Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 10 из 20<  1 ... 7  8  9  10  11  12  13 ... 20  >
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 71.43 fps, 3901.21 kb/s
encoded 1442 frames, 71.05 fps, 3900.68 kb/s
encoded 1442 frames, 71.93 fps, 3900.68 kb/s
encoded 1442 frames, 72.05 fps, 3900.68 kb/s
encoded 1442 frames, 22.73 fps, 3970.56 kb/s
encoded 1442 frames, 21.98 fps, 3971.28 kb/s
encoded 1442 frames, 22.70 fps, 3970.56 kb/s
encoded 1442 frames, 22.56 fps, 3971.73 kb/s
System Details
Name AMD Phenom II X4 940
Codename Deneb
Specification AMD Phenom(tm) II X4 940 Processor
Core Stepping RB-C2
Technology 45 nm
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Core Speed 3600.3 MHz
Northbridge AMD 790X rev. 00
Southbridge ATI SB750 rev. 00
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Command Rate (CR) 2T
Memory Frequency 480.0 MHz (1:2)
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual, (Ganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 36°C (96°F) [0x24] (TMPIN0)
Temperature 1 55°C (130°F) [0x37] (TMPIN1)
Temperature 2 51°C (123°F) [0x33] (TMPIN2)
Temperature 0 56°C (131°F) [0x1BC] (Core #0)
Temperature 1 56°C (131°F) [0x1BC] (Core #1)
Temperature 3 56°C (131°F) [0x1BC] (Core #3)
Temperature 2 56°C (131°F) [0x1BC] (Core #2)
Код:
encoded 1442 frames, 89.47 fps, 3900.69 kb/s
encoded 1442 frames, 89.99 fps, 3901.17 kb/s
encoded 1442 frames, 89.53 fps, 3901.22 kb/s
encoded 1442 frames, 88.63 fps, 3900.04 kb/s
encoded 1442 frames, 27.49 fps, 3972.01 kb/s
encoded 1442 frames, 27.42 fps, 3971.49 kb/s
encoded 1442 frames, 27.31 fps, 3970.64 kb/s
System Details
   Name         Intel Core 2 Quad Q9550
   Codename      Yorkfield
   Specification      Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz
   Core Stepping      E0
   Technology      45 nm
   Stock frequency      2833 MHz
   Core Speed      4088.5 MHz
   FID range      6.0x - 8.5x
Northbridge         Intel P45/P43/G45/G43 rev. A2
Southbridge         Intel 82801JR (ICH10R) rev. 00
Memory Frequency      601.2 MHz (4:5)
Memory Type         DDR2
Channels         Dual, (Symmetric)
Number of threads      4
   L2 cache      2 x 6144 KBytes, 24-way set associative, 64-byte line size
   Instructions sets   MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
   Package (platform ID)   Socket 775 LGA (0x4)
   Temperature 0   37°C (98°F) [0x25] (SYSTIN)
   Temperature 1   55°C (130°F) [0x6D] (CPUTIN)
   Temperature 2   9°C (48°F) [0x12] (AUXTIN)
   Temperature 0   61°C (141°F) [0x27] (Core #0)
   Temperature 1   57°C (134°F) [0x2B] (Core #1)
   Temperature 2   54°C (129°F) [0x2E] (Core #2)
   Temperature 3   64°C (147°F) [0x24] (Core #3)
alexdvs писал(а):
Это разница между DDR3 1066 и 1600Mhz на Core i7 920, частота ядер стандартная.
1066
Results for x264.exe v0.58.747
encoded 1442 frames, 67.87 fps, 3904.94 kb/s
encoded 1442 frames, 67.83 fps, 3904.94 kb/s
encoded 1442 frames, 67.80 fps, 3904.94 kb/s
encoded 1442 frames, 66.50 fps, 3904.94 kb/s
encoded 1442 frames, 23.72 fps, 3974.08 kb/s
encoded 1442 frames, 23.70 fps, 3974.08 kb/s
encoded 1442 frames, 23.69 fps, 3974.08 kb/s
encoded 1442 frames, 23.52 fps, 3974.08 kb/s
1600
encoded 1442 frames, 71.25 fps, 3904.94 kb/s
encoded 1442 frames, 69.96 fps, 3904.94 kb/s
encoded 1442 frames, 69.34 fps, 3904.94 kb/s
encoded 1442 frames, 69.22 fps, 3904.94 kb/s
encoded 1442 frames, 24.11 fps, 3974.08 kb/s
encoded 1442 frames, 23.62 fps, 3974.08 kb/s
encoded 1442 frames, 23.79 fps, 3974.08 kb/s
Добавлено спустя 2 минуты 21 секунду:
Покупка дорогой быстрой памяти это лохотрон))
У меня тоже прирост небольшой (около 5% в среднем).
Разница между DDR3-1066-8-8-8 и DDR3-1600-5-5-5 на Phenom II X4 965, частота ядер стандартная:
1066-8-8-8-1T
encoded 1442 frames, 73.07 fps, 3900.68 kb/s
encoded 1442 frames, 74.48 fps, 3901.21 kb/s
encoded 1442 frames, 74.48 fps, 3900.68 kb/s
encoded 1442 frames, 74.37 fps, 3901.21 kb/s
encoded 1442 frames, 22.64 fps, 3971.54 kb/s
encoded 1442 frames, 22.70 fps, 3971.37 kb/s
encoded 1442 frames, 22.76 fps, 3971.77 kb/s
encoded 1442 frames, 22.81 fps, 3970.67 kb/s
1600-5-6-5-1T
encoded 1442 frames, 77.68 fps, 3901.21 kb/s
encoded 1442 frames, 77.48 fps, 3900.68 kb/s
encoded 1442 frames, 78.87 fps, 3900.68 kb/s
encoded 1442 frames, 23.17 fps, 3971.82 kb/s
encoded 1442 frames, 23.14 fps, 3971.89 kb/s
encoded 1442 frames, 23.13 fps, 3971.66 kb/s
encoded 1442 frames, 23.08 fps, 3972.01 kb/s
«К язычникам севера не ходите, ибо безгрешны они и не знают пороков и грехов дома Израилева» (Евангелие от Андрея гл.5 ст.1-3).
подскажите как на этом ресурсе делать"spoiler"
Windows 7 x64
i7 920 revision CO -> без разгона: CPU 2.67 GHz/RAM 1068 MHz(6Gb 1.50v)/Turbo off
encoded 1442 frames, 62.97 fps, 3899.02 kb/s
encoded 1442 frames, 63.14 fps, 3899.02 kb/s
encoded 1442 frames, 62.21 fps, 3898.50 kb/s
encoded 1442 frames, 63.10 fps, 3899.02 kb/s
encoded 1442 frames, 24.67 fps, 3968.74 kb/s
encoded 1442 frames, 24.66 fps, 3960.38 kb/s
encoded 1442 frames, 24.65 fps, 3970.59 kb/s
encoded 1442 frames, 24.68 fps, 3952.36 kb/s
System Details
Name Intel Core i7 920
product System Product Name
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Specification PC3-14900
Core Stepping C0/C1
Technology 45 nm
Stock frequency 2666 MHz
Core Speed 2670.0 MHz
Northbridge Intel X58 rev. 12
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 20
Command Rate (CR) 1T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 534.0 MHz (2:8)
Memory Type DDR3
Memory Size 6144 MBytes
Channels Triple
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 1 48°C (117°F) [0x5F] (CPUTIN)
Temperature 2 10°C (49°F) [0x13] (AUXTIN)
Temperature 0 55°C (130°F) [0x2D] (Core #0)
Temperature 1 53°C (127°F) [0x2F] (Core #1)
Temperature 2 51°C (123°F) [0x31] (Core #2)
Temperature 3 54°C (129°F) [0x2E] (Core #3)
Windows 7 x64
i7 920 revision CO -> разгон:RAM 1886 MHz(6Gb 1.65v)
(от быстрадействия памяти прирост не большой)
encoded 1442 frames, 65.33 fps, 3899.02 kb/s
encoded 1442 frames, 65.75 fps, 3899.02 kb/s
encoded 1442 frames, 65.37 fps, 3898.50 kb/s
encoded 1442 frames, 65.19 fps, 3899.02 kb/s
encoded 1442 frames, 25.10 fps, 3965.80 kb/s
encoded 1442 frames, 25.13 fps, 3967.97 kb/s
encoded 1442 frames, 25.23 fps, 3972.14 kb/s
encoded 1442 frames, 25.10 fps, 3964.91 kb/s
System Details
Codename Bloomfield
Core Stepping C0/C1
Technology 45 nm
Core Speed 2669.9 MHz
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 934.5 MHz (2:14)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 38°C (100°F) [0x26] (SYSTIN)
Temperature 1 51°C (123°F) [0x66] (CPUTIN)
Temperature 2 8°C (45°F) [0xF] (AUXTIN)
Temperature 0 60°C (139°F) [0x28] (Core #0)
Temperature 2 58°C (136°F) [0x2A] (Core #2)
Temperature 3 56°C (132°F) [0x2C] (Core #3)
Windows 7 x64
i7 920 revision CO -> разгон: CPU 3.612GHz/RAM 1724 MHZ(6Gb 1.65v)/VCore 1.21v) - проходит тест OCCT-LINPACK (температ.CPU < 85 C)- охлаждение воздушное
encoded 1442 frames, 86.79 fps, 3899.02 kb/s
encoded 1442 frames, 83.95 fps, 3898.30 kb/s
encoded 1442 frames, 85.51 fps, 3898.50 kb/s
encoded 1442 frames, 85.27 fps, 3899.02 kb/s
encoded 1442 frames, 33.82 fps, 3947.57 kb/s
encoded 1442 frames, 33.78 fps, 3961.21 kb/s
encoded 1442 frames, 33.83 fps, 3951.81 kb/s
encoded 1442 frames, 33.58 fps, 3961.74 kb/s
System Details
Codename Bloomfield
Core Stepping C0/C1
Technology 45 nm
Core Speed 3622.4 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 862.5 MHz (2:10)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 39°C (102°F) [0x27] (SYSTIN)
Temperature 1 57°C (133°F) [0x71] (CPUTIN)
Temperature 2 6°C (42°F) [0xC] (AUXTIN)
Temperature 0 64°C (147°F) [0x24] (Core #0)
Temperature 1 62°C (143°F) [0x26] (Core #1)
Temperature 2 64°C (147°F) [0x24] (Core #2)
Temperature 3 60°C (139°F) [0x28] (Core #3)
Windows 7 x64
i7 920 revision CO -> разгон:CPU 3.990 GHz/RAM 1523 MHz(6Gb 1.65v)/VCore 1.42v)
encoded 1442 frames, 89.83 fps, 3899.02 kb/s
encoded 1442 frames, 91.16 fps, 3899.02 kb/s
encoded 1442 frames, 92.25 fps, 3898.50 kb/s
encoded 1442 frames, 93.18 fps, 3899.02 kb/s
encoded 1442 frames, 36.64 fps, 3962.16 kb/s
encoded 1442 frames, 36.54 fps, 3971.32 kb/s
encoded 1442 frames, 36.83 fps, 3968.02 kb/s
encoded 1442 frames, 36.56 fps, 3959.61 kb/s
System Details
Codename Bloomfield
Core Stepping C0/C1
Technology 45 nm
Core Speed 4000.4 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 762.0 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 1 67°C (152°F) [0x86] (CPUTIN)
Temperature 2 7°C (43°F) [0xD] (AUXTIN)
Temperature 0 77°C (170°F) [0x17] (Core #0)
Temperature 1 80°C (175°F) [0x14] (Core #1)
Temperature 2 74°C (165°F) [0x1A] (Core #2)
Temperature 3 78°C (172°F) [0x16] (Core #3)
Windows 7 x64
i7 920 revision CO -> разгон: CPU 4.200 GHz/RAM 1600MHz(6Gb 1.65v)/VCore 1.52v/
- машинка явно не в гармонии - требует тщательной настройки разгона
encoded 1442 frames, 94.03 fps, 3899.02 kb/s
encoded 1442 frames, 95.49 fps, 3898.50 kb/s
encoded 1442 frames, 92.06 fps, 3899.02 kb/s
encoded 1442 frames, 90.89 fps, 3898.50 kb/s
encoded 1442 frames, 30.34 fps, 3961.56 kb/s
encoded 1442 frames, 28.29 fps, 3965.77 kb/s
encoded 1442 frames, 28.30 fps, 3966.74 kb/s
encoded 1442 frames, 27.69 fps, 3970.78 kb/s
System Details
Codename Bloomfield
Core Stepping C0/C1
Technology 45 nm
Core Speed 4209.3 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 801.8 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 1 80°C (175°F) [0x9F] (CPUTIN)
Temperature 2 5°C (40°F) [0xA] (AUXTIN)
Temperature 0 95°C (202°F) [0x5] (Core #0)
Temperature 1 91°C (195°F) [0x9] (Core #1)
Temperature 2 77°C (170°F) [0x17] (Core #2)
Temperature 3 86°C (186°F) [0xE] (Core #3)
Последний раз редактировалось @xel@ 22.01.2010 14:16, всего редактировалось 3 раз(а).
i7 920@4200, win7x64
encoded 1442 frames, 101.58 fps, 3899.02 kb/s
encoded 1442 frames, 102.93 fps, 3899.02 kb/s
encoded 1442 frames, 99.72 fps, 3899.02 kb/s
encoded 1442 frames, 101.92 fps, 3899.02 kb/s
encoded 1442 frames, 39.60 fps, 3966.00 kb/s
encoded 1442 frames, 39.72 fps, 3961.05 kb/s
encoded 1442 frames, 39.66 fps, 3947.94 kb/s
encoded 1442 frames, 39.71 fps, 3970.63 kb/s
System Details
Codename Bloomfield
Specification PC3-10700
Specification PC3-17100
Core Stepping D0
Technology 45 nm
Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000)
Core Speed 4200.0 MHz
CAS# latency (CL) 7.0
RAS# Precharge (tRP) 7
Memory Frequency 1000.0 MHz (2:10)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 47°C (116°F) [0x2F] (SYSTIN)
Temperature 1 56°C (131°F) [0x6F] (CPUTIN)
Temperature 2 125°C (256°F) [0xF9] (AUXTIN)
Temperature 0 54°C (129°F) [0x2E] (Core #0)
Temperature 1 60°C (139°F) [0x28] (Core #1)
Temperature 2 56°C (132°F) [0x2C] (Core #2)
Temperature 3 52°C (125°F) [0x30] (Core #3)
Код:
encoded 1442 frames, 40.16 fps, 3899.26 kb/s
encoded 1442 frames, 40.32 fps, 3899.26 kb/s
encoded 1442 frames, 40.41 fps, 3899.26 kb/s
encoded 1442 frames, 40.39 fps, 3899.26 kb/s
encoded 1442 frames, 10.00 fps, 3971.41 kb/s
encoded 1442 frames, 10.08 fps, 3970.90 kb/s
encoded 1442 frames, 10.07 fps, 3971.56 kb/s
encoded 1442 frames, 10.13 fps, 3970.92 kb/s
System Details
   Name         Intel Core 2 Duo E8400
   Codename      Wolfdale
   Specification      Intel(R) Core(TM)2 CPU         E8400  @ 3.00GHz
   Core Stepping      E0
   Technology      45 nm
   Stock frequency      3000 MHz
   Core Speed      2982.9 MHz
Northbridge         Intel G35 rev. 03
Southbridge         Intel 82801HB/HR (ICH8/R) rev. B0
Memory Type         DDR2
Memory Size         2048 MBytes
Windows Version         Microsoft Windows XP Professional  Service Pack 2 (Build 2600)
Number of threads      2
   Number of threads   2 (max 2)
   L2 cache      6144 KBytes, 24-way set associative, 64-byte line size
   Instructions sets   MMX, SSE, SSE2, SSE3, SSSE3, EM64T
   Package (platform ID)   Socket 775 LGA (0x0)
   Temperature 0   90°C (193°F) [0x5A] (SYSTIN)
   Temperature 1   121°C (249°F) [0xF2] (CPUTIN)
   Temperature 2   73°C (162°F) [0x91] (AUXTIN)
   Temperature 0   44°C (111°F) [0x38] (Core #0)
   Temperature 1   43°C (109°F) [0x39] (Core #1)
encoded 1442 frames, 56.07 fps, 3899.26 kb/s
encoded 1442 frames, 56.14 fps, 3899.26 kb/s
encoded 1442 frames, 56.03 fps, 3899.26 kb/s
encoded 1442 frames, 55.97 fps, 3899.26 kb/s
encoded 1442 frames, 13.98 fps, 3970.77 kb/s
encoded 1442 frames, 13.94 fps, 3970.56 kb/s
encoded 1442 frames, 13.93 fps, 3971.96 kb/s
encoded 1442 frames, 14.02 fps, 3971.59 kb/s
System Details
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Core Stepping E0
Technology 45 nm
Core Speed 4050.0 MHz
FID range 6.0x - 9.0x
Northbridge Intel P45/P43 rev. A3
CAS# latency (CL) 4.0
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 12
Memory Frequency 450.0 MHz (1:1)
Memory Type DDR2
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
Number of threads 2
Temperature 0 32°C (89°F) [0x20] (System)
Temperature 1 40°C (103°F) [0x4F] (CPU)
Temperature 2 22°C (71°F) [0x2C] (AUX)
Temperature 0 51°C (123°F) [0x31] (Core #0)
Temperature 1 47°C (116°F) [0x35] (Core #1)
encoded 1442 frames, 37.78 fps, 3899.26 kb/s
encoded 1442 frames, 37.71 fps, 3899.26 kb/s
encoded 1442 frames, 37.04 fps, 3899.26 kb/s
encoded 1442 frames, 37.18 fps, 3899.26 kb/s
encoded 1442 frames, 9.35 fps, 3971.52 kb/s
encoded 1442 frames, 9.34 fps, 3970.96 kb/s
encoded 1442 frames, 9.32 fps, 3970.54 kb/s
encoded 1442 frames, 9.31 fps, 3972.04 kb/s
System Details
Name Intel Pentium E2180
Codename Conroe
Specification Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
Core Stepping M0
Technology 65 nm
Stock frequency 2000 MHz
Core Speed 3195.0 MHz
FID range 6.0x - 10.0x
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 15
Memory Frequency 426.0 MHz (5:6)
Memory Type DDR2
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7600)
Number of threads 2
L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
Temperature 0 37°C (98°F) [0x25] (System)
Temperature 1 52°C (125°F) [0x34] (CPU)
Temperature 0 60°C (139°F) [0x19] (Core #0)
Temperature 1 58°C (136°F) [0x1B] (Core #1)
encoded 1442 frames, 106.04 fps, 3901.21 kb/s
encoded 1442 frames, 106.58 fps, 3900.68 kb/s
encoded 1442 frames, 105.11 fps, 3900.68 kb/s
encoded 1442 frames, 106.34 fps, 3901.21 kb/s
encoded 1442 frames, 31.70 fps, 3971.69 kb/s
encoded 1442 frames, 31.81 fps, 3971.43 kb/s
encoded 1442 frames, 31.73 fps, 3970.66 kb/s
encoded 1442 frames, 31.85 fps, 3970.53 kb/s
System Details
Codename Bloomfield
Specification PC3-16000
Specification PC3-8500
Core Stepping D0
Technology 45 nm
Core Speed 4216.9 MHz
RAS# to CAS# delay (tRCD) 7
Memory Frequency 803.2 MHz (2:8)
Memory Type DDR3
Memory Size 9216 MBytes
Channels Triple
Number of threads 4
Number of threads 4 (max 16)
Temperature 1 53°C (126°F) [0x69] (CPUTIN)
Temperature 2 32°C (89°F) [0x40] (AUXTIN)
Temperature 1 59°C (138°F) [0x29] (Core #1)
Temperature 2 53°C (127°F) [0x2F] (Core #2)
Temperature 3 57°C (134°F) [0x2B] (Core #3)
Фото: 10
И какой усредненный результат? Чтоб сравнить его с этими http://www.overclockers.ru/softnews/360 ... video.html
encoded 1442 frames, 97.82 fps, 3900.68 kb/s
encoded 1442 frames, 97.72 fps, 3900.68 kb/s
encoded 1442 frames, 97.70 fps, 3901.21 kb/s
encoded 1442 frames, 96.92 fps, 3900.43 kb/s
encoded 1442 frames, 30.21 fps, 3971.55 kb/s
encoded 1442 frames, 30.27 fps, 3971.26 kb/s
encoded 1442 frames, 30.17 fps, 3971.51 kb/s
encoded 1442 frames, 30.21 fps, 3970.67 kb/s
System Details
Name Intel Core i5 750
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Specification PC3-12800
Core Stepping B1
Technology 45 nm
Core Speed 3999.8 MHz
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 05
Memory Frequency 800.0 MHz (2:8)
Memory Type DDR3
Channels Dual
Windows Version Microsoft Windows 7 (6.1) (Build 7600)
Number of threads 4
Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 40°C (103°F) [0x28] (TMPIN0)
Temperature 1 25°C (76°F) [0x19] (TMPIN1)
Temperature 2 59°C (138°F) [0x3B] (TMPIN2)
Temperature 0 67°C (152°F) [0x20] (Core #0)
Temperature 1 64°C (147°F) [0x23] (Core #1)
Temperature 2 66°C (150°F) [0x21] (Core #2)
Temperature 3 65°C (148°F) [0x22] (Core #3)
encoded 1442 frames, 69.68 fps, 3900.68 kb/s
encoded 1442 frames, 70.22 fps, 3900.68 kb/s
encoded 1442 frames, 70.30 fps, 3900.68 kb/s
encoded 1442 frames, 68.85 fps, 3900.68 kb/s
encoded 1442 frames, 20.03 fps, 3971.10 kb/s
encoded 1442 frames, 20.07 fps, 3971.78 kb/s
encoded 1442 frames, 19.91 fps, 3971.81 kb/s
encoded 1442 frames, 20.10 fps, 3970.69 kb/s
System Details
Name Intel Core i3 530
Codename Clarkdale
Specification Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz
Core Stepping
Technology 32 nm
Manufacturer (ID) Apacer Technology (7F7A000000000000)
Stock frequency 2933 MHz
Core Speed 4501.4 MHz
Northbridge Intel Havendale/Clarkdale Host Bridge rev. 12
Memory Frequency 613.8 MHz (4:12)
Memory Type DDR3
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 2 (Build 7600)
Number of threads 4
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
Temperature 0 56°C (132°F) [0x38] (SYSTIN)
Temperature 2 41°C (105°F) [0x52] (AUXTIN)
Temperature 0 56°C (132°F) [0x31] (Core #0)
Temperature 2 47°C (116°F) [0x3A] (Core #2)
encoded 1442 frames, 29.38 fps, 3899.26 kb/s
encoded 1442 frames, 29.76 fps, 3899.26 kb/s
encoded 1442 frames, 29.48 fps, 3899.26 kb/s
encoded 1442 frames, 28.96 fps, 3899.26 kb/s
encoded 1442 frames, 6.96 fps, 3971.66 kb/s
encoded 1442 frames, 6.99 fps, 3971.53 kb/s
encoded 1442 frames, 7.00 fps, 3970.81 kb/s
encoded 1442 frames, 6.98 fps, 3971.91 kb/s
System Details
Name AMD Athlon 64 X2 5400+
Codename Brisbane
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5400+
Core Stepping BH-G2
Technology 65 nm
Stock frequency 2800 MHz
Core Speed 2830.5 MHz
Northbridge NVIDIA nForce 570 SLI rev. A2
Southbridge NVIDIA nForce 570 SLI rev. A3
Memory Frequency 404.4 MHz (CPU/7)
Memory Type DDR2
Channels Dual
Number of threads 2
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Package Socket AM2 (940)
Temperature 0 36°C (96°F) [0x24] (SYSTIN)
Temperature 1 63°C (145°F) [0x7E] (CPUTIN)
Temperature 2 62°C (142°F) [0x7B] (AUXTIN)
Temperature 0 63°C (144°F) [0x16A] (Core #0)
Temperature 1 66°C (151°F) [0x179] (Core #1)
Фото: 4
encoded 1442 frames, 40.63 fps, 3899.26 kb/s
encoded 1442 frames, 40.21 fps, 3899.26 kb/s
encoded 1442 frames, 40.83 fps, 3899.26 kb/s
encoded 1442 frames, 40.19 fps, 3899.26 kb/s
encoded 1442 frames, 9.78 fps, 3971.57 kb/s
encoded 1442 frames, 9.77 fps, 3971.34 kb/s
encoded 1442 frames, 9.77 fps, 3971.41 kb/s
encoded 1442 frames, 9.47 fps, 3971.07 kb/s
System Details
Name Intel Pentium G6950
Codename Clarkdale
Specification Intel(R) Pentium(R) CPU G6950 @ 2.80GHz
Core Stepping
Technology 32 nm
Core Speed 2798.1 MHz
Memory Frequency 533.0 MHz (4:16)
Memory Type DDR3
Number of threads 2
Number of threads 2 (max 16)
Temperature 0 30°C (85°F) [0x1E] (TMPIN0)
Temperature 2 54°C (129°F) [0x36] (TMPIN2)
Temperature 0 62°C (143°F) [0x2B] (Core #0)
Temperature 2 64°C (147°F) [0x29] (Core #2)
encoded 1442 frames, 61.36 fps, 3900.68 kb/s
encoded 1442 frames, 60.71 fps, 3900.68 kb/s
encoded 1442 frames, 61.83 fps, 3900.68 kb/s
encoded 1442 frames, 61.41 fps, 3900.68 kb/s
encoded 1442 frames, 18.46 fps, 3971.62 kb/s
encoded 1442 frames, 18.48 fps, 3970.45 kb/s
encoded 1442 frames, 18.28 fps, 3970.52 kb/s
encoded 1442 frames, 18.29 fps, 3971.72 kb/s
System Details
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Core Stepping G0
Technology 65 nm
Stock frequency 2400 MHz
Core Speed 3052.2 MHz
Northbridge Intel P35/G33/G31 rev. 10
Southbridge Intel 82801GB (ICH7/R) rev. A1
Memory Frequency 423.9 MHz (4:5)
Memory Type DDR2
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 3 (Build 7600)
Number of threads 4
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Temperature 2 46°C (114°F) [0x2E] (TMPIN2)
Temperature 0 66°C (150°F) [0x22] (Core #0)
Temperature 1 63°C (145°F) [0x25] (Core #1)
Temperature 2 61°C (141°F) [0x27] (Core #2)
Temperature 3 62°C (143°F) [0x26] (Core #3)
Поставил последнюю на сегодняшний день ревизию x264 (core 84 r1416kGIT fcf70c2) и получил другой результат...Был очень удивлён, насколько оптимизировали х264, пред идущая версия в бенчмарке была r1342
encoded 1442 frames, 73.47 fps, 3901.94 kb/s
encoded 1442 frames, 77.76 fps, 3901.94 kb/s
encoded 1442 frames, 77.83 fps, 3901.94 kb/s
encoded 1442 frames, 76.39 fps, 3901.94 kb/s
encoded 1442 frames, 21.01 fps, 3982.12 kb/s
encoded 1442 frames, 21.03 fps, 3981.55 kb/s
encoded 1442 frames, 20.85 fps, 3981.55 kb/s
encoded 1442 frames, 20.81 fps, 3980.50 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3052.3 MHz
Memory Type DDR2
Number of threads 4
Temperature 2 45°C (112°F) [0x2D] (TMPIN2)
Temperature 0 65°C (148°F) [0x23] (Core #0)
Core i7 3930K@4,7GHz/16Gb DDR3 Samsung BH0-CK0@2400GHz(Quad Ch)/Asus Rampage IV Formula/Thermalright Silver Arrow+3*TR TY-150/12Tb/Asus Radeon R9 290
encoded 1442 frames, 106.62 fps, 3901.21 kb/s
encoded 1442 frames, 107.11 fps, 3900.68 kb/s
encoded 1442 frames, 106.86 fps, 3901.21 kb/s
encoded 1442 frames, 106.62 fps, 3900.68 kb/s
encoded 1442 frames, 32.26 fps, 3971.02 kb/s
encoded 1442 frames, 32.21 fps, 3971.54 kb/s
encoded 1442 frames, 32.17 fps, 3970.65 kb/s
encoded 1442 frames, 32.18 fps, 3973.33 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 4209.5 MHz
Northbridge Intel X58 rev. 13
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Type DDR3
Channels Triple
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600)
Number of threads 4
Temperature 0 34°C (93°F) [0x22] (SYSTIN)
Temperature 1 48°C (118°F) [0x60] (CPUTIN)
Temperature 2 36°C (95°F) [0x47] (AUXTIN)
Temperature 2 60°C (139°F) [0x28] (Core #2)
Temperature 3 61°C (141°F) [0x27] (Core #3)
Код:
encoded 1442 frames, 64.73 fps, 3900.68 kb/s
encoded 1442 frames, 65.10 fps, 3900.68 kb/s
encoded 1442 frames, 65.33 fps, 3901.21 kb/s
encoded 1442 frames, 63.92 fps, 3900.68 kb/s
encoded 1442 frames, 20.32 fps, 3971.65 kb/s
encoded 1442 frames, 20.48 fps, 3971.73 kb/s
encoded 1442 frames, 20.17 fps, 3971.40 kb/s
encoded 1442 frames, 20.34 fps, 3971.61 kb/s
System Details
   Codename      Yorkfield
   Specification      Intel(R) Core(TM)2 Quad CPU    Q8400  @ 2.66GHz
   Core Stepping      R0
   Technology      45 nm
   Core Speed      3200.3 MHz
   FID range      6.0x - 8.0x
Memory Frequency      400.0 MHz (1:1)
Memory Type         DDR2
Windows Version         Microsoft Windows 7 (6.1) Enterprise Edition  (Build 7600)
Number of threads      4
   L2 cache      2 x 2048 KBytes, 8-way set associative, 64-byte line size
   Temperature 0   37°C (98°F) [0x25] (TMPIN0)
   Temperature 1   49°C (120°F) [0x31] (TMPIN1)
   Temperature 3   55°C (130°F) [0x2D] (Core #3)
   Temperature 2   55°C (130°F) [0x2D] (Core #2)
   Temperature 1   52°C (125°F) [0x30] (Core #1)
encoded 1442 frames, 40.02 fps, 3899.22 kb/s
encoded 1442 frames, 41.26 fps, 3899.84 kb/s
encoded 1442 frames, 41.55 fps, 3899.38 kb/s
encoded 1442 frames, 41.35 fps, 3899.35 kb/s
encoded 1442 frames, 10.08 fps, 3971.05 kb/s
encoded 1442 frames, 10.06 fps, 3970.52 kb/s
encoded 1442 frames, 10.09 fps, 3971.55 kb/s
encoded 1442 frames, 10.06 fps, 3971.52 kb/s
System Details
Name Intel Pentium E2160
Codename Conroe
Specification Genuine Intel(R) CPU 2160 @ 1.80GHz
Core Stepping L2
Technology 65 nm
Stock frequency 1800 MHz
Core Speed 3330.0 MHz
Cycle Time (tRAS) 17
Memory Frequency 370.0 MHz (1:1)
Memory Type DDR2
Number of threads 2
Temperature 0 42°C (107°F) [0x2A] (System)
Temperature 1 62°C (143°F) [0x3E] (CPU)
Temperature 0 82°C (179°F) [0x12] (Core #0)
Temperature 1 79°C (174°F) [0x15] (Core #1)
Статус: В сети
Фото: 5
encoded 1442 frames, 49.25 fps, 3899.26 kb/s
encoded 1442 frames, 50.43 fps, 3899.26 kb/s
encoded 1442 frames, 50.62 fps, 3899.26 kb/s
encoded 1442 frames, 50.40 fps, 3899.26 kb/s
encoded 1442 frames, 13.30 fps, 3971.65 kb/s
encoded 1442 frames, 13.32 fps, 3971.20 kb/s
encoded 1442 frames, 13.34 fps, 3971.55 kb/s
encoded 1442 frames, 13.30 fps, 3970.90 kb/s
System Details
Name Intel Pentium
Codename Wolfdale
Specification Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
Core Stepping R0
Technology 45 nm
Stock frequency 2600 MHz
Core Speed 4162.5 MHz
FID range 6.0x - 13.0x
Memory Frequency 499.5 MHz (2:3)
Memory Type DDR2
Memory Size 3072 MBytes
Number of threads 2
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
Temperature 0 38°C (100°F) [0x26] (System)
Temperature 1 58°C (136°F) [0x3A] (CPU)
Temperature 0 63°C (145°F) [0x25] (Core #0)
Temperature 1 55°C (130°F) [0x2D] (Core #1)
Решил проверить что дает включение HT при кодировании видео на core i7 920 - выводы неутешительные...
В сотый раз убедился в бесполезности этой технологии...
Без HT:
encoded 1442 frames, 103.33 fps, 3900.68 kb/s
encoded 1442 frames, 103.28 fps, 3900.68 kb/s
encoded 1442 frames, 102.93 fps, 3901.21 kb/s
encoded 1442 frames, 103.65 fps, 3900.68 kb/s
encoded 1442 frames, 31.60 fps, 3971.33 kb/s
encoded 1442 frames, 31.78 fps, 3970.76 kb/s
encoded 1442 frames, 31.89 fps, 3971.86 kb/s
encoded 1442 frames, 31.67 fps, 3971.49 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 4199.8 MHz
Memory Type DDR3
Channels Triple
Number of threads 4
Temperature 0 43°C (109°F) [0x2B] (TMPIN0)
Temperature 1 46°C (114°F) [0x2E] (TMPIN1)
Temperature 2 52°C (125°F) [0x34] (TMPIN2)
Temperature 0 59°C (138°F) [0x29] (Core #0)
Temperature 2 59°C (138°F) [0x29] (Core #2)
Temperature 3 59°C (138°F) [0x29] (Core #3)
С включенным HT:
encoded 1442 frames, 91.43 fps, 3899.02 kb/s
encoded 1442 frames, 93.05 fps, 3899.02 kb/s
encoded 1442 frames, 92.92 fps, 3899.02 kb/s
encoded 1442 frames, 92.62 fps, 3899.02 kb/s
encoded 1442 frames, 37.71 fps, 3962.82 kb/s
encoded 1442 frames, 38.29 fps, 3957.13 kb/s
encoded 1442 frames, 38.30 fps, 3971.25 kb/s
encoded 1442 frames, 38.31 fps, 3955.70 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 42°C (107°F) [0x2A] (TMPIN0)
Temperature 1 54°C (129°F) [0x36] (TMPIN1)
Temperature 0 72°C (161°F) [0x1C] (Core #0)
Temperature 1 72°C (161°F) [0x1C] (Core #1)
Temperature 3 65°C (148°F) [0x23] (Core #3)
http://people.overclockers.ru/alex1974/record27
encoded 1442 frames, 51.01 fps, 3900.68 kb/s
encoded 1442 frames, 50.73 fps, 3900.68 kb/s
encoded 1442 frames, 51.24 fps, 3900.68 kb/s
encoded 1442 frames, 50.46 fps, 3900.68 kb/s
encoded 1442 frames, 14.38 fps, 3966.81 kb/s
encoded 1442 frames, 14.40 fps, 3971.70 kb/s
encoded 1442 frames, 14.39 fps, 3970.77 kb/s
encoded 1442 frames, 14.38 fps, 3971.81 kb/s
System Details
Codename Clarkdale
Core Stepping
Technology 32 nm
Core Speed 3102.1 MHz
Southbridge Intel H55 rev. 06
Memory Frequency 705.0 MHz (4:20)
Memory Type DDR3
Channels Single
Number of threads 4
Temperature 0 31°C (87°F) [0x1F] (SYSTIN)
Temperature 1 42°C (106°F) [0x53] (CPUTIN)
Temperature 2 122°C (251°F) [0xF4] (AUXTIN)
Temperature 0 49°C (120°F) [0x38] (Core #0)
Temperature 2 45°C (112°F) [0x3C] (Core #2)
Мы - есть пищевая цепочка самих себя...
