Статус: Не в сети Регистрация: 20.09.2013 Откуда: Беларусь
Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data to http://x265.ru/x265-hd-benchmark/.html
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x265.exe build 1.4+5 x265 Benchmark: 64-bit ==========================
CRF-20 preset-"fast" -------------------- encoded 1128 frames in 80.09s (14.08 fps), 2266.68 kb/s encoded 1128 frames in 79.83s (14.13 fps), 2266.68 kb/s encoded 1128 frames in 79.53s (14.18 fps), 2266.68 kb/s encoded 1128 frames in 80.02s (14.10 fps), 2266.68 kb/s
System Details -------------- Name AMD FX-8320 Codename Vishera Specification AMD FX(tm)-8320 Eight-Core Processor Core Stepping OR-C0 Technology 32 nm Stock frequency 3700 MHz Core Speed 4512.3 MHz
TSC! Russia member
Статус: Не в сети Регистрация: 20.10.2014 Фото: 14
8370 на заводской частоте.
Код:
x265 HD BENCHMARK 0.1.4 RESULTS
CRF-20 preset-"fast" -------------------- encoded 1128 frames in 86.23s (13.08 fps), 2266.68 kb/s encoded 1128 frames in 85.89s (13.13 fps), 2266.68 kb/s encoded 1128 frames in 85.81s (13.14 fps), 2266.68 kb/s encoded 1128 frames in 85.98s (13.12 fps), 2266.68 kb/s
System Details -------------- Name AMD FX-8370 Codename Vishera Specification AMD FX-8370 Eight-Core Processor Core Stepping OR-C0 Technology 32 nm Stock frequency 4000 MHz Core Speed 4114.0 MHz
CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Memory Frequency 802.7 MHz (1:4) Memory Type DDR3 Memory Size 16284 MBytes Channels Dual
Windows Version Microsoft Windows 8.1 (6.3) 64-bit (Build 9600)
Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4 Package Socket AM3+ (942) Package Type 0x1
Temperature 0 64°C (147°F) [0x40] (CPU) Temperature 1 37°C (98°F) [0x25] (Mainboard)
_________________ TSC! Russia - добровольные распределённые вычисления. Не используемые мощности твоего ПК могут помочь науке и людям в борьбе с тяжелыми заболеваниями.
CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Memory Frequency 840.1 MHz (1:4) Memory Type DDR3 Memory Size 8168 MBytes Channels Dual
Windows Version Microsoft Windows 8.1 (6.3) Enterprise Edition 64-bit (Build 9600)
Temperature 0 37°C (98°F) [0x25] (TMPIN0) Temperature 1 47°C (116°F) [0x2F] (TMPIN1) Temperature 2 38°C (100°F) [0x26] (TMPIN2)
Добавлено спустя 12 минут 17 секунд: targitaj:тротлинг скорее всего изза температуры vrm -у меня на 4620 происходит точно такое же -но температура за 71 не уходит ,что норма для жтих процов в принципе -а вот питальник раскален
Статус: Не в сети Регистрация: 17.02.2008 Откуда: Москва Фото: 12
i5 3570K @ 4545 13,25 FPS
CRF-20 preset-"fast" -------------------- encoded 1128 frames in 85.23s (13.23 fps), 2266.68 kb/s encoded 1128 frames in 85.13s (13.25 fps), 2266.68 kb/s encoded 1128 frames in 85.11s (13.25 fps), 2266.68 kb/s encoded 1128 frames in 84.95s (13.28 fps), 2266.68 kb/s
System Details -------------- Name Intel Core i5 3570K Codename Ivy Bridge Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Core Stepping E1/L1 Technology 22 nm Stock frequency 3400 MHz Core Speed 1615.7 MHz
CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 27 Command Rate (CR) 1T Memory Frequency 908.9 MHz (1:9) Memory Type DDR3 Memory Size 8140 MBytes Channels Dual
Windows Version Microsoft Windows NT10.0 (Build 10240)
Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1)
Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 44°C (111°F) [0x58] (CPUTIN) Temperature 3 35°C (94°F) [0x23] (TMPIN3)
Intel Xeon E5450 @ 3780 7,44 FPS
CRF-20 preset-"fast" -------------------- encoded 1128 frames in 151.59s (7.44 fps), 2266.68 kb/s encoded 1128 frames in 151.38s (7.45 fps), 2266.68 kb/s encoded 1128 frames in 152.96s (7.37 fps), 2266.68 kb/s encoded 1128 frames in 151.09s (7.47 fps), 2266.68 kb/s
System Details -------------- Name Intel Xeon E5450 Codename Harpertown Specification Intel(R) Xeon(R) CPU E5450 @ 3.00GHz Core Stepping E0 Technology 45 nm Stock frequency 3000 MHz Core Speed 3779.8 MHz FID range 6.0x - 9.0x
CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 19 Command Rate (CR) 2T Memory Frequency 420.0 MHz (1:1) Memory Type DDR2 Memory Size 6 GBytes Channels Dual, (Symmetric)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 771 LGA (0x6)
Temperature 0 43°C (109°F) [0x2B] (TMPIN0) Temperature 1 40°C (103°F) [0x28] (TMPIN1) Temperature 2 -1°C (28°F) [0xFE] (TMPIN2)
_________________ I am only the NoIsE on the WiReS! Z80 -> i386 40 -> Am100 -> P100 -> Cel.667 -> Cel.Tualatin1,2 -> XeonE5450 (sold), профильные =)
CRF-20 preset-"fast" -------------------- encoded 1128 frames in 64.08s (17.60 fps), 2266.68 kb/s encoded 1128 frames in 64.10s (17.60 fps), 2266.68 kb/s encoded 1128 frames in 64.13s (17.59 fps), 2266.68 kb/s encoded 1128 frames in 64.24s (17.56 fps), 2266.68 kb/s
System Details -------------- Name Intel Core i3/i5/i7 5xxx Codename Broadwell Specification Intel(R) Core(TM) i7-5775C CPU @ 3.30GHz Core Stepping Technology 14 nm Stock frequency 3300 MHz Core Speed 799.8 MHz
Прогнал на Athlon2 X4 3.7Ghz сей бенч...в процессе консоль командной строки демонстрировала показатели менее 2 фпс. Ждать финала не стал...что за? Интел кор2квад на 2Ghz (профильный Xeon e5405) выдает 4 fps Помогите понять в чем загвоздка? Неужели к10.5 нет какой-то оптимизации (поддержки каких-то инструкций) под данный кодер? По сравнению с квадом разве что sse4.1 нет.
Вот резалт Xeon e5405 2Ghz:
CRF-20 preset-"fast" -------------------- encoded 1128 frames in 277.59s (4.06 fps), 2266.68 kb/s encoded 1128 frames in 278.10s (4.06 fps), 2266.68 kb/s encoded 1128 frames in 276.79s (4.08 fps), 2266.68 kb/s encoded 1128 frames in 277.02s (4.07 fps), 2266.68 kb/s
System Details -------------- Name Intel Xeon E5405 Codename Harpertown Specification Intel(R) Xeon(R) CPU E5405 @ 2.00GHz Core Stepping E0 Technology 45 nm Stock frequency 2000 MHz Core Speed 1999.9 MHz
CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 400.0 MHz (5:6) Memory Type DDR2 Memory Size 4 GBytes Channels Dual, (Symmetric)
Temperature 0 53°C (127°F) [0x35] (TMPIN0) Temperature 1 -2°C (26°F) [0xFD] (TMPIN1) Temperature 2 51°C (123°F) [0x33] (TMPIN2)
Вот пентиум г3258 4.48Ghz (+ddr3 1993 10-10-10-28):
CRF-20 preset-"fast" -------------------- encoded 1128 frames in 140.31s (8.04 fps), 2266.23 kb/s encoded 1128 frames in 141.16s (7.99 fps), 2266.23 kb/s encoded 1128 frames in 140.24s (8.04 fps), 2266.23 kb/s encoded 1128 frames in 140.10s (8.05 fps), 2266.23 kb/s
System Details -------------- Name Intel Pentium G3258 Codename Haswell Specification Intel(R) Pentium(R) CPU G3258 @ 3.20GHz Core Stepping C0 Technology 22 nm Stock frequency 3200 MHz Core Speed 996.8 MHz
CAS# latency (CL) 10.0 RAS# to CAS# delay (tRCD) 10 RAS# Precharge (tRP) 10 Cycle Time (tRAS) 28 Command Rate (CR) 1T Memory Frequency 996.9 MHz (1:6) Memory Type DDR3 Memory Size 8142 MBytes Channels Dual
Windows Version Microsoft Windows 8 (6.2) 64-bit (Build 9200)
Number of processors 1 Number of threads 2 Number of threads 2 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1150 LGA (0x1)
Temperature 0 41°C (105°F) [0x29] (SYSTIN) Temperature 3 39°C (102°F) [0x27] (TMPIN3) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Сравнил два окна для случая с Xeon e5405 и Athlon2 X4
Там есть список поддерживаемых инструкций процессором...для Xeon все нормально - SSE3, SSE4 - все на месте. #77 Для атлон эта строчка выглядит как MMX, SSE2...и всё. #77
Видимо прога не определяет более прогрессивных инструкций, которые этот проц поддерживает. Полный список симд расширений для K10.5 такой: MMX, 3DNow!, SSE, SSE2, SSE3, SSE4a У Xeon e5405 (архитектура C2D) MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1
