Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 503 • Страница 10 из 26<  1 ... 7  8  9  10  11  12  13 ... 26  >
Фото: 4
benchmark_cpu
DX10 1900x1200 AA=No AA, 64 bit test, Quality: VeryHigh ~~ Last Average FPS: 24.99
Min FPS: 12.59 at frame 196, Max FPS: 36.41 at frame 120
DX10 1680x1050 AA=No AA, 64 bit test, Quality: VeryHigh ~~ Last Average FPS: 28.94
benchmark_gpu
DX10 1680x1050 AA=No AA, 64 bit test, Quality: VeryHigh ~~ Last Average FPS: 30.53
1 прогон каждого теста
XFX 780i
XFX 8800 Ultra x 2 SLi без разгона
8400@3.6
4x2048 OCZ
HDD 74 WD 10000 - System
HREN
Надо как минимум 3 раза прогнать каждый тест - в первом прогоне очень низкие результаты получаются.
The pleasure, I'm sure, was all mine.
Intel C2D E6600 @ 3.6 Ghz,
Nvidia 8800 GTS 512 Mb @ 818/1944/2345 Mhz,
DDR2-800 4-4-4-12 4x1Gb,
Forceware 174.93,
Windows XP SP2 (DX9),
benchmark_gpu, 2-3 прогоны.
- High Quality:
1280x1024 - 54.51 fps (min - 32.06 fps), с 4AA - 40.96 fps (min - 25.85 fps),
1680x1050 - 41.85 fps (min - 23.76 fps), с 4AA - 29.03 fps (min - 20.34 fps),
- Very High Quality:
1280x1024 - 42.24 fps (min - 21.59 fps),
1680x1050 - 32.47 fps (min - 20.76 fps).
PS. Скрины не делал, если надо сделаю.
Nvidia geforce 9800 GX2, 175.12(БЕТА)
05.05.2008 20:52:13 - Vista 64
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX10 1680x1050, AA=No AA, Vsync=Disabled, 64 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: VeryHigh
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 91.87s, Average FPS: 21.77
Min FPS: 7.99 at frame 145, Max FPS: 35.39 at frame 977
Average Tri/Sec: -8795016, Tri/Frame: -403988
Recorded/Played Tris ratio: -2.27
!TimeDemo Run 1 Finished.
Play Time: 73.88s, Average FPS: 27.07
Min FPS: 7.99 at frame 145, Max FPS: 41.59 at frame 94
Average Tri/Sec: -10575413, Tri/Frame: -390635
Recorded/Played Tris ratio: -2.35
!TimeDemo Run 2 Finished.
Play Time: 73.67s, Average FPS: 27.15
Average Tri/Sec: -10544075, Tri/Frame: -388403
Recorded/Played Tris ratio: -2.36
TimeDemo Play Ended, (3 Runs Performed)
Beginning Run #2 on Map-island, Demo-benchmark_gpu
DX10 1280x1024, AA=No AA, Vsync=Disabled, 64 bit test, FullScreen
Play Time: 92.41s, Average FPS: 21.64
Min FPS: 12.63 at frame 137, Max FPS: 35.89 at frame 989
Average Tri/Sec: -8737704, Tri/Frame: -403710
Play Time: 81.12s, Average FPS: 24.65
Min FPS: 12.63 at frame 137, Max FPS: 39.73 at frame 92
Average Tri/Sec: -9638226, Tri/Frame: -390934
Recorded/Played Tris ratio: -2.34
Play Time: 84.08s, Average FPS: 23.79
Average Tri/Sec: -9243442, Tri/Frame: -388578
Beginning Run #3 on Map-island, Demo-benchmark_gpu
DX10 1280x720, AA=No AA, Vsync=Disabled, 64 bit test, FullScreen
Play Time: 94.61s, Average FPS: 21.14
Min FPS: 11.96 at frame 150, Max FPS: 35.31 at frame 977
Average Tri/Sec: -8520574, Tri/Frame: -403073
Play Time: 80.84s, Average FPS: 24.74
Min FPS: 11.96 at frame 150, Max FPS: 39.92 at frame 70
Average Tri/Sec: -9659144, Tri/Frame: -390402
Play Time: 79.88s, Average FPS: 25.04
Average Tri/Sec: -9768915, Tri/Frame: -390186
Completed All Tests
G-box Мдэ! Результаты убогие донельзя. :rip:
Сейчас у себя на висте проверю. :hitrost:
Добавлено спустя 1 час, 1 минуту, 51 секунду
И что же мы видим.
На абсолютно дефолтной(ни одного мегагерца разгона) машине
Intel Core 2 E8400@3000
Kingston 2GB kit DDR2 1066MHz@800
ABIT IP35-E
GeForce 9800GTХ
На тех же дровах 175,12
1280-1024 no aa all veryhigh
Min FPS: 13.88 Average FPS: 24.27 Max FPS: 28.30
http://i015..radikal.ru/0805/4d/d69fd8ae0adf.jpg
У тебя практически такие же результаты
G-box
Но системы какбы немного отличаются. :wink:
Так зачем платить больше?
Только что замерял в 1920 на 1080, результаты практически такие же, короче чё не тесть везде все огдно и тоже практически
Фото: 3
этот бенч(макс,8х) может считаться тестом на стабильность? Сейчас шейдеры на 2052 прогнал.
Приходит время, когда вы смотритесь в зеркало и осознаёте, что увиденное там — всё, чем вы когда–либо станете.
Darth Vader вряд ли,раньше шейдеры хорошо грел LostPlanet, да и марки для этого годятся.
The cruncher's way is long as a Jedi's one © Fe[R]gity
1280*1024
WinXPSp2
NoAA/AF 8800GT@760/2050 (игра без патча)
GPU
Play Time: 50.48s, Average FPS: 39.62
Min FPS: 19.30 at frame 151, Max FPS: 48.99 at frame 968
Average Tri/Sec: 40080624, Tri/Frame: 1011616
Recorded/Played Tris ratio: 0.91
Play Time: 45.40s, Average FPS: 44.05
Min FPS: 19.30 at frame 151, Max FPS: 51.52 at frame 1024
Average Tri/Sec: 44993772, Tri/Frame: 1021382
Recorded/Played Tris ratio: 0.90
Play Time: 45.42s, Average FPS: 44.03
Average Tri/Sec: 45007276, Tri/Frame: 1022117
!TimeDemo Run 3 Finished.
Play Time: 45.41s, Average FPS: 44.05
Min FPS: 19.30 at frame 151, Max FPS: 51.85 at frame 1024
Average Tri/Sec: 45035928, Tri/Frame: 1022489
TimeDemo Play Ended, (4 Runs Performed)
Win XPSP3 (офф релиз)
CPU
2180@3.2Ггц
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 42.90s, Average FPS: 34.96
Min FPS: 16.93 at frame 196, Max FPS: 47.75 at frame 127
Average Tri/Sec: 35774544, Tri/Frame: 1023249
Recorded/Played Tris ratio: 0.70
Play Time: 38.20s, Average FPS: 39.27
Min FPS: 16.93 at frame 196, Max FPS: 50.31 at frame 379
Average Tri/Sec: 40158676, Tri/Frame: 1022636
Play Time: 38.69s, Average FPS: 38.77
Min FPS: 16.93 at frame 196, Max FPS: 50.54 at frame 384
Average Tri/Sec: 39664460, Tri/Frame: 1022979
Play Time: 39.19s, Average FPS: 38.27
Average Tri/Sec: 39066820, Tri/Frame: 1020790
В сп3 наблюдаю тотальное снижение фпс на 3-5%
Asus p5k pro/e8400@4.3Ghz/8800GT 774/2050 Zilent 1000/Corsair TWIN2048C4 6400@1050Mhz/Tt 120Vx/Benq e2200hda
Последний раз редактировалось CroNu4 14.05.2008 8:41, всего редактировалось 1 раз.
Протестил новые дрова 175.16 и получается какой-то бред на них в среднем выдает на 10 фпс меньше чем на 175.12 или 174.74, не понимаю с чем это может быть связано? Откатился обратно на 175.12 и снова 25-28 фпс!?
В здмарке 06 выдает 5000! Хотя на 174.74 выдавал ~12500 примерно, не понимаю чё за фигня???
c2d e8400 @ 4.23GHz / Asus p5n-d / OCZ 2x2GB 940MHz
2 x 8800GTS_512 @ 740/1836/2044
дрова 175.16whql / Vista 32
20.05.2008 23:01:51 - Vista
DX10 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 61.67s, Average FPS: 32.43
Min FPS: 19.56 at frame 1091, Max FPS: 41.60 at frame 955
Average Tri/Sec: -12924779, Tri/Frame: -398537
Recorded/Played Tris ratio: -2.30
Play Time: 55.54s, Average FPS: 36.01
Min FPS: 19.56 at frame 1091, Max FPS: 43.83 at frame 64
Average Tri/Sec: -13895137, Tri/Frame: -385878
Recorded/Played Tris ratio: -2.38
Play Time: 55.24s, Average FPS: 36.21
Average Tri/Sec: -13895048, Tri/Frame: -383777
Recorded/Played Tris ratio: -2.39
NEXT BENCH RUN- 20.05.2008 23:07:06 - Vista
DX10 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 49.12s, Average FPS: 40.72
Min FPS: 24.54 at frame 157, Max FPS: 54.36 at frame 855
Average Tri/Sec: -27004032, Tri/Frame: -663221
Recorded/Played Tris ratio: -1.38
Play Time: 42.63s, Average FPS: 46.92
Min FPS: 24.54 at frame 157, Max FPS: 56.54 at frame 1003
Average Tri/Sec: -30609120, Tri/Frame: -652384
Recorded/Played Tris ratio: -1.41
Play Time: 41.78s, Average FPS: 47.87
Min FPS: 24.54 at frame 157, Max FPS: 56.82 at frame 1009
Average Tri/Sec: -31072660, Tri/Frame: -649043
Completed All Tests
175.16whql / WinXP 32 / Crysis build 6115
24.05.2008 14:06:49 - XP
DX9 1680x1050, AA=4x, Vsync=Disabled, 32 bit test, FullScreen
Global Game Quality: High
Play Time: 54.52s, Average FPS: 36.69
Min FPS: 22.11 at frame 144, Max FPS: 48.63 at frame 983
Average Tri/Sec: -25340290, Tri/Frame: -690750
Recorded/Played Tris ratio: -1.33
Play Time: 50.20s, Average FPS: 39.84
Min FPS: 22.11 at frame 144, Max FPS: 49.74 at frame 74
Average Tri/Sec: -27439832, Tri/Frame: -688725
Play Time: 49.71s, Average FPS: 40.23
Min FPS: 22.11 at frame 144, Max FPS: 50.16 at frame 91
Average Tri/Sec: -27702456, Tri/Frame: -688519
DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 45.36s, Average FPS: 44.09
Min FPS: 24.87 at frame 162, Max FPS: 59.60 at frame 977
Average Tri/Sec: -31705614, Tri/Frame: -719050
Recorded/Played Tris ratio: -1.27
Play Time: 39.48s, Average FPS: 50.66
Min FPS: 24.87 at frame 162, Max FPS: 62.77 at frame 91
Average Tri/Sec: -36341596, Tri/Frame: -717431
Recorded/Played Tris ratio: -1.28
Play Time: 38.67s, Average FPS: 51.72
Min FPS: 24.87 at frame 162, Max FPS: 64.91 at frame 78
Average Tri/Sec: -37045176, Tri/Frame: -716330
DX9 1280x1024, AA=4x, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 45.15s, Average FPS: 44.30
Min FPS: 30.24 at frame 169, Max FPS: 62.64 at frame 883
Average Tri/Sec: -39267116, Tri/Frame: -886430
Recorded/Played Tris ratio: -1.03
Play Time: 38.20s, Average FPS: 52.35
Min FPS: 30.24 at frame 169, Max FPS: 63.82 at frame 976
Average Tri/Sec: -46350788, Tri/Frame: -885408
Recorded/Played Tris ratio: -1.04
Play Time: 37.81s, Average FPS: 52.90
Min FPS: 30.24 at frame 169, Max FPS: 67.73 at frame 1003
Average Tri/Sec: -46764528, Tri/Frame: -884041
Beginning Run #4 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 40.15s, Average FPS: 49.81
Min FPS: 28.52 at frame 141, Max FPS: 72.30 at frame 878
Average Tri/Sec: -45616692, Tri/Frame: -915841
Recorded/Played Tris ratio: -1.00
Play Time: 33.20s, Average FPS: 60.23
Min FPS: 28.52 at frame 141, Max FPS: 78.85 at frame 96
Average Tri/Sec: -55135964, Tri/Frame: -915370
Play Time: 32.61s, Average FPS: 61.34
Average Tri/Sec: -56077276, Tri/Frame: -914256
Completed All Tests
Кризис стоит на диске с Вистой 32Бит., и Виста этa какая-то тормозная, в 3ДМарк06 выдаёт 14000, в то время как на ХР - 15600
Q6600 - 3.4GHz
BFG 8800 Ultra 675/1674/1161
P5K Premium
Kngston 2*1Gb
DX10/175.16
GPU
max - 16.56/23.23/28.58
hi - 22.95/38.66/43.25
med - 39.28/66.11/83.83
lo - 96.38/127.37/175.12
CPU
max - 12.13/20.89/31.29
hi - 22.33/38.47/48.32
med - 43.54/65.05/79.24
lo - 69.41/152.38/175.90
Проц Е6550 ~ 3.2ГГц, 8800GS 768Mb 720/1900
31.05.2008 0:30:10 - Vista
Global Game Quality: VeryHigh ==============================================================
Play Time: 95.96s, Average FPS: 20.84
Min FPS: 13.47 at frame 143, Max FPS: 24.51 at frame 856
Average Tri/Sec: -18454548, Tri/Frame: -885484
Play Time: 92.43s, Average FPS: 21.64
Min FPS: 13.47 at frame 143, Max FPS: 24.74 at frame 858
Average Tri/Sec: -18953566, Tri/Frame: -875977
Recorded/Played Tris ratio: -1.05
Play Time: 92.36s, Average FPS: 21.65
Min FPS: 13.47 at frame 143, Max FPS: 24.79 at frame 875
Average Tri/Sec: -18953926, Tri/Frame: -875334
не качается этот тест. Дайте ссылку нормальную
Карлитос
Ты что курил? Поделись с друзьями-оверами! :D
ЗЫ. Все гоняют встроенные в саму игру бенчи..
Team MXS ModLabs.net В ЛС не пишите, глюк - у меня их нет.
DarthEx писал(а):
Карлитос
..... о блин.... :shock:
мне просто кризис не понравился, я его снес особо в него не углубляясь :D
Карлитос
Ну, бенчи там не совсем в самОй игре, а в папке /bin(32, 64)(если не ошибаюсь - давно это было :D), так что, можно и не заметить... Даже без кумара :)
