Статус: Не в сети Регистрация: 09.04.2011 Фото: 10
На GTX 970 видит только 2,8 Гб
Result
Код:
"e:\Hardware\oclmembench\bin64">OclMemBench.exe p 2 d 1 s 128 r 2 a f stop OpenCL memory test. Build 15.01.29. https://github.com/duzenko/OpenclMemBench Init OpenCL... Create platforms... [1] AMD Accelerated Parallel Processing [2] NVIDIA CUDA Using platform NVIDIA CUDA Enumerate devices... [1] GeForce GTX 970 (13 compute units) Using device GeForce GTX 970. Memory available 1024 MB of 4096MB Chunk size: 128 MB. Repeats: 2. Allocating chunk 32 User stop after memory alloc. Press ENTER to continue...
Chunk 1 0 MB 1.5 ms 84.9 GB/s TRUE Chunk 1 0 MB 0.8 ms 152.3 GB/s TRUE
Chunk 2 128 MB 1.3 ms 96.5 GB/s TRUE Chunk 2 128 MB 0.8 ms 152.7 GB/s TRUE
Chunk 3 256 MB 1.5 ms 88.2 GB/s TRUE Chunk 3 256 MB 0.9 ms 138.7 GB/s TRUE
Chunk 4 384 MB 1.4 ms 93.2 GB/s TRUE Chunk 4 384 MB 0.9 ms 148.7 GB/s TRUE
Chunk 5 512 MB 1.6 ms 82.5 GB/s TRUE Chunk 5 512 MB 0.9 ms 147.5 GB/s TRUE
Chunk 6 640 MB 1.4 ms 89.5 GB/s TRUE Chunk 6 640 MB 1.2 ms 110.7 GB/s TRUE
Chunk 7 768 MB 1.4 ms 88.5 GB/s TRUE Chunk 7 768 MB 0.8 ms 151.4 GB/s TRUE
Chunk 8 896 MB 1.4 ms 88.5 GB/s TRUE Chunk 8 896 MB 0.9 ms 148.9 GB/s TRUE
Chunk 9 1024 MB 1.4 ms 93.5 GB/s TRUE Chunk 9 1024 MB 0.9 ms 138.4 GB/s TRUE
Chunk 10 1152 MB 1.4 ms 93.4 GB/s TRUE Chunk 10 1152 MB 0.9 ms 150.4 GB/s TRUE
Chunk 11 1280 MB 1.4 ms 93.8 GB/s TRUE Chunk 11 1280 MB 0.8 ms 151.4 GB/s TRUE
Chunk 12 1408 MB 1.3 ms 99.4 GB/s TRUE Chunk 12 1408 MB 1.0 ms 128.4 GB/s TRUE
Chunk 13 1536 MB 1.4 ms 90.5 GB/s TRUE Chunk 13 1536 MB 0.9 ms 149.0 GB/s TRUE
Chunk 14 1664 MB 1.5 ms 87.6 GB/s TRUE Chunk 14 1664 MB 0.9 ms 145.3 GB/s TRUE
Chunk 15 1792 MB 1.4 ms 88.8 GB/s TRUE Chunk 15 1792 MB 1.0 ms 132.7 GB/s TRUE
Chunk 16 1920 MB 1.3 ms 95.4 GB/s TRUE Chunk 16 1920 MB 0.8 ms 152.2 GB/s TRUE
Chunk 17 2048 MB 1.3 ms 95.8 GB/s TRUE Chunk 17 2048 MB 1.0 ms 127.5 GB/s TRUE
Chunk 18 2176 MB 1.5 ms 87.5 GB/s TRUE Chunk 18 2176 MB 0.9 ms 149.1 GB/s TRUE
Chunk 19 2304 MB 1.5 ms 85.9 GB/s TRUE Chunk 19 2304 MB 0.9 ms 146.6 GB/s TRUE
Chunk 20 2432 MB 1.3 ms 95.4 GB/s TRUE Chunk 20 2432 MB 0.9 ms 134.8 GB/s TRUE
Chunk 21 2560 MB 1.5 ms 83.8 GB/s TRUE Chunk 21 2560 MB 0.8 ms 151.1 GB/s TRUE
Chunk 22 2688 MB 1.4 ms 90.1 GB/s TRUE Chunk 22 2688 MB 0.9 ms 148.0 GB/s TRUE
Chunk 23 2816 MB 1.5 ms 83.7 GB/s TRUE Chunk 23 2816 MB 0.9 ms 148.7 GB/s TRUE
Chunk 24 2944 MB 0.0 ms 3601.8 GB/s FALSE Chunk 24 2944 MB 0.0 ms 4126.3 GB/s FALSE
Chunk 25 3072 MB 0.0 ms 3695.7 GB/s FALSE Chunk 25 3072 MB 0.0 ms 4271.5 GB/s FALSE
Chunk 26 3200 MB 0.0 ms 3728.2 GB/s FALSE Chunk 26 3200 MB 0.0 ms 4250.1 GB/s FALSE
Chunk 27 3328 MB 0.0 ms 3695.7 GB/s FALSE Chunk 27 3328 MB 0.0 ms 4229.0 GB/s FALSE
Chunk 28 3456 MB 0.0 ms 3761.1 GB/s FALSE Chunk 28 3456 MB 0.0 ms 4166.8 GB/s FALSE
Chunk 29 3584 MB 0.0 ms 3761.1 GB/s FALSE Chunk 29 3584 MB 0.0 ms 4271.5 GB/s FALSE
Chunk 30 3712 MB 0.0 ms 3761.1 GB/s FALSE Chunk 30 3712 MB 0.0 ms 4250.1 GB/s FALSE
Chunk 31 3840 MB 0.0 ms 3695.7 GB/s FALSE Chunk 31 3840 MB 0.0 ms 4187.3 GB/s FALSE
Chunk 32 3968 MB 0.0 ms 3695.7 GB/s FALSE Chunk 32 3968 MB 0.0 ms 4208.0 GB/s FALSE
duzenko, ой ((. Зачем сделал _две_ строки, когда и одна то используется не полностью. Можно было выдать в виде XXX/YYY, как для времени, так и для скорости.
Код:
Chunk 10 1152 MB 1.4/0.9 ms 93.4/128.4 GB/s TRUE
Добавлено спустя 3 минуты 6 секунд: Кстати, по точности. Нет никакого смысла выдавать дробную часть, если число >99 Т.е. количество значащих цифр не должно быть чрезмерным - трех более чем достаточно.
32 версия заработала. результаты последних ~100 метров низкие из за того что они сожраны виндой. псп в тесте 108 gb/s, в gpu-z 160 gb/s. Как я понял gpu-z показывает тупо калькулированный псп (256/8)*(1250*4)=160000
Статус: Не в сети Регистрация: 11.11.2005 Откуда: VoID
На R9 290 тест в 32 бит не видит всю память (только 3072 мб), 64 валится в сегфолт, но видит память. Подумал, может проблема в 64 битных библиотеках опенцл, скачал последний APP SDK, не помогло. Может быть у дельфи какие-то проблемы с 64 битными указателями? В ней есть аналог size_t?
Статус: Не в сети Регистрация: 08.08.2010 Откуда: РФ
Херня тест. Гоняю сейчас в Мидл Ес Шадоу оф Мордор, памяти 2960, фризов ноль. Частота кадров стабильно на 59 (залочено) и время кадра 16.949. Настройками довёл потребление до 2400 - те же 59 кадров и те же 16.949.
_________________ Невозможно пить мало,изменять жене в пределах разумного.Нет золотой середины при определении степени порочности.Нельзя деградировать в меру
