CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 839.1 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
Number of processors 1 Number of threads 8 Number of threads 8 (max 32) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x0)
Temperature 0 42°C (107°F) [0x2A] (SYSTIN) Temperature 1 53°C (127°F) [0x6A] (CPUTIN) Temperature 2 25°C (76°F) [0x31] (AUXTIN) Temperature 0 48°C (118°F) [0x2F] (Core #0) Temperature 1 50°C (121°F) [0x2D] (Core #1) Temperature 9 45°C (112°F) [0x32] (Core #9) Temperature 10 50°C (121°F) [0x2D] (Core #10)
Temperature 0 42°C (107°F) [0x2A] (SYSTIN) Temperature 1 55°C (130°F) [0x6D] (CPUTIN) Temperature 2 23°C (73°F) [0x2E] (AUXTIN) Temperature 0 46°C (114°F) [0x31] (Core #0) Temperature 1 52°C (125°F) [0x2B] (Core #1) Temperature 9 49°C (120°F) [0x2E] (Core #9) Temperature 10 52°C (125°F) [0x2B] (Core #10)
О! Это ж совершенно другое дело!
А вот запуск через "Run Benchmark x64.vbs"
x64
x264 HD BENCHMARK 3.19 RESULTS
Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data
Temperature 0 42°C (107°F) [0x2A] (SYSTIN) Temperature 1 54°C (129°F) [0x6C] (CPUTIN) Temperature 2 24°C (74°F) [0x2F] (AUXTIN) Temperature 0 48°C (118°F) [0x2F] (Core #0) Temperature 1 50°C (121°F) [0x2D] (Core #1) Temperature 9 46°C (114°F) [0x31] (Core #9) Temperature 10 44°C (111°F) [0x33] (Core #10)
CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 668.7 MHz (2:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 46°C (114°F) [0x2E] (SYSTIN) Temperature 1 47°C (115°F) [0x5D] (CPUTIN) Temperature 2 41°C (105°F) [0x52] (AUXTIN) Temperature 0 43°C (109°F) [0x38] (Core #0) Temperature 1 41°C (105°F) [0x3A] (Core #1) Temperature 2 45°C (112°F) [0x36] (Core #2) Temperature 3 42°C (107°F) [0x39] (Core #3)
Windows 7 x64 with r1900 x64 (i7-870 w/o OC)
Код:
x264 HD BENCHMARK 3.0 RESULTS
Temperature 0 57°C (134°F) [0x39] (SYSTIN) Temperature 1 57°C (134°F) [0x72] (CPUTIN) Temperature 2 43°C (108°F) [0x55] (AUXTIN) Temperature 0 55°C (130°F) [0x2C] (Core #0) Temperature 1 52°C (125°F) [0x2F] (Core #1) Temperature 2 57°C (134°F) [0x2A] (Core #2) Temperature 3 53°C (127°F) [0x2E] (Core #3)
пароль на архив: -> x264_benchmark <- контрольные суммы: MD5 5c35d25ffd7e758b5f6f4037395d48c5 SHA1 8a7b943f0609808d49876b52b1c2c62cf4d48ae1 CRC32 53b18aee Прогу "Avisynth 258",ставить обязательно,иначе тест не завести. У меня на х64 оси,тест работает без установки "pludins x64". Включается тест,через файл с расширением "bat",соответствующей разрядности.
Добавлено спустя 1 час 34 минуты 46 секунд: На слабой машине.
"x64"
x264 HD BENCHMARK 4.0 RESULTS
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 399.3 MHz (2:3) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric)
Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 37°C (98°F) [0x25] (SYSTIN) Temperature 1 44°C (111°F) [0x58] (CPUTIN) Temperature 2 51°C (123°F) [0x66] (AUXTIN) Temperature 0 43°C (108°F) [0xC55] (THRM)
"x86"
Temperature 0 37°C (98°F) [0x25] (SYSTIN) Temperature 1 44°C (111°F) [0x58] (CPUTIN) Temperature 2 38°C (99°F) [0x4B] (AUXTIN) Temperature 0 44°C (110°F) [0xC5F] (THRM)
Это тесты двух разных компьютеров. Как их сравнить, какие цифры лучше, какие хуже ? Может где-то есть расшифровка этого теста ? Меня интересует просто сравнение компьютеров по производительности. Может я не тем меряю ? Подскажите.
Bozo Спасибо, но не очень понятно. В первом тесте первые 4 результата меньше, чем во втором. Во втором тесте вторые 4 - больше. Как сравнивать эти fps ? Строчку со строчкой или среднее значение выводить ?
Статус: Не в сети Регистрация: 11.02.2010 Откуда: Северск
generator3 Ну начнём с того, что один и тот же ролик кодится 4 раза, в 2-pass режиме (двупроходном)...В первом проходе собирается инфо о контенте, во втором проходе идет сам энкод...Соответственен первый проход не так сильно грузит проц, по сравнению со вторым, по этому такое различие в fpsах...А разница по тестам ничтожно мала, компы примерно одинаковы по производительности...Кстати, скорость зависит от "новизны" винды, т.е. если недавно было "перестекление окошек" на одном, то второй, при том же конфиге, будет медленнее...Как вариант потестит Linxом, но судя по этому бенчу (x264 HD Benchmark) победитель не далёко убежит от побеждённого
CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 11 Command Rate (CR) 2T Memory Frequency 416.0 MHz (3:4) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric)
Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 43°C (109°F) [0x2B] (System) Temperature 1 38°C (100°F) [0x26] (CPU)
Статус: Не в сети Регистрация: 22.05.2011 Откуда: с того тыс.лет.
Patrontaj Ребят простите,здесь на работе так накувыркаешся,придёшь домой,там ещё подруга вставит.
Добавлено спустя 54 минуты 38 секунд: generator3 пускай меня накажут. Чисто моё мнение вы G3 просто поганец. Славинчик,сегодня Власыча закопали,земля ему пухоми. Ребята всё сделали.
CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 31 Command Rate (CR) 1T Memory Frequency 850.0 MHz (2:10) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple
Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 46°C (114°F) [0x2E] (TMPIN0) Temperature 1 56°C (132°F) [0x38] (TMPIN1) Temperature 2 54°C (129°F) [0x36] (TMPIN2)
Сейчас этот форум просматривают: Setkos и гости: 1
