Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 13 из 20<  1 ... 10  11  12  13  14  15  16 ... 20  >
7-Ply писал(а):
так она еще и выиграла дополнительные 4-5%
Мдееее а результаты теста как-то диаметрально противоположены :spy:
Results for x264.exe r1745-1
encoded 1442 frames, 72.22 fps, 3908.24 kb/s
Results for x264_64.exe r1745-1
encoded 1442 frames, 65.55 fps, 3908.27 kb/s
Что и подтверждается и моим тестом
х32
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 113.19 fps, 3908.58 kb/s
encoded 1442 frames, 111.09 fps, 3908.58 kb/s
encoded 1442 frames, 113.72 fps, 3908.58 kb/s
encoded 1442 frames, 111.78 fps, 3908.58 kb/s
encoded 1442 frames, 25.57 fps, 3963.46 kb/s
encoded 1442 frames, 25.59 fps, 3963.36 kb/s
encoded 1442 frames, 25.58 fps, 3963.48 kb/s
encoded 1442 frames, 25.67 fps, 3963.56 kb/s
System Details
Name Intel Core 2 Quad Q9400
product System Product Name
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
Core Stepping R0
Technology 45 nm
Stock frequency 2666 MHz
Core Speed 3800.1 MHz
FID range 6.0x - 8.0x
Northbridge Intel P45/P43/G45/G43 rev. A2
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Command Rate (CR) 2T
Memory Frequency 475.0 MHz (1:1)
Memory Type DDR2
Memory Size 6144 MBytes
Channels Dual, (Symmetric)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1, v.721 (Build 7601)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 33°C (91°F) [0x21] (SYSTIN)
Temperature 1 38°C (99°F) [0x4B] (CPUTIN)
Temperature 2 19°C (65°F) [0x25] (AUXTIN)
Temperature 0 47°C (116°F) [0x35] (Core #0)
Temperature 1 44°C (111°F) [0x38] (Core #1)
Temperature 2 44°C (111°F) [0x38] (Core #2)
Temperature 3 41°C (105°F) [0x3B] (Core #3)
х64
encoded 1442 frames, 103.00 fps, 3910.59 kb/s
encoded 1442 frames, 96.13 fps, 3910.59 kb/s
encoded 1442 frames, 26.70 fps, 3965.15 kb/s
encoded 1442 frames, 26.70 fps, 3965.16 kb/s
encoded 1442 frames, 27.21 fps, 3964.80 kb/s
encoded 1442 frames, 26.70 fps, 3965.05 kb/s
System Details
Codename Yorkfield
Core Stepping R0
Technology 45 nm
Core Speed 3800.0 MHz
Memory Type DDR2
Number of threads 4
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
Temperature 0 32°C (89°F) [0x20] (SYSTIN)
Temperature 2 19°C (66°F) [0x26] (AUXTIN)
Temperature 0 46°C (114°F) [0x36] (Core #0)
Temperature 1 42°C (107°F) [0x3A] (Core #1)
Temperature 2 43°C (109°F) [0x39] (Core #2)
--- The place where gods come to die. ---
cure72
Ну, знаете. Вы на второй проход смотрите - первый ничего не решает и процессор в нем не раскрывается, в подтверждение моих слов можете сравнить нагрев или энергопотребление при первом и втором проходе. Сравнив множество результатов, приведённых здесь можно так же увидеть, что иногда у более слабых процессоров первый проход значительно быстрее, но во втором они сдают. Это, во-первых.
Вот пример:
Код:
Процессор         x264   1-pass   2-pass
Intel Core 2 Quad Q9505S   1342   75,89   24,8
AMD Phenom(tm) II X6 1090T   1342   69,43   28,98
Во-вторых, не правильно считать средний FPS по первому и второму проходам, правильнее считать суммарное (или среднее) время, как сумму продолжительностей проходов:
ti=N/FPSi, N=1442 - число кадров, FPSi - скорость одного прохода.
В вашем случае результат x64 по среднему FPS проигрывает на 7%, а по суммарному времени - выигрывает 2% (если брать в расчёт только время второго прохода, выигрывает 5% - что соответствует приведенным мной ранее цифрам).
ЗЫ. Чтобы уравнять шансы обоих кодеков в ближайшее время выложу новую версию.
7-Ply
Вот резалты
х86
encoded 1442 frames, 89.49 fps, 3908.58 kb/s
encoded 1442 frames, 99.55 fps, 3908.58 kb/s
encoded 1442 frames, 99.26 fps, 3908.58 kb/s
encoded 1442 frames, 97.08 fps, 3908.58 kb/s
encoded 1442 frames, 22.27 fps, 3963.77 kb/s
encoded 1442 frames, 22.39 fps, 3963.59 kb/s
encoded 1442 frames, 22.30 fps, 3963.64 kb/s
encoded 1442 frames, 21.82 fps, 3963.82 kb/s
System Details
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Core Stepping G0
Technology 65 nm
Manufacturer (ID) Apacer Technology (7F7A000000000000)
Stock frequency 2400 MHz
Core Speed 3599.8 MHz
FID range 6.0x - 9.0x
Northbridge Intel P45/P43 rev. A3
Memory Frequency 480.0 MHz (5:6)
Memory Type DDR2
Memory Size 4096 MBytes
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1, v.178 (Build 7601)
Number of threads 4
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Temperature 0 36°C (96°F) [0x24] (SYSTIN)
Temperature 1 40°C (103°F) [0x50] (CPUTIN)
Temperature 2 28°C (82°F) [0x38] (AUXTIN)
Temperature 0 68°C (154°F) [0x20] (Core #0)
Temperature 1 65°C (148°F) [0x23] (Core #1)
Temperature 2 57°C (134°F) [0x2B] (Core #2)
Temperature 3 58°C (136°F) [0x2A] (Core #3)
х64
encoded 1442 frames, 94.71 fps, 3910.59 kb/s
encoded 1442 frames, 101.14 fps, 3910.59 kb/s
encoded 1442 frames, 97.41 fps, 3910.59 kb/s
encoded 1442 frames, 100.59 fps, 3910.59 kb/s
encoded 1442 frames, 22.64 fps, 3964.90 kb/s
encoded 1442 frames, 22.61 fps, 3964.56 kb/s
encoded 1442 frames, 22.74 fps, 3965.27 kb/s
encoded 1442 frames, 22.71 fps, 3965.39 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3599.7 MHz
Memory Type DDR2
Number of threads 4
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
Temperature 1 41°C (104°F) [0x51] (CPUTIN)
Temperature 0 69°C (156°F) [0x1F] (Core #0)
Temperature 1 66°C (150°F) [0x22] (Core #1)
Temperature 2 56°C (132°F) [0x2C] (Core #2)
Temperature 3 59°C (138°F) [0x29] (Core #3)
Core i7 3930K@4,7GHz/16Gb DDR3 Samsung BH0-CK0@2400GHz(Quad Ch)/Asus Rampage IV Formula/Thermalright Silver Arrow+3*TR TY-150/12Tb/Asus Radeon R9 290
Фото: 3
encoded 1442 frames, 156.65 fps, 3909.96 kb/s
encoded 1442 frames, 156.82 fps, 3909.96 kb/s
encoded 1442 frames, 156.69 fps, 3909.96 kb/s
encoded 1442 frames, 158.79 fps, 3909.96 kb/s
encoded 1442 frames, 40.55 fps, 3960.91 kb/s
encoded 1442 frames, 40.38 fps, 3960.97 kb/s
encoded 1442 frames, 40.54 fps, 3962.75 kb/s
encoded 1442 frames, 40.45 fps, 3961.14 kb/s
System Details
Name Intel Core i7 950
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Core Stepping D0
Technology 45 nm
Stock frequency 3066 MHz
Core Speed 4199.9 MHz
Northbridge Intel X58 rev. 13
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 24
Command Rate (CR) 1T
Memory Frequency 800.0 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 34°C (93°F) [0x22] (SYSTIN)
Temperature 1 54°C (129°F) [0x6C] (CPUTIN)
Temperature 2 27°C (79°F) [0x35] (AUXTIN)
Temperature 1 57°C (134°F) [0x2B] (Core #1)
Temperature 2 61°C (141°F) [0x27] (Core #2)
Temperature 3 63°C (145°F) [0x25] (Core #3)
Windows Server 2008 R2(x64),к сожалению рабочую прогу(или плагин) Avisynth 2.5.8 x64 найти не удалось,поэтому x264.exe применил 32bit.
x264 HD Benchmark v3.19/x264.exe v1342
encoded 1442 frames, 107.36 fps, 3899.02 kb/s
encoded 1442 frames, 107.36 fps, 3898.50 kb/s
encoded 1442 frames, 106.25 fps, 3899.02 kb/s
encoded 1442 frames, 106.86 fps, 3899.02 kb/s
encoded 1442 frames, 42.93 fps, 3971.84 kb/s
encoded 1442 frames, 42.97 fps, 3964.03 kb/s
encoded 1442 frames, 42.95 fps, 3944.41 kb/s
encoded 1442 frames, 42.77 fps, 3957.26 kb/s
System Details
Name Intel Core i7 960
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
Specification PC3-14900
Core Stepping D0
Technology 45 nm
Stock frequency 3200 MHz
Core Speed 4562.6 MHz
Northbridge Intel X58 rev. 12
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 912.5 MHz (2:10)
Memory Type DDR3
Channels Triple
Windows Version Microsoft Windows Server 2008 R2 Datacenter Edition (Full) (Build 7600)
Number of threads 8
Temperature 0 28°C (82°F) [0x1C] (SYSTIN)
Temperature 1 67°C (152°F) [0x86] (CPUTIN)
Temperature 2 22°C (71°F) [0x2C] (AUXTIN)
Temperature 0 37°C (98°F) [0x25] (SB)
Temperature 1 41°C (105°F) [0x29] (NB)
Temperature 0 71°C (159°F) [0x1B] (Core #0)
Temperature 1 69°C (156°F) [0x1D] (Core #1)
Temperature 2 77°C (170°F) [0x15] (Core #2)
Temperature 3 59°C (138°F) [0x27] (Core #3)
x264 HD Benchmark v3.19/x264.exe v1790
encoded 1442 frames, 171.48 fps, 3909.93 kb/s
encoded 1442 frames, 171.81 fps, 3909.93 kb/s
encoded 1442 frames, 170.85 fps, 3909.93 kb/s
encoded 1442 frames, 170.55 fps, 3909.93 kb/s
encoded 1442 frames, 43.17 fps, 3960.68 kb/s
encoded 1442 frames, 42.99 fps, 3961.52 kb/s
encoded 1442 frames, 43.07 fps, 3961.70 kb/s
encoded 1442 frames, 43.17 fps, 3961.99 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 4562.5 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 27°C (80°F) [0x1B] (SYSTIN)
Temperature 1 71°C (158°F) [0x8D] (CPUTIN)
Temperature 0 79°C (174°F) [0x13] (Core #0)
Temperature 1 78°C (172°F) [0x14] (Core #1)
Temperature 2 71°C (159°F) [0x1B] (Core #2)
Temperature 3 68°C (154°F) [0x1E] (Core #3)
P.S. Для того что бы результаты хоть как-то сводить,наверное лучше указывать версию проги и версию кодека.
А вот мои результаты.... :D
encoded 1442 frames, 28.26 fps, 3899.26 kb/s
encoded 1442 frames, 28.27 fps, 3899.26 kb/s
encoded 1442 frames, 27.71 fps, 3899.26 kb/s
encoded 1442 frames, 27.72 fps, 3899.26 kb/s
encoded 1442 frames, 6.60 fps, 3971.70 kb/s
encoded 1442 frames, 6.59 fps, 3972.06 kb/s
encoded 1442 frames, 6.69 fps, 3971.03 kb/s
encoded 1442 frames, 6.68 fps, 3970.68 kb/s
System Details
Name AMD Opteron 165 (UP)
Codename Denmark
Specification Dual Core AMD Opteron(tm) Processor 165
Core Stepping JH9-E6
Technology 90 nm
Stock frequency 1800 MHz
Core Speed 2700.5 MHz
Northbridge NVIDIA nForce4 rev. A3
Southbridge NVIDIA nForce4 MCP rev. A3
CAS# latency (CL) 2.5
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 7
Memory Frequency 225.0 MHz (CPU/12)
Memory Type DDR
Memory Size 2048 MBytes
Channels Dual
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of threads 2
Number of threads 2 (max 2)
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
Package Socket 939
Temperature 0 64°C (147°F) [0x40] (TMPIN0)
Temperature 1 40°C (103°F) [0x28] (TMPIN1)
Temperature 2 83°C (181°F) [0x53] (TMPIN2)
Temperature 0 22°C (71°F) [0xB86] (THRM)
Temperature 0 75°C (166°F) [0x7C] (Core #0)
Temperature 1 74°C (165°F) [0x7B] (Core #1)
Sandy Bridge =)
encoded 1442 frames, 130.73 fps, 3900.68 kb/s
encoded 1442 frames, 132.15 fps, 3900.68 kb/s
encoded 1442 frames, 130.62 fps, 3900.68 kb/s
encoded 1442 frames, 130.77 fps, 3900.68 kb/s
encoded 1442 frames, 38.90 fps, 3970.27 kb/s
encoded 1442 frames, 39.07 fps, 3971.29 kb/s
encoded 1442 frames, 39.10 fps, 3971.73 kb/s
encoded 1442 frames, 39.16 fps, 3971.19 kb/s
System Details
Name Intel Sandy Bridge
Codename
Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Core Stepping
Technology 32 nm
Stock frequency 3300 MHz
Core Speed 3300.1 MHz
Northbridge Intel ID0100 rev. 09
Southbridge Intel ID1C46 rev. 04
Memory Type
Memory Size 8192 MBytes
Windows Version Microsoft Windows 7 (6.1) (Build 7600)
Number of threads 4
Number of threads 4 (max 16)
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
Package (platform ID) (0x1)
Temperature 0 37°C (98°F) [0x25] (SYSTIN)
Temperature 1 60°C (139°F) [0x188] (CPUTIN)
Temperature 2 53°C (126°F) [0x69] (AUXTIN)
Temperature 0 62°C (143°F) [0x24] (Core #0)
Temperature 1 65°C (148°F) [0x21] (Core #1)
Temperature 2 66°C (150°F) [0x20] (Core #2)
Temperature 3 60°C (139°F) [0x26] (Core #3)
silentstar
Последняя версия
Results for x264.exe r1867
encoded 1442 frames, 110.00 fps, 4755.34 kb/s
encoded 1442 frames, 109.21 fps, 4755.34 kb/s
encoded 1442 frames, 109.73 fps, 4755.34 kb/s
encoded 1442 frames, 108.45 fps, 4754.89 kb/s
encoded 1442 frames, 22.20 fps, 4818.60 kb/s
encoded 1442 frames, 22.18 fps, 4818.40 kb/s
encoded 1442 frames, 22.17 fps, 4818.07 kb/s
encoded 1442 frames, 22.10 fps, 4814.32 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3591.0 MHz
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IR (ICH9R) rev. 02
Memory Frequency 498.75 MHz (4:5)
Memory Type DDR2
Windows Version Microsoft Windows Server 2003 Enterprise x64 Edition Service Pack 2 (Build 3790)
Temperature 0 43°C (109°F) [0x2B] (SYSTIN)
Temperature 1 56°C (132°F) [0x70] (CPUTIN)
Temperature 1 68°C (154°F) [0x20] (Core #1)
Temperature 2 66°C (150°F) [0x22] (Core #2)
Temperature 3 66°C (150°F) [0x22] (Core #3)
Переустановил кулер, поддал газку на памяти и проце, плюс последняя рефизия х264
encoded 1442 frames, 106.05 fps, 3912.26 kb/s
encoded 1442 frames, 107.72 fps, 3912.26 kb/s
encoded 1442 frames, 107.73 fps, 3912.26 kb/s
encoded 1442 frames, 106.14 fps, 3912.26 kb/s
encoded 1442 frames, 22.96 fps, 3961.09 kb/s
encoded 1442 frames, 22.91 fps, 3960.51 kb/s
encoded 1442 frames, 23.03 fps, 3960.87 kb/s
encoded 1442 frames, 23.02 fps, 3960.86 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Manufacturer (ID) Hexon Technology (7F7F7F7F7FDC0000)
Core Speed 3663.3 MHz
Memory Frequency 542.7 MHz (3:4)
Memory Type DDR2
Number of threads 4
Temperature 1 35°C (94°F) [0x46] (CPUTIN)
Temperature 2 29°C (83°F) [0x39] (AUXTIN)
Temperature 0 54°C (129°F) [0x2E] (Core #0)
Temperature 1 58°C (136°F) [0x2A] (Core #1)
Temperature 2 52°C (125°F) [0x30] (Core #2)
Temperature 3 52°C (125°F) [0x30] (Core #3)
Последний раз редактировалось IBodyB 20.01.2011 15:44, всего редактировалось 1 раз.
encoded 1442 frames, 72.10 fps, 3901.21 kb/s
encoded 1442 frames, 72.38 fps, 3900.68 kb/s
encoded 1442 frames, 72.61 fps, 3900.68 kb/s
encoded 1442 frames, 72.15 fps, 3900.68 kb/s
encoded 1442 frames, 22.26 fps, 3971.63 kb/s
encoded 1442 frames, 22.26 fps, 3971.35 kb/s
encoded 1442 frames, 22.28 fps, 3970.54 kb/s
encoded 1442 frames, 22.27 fps, 3970.85 kb/s
Athlon X4 @3555
GF440MX->R9600SE->GF6600GT->HD3850->HD4730->HD5770
Cel800->Celeron2000->PenIV 2400->X2 3800->X2 7750->X3 440->X4 B40
Фото: 5
encoded 1442 frames, 137.74 fps, 3911.63 kb/s
encoded 1442 frames, 138.99 fps, 3911.63 kb/s
encoded 1442 frames, 137.33 fps, 3911.63 kb/s
encoded 1442 frames, 37.14 fps, 3958.47 kb/s
encoded 1442 frames, 37.27 fps, 3958.86 kb/s
encoded 1442 frames, 37.21 fps, 3958.60 kb/s
encoded 1442 frames, 37.21 fps, 3957.79 kb/s
System Details
Name Intel Xeon
Codename Gainestown
Specification Intel(R) Xeon(R) CPU E5530 @ 2.40GHz
Core Stepping D0
Technology 45 nm
Core Speed 3959.8 MHz
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Memory Frequency 833.7 MHz (2:8)
Memory Type DDR3
Channels Single
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
Number of threads 8
Package (platform ID) Socket 1366 LGA (0x0)
Temperature 0 35°C (94°F) [0x23] (SYSTIN)
Temperature 1 53°C (126°F) [0x69] (CPUTIN)
Temperature 0 63°C (145°F) [0x22] (Core #0)
Temperature 1 59°C (138°F) [0x26] (Core #1)
Temperature 2 60°C (139°F) [0x25] (Core #2)
Temperature 3 59°C (138°F) [0x26] (Core #3)
Фото: 9
x264 HD BENCHMARK RESULTS
Please copy/paste everything below the line into the forum post to report your data
Results for x264.exe v0.58.747
encoded 1442 frames, 108.49 fps, 3905.42 kb/s
encoded 1442 frames, 108.54 fps, 3905.42 kb/s
encoded 1442 frames, 108.42 fps, 3905.42 kb/s
encoded 1442 frames, 89.11 fps, 3905.42 kb/s
encoded 1442 frames, 29.44 fps, 3952.85 kb/s
encoded 1442 frames, 29.51 fps, 3952.85 kb/s
encoded 1442 frames, 26.56 fps, 3952.85 kb/s
encoded 1442 frames, 28.36 fps, 3952.85 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 117.16 fps, 3891.55 kb/s
encoded 1442 frames, 95.53 fps, 3891.55 kb/s
encoded 1442 frames, 97.62 fps, 3891.55 kb/s
encoded 1442 frames, 97.75 fps, 3891.55 kb/s
encoded 1442 frames, 32.54 fps, 3963.43 kb/s
encoded 1442 frames, 26.57 fps, 3963.44 kb/s
encoded 1442 frames, 31.15 fps, 3963.43 kb/s
encoded 1442 frames, 26.55 fps, 3963.42 kb/s
System Details
Name Intel Processor
Codename
Core Stepping
Core Speed 4090.8 MHz
Memory Type
Memory Size 12266 MBytes
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition Service Pack 1 (Build 7601)
Number of threads 4
Package
Temperature sensor 0 40°C (103°F) [0x28] (GPU Core)
Zio
А можно то же самое, но со стандартным для ветки x264 HD BENCHMARK 3.0 ?
Фото: 9
encoded 1442 frames, 110.17 fps, 3901.21 kb/s
encoded 1442 frames, 109.51 fps, 3900.68 kb/s
encoded 1442 frames, 110.80 fps, 3901.21 kb/s
encoded 1442 frames, 110.00 fps, 3900.68 kb/s
encoded 1442 frames, 33.60 fps, 3972.04 kb/s
encoded 1442 frames, 33.50 fps, 3971.00 kb/s
encoded 1442 frames, 33.60 fps, 3970.34 kb/s
encoded 1442 frames, 33.70 fps, 3971.80 kb/s
System Details
Codename
Core Stepping
Technology 32 nm
Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000)
Core Speed 3292.9 MHz
Memory Type
Memory Size 12288 MBytes
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
Number of threads 4
Temperature 0 56°C (132°F) [0x2A] (Core #0)
Temperature 1 58°C (136°F) [0x28] (Core #1)
Temperature 2 54°C (129°F) [0x2C] (Core #2)
Temperature 3 58°C (136°F) [0x28] (Core #3)
Интересно, чем обьясняется то что у Victory x264 HD Benchmark - тестируем процессоры и память при кодировании видео #7997960 и Zio x264 HD Benchmark - тестируем процессоры и память при кодировании видео #8124834 на одинаковом проце и одинаковой (?) частоте результаты очень разнятся? Или бенчмарк неправильно определяет частоту проца, а у вас обоих они разогнаны?
Вот доработал последнюю версию для x64 операционок на досуге. Ccылка
Кодек тоже последний на текущий момент - r1900.
x264 HD BENCHMARK 2.0
(3 версию ен скачал, трафика мало)
encoded 1442 frames, 29.02 fps, 3905.08 kb/s
encoded 1442 frames, 27.09 fps, 3905.08 kb/s
encoded 1442 frames, 27.12 fps, 3905.08 kb/s
encoded 1442 frames, 27.06 fps, 3905.08 kb/s
encoded 1442 frames, 6.86 fps, 3942.92 kb/s
encoded 1442 frames, 6.66 fps, 3942.92 kb/s
encoded 1442 frames, 6.67 fps, 3942.92 kb/s
encoded 1442 frames, 6.63 fps, 3942.92 kb/s
encoded 1442 frames, 31.83 fps, 3887.89 kb/s
encoded 1442 frames, 30.26 fps, 3888.91 kb/s
encoded 1442 frames, 30.10 fps, 3887.97 kb/s
encoded 1442 frames, 30.20 fps, 3887.38 kb/s
encoded 1442 frames, 7.48 fps, 3953.36 kb/s
encoded 1442 frames, 7.46 fps, 3953.12 kb/s
encoded 1442 frames, 7.43 fps, 3953.01 kb/s
encoded 1442 frames, 7.46 fps, 3953.42 kb/s
System Details
Name Intel Core 2 Duo E4400
Codename Conroe
Specification Intel(R) Core(TM)2 CPU 4400 @ 2.00GHz
Core Stepping L2
Technology 65 nm
Stock frequency 2000 MHz
Core Speed 2800.0 MHz (10.0 x 280.0 MHz)
FID range 6.0x - 10.0x
Southbridge Intel 82801IB (ICH9) rev. 02
CAS# 5.0
RAS# to CAS# 6
RAS# Precharge 6
Cycle Time (tRAS) 17
Command Rate 2T
Memory Frequency 420.0 MHz (2:3)
Memory Type DDR2
Channels Dual (Symmetric)
max VID 1.325 V
Voltage sensor 0 1.36 Volts [0x55] (CPU VCORE)
Number of threads 2
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
Package Socket 775 LGA (platform ID = 0h)
Temperature sensor 0 45°C (112°F) [0x2D] (TMPIN0)
Temperature sensor 1 77°C (170°F) [0x4D] (TMPIN1)
Temperature sensor 0 98°C (208°F) [0x2] (core #0)
Temperature sensor 1 93°C (199°F) [0x7] (core #1)
Temperature sensor 0 52°C (125°F) [0x34] (GPU Core)
encoded 1442 frames, 20.97 fps, 3905.08 kb/s
encoded 1442 frames, 21.13 fps, 3905.08 kb/s
encoded 1442 frames, 21.07 fps, 3905.08 kb/s
encoded 1442 frames, 21.05 fps, 3905.08 kb/s
encoded 1442 frames, 5.39 fps, 3942.92 kb/s
encoded 1442 frames, 5.40 fps, 3942.92 kb/s
encoded 1442 frames, 5.10 fps, 3942.92 kb/s
encoded 1442 frames, 23.20 fps, 3888.48 kb/s
encoded 1442 frames, 23.52 fps, 3887.25 kb/s
encoded 1442 frames, 23.55 fps, 3887.65 kb/s
encoded 1442 frames, 23.46 fps, 3887.10 kb/s
encoded 1442 frames, 6.04 fps, 3953.47 kb/s
encoded 1442 frames, 6.06 fps, 3954.88 kb/s
encoded 1442 frames, 6.04 fps, 3953.06 kb/s
encoded 1442 frames, 6.05 fps, 3953.45 kb/s
System Details
Codename Conroe
Core Stepping L2
Technology 65 nm
Core Speed 2000.1 MHz (10.0 x 200.0 MHz)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 16
Command Rate 2T
Memory Frequency 400.0 MHz (1:2)
Memory Type DDR2
max VID 1.325 V
Voltage sensor 0 1.02 Volts [0x40] (CPU VCORE)
Number of threads 2
Temperature sensor 0 43°C (109°F) [0x2B] (TMPIN0)
Temperature sensor 1 52°C (125°F) [0x34] (TMPIN1)
Temperature sensor 0 72°C (161°F) [0x1C] (core #0)
Temperature sensor 1 69°C (156°F) [0x1F] (core #1)
Temperature sensor 0 51°C (123°F) [0x33] (GPU Core)
странно, но увеличение частоты на 800 МГц дала отдачу только в первом проходе, во втором по меньше прирост
7-Ply
Вот резалты
"x32"
x264 HD BENCHMARK 3.19 RESULTS
Results for x264.exe r1900
encoded 1442 frames, 110.15 fps, 3912.26 kb/s
encoded 1442 frames, 110.10 fps, 3912.26 kb/s
encoded 1442 frames, 110.93 fps, 3912.26 kb/s
encoded 1442 frames, 109.35 fps, 3912.26 kb/s
encoded 1442 frames, 23.54 fps, 3961.80 kb/s
encoded 1442 frames, 23.61 fps, 3961.77 kb/s
encoded 1442 frames, 23.57 fps, 3961.28 kb/s
encoded 1442 frames, 23.64 fps, 3961.53 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3798.0 MHz
Memory Frequency 527.5 MHz (4:5)
Memory Type DDR2
Number of threads 4
Temperature 1 37°C (98°F) [0x4A] (CPUTIN)
Temperature 2 30°C (85°F) [0x3C] (AUXTIN)
Temperature 0 60°C (139°F) [0x28] (Core #0)
Temperature 1 63°C (145°F) [0x25] (Core #1)
Temperature 2 59°C (138°F) [0x29] (Core #2)
Temperature 3 56°C (132°F) [0x2C] (Core #3)
"x64"
Results for x264_64.exe r1900
encoded 1442 frames, 104.15 fps, 3912.26 kb/s
encoded 1442 frames, 103.30 fps, 3912.26 kb/s
encoded 1442 frames, 103.79 fps, 3912.26 kb/s
encoded 1442 frames, 102.60 fps, 3912.26 kb/s
encoded 1442 frames, 24.84 fps, 3961.68 kb/s
encoded 1442 frames, 24.48 fps, 3961.33 kb/s
encoded 1442 frames, 24.68 fps, 3961.63 kb/s
encoded 1442 frames, 24.65 fps, 3961.60 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3798.2 MHz
Memory Type DDR2
Number of threads 4
Temperature 2 31°C (86°F) [0x3D] (AUXTIN)
Temperature 0 61°C (141°F) [0x27] (Core #0)
Temperature 1 60°C (139°F) [0x28] (Core #1)
Temperature 3 55°C (130°F) [0x2D] (Core #3)
Me4tatelI>, при грамотном разгоне производительность второго прохода растет пропорционально частоте независимо от версии кодека.
У Вас разгон - 40%, прирост производительности - около 25%. Возможно процессор входит в троттлинг. Вероятно небольшое снижение частоты даст прирост FPS.
Здесь немало примеров экстремального разгона. Один и тот же процессор разогнанный до предельной частоты дает меньше FPS, чем на меньшей частоте. Не найду что-то пост, но вот выдержка из результатов опубликованных здесь ранее:
Код:
System                                                          Stock  Current Threads x264  1-pass  2-pass
Intel Core i7 920 (1523 RAM) 9-9-9-24 TB-Off   2666   4000,4      8      1342   93,18   36,83
Intel Core i7 920 (1600 RAM) 9-9-9-24 TB-Off   2666   4209,3      8      1342   95,49   30,34
IBodyB, разработчики кодека заявляют о приросте в 5%, что и наблюдается во втором проходе)
Если оптимизировать код под x64, максимум что можно выжать это 10% по сравнению с x86. Но этого кажется делать никто не собирается.
7-Ply
один раз я при разгоне до 2800 выставлял анпряжение авто
но кажется результат который выше это не авто режим
но тротлинг скорее всего имеет место, потому что там темпиратура написана 90 градусов )) это много
однако раньше я в MeGUI запускал одну и туже задачу (кодирвоание в AVC/H.264 с помощью x264 core:98 r1649) на дефолте и на 2880 МГц, вот там был пропорциональный прирост, правда я не помню там двухпроходовый тест или нет
