Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 93 • Страница 2 из 5<  1  2  3  4  5  >
Фото: 130
FX-8350 @ 5100 - 16.68fps
7156
i5 750 - летим на старике хоттабыче :dance:
Фото: 77
X5670 @ 4400 Mhz ~17.46 (кто там говорил что тут авх юзаеться?) :D
http://valid.canardpc.com/v0pw6y http://valid.canardpc.com/kq21c1 http://valid.x86.fr/3jg01g
Belarus OC Team
i7 4770K - 4.1GHz. 16.54fps
Фильтрами ЛС было удалено личных сообщений: ...
i5 4670K @ 4000
Dual 2200
12.43
Фото: 128
i7 4790K 4.6Ghz - 18.85
7700X • 32Gb • RTX 5090 • UHD Oled
Intel(R) Core(TM) i3-4030U CPU @ 1.90GHz
x265 HD BENCHMARK 0.1.4 RESULTS
Please do NOT compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your
data to http://x265.ru/x265-hd-benchmark/.html
Results for x265.exe build 1.4+5
x265 Benchmark: 64-bit
CRF-20 preset-"fast"
encoded 1128 frames in 279.49s (4.04 fps), 2266.68 kb/s
encoded 1128 frames in 280.19s (4.03 fps), 2266.68 kb/s
encoded 1128 frames in 280.33s (4.02 fps), 2266.68 kb/s
System Details
Name Intel Core i3/i5/i7 4xxx
Codename Haswell ULT
Specification Intel(R) Core(TM) i3-4030U CPU @ 1.90GHz
Core Stepping C0
Technology 22 nm
Stock frequency 1900 MHz
Core Speed 1895.7 MHz
Northbridge Intel Haswell-ULT rev. 0B
Southbridge Intel ID9C43 rev. 04
CAS# latency (CL) 11.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 28
Command Rate (CR) 1T
Memory Frequency 798.2 MHz (1:6)
Memory Type DDR3
Memory Size 8084 MBytes
Channels Dual
Windows Version Microsoft Windows 8.1 (6.3) 64-bit (Build 9600)
Number of processors 1
Number of threads 4
Number of threads 4 (max 16)
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
Package (platform ID) Socket 1168 BGA (0x6)
Intel(R) Pentium(R) CPU G3420 @ 3.20GHz
x265 Benchmark: 32-bit
encoded 1128 frames in 222.41s (5.07 fps), 2266.23 kb/s
encoded 1128 frames in 221.18s (5.10 fps), 2266.23 kb/s
encoded 1128 frames in 220.76s (5.11 fps), 2266.23 kb/s
encoded 1128 frames in 222.19s (5.08 fps), 2266.23 kb/s
System Details
Name Intel Pentium G3420
Codename Haswell
Specification Intel(R) Pentium(R) CPU G3420 @ 3.20GHz
Core Stepping C0
Technology 22 nm
Stock frequency 3200 MHz
Core Speed 798.2 MHz
Northbridge Intel Haswell rev. 06
Southbridge Intel ID8C50 rev. 04
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 27
Memory Type DDR3
Memory Size 2972 MBytes
Channels Dual
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 32-bit Service Pack 1 (Build 7601)
Number of threads 2
Number of threads 2 (max 16)
Package (platform ID) Socket 1150 LGA (0x1)
Temperature 0 36°C (96°F) [0x24] (TMPIN0)
Temperature 1 25°C (76°F) [0x19] (TMPIN1)
Temperature 2 32°C (89°F) [0x20] (TMPIN2)
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Фото: 77
X5670 @ 4560 Mhz
18.42
Belarus OC Team
Фото: 40
3570k 4500 13.17fps
encoded 1128 frames in 86.69s (13.01 fps), 2266.68 kb/s
encoded 1128 frames in 85.82s (13.14 fps), 2266.68 kb/s
encoded 1128 frames in 85.81s (13.14 fps), 2266.68 kb/s
encoded 1128 frames in 85.67s (13.17 fps), 2266.68 kb/s
System Details
Name Intel Core i5 3570K
Codename Ivy Bridge
Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Core Stepping E1/L1
Technology 22 nm
Stock frequency 3400 MHz
Core Speed 4504.4 MHz
Northbridge Intel Ivy Bridge rev. 09
Southbridge Intel Z77 rev. 04
Memory Frequency 1201.2 MHz (1:9)
Memory Type DDR3
Memory Size 8152 MBytes
Channels Dual
Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601)
Number of threads 4
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Package (platform ID) Socket 1155 LGA (0x1)
Temperature 0 25°C (76°F) [0x19] (TMPIN0)
Temperature 2 31°C (87°F) [0x1F] (TMPIN2)
Overclocked Tester
Intel Core i7 5820K @4075MHz – 22.70 FPS
MSI MPG Z790 Edge WiFi | Intel Core i9-13900K
ASUS ROG Strix X870E-E Gaming WiFi | AMD Ryzen 9 9950X
https://t.me/bench_and_play
Overclocked Tester
Intel Core i7 5960X 3000-3500MHz 2666MHz mem – 25.09 FPS
Overclocked Tester
Intel Core i7 5960X 4200MHz 2800MHz mem – 30.08 FPS
Фото: 58
Jordan
не взорвутся 8 ядер на такой частоте
Запахло рывком.....
Overclocked Tester
Ecowar
На зарубежных форумах пишут, что для 5960X хороший разгон на воздухе это 4,5-4,6 ГГц при 1,3-1,35В или выше.
Но мне неудачный процессор попался, к сожалению.
i7 3770 @ 4.1ghz 13.71 fps
encoded 1128 frames in 82.22s (13.72 fps), 2266.68 kb/s
encoded 1128 frames in 82.27s (13.71 fps), 2266.68 kb/s
encoded 1128 frames in 82.25s (13.71 fps), 2266.68 kb/s
encoded 1128 frames in 82.10s (13.74 fps), 2266.68 kb/s
System Details
Name Intel Core i7 3770
Codename Ivy Bridge
Specification Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Core Stepping E1/L1
Technology 22 nm
Core Speed 1601.1 MHz
CAS# latency (CL) 10.0
Memory Frequency 1067.4 MHz (1:8)
Memory Type DDR3
Memory Size 8148 MBytes
Channels Dual
Фото: 5
Q9550 @ 4.0GHz 7.72 fps
encoded 1128 frames in 145.71s (7.74 fps), 2266.68 kb/s
encoded 1128 frames in 146.07s (7.72 fps), 2266.68 kb/s
encoded 1128 frames in 146.19s (7.72 fps), 2266.68 kb/s
encoded 1128 frames in 146.15s (7.72 fps), 2266.68 kb/s
System Details
Name Intel Core 2 Quad Q9550
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Core Stepping E0
Technology 45 nm
Stock frequency 2833 MHz
Core Speed 3991.5 MHz
FID range 6.0x - 8.5x
Northbridge Intel P45/P43/G45/G43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Command Rate (CR) 2T
Memory Frequency 469.6 MHz (1:1)
Memory Type DDR2
Memory Size 8 GBytes
Channels Dual, (Symmetric)
Windows Version Microsoft Windows NT10.0 (Build 10074)
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 34°C (93°F) [0x22] (SYSTIN)
Temperature 1 18°C (64°F) [0x24] (CPUTIN)
Temperature 2 30°C (85°F) [0x3B] (AUXTIN)
4690k 3500mhz
encoded 1128 frames in 88.27s (12.78 fps), 2266.68 kb/s
encoded 1128 frames in 88.30s (12.77 fps), 2266.68 kb/s
encoded 1128 frames in 88.38s (12.76 fps), 2266.68 kb/s
encoded 1128 frames in 88.50s (12.75 fps), 2266.68 kb/s
System Details
Name Intel Core i5 4690K
Codename Haswell
Specification Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
Core Stepping C0
Technology 22 nm
Stock frequency 3500 MHz
Core Speed 3491.9 MHz
Southbridge Intel Z97 rev. 00
Memory Frequency 1064.2 MHz (1:8)
Memory Type DDR3
Memory Size 16342 MBytes
Channels Dual
Number of threads 4
Temperature 0 33°C (91°F) [0x21] (SYSTIN)
Temperature 1 41°C (105°F) [0x52] (CPUTIN)
Temperature 2 35°C (94°F) [0x46] (AUXTIN)
Temperature 3 35°C (94°F) [0x23] (TMPIN3)
Добавлено спустя 58 минут 38 секунд:
4690k 4000mhz
encoded 1128 frames in 77.85s (14.49 fps), 2266.68 kb/s
encoded 1128 frames in 78.49s (14.37 fps), 2266.68 kb/s
encoded 1128 frames in 77.77s (14.50 fps), 2266.68 kb/s
encoded 1128 frames in 77.81s (14.50 fps), 2266.68 kb/s
System Details
Codename Haswell
Core Stepping C0
Technology 22 nm
Core Speed 3999.9 MHz
Memory Frequency 1066.7 MHz (1:8)
Memory Type DDR3
Channels Dual
Number of threads 4
Temperature 3 36°C (96°F) [0x24] (TMPIN3)
Добавлено спустя 12 минут 27 секунд:
4690k 4400mhz
encoded 1128 frames in 70.72s (15.95 fps), 2266.68 kb/s
encoded 1128 frames in 70.68s (15.96 fps), 2266.68 kb/s
encoded 1128 frames in 70.69s (15.96 fps), 2266.68 kb/s
encoded 1128 frames in 71.11s (15.86 fps), 2266.68 kb/s
System Details
Codename Haswell
Core Stepping C0
Technology 22 nm
Core Speed 4399.9 MHz
Memory Type DDR3
Channels Dual
Number of threads 4
Temperature 3 40°C (103°F) [0x28] (TMPIN3)
THX/SBX TruStudio surround sound effects are better than Creative’s CMSS3D.
Recon3D hardware accelerated THX/SBX TruStudio/CrystalVoice effects.
Intel Xeon E5440 - encoded 1128 frames in 205.47s (5.49 fps)
encoded 1128 frames in 206.57s (5.46 fps), 2266.68 kb/s
encoded 1128 frames in 206.54s (5.46 fps), 2266.68 kb/s
encoded 1128 frames in 205.47s (5.49 fps), 2266.68 kb/s
encoded 1128 frames in 206.92s (5.45 fps), 2266.68 kb/s
System Details
Name Intel Xeon E5440
Codename Harpertown
Specification Intel(R) Xeon(R) CPU E5440 @ 2.83GHz
Core Stepping C0
Technology 45 nm
Core Speed 2000.0 MHz
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 18
Memory Frequency 400.0 MHz (5:6)
Memory Type DDR2
Memory Size 4 GBytes
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
Number of threads 4
Package (platform ID) Socket 771 LGA (0x6)
Temperature 0 51°C (123°F) [0x33] (TMPIN0)
Temperature 1 54°C (129°F) [0x36] (TMPIN1)
Temperature 2 -1°C (28°F) [0xFE] (TMPIN2)
Xeon E5440 / GA-P35-DS3 / 4 DDR2 / HD7750 - Windows 7 64 bit
Фото: 6
AMD FX-8350 @ 4700MHz
encoded 1128 frames in 73.55s (15.34 fps), 2266.68 kb/s
encoded 1128 frames in 78.12s (14.44 fps), 2266.68 kb/s
encoded 1128 frames in 88.81s (12.70 fps), 2266.68 kb/s
encoded 1128 frames in 90.61s (12.45 fps), 2266.68 kb/s
System Details
Name AMD FX-8350
Codename Vishera
Specification AMD FX(tm)-8350 Eight-Core Processor
Core Stepping OR-C0
Technology 32 nm
Stock frequency 4100 MHz
Core Speed 4716.2 MHz
Northbridge AMD RD9x0 rev. 02
Southbridge AMD SB910/950 rev. 40
Memory Frequency 936.5 MHz (3:14)
Memory Type DDR3
Memory Size 16286 MBytes
Channels Dual
Number of threads 8
Number of threads 8 (max 8)
L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Package Socket AM3+ (942)
Package Type 0x1
Temperature 0 68°C (154°F) [0x44] (CPU)
Temperature 1 26°C (78°F) [0x1A] (Mainboard)
It's dolomite, baby! (c)
