Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 15 из 20 • <  1 ... 12  13  14  15  16  17  18 ... 20  >
Results for x264.exe r1913
Pass 1
encoded 1442 frames, 108.37 fps, 3912.32 kb/s
encoded 1442 frames, 108.49 fps, 3912.32 kb/s
encoded 1442 frames, 108.63 fps, 3912.32 kb/s
encoded 1442 frames, 108.24 fps, 3912.32 kb/s
Pass 2
encoded 1442 frames, 21.90 fps, 3961.54 kb/s
encoded 1442 frames, 21.90 fps, 3961.29 kb/s
encoded 1442 frames, 21.82 fps, 3961.69 kb/s
encoded 1442 frames, 21.96 fps, 3961.40 kb/s
System Details
Name AMD Phenom II X4 955
product System Product Name
Codename Deneb
Specification AMD Phenom(tm) II X4 955 Processor
Core Stepping RB-C3
Technology 45 nm
Core Speed 803.6 MHz
Northbridge NVIDIA GeForce 7025 rev. A3
Southbridge NVIDIA nForce 630a rev. A2
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 27
Command Rate (CR) 1T
Memory Frequency 803.6 MHz (1:4)
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
Package Socket AM3 (938)
Package Type 0x1
Temperature 0 43°C (109°F) [0x2B] (CPU)
Temperature 1 36°C (96°F) [0x24] (Mainboard)
AndyK2008
устарело,прогшу и кодек пора поменять.
Фото: 54
прогнал тест на профильной системе:
i5-2500K 3300MHz x264 HD BENCHMARK 4.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264_64.exe r1995
encoded 1442 frames, 148.61 fps, 3912.46 kb/s
encoded 1442 frames, 150.07 fps, 3912.46 kb/s
encoded 1442 frames, 150.54 fps, 3912.46 kb/s
encoded 1442 frames, 149.57 fps, 3912.46 kb/s
encoded 1442 frames, 30.64 fps, 3963.07 kb/s
encoded 1442 frames, 30.45 fps, 3962.96 kb/s
encoded 1442 frames, 30.91 fps, 3963.31 kb/s
encoded 1442 frames, 30.92 fps, 3963.17 kb/s
System Details
Name Intel Core i5 2500K
Codename Sandy Bridge
Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Specification PC3-12800
Core Stepping D2
Technology 32 nm
Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000)
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Stock frequency 3300 MHz
Core Speed 3301.1 MHz
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel P67 rev. B3
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 24
Command Rate (CR) 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 800.3 MHz (1:6)
Memory Type DDR3
Number of threads 4
Number of threads 4 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
Package (platform ID) Socket 1155 LGA (0x1)
Temperature 0 39°C (102°F) [0x27] (TMPIN0)
Temperature 1 25°C (76°F) [0x19] (TMPIN1)
Temperature 2 38°C (100°F) [0x26] (TMPIN2)
i5-2500K@4600MHz x264 HD BENCHMARK 4.0 RESULTS
encoded 1442 frames, 194.60 fps, 3912.46 kb/s
encoded 1442 frames, 195.84 fps, 3912.46 kb/s
encoded 1442 frames, 196.27 fps, 3912.46 kb/s
encoded 1442 frames, 192.19 fps, 3912.46 kb/s
encoded 1442 frames, 42.15 fps, 3962.97 kb/s
encoded 1442 frames, 42.29 fps, 3963.06 kb/s
encoded 1442 frames, 42.23 fps, 3963.75 kb/s
encoded 1442 frames, 42.36 fps, 3963.27 kb/s
System Details
Core Stepping D2
Technology 32 nm
Core Speed 4601.5 MHz
Command Rate 2T
Command Rate 2T
Memory Type DDR3
Number of threads 4
Temperature 0 37°C (98°F) [0x25] (TMPIN0)
Temperature 2 45°C (112°F) [0x2D] (TMPIN2)
i5-2500K@5000MHz x264 HD BENCHMARK 4.0 RESULTS
encoded 1442 frames, 209.59 fps, 3912.46 kb/s
encoded 1442 frames, 209.14 fps, 3912.46 kb/s
encoded 1442 frames, 209.11 fps, 3912.46 kb/s
encoded 1442 frames, 205.41 fps, 3912.46 kb/s
encoded 1442 frames, 45.51 fps, 3962.81 kb/s
encoded 1442 frames, 45.62 fps, 3963.19 kb/s
encoded 1442 frames, 45.67 fps, 3963.65 kb/s
encoded 1442 frames, 45.72 fps, 3963.08 kb/s
System Details
Core Stepping D2
Technology 32 nm
Core Speed 5001.8 MHz
Command Rate 2T
Command Rate 2T
Memory Type DDR3
Number of threads 4
Temperature 0 38°C (100°F) [0x26] (TMPIN0)
Temperature 2 56°C (132°F) [0x38] (TMPIN2)
990X@4880
SMT off
SMT on
ideykin писал(а):
http://tinypaste.com/ee8a7 :facepalm:
"Всё существующее – сон; всё, что не сон – не существует". Хорхе Луис Борхес.
i7-2600K 100x46 4600 x64
Results for x264_64.exe r2019
encoded 1442 frames, 187.18 fps, 3912.36 kb/s
encoded 1442 frames, 186.43 fps, 3912.36 kb/s
encoded 1442 frames, 187.59 fps, 3912.36 kb/s
encoded 1442 frames, 186.81 fps, 3912.36 kb/s
encoded 1442 frames, 50.40 fps, 3966.64 kb/s
encoded 1442 frames, 50.40 fps, 3967.20 kb/s
encoded 1442 frames, 50.40 fps, 3966.36 kb/s
encoded 1442 frames, 50.40 fps, 3966.44 kb/s
System Details
Name Intel Core i7 2600K
Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
Core Stepping D2
Technology 32 nm
Stock frequency 3400 MHz
Core Speed 4600.0 MHz
Southbridge Intel ID1C44 rev. 05
Memory Frequency 800.0 MHz (1:6)
Memory Type DDR3
Memory Size 16384 MBytes
Channels Dual
Windows Version Microsoft Windows Server 2003 Enterprise Edition Service Pack 2 (Build 3790)
Number of threads 8
Number of threads 8 (max 16)
Temperature 0 61°C (141°F) [0x3D] (TMPIN0)
Temperature 1 53°C (127°F) [0x35] (TMPIN1)
Temperature 2 46°C (114°F) [0x2E] (TMPIN2)
Temperature 0 52°C (125°F) [0x70] (PCH)
Overclocked Tester
Pass 1
encoded 1442 frames, 200.08 fps, 3913.22 kb/s
encoded 1442 frames, 200.53 fps, 3913.22 kb/s
Pass 2
encoded 1442 frames, 50.29 fps, 3959.71 kb/s
encoded 1442 frames, 50.22 fps, 3959.18 kb/s
encoded 1442 frames, 50.28 fps, 3960.23 kb/s
encoded 1442 frames, 50.21 fps, 3959.72 kb/s
System Details
Name Intel Core i7 Extreme 980X
Codename Gulftown
Specification Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz (Engineering Sample)
Core Stepping B1
Technology 32 nm
Stock frequency 3333 MHz
Core Speed 4450.2 MHz
Northbridge Intel X58 rev. 13
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 16
Memory Frequency 712.0 MHz (2:8)
Memory Type DDR3
Memory Size 6144 MBytes
Channels Triple
Number of threads 6
Number of threads 6 (max 32)
L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 44°C (111°F) [0x2C] (TMPIN0)
Temperature 1 47°C (116°F) [0x2F] (TMPIN1)
Temperature 2 64°C (147°F) [0x40] (TMPIN2)
MSI MPG Z790 Edge WiFi | Intel Core i9-13900K
ASUS ROG Strix X870E-E Gaming WiFi | AMD Ryzen 9 9950X
https://t.me/bench_and_play
Pass 1
encoded 1442 frames, 145.57 fps, 3913.37 kb/s
encoded 1442 frames, 146.72 fps, 3913.37 kb/s
encoded 1442 frames, 146.03 fps, 3913.37 kb/s
encoded 1442 frames, 146.49 fps, 3913.37 kb/s
Pass 2
encoded 1442 frames, 42.25 fps, 3962.01 kb/s
encoded 1442 frames, 42.23 fps, 3963.26 kb/s
encoded 1442 frames, 42.21 fps, 3962.55 kb/s
encoded 1442 frames, 42.11 fps, 3963.77 kb/s
System Details
Name AMD Phenom II X6 1090T
Codename Thuban
Specification AMD Phenom(tm) II X6 1090T Processor
Core Stepping PH-E0
Technology 45 nm
Stock frequency 3700 MHz
Core Speed 4009.4 MHz
Northbridge AMD 890GX rev. 00
Southbridge AMD SB850 rev. 40
Memory Frequency 870.3 MHz (1:4)
Memory Type DDR3
Memory Size 8192 MBytes
Number of threads 6
Number of threads 6 (max 6)
L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
Package Type 0x1
Temperature 0 45°C (112°F) [0x2F] (CPU)
Temperature 1 28°C (82°F) [0x1C] (Mainboard)
А ГДЕ НАХОДИТСЯ САМ ЛОГ
Фото: 6
x264 HD BENCHMARK RESULTS
Please copy/paste everything below the line into the forum post to report your data
Results for x264.exe v0.58.747
encoded 1442 frames, 37.61 fps, 3905.08 kb/s
encoded 1442 frames, 37.55 fps, 3905.08 kb/s
encoded 1442 frames, 37.59 fps, 3905.08 kb/s
encoded 1442 frames, 37.58 fps, 3905.08 kb/s
encoded 1442 frames, 10.43 fps, 3942.92 kb/s
encoded 1442 frames, 10.44 fps, 3942.92 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 42.12 fps, 3887.32 kb/s
encoded 1442 frames, 42.12 fps, 3889.23 kb/s
encoded 1442 frames, 42.04 fps, 3888.97 kb/s
encoded 1442 frames, 42.06 fps, 3889.96 kb/s
encoded 1442 frames, 11.66 fps, 3953.49 kb/s
encoded 1442 frames, 11.67 fps, 3953.39 kb/s
encoded 1442 frames, 11.66 fps, 3953.40 kb/s
encoded 1442 frames, 11.67 fps, 3953.35 kb/s
System Details
Name Intel Pentium
Codename Wolfdale
Specification Pentium(R) Dual-Core CPU E5800 @ 3.20GHz
Core Stepping
Technology 45 nm
Stock frequency 3200 MHz
Core Speed 3680.1 MHz (16.0 x 230.0 MHz)
Northbridge Intel P35/G33/G31 rev. 10
Southbridge Intel 82801GB (ICH7/R) rev. A1
CAS# 6.0
RAS# to CAS# 6
RAS# Precharge 6
Cycle Time (tRAS) 18
Command Rate 2T
Memory Frequency 460.0 MHz (1:2)
Memory Type DDR2
Memory Size 2048 MBytes
Channels Single
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
Voltage sensor 0 1.79 Volts [0x70] (CPU VCORE)
Number of threads 2
Number of threads 2 (max 2)
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Package Socket 775 LGA (platform ID = 0h)
Temperature sensor 0 52°C (125°F) [0x34] (TMPIN0)
Temperature sensor 0 76°C (168°F) [0x1D] (core #0)
Temperature sensor 1 68°C (154°F) [0x25] (core #1)
Temperature sensor 0 50°C (121°F) [0x31] (GPU Core)
Добавлено спустя 9 минут 32 секунды:
На е5800 сделал е8400, лол, это ещё при том, что он стоит в 2,5 раза дороже !!!!
По цена / производительность е8400 ужастный процессор
Код:
Please do NOT compare it with older versions of the benchmark!
to http://forums.techarp.com/reviews-articles/26363-x264-hd-benchmark-4-0-a.html
Pass 1
encoded 1442 frames, 191.55 fps, 3911.63 kb/s
encoded 1442 frames, 189.66 fps, 3911.63 kb/s
encoded 1442 frames, 193.74 fps, 3911.63 kb/s
encoded 1442 frames, 189.49 fps, 3911.63 kb/s
Pass 2
encoded 1442 frames, 46.96 fps, 3959.94 kb/s
encoded 1442 frames, 47.05 fps, 3959.88 kb/s
encoded 1442 frames, 47.07 fps, 3960.06 kb/s
encoded 1442 frames, 46.99 fps, 3959.20 kb/s
System Details
   Core Stepping      D2
   Technology      32 nm
   Core Speed      4512.8 MHz
RAS# to CAS# delay (tRCD)   10
Cycle Time (tRAS)      30
Memory Frequency      936.1 MHz (1:7)
Memory Type         DDR3
Number of threads      8
   Temperature 0   33°C (91°F) [0x21] (TMPIN0)
   Temperature 2   40°C (103°F) [0x28] (TMPIN2)
   Temperature 0   45°C (112°F) [0x7D] (PCH)
Код:
Pass 1
encoded 1442 frames, 202.07 fps, 3911.63 kb/s
encoded 1442 frames, 198.65 fps, 3911.63 kb/s
encoded 1442 frames, 201.62 fps, 3911.63 kb/s
encoded 1442 frames, 197.53 fps, 3911.62 kb/s
Pass 2
encoded 1442 frames, 50.08 fps, 3959.21 kb/s
encoded 1442 frames, 50.33 fps, 3960.06 kb/s
encoded 1442 frames, 50.17 fps, 3959.04 kb/s
encoded 1442 frames, 50.21 fps, 3959.83 kb/s
System Details
   Core Stepping      D2
   Technology      32 nm
   Core Speed      4814.0 MHz
CAS# latency (CL)      10.0
RAS# to CAS# delay (tRCD)   11
RAS# Precharge (tRP)      10
Cycle Time (tRAS)      34
Memory Frequency      1069.8 MHz (1:8)
Memory Type         DDR3
Memory Size         15886 MBytes
Number of threads      8
   Temperature 0   34°C (93°F) [0x22] (TMPIN0)
   Temperature 2   41°C (105°F) [0x29] (TMPIN2)
encoded 1442 frames, 66.84 fps, 3905.42 kb/s
encoded 1442 frames, 67.47 fps, 3905.42 kb/s
encoded 1442 frames, 67.57 fps, 3905.42 kb/s
encoded 1442 frames, 16.70 fps, 3952.85 kb/s
encoded 1442 frames, 16.73 fps, 3952.85 kb/s
encoded 1442 frames, 16.68 fps, 3952.85 kb/s
encoded 1442 frames, 16.63 fps, 3952.85 kb/s
encoded 1442 frames, 69.45 fps, 3891.55 kb/s
encoded 1442 frames, 59.52 fps, 3889.39 kb/s
encoded 1442 frames, 69.34 fps, 3887.88 kb/s
encoded 1442 frames, 69.76 fps, 3891.55 kb/s
encoded 1442 frames, 16.70 fps, 3963.43 kb/s
encoded 1442 frames, 17.12 fps, 3963.56 kb/s
encoded 1442 frames, 17.92 fps, 3963.18 kb/s
encoded 1442 frames, 17.40 fps, 3963.43 kb/s
System Details
Name AMD Phenom
Codename Deneb
Specification AMD Phenom(tm) II X4 810 Processor
Core Stepping
Technology 45 nm
Stock frequency 2600 MHz
Core Speed 3129.1 MHz (13.0 x 240.7 MHz)
Northbridge AMD ID9601 rev. 00
Southbridge ATI SB700 rev. 00
CAS# 7.0
RAS# to CAS# 7
RAS# Precharge 7
Cycle Time (tRAS) 22
Command Rate 1T
Memory Frequency 641.9 MHz (3:8)
Memory Type DDR3
Memory Size 3584 MBytes
Channels Dual (Unganged)
Windows Version Microsoft Windows Vista (6.1) Service Pack 1 (Build 7601)
max VID 1.250 V
Number of threads 4
Package Socket AM2+ (940)
Package Type 0x1
Temperature sensor 0 0°C (32°F) [0x0] (core #0)
Temperature sensor 1 0°C (32°F) [0x0] (core #1)
Temperature sensor 2 0°C (32°F) [0x0] (core #2)
Temperature sensor 3 0°C (32°F) [0x0] (core #3)
Наш мир – как Ноев ковчег: горстка людей и уйма скотов. (с) Сэмюэл Батлер.
Сменил платформу LGA 775 на LGA1155.
Ревизия x264 последняя: x264 core 116 r2074 2641b9e
резалт
to http://forums.techarp.com/reviews-artic ... 4-0-a.html
Pass 1
encoded 1442 frames, 199.53 fps, 3912.37 kb/s
encoded 1442 frames, 204.63 fps, 3912.37 kb/s
encoded 1442 frames, 201.28 fps, 3912.37 kb/s
encoded 1442 frames, 202.98 fps, 3912.37 kb/s
Pass 2
encoded 1442 frames, 51.33 fps, 3967.10 kb/s
encoded 1442 frames, 51.49 fps, 3967.27 kb/s
encoded 1442 frames, 51.58 fps, 3967.05 kb/s
encoded 1442 frames, 51.48 fps, 3965.33 kb/s
System Details
Core Stepping D2
Technology 32 nm
Core Speed 4900.8 MHz
Memory Frequency 933.5 MHz (1:7)
Memory Type DDR3
Number of threads 4
Temperature 0 26°C (78°F) [0x1A] (SYSTIN)
Temperature 1 0°C (32°F) [0x0] (CPUTIN)
Temperature 2 0°C (32°F) [0x0] (AUXTIN)
Core i7 3930K@4,7GHz/16Gb DDR3 Samsung BH0-CK0@2400GHz(Quad Ch)/Asus Rampage IV Formula/Thermalright Silver Arrow+3*TR TY-150/12Tb/Asus Radeon R9 290
Фото: 6
encoded 1442 frames, 70.40 fps, 3905.42 kb/s
encoded 1442 frames, 70.72 fps, 3905.42 kb/s
encoded 1442 frames, 20.48 fps, 3952.85 kb/s
encoded 1442 frames, 20.53 fps, 3952.85 kb/s
encoded 1442 frames, 18.57 fps, 3952.85 kb/s
encoded 1442 frames, 18.50 fps, 3952.85 kb/s
encoded 1442 frames, 77.75 fps, 3889.38 kb/s
encoded 1442 frames, 77.75 fps, 3889.35 kb/s
encoded 1442 frames, 75.27 fps, 3889.52 kb/s
encoded 1442 frames, 69.23 fps, 3889.39 kb/s
encoded 1442 frames, 23.14 fps, 3962.44 kb/s
encoded 1442 frames, 20.86 fps, 3962.79 kb/s
encoded 1442 frames, 21.48 fps, 3962.65 kb/s
encoded 1442 frames, 21.62 fps, 3963.56 kb/s
System Details
Name Intel Core 2 Extreme QX9650
Codename Yorkfield
Specification Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz
Core Stepping C0
Technology 45 nm
Stock frequency 3000 MHz
Core Speed 3478.0 MHz (9.0 x 386.4 MHz)
FID range 6.0x - 9.0x
CAS# 6.0
RAS# to CAS# 6
RAS# Precharge 6
Command Rate 2T
Memory Frequency 463.7 MHz (5:6)
Memory Type DDR2
Channels Dual (Symmetric)
max VID 1.250 V
Voltage sensor 0 1.84 Volts [0x73] (CPU VCORE)
Number of threads 4
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 68°C (154°F) [0x44] (TMPIN0)
Temperature sensor 0 87°C (188°F) [0x12] (core #0)
Temperature sensor 1 87°C (188°F) [0x12] (core #1)
Temperature sensor 2 84°C (183°F) [0x15] (core #2)
Temperature sensor 3 85°C (184°F) [0x14] (core #3)
Temperature sensor 0 42°C (107°F) [0x2A] (GPU Core)
Pass 1
encoded 1442 frames, 199.25 fps, 3912.26 kb/s
encoded 1442 frames, 201.20 fps, 3912.26 kb/s
encoded 1442 frames, 201.12 fps, 3912.26 kb/s
encoded 1442 frames, 200.36 fps, 3912.26 kb/s
Pass 2
encoded 1442 frames, 40.75 fps, 3961.68 kb/s
encoded 1442 frames, 40.93 fps, 3961.62 kb/s
encoded 1442 frames, 40.86 fps, 3961.42 kb/s
encoded 1442 frames, 40.80 fps, 3960.81 kb/s
System Details
Core Stepping D2
Technology 32 nm
Core Speed 5001.5 MHz
Command Rate 2T
Command Rate 2T
Memory Type DDR3
Number of threads 4
Temperature 2 49°C (120°F) [0x31] (TMPIN2)
Temperature 0 61°C (141°F) [0x62] (PCH)
http://tinypaste.com/2e571155
Pass 1
encoded 1442 frames, 115.13 fps, 3911.61 kb/s
encoded 1442 frames, 116.36 fps, 3911.61 kb/s
encoded 1442 frames, 117.01 fps, 3911.61 kb/s
encoded 1442 frames, 115.78 fps, 3911.61 kb/s
Pass 2
encoded 1442 frames, 36.03 fps, 3959.50 kb/s
encoded 1442 frames, 36.05 fps, 3960.35 kb/s
encoded 1442 frames, 35.93 fps, 3959.58 kb/s
encoded 1442 frames, 36.05 fps, 3959.86 kb/s
System Details
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Name AMD Processor
Codename
Codename
Codename
Codename
Codename
Codename
Codename
Codename
Specification AMD FX(tm)-8150 Eight-Core Processor
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Stepping
Core Speed 3612.2 MHz
Core Speed 3612.6 MHz
Core Speed 3612.4 MHz
Core Speed 3611.6 MHz
Core Speed 3612.5 MHz
Core Speed 3612.3 MHz
Core Speed 3611.7 MHz
Northbridge AMD 890FX rev. 02
Cycle Time (tRAS) 20
Memory Type DDR3
Channels Dual
Windows Version Microsoft Windows 7 (6.1) Service Pack 1 (Build 7601)
Number of processors 8
Number of threads 8
Number of threads 1 (max 1)
L2 cache 2048 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP
Package
Package
Package
Package
Package
Package
Package
Package
Temperature 0 48°C (118°F) [0x30] (CPU)
Temperature 1 38°C (100°F) [0x26] (Mainboard)
Temperature 0 42°C (107°F) [0x2A] (SB)
Temperature 1 51°C (123°F) [0x33] (NB)
Гробы разработчиков надо делать круглыми, чтоб переворачиваться было удобно!
На 4,5GHz
Pass 1
encoded 1442 frames, 137.02 fps, 3911.61 kb/s
encoded 1442 frames, 136.22 fps, 3911.61 kb/s
encoded 1442 frames, 138.18 fps, 3911.61 kb/s
encoded 1442 frames, 138.33 fps, 3911.61 kb/s
Pass 2
encoded 1442 frames, 42.22 fps, 3958.76 kb/s
encoded 1442 frames, 42.05 fps, 3959.45 kb/s
encoded 1442 frames, 42.22 fps, 3960.31 kb/s
encoded 1442 frames, 42.26 fps, 3959.17 kb/s
System Details
Name AMD FX-8150
Name AMD Radeon HD 6900 Series
Codename Zambezi
Core Stepping OR-B2
Technology 32 nm
Stock frequency 3600 MHz
Core Speed 1404.7 MHz
Memory Frequency 802.7 MHz (1:4)
Memory Type DDR3
Channels Dual
Number of threads 8
Number of threads 8 (max 8)
L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
Package Socket AM3+ (942)
Package Type 0x1
Temperature 0 46°C (114°F) [0x2E] (CPU)
Temperature 0 43°C (109°F) [0x2B] (TMPIN0)
Alexandr82 писал(а):
На 4,5GHz
где-то на 6 Ггц догонит интел :writer:
http://audio-hi-end.livejournal.com/profile Аудиоэкспертиза - это не слух, а анализ услышанного
cron
