperature 0 30°C (85°F) [0x1E] (System)
Temperature 1 45°C (112°F) [0x5A] (CPU)
Temperature 2 16°C (59°F) [0x1F] (AUX)
Temperature 0 54°C (129°F) [0x2E] (Core #0)
Temperature 1 51°C (123°F) [0x31] (Core #1)
Temperature 2 51°C (123°F) [0x31] (Core #2)
Temperature 3 54°C (129°F) [0x2E] (Core #3)
encoded 1442 frames, 53.38 fps, 3900.68 kb/s
encoded 1442 frames, 54.62 fps, 3901.21 kb/s
encoded 1442 frames, 54.92 fps, 3900.68 kb/s
encoded 1442 frames, 54.11 fps, 3901.21 kb/s
encoded 1442 frames, 18.04 fps, 3970.42 kb/s
encoded 1442 frames, 18.05 fps, 3972.07 kb/s
encoded 1442 frames, 17.88 fps, 3970.94 kb/s
encoded 1442 frames, 18.06 fps, 3971.62 kb/s
System Details
Name Intel Core 2 Quad Q8200
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz
Core Stepping M1
Technology 45 nm
Stock frequency 2333 MHz
Core Speed 3010.0 MHz
FID range 6.0x - 7.0x
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
Memory Frequency 430.0 MHz (1:1)
Memory Type DDR2
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 2 (Build 6002)
Number of threads 4
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
Temperature 0 43°C (109°F) [0x2B] (System)
Temperature 0 68°C (154°F) [0x20] (Core #0)
Temperature 2 68°C (154°F) [0x20] (Core #2)
Temperature 3 62°C (143°F) [0x26] (Core #3)
"Господа,.."-это обращение лакеев и холопов к своим хозяевам. ;)
encoded 1442 frames, 20.71 fps, 3899.26 kb/s
encoded 1442 frames, 21.43 fps, 3899.26 kb/s
encoded 1442 frames, 21.67 fps, 3899.26 kb/s
encoded 1442 frames, 21.28 fps, 3899.26 kb/s
encoded 1442 frames, 4.96 fps, 3971.32 kb/s
encoded 1442 frames, 4.94 fps, 3971.20 kb/s
encoded 1442 frames, 4.90 fps, 3971.94 kb/s
encoded 1442 frames, 4.90 fps, 3970.61 kb/s
System Details
Name AMD Athlon 64 X2 3600+
Codename Windsor
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 3600+
Core Stepping BH-F2
Technology 90 nm
Stock frequency 2000 MHz
Core Speed 2009.2 MHz
Northbridge NVIDIA GeForce 6100 rev. A2
Southbridge NVIDIA nForce 410/430 MCP rev. A3
Memory Frequency 334.9 MHz (CPU/6)
Memory Type DDR2
Memory Size 512 MBytes
Channels Single
Number of threads 2
L2 cache 2 x 256 KBytes, 16-way set associative, 64-byte line size
Temperature 1 30°C (85°F) [0x1E] (TMPIN1)
Temperature 2 43°C (109°F) [0x2B] (TMPIN2)
Temperature 0 53°C (127°F) [0x66] (Core #0)
Temperature 1 53°C (127°F) [0x66] (Core #1)
encoded 1442 frames, 83.26 fps, 3899.02 kb/s
encoded 1442 frames, 84.09 fps, 3899.02 kb/s
encoded 1442 frames, 82.66 fps, 3899.02 kb/s
encoded 1442 frames, 81.68 fps, 3899.02 kb/s
encoded 1442 frames, 32.45 fps, 3964.18 kb/s
encoded 1442 frames, 32.59 fps, 3964.73 kb/s
encoded 1442 frames, 32.40 fps, 3961.88 kb/s
encoded 1442 frames, 32.78 fps, 3964.85 kb/s
System Details
Codename Bloomfield
Specification PC3-10700
Core Stepping C0/C1
Technology 45 nm
Core Speed 3700.0 MHz
Command Rate 1T
Command Rate 1T
Command Rate 1T
Command Rate 1T
Command Rate 1T
Command Rate 1T
Memory Frequency 740.0 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 24°C (75°F) [0x18] (SYSTIN)
Temperature 1 48°C (118°F) [0x60] (CPUTIN)
Temperature 2 19°C (65°F) [0x25] (AUXTIN)
Temperature 0 64°C (147°F) [0x24] (Core #0)
Asus RAMPAGE II Extreme/Intel Core i7 920 3.7Ghz/9800GTX/OCZ 6Gb 1484Mhz/ASUS Triton 81
[img]http://img695.imageshack..us/img695/7871/commc.png[/img]
