Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 19 из 20 • <  1 ... 16  17  18  19  20  >
Фото: 17
a8 3500m 2.2gnz,6gb 9-9-9-24 1T 1333,6650m 600/900,вин 7 х64
x264 HD BENCHMARK 4.0 RESULTS
Please do NOT compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
to http://forums.techarp.com/reviews-artic ... 4-0-a.html
Results for x264.exe r1913
Pass 1
encoded 1442 frames, 76.42 fps, 3912.32 kb/s
encoded 1442 frames, 75.97 fps, 3912.32 kb/s
encoded 1442 frames, 76.57 fps, 3912.32 kb/s
encoded 1442 frames, 76.59 fps, 3912.32 kb/s
Pass 2
encoded 1442 frames, 15.05 fps, 3961.21 kb/s
encoded 1442 frames, 15.02 fps, 3961.30 kb/s
encoded 1442 frames, 15.00 fps, 3961.21 kb/s
encoded 1442 frames, 14.99 fps, 3961.62 kb/s
System Details
3D Mark06 (8800gts) ~16k on Win 7 x64
Фото: 17
x6 1045@3820 ddr3 1893 9 11 10 28 1t win7 sp1 x64
x264 HD BENCHMARK 5.0 RESULTS
to http://forums.techarp.com/reviews-artic ... 5-0-a.html
Results for x264.exe r2200
x264 Benchmark: 64-bit
Pass 1
encoded 11812 frames, 35.54 fps, 7754.03 kb/s
encoded 11812 frames, 35.58 fps, 7754.13 kb/s
encoded 11812 frames, 35.58 fps, 7754.12 kb/s
encoded 11812 frames, 35.57 fps, 7754.14 kb/s
Pass 2
encoded 11812 frames, 13.04 fps, 8001.96 kb/s
encoded 11812 frames, 13.04 fps, 8001.97 kb/s
encoded 11812 frames, 13.06 fps, 8002.02 kb/s
System Details
Name AMD Phenom II X6 1045T
Codename Thuban
Specification AMD Phenom(tm) II X6 1045T Processor
Core Stepping PH-E0
Technology 45 nm
Stock frequency 2700 MHz
Core Speed 1135.8 MHz
FID range 4.0x - 16.0x
Northbridge AMD RD9x0 rev. 02
Southbridge AMD SB910/950 rev. 40
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 10
Cycle Time (tRAS) 28
Command Rate (CR) 1T
Memory Frequency 946.5 MHz (3:10)
Memory Type DDR3
Memory Size 8192 MBytes
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
Number of processors 1
Number of threads 6
Number of threads 6 (max 6)
L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
Package Socket AM3 (938)
Package Type 0x1
Temperature 0 51°C (123°F) [0x33] (CPU)
Temperature 1 26°C (78°F) [0x1A] (Mainboard)
у меня так #77 37,11fps за 1:08
2х xeon E5 2470(ES), 4gbx4 ddr3 1600(только 2 канала из 3)
40.55
http://rghost.ru/44200807/image.png
Overclocked Tester
Intel Siler DX79SR BIOS 0553
Intel Core i7-3970X Extreme Edition @4.8GHz 1.38V
4x4GB Mushkin RedLine 2133 MHz (9-11-10-28_1T)
Windows 7 x64
x264 HD Benchmark 5.0.1
Pass 1
encoded 11812 frames, 120.07 fps, 7756.83 kb/s
encoded 11812 frames, 120.15 fps, 7757.10 kb/s
encoded 11812 frames, 120.28 fps, 7756.81 kb/s
encoded 11812 frames, 119.81 fps, 7756.83 kb/s
Pass 2
encoded 11812 frames, 26.26 fps, 8000.19 kb/s
encoded 11812 frames, 26.25 fps, 8000.21 kb/s
encoded 11812 frames, 26.19 fps, 8000.24 kb/s
encoded 11812 frames, 26.29 fps, 8000.19 kb/s
MSI MPG Z790 Edge WiFi | Intel Core i9-13900K
ASUS ROG Strix X870E-E Gaming WiFi | AMD Ryzen 9 9950X
https://t.me/bench_and_play
Фото: 17
AMD Phenom II X6:
x264 Benchmark v5.0.1
Republic of Gamers
Фото: 17
Intel Core i7 3930K :
Republic of Gamers
3930K @4223MHz (offset -0,050v)
Zalman CNPS12X + Coollaboratory Liquid Pro
ASUS P9X79 (bios 4005)
RAM 32Gb @1923MHz Corsair Vengeance CMZ32GX3M4X1600C10 (10-12-11-27-1)
encoded 2500 frames, 33.36 fps, 22397.57 kb/s
x264 [info]: encoding duration 0:01:15
Фото: 15
Pentium II 300/AMD Duron 700/Core 2 Duo E8400/Core i7-920/Core i5-2500k/Core i7-4790k/Core i7-10700k/AMD 9800X3D
Pass 1
encoded 1442 frames, 89.92 fps, 3909.88 kb/s
encoded 1442 frames, 90.01 fps, 3909.88 kb/s
encoded 1442 frames, 89.74 fps, 3909.88 kb/s
encoded 1442 frames, 89.92 fps, 3909.79 kb/s
Pass 2
encoded 1442 frames, 17.11 fps, 3962.53 kb/s
encoded 1442 frames, 17.15 fps, 3962.67 kb/s
encoded 1442 frames, 17.14 fps, 3962.63 kb/s
encoded 1442 frames, 17.03 fps, 3962.70 kb/s
System Details
Name Intel Pentium G3420
Name Intel(R) HD Graphics
Codename Haswell
Specification Intel(R) Pentium(R) CPU G3420 @ 3.20GHz
Technology 22 nm
manufacturer Gigabyte Technology Co., Ltd.
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 32-bit Service Pack 1 (Build 7601)
Temperature 0 27°C (80°F) [0x1B] (TMPIN0)
Temperature 1 25°C (76°F) [0x19] (TMPIN1)
Temperature 2 28°C (82°F) [0x1C] (TMPIN2)
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
AMD Athlon II 455x3@B55x4 unlock 3.3@3.95Ghz Win 7 64
x264 Benchmark HD 2.0
Results for x264.exe v0.58.747
encoded 1442 frames, 81.05 fps, 3905.42 kb/s
encoded 1442 frames, 79.19 fps, 3905.42 kb/s
encoded 1442 frames, 80.92 fps, 3905.42 kb/s
encoded 1442 frames, 79.39 fps, 3905.42 kb/s
encoded 1442 frames, 20.90 fps, 3952.85 kb/s
encoded 1442 frames, 20.87 fps, 3952.85 kb/s
encoded 1442 frames, 20.61 fps, 3952.85 kb/s
encoded 1442 frames, 20.75 fps, 3952.85 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 79.62 fps, 3891.55 kb/s
encoded 1442 frames, 79.34 fps, 3891.55 kb/s
encoded 1442 frames, 80.92 fps, 3889.35 kb/s
encoded 1442 frames, 79.38 fps, 3891.55 kb/s
encoded 1442 frames, 22.12 fps, 3963.43 kb/s
encoded 1442 frames, 22.15 fps, 3963.43 kb/s
encoded 1442 frames, 22.12 fps, 3963.51 kb/s
encoded 1442 frames, 21.97 fps, 3963.43 kb/s
x264 Benchmark HD 5.0.1
Pass 1
encoded 11812 frames, 31.61 fps, 7753.03 kb/s
encoded 11812 frames, 30.18 fps, 7753.00 kb/s
encoded 11812 frames, 31.88 fps, 7752.91 kb/s
encoded 11812 frames, 31.69 fps, 7752.93 kb/s
Pass 2
encoded 11812 frames, 8.74 fps, 8002.54 kb/s
encoded 11812 frames, 8.72 fps, 8002.55 kb/s
encoded 11812 frames, 8.77 fps, 8002.55 kb/s
encoded 11812 frames, 8.76 fps, 8002.55 kb/s
System Details
Name AMD K10
Codename
Specification AMD Phenom(tm) II X4 B55 Processor
Core Stepping
Stock frequency 3300 MHz
Core Speed 3959.9 MHz (16.5 x 240.0 MHz)
FID range 5.0x - 16.5x
Northbridge ATI RD770 rev. 00
Southbridge ATI SB700 rev. 40
CAS# 8.0
RAS# to CAS# 8
RAS# Precharge 8
Cycle Time (tRAS) 24
Command Rate 2T
Memory Frequency 800.0 MHz (3:10)
Memory Type DDR3
Memory Size 4094 MBytes
Channels Single
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition Service Pack 1 (Build 7601)
max VID 1.350 V
Voltage sensor 0 1.55 Volts [0x61] (CPU VCORE)
Number of threads 4
Number of threads 4 (max 4)
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Package Socket AM2+ (940)
Package Type 0x1
В простое 55°C пишет на ядрах кому интересно =)
Temperature sensor 0 48°C (118°F) [0x30] (TMPIN0)
Temperature sensor 1 67°C (152°F) [0x43] (TMPIN1)
Temperature sensor 2 95°C (202°F) [0x5F] (TMPIN2)
Temperature sensor 0 86°C (185°F) [0x2AC] (core #0)
Temperature sensor 1 86°C (185°F) [0x2AC] (core #1)
Temperature sensor 3 86°C (185°F) [0x2AC] (core #3)
Temperature sensor 2 86°C (185°F) [0x2AC] (core #2)
Temperature sensor 0 45°C (112°F) [0x2D] (GPU Core)
AMD FX-9590
ASUS Crosshair V Formula-Z
Patriot Viper Xtreme Division 2 PXD38G2400C11K 2x4GB DDR3 2400MHz
SAPPHIRE HD 6990 4GB GDDR5 880/1250MHz
Windows 8.1 x64 Pro
Гробы разработчиков надо делать круглыми, чтоб переворачиваться было удобно!
Intel 2600K
ASUS P8Z77-V Deluxe
G.Skill RipjawsX CL9-11-10-28 2x4GB DDR3 2133MHz
Windows 8.1 x64
افتوفاز: الأخبار السيئة - الانفجار. والخبر السار - كل دمرت
Фото: 22
Intel Xeon E5620 @3990Mhz 210*19, Asus P6X58D Premium
3x2Gb DDR3-1687 8-8-7-24, Windows 8.1 x64 Pro Update1
20.21 fps, 22399.00 kb/s
Intel Xeon E5620 @ 3.78GHz ( 4C / 8T )
x264 0.119.2106kMod 07efeb4
(libswscale 2.1.0)
(libavformat 53.17.0)
(ffmpegsource 2.16.2.1)
built by Komisar on Oct 23 2011, gcc: 4.4.7 20110720 (prerelease) (x86_64.generic.Komisar)
configuration: --bit-depth=8 --chroma-format=all
x264 license: GPL version 2 or later
libswscale/libavformat/ffmpegsource license: GPL version 2 or later
ffms [info]: 1920x1080p 1:1 @ 50/1 fps (vfr)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264 [info]: profile High, level 4.2
x264 [info]: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 fade_compensate=0.00 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0000 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
x264 [info]: started at Tue Sep 16 19:57:24 2014
x264 [info]: frame I:10 Avg QP:25.24 size:293382
x264 [info]: frame P:1242 Avg QP:28.43 size: 90351
x264 [info]: frame B:1248 Avg QP:31.32 size: 19907
x264 [info]: consecutive B-frames: 8.7% 66.6% 23.2% 1.6%
x264 [info]: mb I I16..4: 3.6% 76.6% 19.8%
x264 [info]: mb P I16..4: 0.1% 4.7% 0.8% P16..4: 38.2% 25.5% 16.0% 0.0% 0.0% skip:14.7%
x264 [info]: mb B I16..4: 0.0% 0.4% 0.0% B16..8: 48.1% 6.2% 1.9% direct: 4.2% skip:39.1% L0:36.0% L1:49.9% BI:14.1%
x264 [info]: 8x8 transform intra:83.2% inter:58.4%
x264 [info]: coded y,uvDC,uvAC intra: 90.8% 82.8% 56.9% inter: 30.4% 19.6% 4.0%
x264 [info]: i16 v,h,dc,p: 17% 37% 10% 36%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 25% 16% 5% 7% 6% 12% 6% 12%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 21% 13% 7% 8% 7% 11% 7% 11%
x264 [info]: i8c dc,h,v,p: 52% 26% 15% 7%
x264 [info]: Weighted P-Frames: Y:1.0% UV:0.1%
x264 [info]: ref P L0: 70.4% 21.8% 5.9% 2.0% 0.0%
x264 [info]: ref B L0: 90.8% 7.8% 1.4%
x264 [info]: ref B L1: 95.6% 4.4%
x264 [info]: kb/s:22399.00
encoded 2500 frames, 20.21 fps, 22399.00 kb/s
x264 [info]: ended at Tue Sep 16 19:59:27 2014
x264 [info]: encoding duration 0:02:03
#77 #77
Фото: 77
X5670 @ 4400 Mhz
http://valid.canardpc.com/v0pw6y http://valid.canardpc.com/kq21c1 http://valid.x86.fr/3jg01g
Belarus OC Team
i7-4790k@4500Mhz
pass1 69.43 pass2 18.27
E5-2676V3@2700Mhz
pass1 100.36 pass2 31.66
Ultra 285K 5.8P 5.2E / Apex Z890 / 48Gb ADATA 9200@9333CL40 / RTX5080 Gigabyte/ Watercooling
i7 4770K @4.5GHz
Фильтрами ЛС было удалено личных сообщений: ...
i7-6700k @4.4Ghz FHD
benchmark 1.0.1#77
i7-6700k @4.4Ghz x264 HD BENCHMARK 5.0
Pass 1
encoded 11812 frames, 104.69 fps, 7753.92 kb/s
encoded 11812 frames, 104.66 fps, 7753.90 kb/s
encoded 11812 frames, 103.50 fps, 7754.09 kb/s
encoded 11812 frames, 105.64 fps, 7754.26 kb/s
Pass 2
encoded 11812 frames, 21.19 fps, 8002.30 kb/s
encoded 11812 frames, 21.18 fps, 8002.24 kb/s
encoded 11812 frames, 21.37 fps, 8002.11 kb/s
encoded 11812 frames, 21.42 fps, 8002.27 kb/s
System Details
Name Intel Processor
product System Product Name
Codename
Specification Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Core Stepping
Core Speed 4011.7 MHz
Northbridge Intel ID191F rev. 07
Southbridge Intel IDA145 rev. 31
Memory Type
Memory Size 32626 MBytes
Windows Version Microsoft Windows 8 (6.2) 64-bit (Build 9200)
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 4-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA
Package
Temperature 0 40°C (103°F) [0x28] (SYSTIN)
Temperature 1 55°C (130°F) [0x6D] (CPUTIN)
MSI PRO X670-P WIFI, 7950x, 64GB 6000 cl32
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 34
