Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 389 • Страница 5 из 20<  1  2  3  4  5  6  7  8 ... 20  >
x264 HD BENCHMARK RESULTS
Please copy/paste everything below the line into the forum post to report your data
Results for x264.exe v0.58.747
encoded 1442 frames, 47.32 fps, 3906.89 kb/s
encoded 1442 frames, 48.02 fps, 3906.89 kb/s
encoded 1442 frames, 48.07 fps, 3906.89 kb/s
encoded 1442 frames, 48.11 fps, 3906.89 kb/s
encoded 1442 frames, 10.94 fps, 3944.00 kb/s
encoded 1442 frames, 10.97 fps, 3944.00 kb/s
encoded 1442 frames, 10.98 fps, 3944.00 kb/s
System Details
Name AMD Phenom
Codename Deneb
Specification AMD Processor model unknown
Core Stepping
Technology 45 nm
Core Speed 2813.0 MHz (14.0 x 200.9 MHz)
Northbridge NVIDIA nForce 570 SLI rev. A2
Southbridge NVIDIA nForce 570 SLI rev. A3
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 18
Command Rate 2T
Memory Frequency 401.9 MHz (1:2)
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual (Unganged)
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7100)
Voltage sensor 0 1.17 Volts [0x49] (CPU VCORE)
Number of processors 1
Number of threads 3
Number of threads 3 (max 3)
L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature sensor 0 44°C (111°F) [0x2C] (TMPIN0)
Temperature sensor 1 32°C (89°F) [0x20] (TMPIN1)
Temperature sensor 2 43°C (109°F) [0x2B] (TMPIN2)
Temperature sensor 0 33°C (91°F) [0x10A] (core #0)
Temperature sensor 1 33°C (91°F) [0x109] (core #1)
Temperature sensor 2 34°C (92°F) [0x10C] (core #2)
Temperature sensor 0 46°C (114°F) [0x2E] (GPU Core)
ф95-9600 без разгона, смысла в кастрированных нет, если только вполцены.
http://audio-hi-end.livejournal.com/profile Аудиоэкспертиза - это не слух, а анализ услышанного
encoded 1442 frames, 59.14 fps, 3904.67 kb/s
encoded 1442 frames, 59.87 fps, 3904.67 kb/s
encoded 1442 frames, 59.83 fps, 3904.67 kb/s
encoded 1442 frames, 61.05 fps, 3904.67 kb/s
encoded 1442 frames, 17.98 fps, 3952.97 kb/s
encoded 1442 frames, 17.97 fps, 3952.97 kb/s
encoded 1442 frames, 17.83 fps, 3952.97 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 65.65 fps, 3889.34 kb/s
encoded 1442 frames, 64.50 fps, 3889.34 kb/s
encoded 1442 frames, 65.47 fps, 3889.34 kb/s
encoded 1442 frames, 65.70 fps, 3889.34 kb/s
encoded 1442 frames, 19.96 fps, 3962.75 kb/s
encoded 1442 frames, 19.86 fps, 3962.76 kb/s
encoded 1442 frames, 20.09 fps, 3962.76 kb/s
encoded 1442 frames, 20.10 fps, 3962.75 kb/s
System Details
Name Intel Core 2 Quad Q8300
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Core Stepping
Technology 45 nm
Stock frequency 2500 MHz
Core Speed 3149.9 MHz (7.5 x 420.0 MHz)
FID range 6.0x - 7.5x
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 420.0 MHz (1:1)
Memory Type DDR2
Memory Size 8190 MBytes
Channels Dual (Symmetric)
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 2 (Build 6002)
max VID 1.250 V
Voltage sensor 0 1.28 Volts [0x50] (CPU VCORE)
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 45°C (112°F) [0x2D] (CPU)
Temperature sensor 1 49°C (120°F) [0x31] (System)
Temperature sensor 0 70°C (157°F) [0x23] (core #0)
Temperature sensor 1 64°C (147°F) [0x29] (core #1)
Temperature sensor 2 69°C (156°F) [0x24] (core #2)
Temperature sensor 3 70°C (157°F) [0x23] (core #3)
Temperature sensor 0 78°C (172°F) [0x4E] (GPU Core)
Это со средним разгоном, так сказать, без изысков особых :)
encoded 1442 frames, 88.88 fps, 3904.94 kb/s
encoded 1442 frames, 88.37 fps, 3904.94 kb/s
encoded 1442 frames, 88.62 fps, 3904.94 kb/s
encoded 1442 frames, 88.63 fps, 3904.94 kb/s
encoded 1442 frames, 30.11 fps, 3974.08 kb/s
encoded 1442 frames, 30.24 fps, 3974.08 kb/s
encoded 1442 frames, 30.14 fps, 3974.08 kb/s
encoded 1442 frames, 30.07 fps, 3974.08 kb/s
encoded 1442 frames, 94.96 fps, 3894.31 kb/s
encoded 1442 frames, 93.25 fps, 3894.31 kb/s
encoded 1442 frames, 92.85 fps, 3895.56 kb/s
encoded 1442 frames, 92.26 fps, 3895.56 kb/s
encoded 1442 frames, 33.47 fps, 3981.71 kb/s
encoded 1442 frames, 33.54 fps, 3981.71 kb/s
encoded 1442 frames, 33.44 fps, 3981.22 kb/s
encoded 1442 frames, 33.32 fps, 3981.30 kb/s
System Details
Name Intel Core 2
Codename Nehalem
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Engineering Sample)
Core Stepping
Technology 45 nm
Core Speed 3599.9 MHz (18.0 x 200.0 MHz)
Northbridge Intel ID3405 rev. 12
Southbridge Intel ID3A16 rev. 00
Memory Type
Memory Size 12286 MBytes
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 3 (Build 6001)
max VID 0.825 V
Voltage sensor 0 1.26 Volts [0x4F] (CPU VCORE)
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Package (platform ID = 1h)
Temperature sensor 0 38°C (100°F) [0x26] (TMPIN0)
Temperature sensor 1 53°C (127°F) [0x35] (TMPIN1)
Temperature sensor 2 45°C (112°F) [0x2D] (TMPIN2)
Temperature sensor 0 73°C (163°F) [0x20] (core #0)
Temperature sensor 1 74°C (165°F) [0x1F] (core #1)
Temperature sensor 2 73°C (163°F) [0x20] (core #2)
Temperature sensor 3 73°C (163°F) [0x20] (core #3)
Temperature sensor 0 44°C (111°F) [0x2C] (GPU Core)
Temperature sensor 0 49°C (120°F) [0x31] (GPU Core)
i5-13600k, giga z790ud, 2*16gb@6666, 3080, 27"ips 2k
Armen ты уже в таблицу не влазишь http://www.techarp.com/x264_Benchmark/hd//results-1.htm :beer:
6a3apoB Не очень-то и хочется. Могу и на 4200 с смт прогнать... Только толку не вижу... :) (табличка-то древняя, i7 не наблюдается :) )
Код:
encoded 1442 frames, 80.52 fps, 3904.94 kb/s
encoded 1442 frames, 82.31 fps, 3904.94 kb/s
encoded 1442 frames, 80.45 fps, 3904.94 kb/s
encoded 1442 frames, 28.04 fps, 3974.08 kb/s
encoded 1442 frames, 27.97 fps, 3974.08 kb/s
encoded 1442 frames, 27.99 fps, 3974.08 kb/s
encoded 1442 frames, 27.95 fps, 3974.08 kb/s
encoded 1442 frames, 84.57 fps, 3895.56 kb/s
encoded 1442 frames, 84.34 fps, 3895.56 kb/s
encoded 1442 frames, 84.03 fps, 3895.56 kb/s
encoded 1442 frames, 83.57 fps, 3895.56 kb/s
encoded 1442 frames, 31.15 fps, 3981.30 kb/s
encoded 1442 frames, 31.13 fps, 3981.22 kb/s
encoded 1442 frames, 31.24 fps, 3981.22 kb/s
encoded 1442 frames, 31.29 fps, 3981.22 kb/s
System Details
Name         Intel Core 2
Codename      Nehalem
Specification      Intel(R) Core(TM) i7 CPU         975  @ 3.33GHz (Engineering Sample)
Core Stepping
Technology      45 nm
Core Speed      3474.6 MHz (26.0 x 133.6 MHz)
Memory Type
Memory Size      2040 MBytes
Windows Version      Microsoft Windows Vista (6.0) Ultimate Edition  Service Pack 1 (Build 6001)
max VID         0.825 V
Voltage sensor 0   1.22 Volts [0x98] (CPU VCORE)
Number of threads   8
Temperature sensor 0   41°C (105°F) [0x29] (SYSTIN)
Temperature sensor 1   51°C (123°F) [0x66] (CPUTIN)
Temperature sensor 2   6°C (42°F) [0x1F4] (AUXTIN)
Temperature sensor 0   63°C (145°F) [0x2A] (core #0)
Temperature sensor 1   63°C (145°F) [0x2A] (core #1)
Temperature sensor 2   63°C (145°F) [0x2A] (core #2)
Temperature sensor 3   62°C (143°F) [0x2B] (core #3)
Temperature sensor 0   84°C (183°F) [0x54] (GPU Core)
Bishounen™
Intel™
Компонентный ремонт ноутбуков.
Восстановление данных.
Быстро=дорого)
encoded 1442 frames, 94.26 fps, 3904.94 kb/s
encoded 1442 frames, 92.45 fps, 3904.94 kb/s
encoded 1442 frames, 93.95 fps, 3904.94 kb/s
encoded 1442 frames, 94.92 fps, 3904.94 kb/s
encoded 1442 frames, 32.53 fps, 3974.08 kb/s
encoded 1442 frames, 32.17 fps, 3974.08 kb/s
encoded 1442 frames, 32.47 fps, 3974.08 kb/s
encoded 1442 frames, 32.48 fps, 3974.08 kb/s
encoded 1442 frames, 99.61 fps, 3894.31 kb/s
encoded 1442 frames, 100.09 fps, 3893.98 kb/s
encoded 1442 frames, 100.12 fps, 3894.62 kb/s
encoded 1442 frames, 100.16 fps, 3894.31 kb/s
encoded 1442 frames, 36.30 fps, 3981.71 kb/s
encoded 1442 frames, 36.34 fps, 3981.60 kb/s
encoded 1442 frames, 36.31 fps, 3981.65 kb/s
encoded 1442 frames, 36.33 fps, 3981.71 kb/s
System Details
Core i7 920 @ 3800 HT on
RAM 2*2 @1520(8.8.8.25)
http://allprojectstats.com/sigr1626103x-40.png
Overhlopec
Кто нибудь может подсказать. У меня тест проходит, все отлично, результаты есть но они висят в досовском окне, а файл с результатами не создается. В этом же окне видно как при создании лога идут ошибки вместо итоговых цифр там надписи "файл уже создан или задано не правильное имя файла" или что то типа того. Можно как то исправить, в принципе, надо только для удобства т.к. вместо лога приходится самому просматривать сколько и чего там накодировалось )
Ryzen 7 7700 ✔ Asus TUF Gaming B650M+ ✔ 32GB RAM【7200 MHz】 ✔ Gigabyte RTX 5060Ti【16 GB】 ✔ 31.5"【2560x1440, 165 Hz, VA】
encoded 1442 frames, 44.37 fps, 3904.07 kb/s
encoded 1442 frames, 44.37 fps, 3905.09 kb/s
encoded 1442 frames, 44.41 fps, 3904.01 kb/s
encoded 1442 frames, 44.35 fps, 3905.10 kb/s
encoded 1442 frames, 11.37 fps, 3942.33 kb/s
encoded 1442 frames, 11.37 fps, 3942.06 kb/s
encoded 1442 frames, 11.38 fps, 3942.30 kb/s
encoded 1442 frames, 11.35 fps, 3942.91 kb/s
encoded 1442 frames, 50.10 fps, 3886.98 kb/s
encoded 1442 frames, 50.24 fps, 3887.05 kb/s
encoded 1442 frames, 50.13 fps, 3888.48 kb/s
encoded 1442 frames, 50.21 fps, 3887.30 kb/s
encoded 1442 frames, 12.79 fps, 3955.22 kb/s
encoded 1442 frames, 12.80 fps, 3953.36 kb/s
encoded 1442 frames, 12.80 fps, 3953.37 kb/s
encoded 1442 frames, 12.79 fps, 3953.37 kb/s
System Details
Name Intel Core 2 Duo E8500
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
Core Stepping E0
Technology 45 nm
Stock frequency 3166 MHz
Core Speed 3808.0 MHz (8.0 x 476.0 MHz)
FID range 6.0x - 9.5x
Northbridge Intel P965/G965 rev. C1
Southbridge Intel 82801HB/HR (ICH8/R) rev. 02
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Command Rate 2T
Memory Frequency 476.0 MHz (1:1)
Memory Type DDR2
Memory Size 3072 MBytes
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
max VID 1.175 V
Voltage sensor 0 1.07 Volts [0x86] (CPU VCORE)
Number of threads 2
Number of threads 2 (max 2)
L2 cache 6144 KBytes, 24-way set associative, 64-byte line size
Package Socket 775 LGA (platform ID = 0h)
Temperature sensor 1 62°C (142°F) [0x7B] (CPUTIN)
Temperature sensor 0 62°C (143°F) [0x2B] (core #0)
Temperature sensor 1 58°C (136°F) [0x2F] (core #1)
Temperature sensor 0 51°C (122°F) [0x32] (GPU Core)
Intel Core 2 Quad Q9550@3833.8 MHz (8.5 x 451.0 MHz)
Код:
encoded 1442 frames, 80.18 fps, 3905.42 kb/s
encoded 1442 frames, 81.31 fps, 3905.42 kb/s
encoded 1442 frames, 80.88 fps, 3905.42 kb/s
encoded 1442 frames, 81.52 fps, 3905.42 kb/s
encoded 1442 frames, 22.77 fps, 3952.85 kb/s
encoded 1442 frames, 22.79 fps, 3952.85 kb/s
encoded 1442 frames, 22.75 fps, 3952.85 kb/s
encoded 1442 frames, 87.98 fps, 3888.04 kb/s
encoded 1442 frames, 87.64 fps, 3889.29 kb/s
encoded 1442 frames, 87.89 fps, 3887.35 kb/s
encoded 1442 frames, 87.72 fps, 3886.76 kb/s
encoded 1442 frames, 25.63 fps, 3963.19 kb/s
encoded 1442 frames, 25.61 fps, 3962.92 kb/s
encoded 1442 frames, 25.61 fps, 3963.52 kb/s
encoded 1442 frames, 25.63 fps, 3963.50 kb/s
System Details
Name         Intel Core 2 Quad Q9550
Codename      Yorkfield
Specification      Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz
Core Stepping      E0
Technology      45 nm
Stock frequency      2833 MHz
Core Speed      3833.8 MHz (8.5 x 451.0 MHz)
FID range      6.0x - 8.5x
CAS#         5.0
RAS# to CAS#      5
RAS# Precharge      5
Command Rate      2T
Memory Frequency   451.0 MHz (1:1)
Memory Type      DDR2
max VID         1.150 V
Voltage sensor 0   1.34 Volts [0xA8] (CPU VCORE)
Number of threads   4
L2 cache      2 x 6144 KBytes, 24-way set associative, 64-byte line size
Temperature sensor 0   35°C (94°F) [0x23] (SYSTIN)
Temperature sensor 1   75°C (166°F) [0x96] (CPUTIN)
Temperature sensor 2   125°C (256°F) [0xF9] (AUXTIN)
Temperature sensor 0   83°C (181°F) [0x16] (core #0)
Temperature sensor 1   77°C (170°F) [0x1C] (core #1)
Temperature sensor 2   82°C (179°F) [0x17] (core #2)
Temperature sensor 3   81°C (177°F) [0x18] (core #3)
Temperature sensor 0   36°C (96°F) [0x24] (GPU Core)
Фото: 6
encoded 1442 frames, 97.30 fps, 3905.42 kb/s
encoded 1442 frames, 96.49 fps, 3905.42 kb/s
encoded 1442 frames, 96.39 fps, 3905.42 kb/s
encoded 1442 frames, 96.38 fps, 3905.42 kb/s
encoded 1442 frames, 26.62 fps, 3952.85 kb/s
encoded 1442 frames, 26.78 fps, 3952.85 kb/s
encoded 1442 frames, 26.75 fps, 3952.85 kb/s
encoded 1442 frames, 26.66 fps, 3952.85 kb/s
encoded 1442 frames, 102.59 fps, 3891.55 kb/s
encoded 1442 frames, 103.51 fps, 3891.55 kb/s
encoded 1442 frames, 103.40 fps, 3891.55 kb/s
encoded 1442 frames, 29.71 fps, 3963.43 kb/s
encoded 1442 frames, 29.90 fps, 3963.43 kb/s
encoded 1442 frames, 29.94 fps, 3963.44 kb/s
encoded 1442 frames, 29.87 fps, 3963.43 kb/s
System Details
Name Intel Core 2
Codename
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz (Engineering Sample)
Core Stepping
Core Speed 3999.9 MHz (20.0 x 200.0 MHz)
Northbridge Intel IDD131 rev. 11
Southbridge Intel ID3B02 rev. 05
Memory Type
Memory Size 3580 MBytes
Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 2 (Build 6002)
max VID 0.825 V
Number of threads 4
Number of threads 4 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Temperature sensor 0 41°C (105°F) [0x29] (TMPIN0)
Temperature sensor 1 25°C (76°F) [0x19] (TMPIN1)
Temperature sensor 2 55°C (130°F) [0x37] (TMPIN2)
Temperature sensor 0 69°C (156°F) [0x24] (core #0)
Temperature sensor 1 67°C (152°F) [0x26] (core #1)
Temperature sensor 2 70°C (157°F) [0x23] (core #2)
Temperature sensor 3 65°C (148°F) [0x28] (core #3)
Temperature sensor 0 57°C (134°F) [0x39] (GPU Core)
Код:
encoded 1442 frames, 81.58 fps, 3905.42 kb/s
encoded 1442 frames, 82.09 fps, 3905.42 kb/s
encoded 1442 frames, 82.17 fps, 3905.42 kb/s
encoded 1442 frames, 82.39 fps, 3905.42 kb/s
encoded 1442 frames, 23.17 fps, 3952.85 kb/s
encoded 1442 frames, 23.23 fps, 3952.85 kb/s
encoded 1442 frames, 23.15 fps, 3952.85 kb/s
encoded 1442 frames, 23.22 fps, 3952.85 kb/s
encoded 1442 frames, 88.03 fps, 3891.55 kb/s
encoded 1442 frames, 87.62 fps, 3891.55 kb/s
encoded 1442 frames, 89.65 fps, 3891.55 kb/s
encoded 1442 frames, 89.39 fps, 3891.55 kb/s
encoded 1442 frames, 25.90 fps, 3963.44 kb/s
encoded 1442 frames, 25.97 fps, 3963.44 kb/s
encoded 1442 frames, 25.94 fps, 3963.43 kb/s
encoded 1442 frames, 25.95 fps, 3963.43 kb/s
System Details
   Core Stepping      B1
   Stock frequency      2666 MHz
   Core Speed      3486.1 MHz
Northbridge         Intel DMI Host Bridge rev. 11
Southbridge         Intel P55 rev. 05
CAS# latency (CL)      9.0
RAS# to CAS# delay (tRCD)   9
RAS# Precharge (tRP)      9
Cycle Time (tRAS)      24
Command Rate (CR)      1T
Memory Frequency      664.0 MHz (2:8)
Memory Type         DDR3
Memory Size         4092 MBytes
Channels         Dual
Windows Version         Microsoft Windows 7 (6.1) Ultimate Edition   (Build 7600)
Number of threads      4
   Package (platform ID)   Socket 1156 LGA (0x1)
   Temperature 0   36°C (96°F) [0x24] (TMPIN0)
   Temperature 1   25°C (76°F) [0x19] (TMPIN1)
   Temperature 2   65°C (148°F) [0x41] (TMPIN2)
   Temperature 0   74°C (165°F) [0x19] (Core #0)
   Temperature 1   73°C (163°F) [0x1A] (Core #1)
   Temperature 2   70°C (157°F) [0x1D] (Core #2)
   Temperature 3   70°C (157°F) [0x1D] (Core #3)
   Temperature 0   62°C (143°F) (GPU Core)
и тест в x264_Benchmark_HD_v3.0
Код:
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 82.53 fps, 3901.21 kb/s
encoded 1442 frames, 83.42 fps, 3900.68 kb/s
encoded 1442 frames, 82.97 fps, 3900.68 kb/s
encoded 1442 frames, 83.13 fps, 3900.68 kb/s
encoded 1442 frames, 26.15 fps, 3971.07 kb/s
encoded 1442 frames, 26.06 fps, 3971.90 kb/s
encoded 1442 frames, 26.39 fps, 3971.69 kb/s
encoded 1442 frames, 26.35 fps, 3971.84 kb/s
System Details
   Name         Intel Core i5 750
   Codename      Lynnfield
   Core Stepping      B1
   Technology      45 nm
   manufacturer      Gigabyte Technology Co., Ltd.
   vendor         Gigabyte Technology Co., Ltd.
   Core Speed      3485.9 MHz
Memory Type         DDR3
Channels         Dual
Number of threads      4
   Temperature 0   35°C (94°F) [0x23] (TMPIN0)
   Temperature 2   60°C (139°F) [0x3C] (TMPIN2)
   Temperature 0   68°C (154°F) [0x1F] (Core #0)
   Temperature 1   70°C (157°F) [0x1D] (Core #1)
   Temperature 2   66°C (150°F) [0x21] (Core #2)
   Temperature 3   64°C (147°F) [0x23] (Core #3)
V3.0 на частоте 3.6 с шиной 200, сразу видно, что кулер слабоват
Код:
encoded 1442 frames, 82.98 fps, 3900.68 kb/s
encoded 1442 frames, 85.83 fps, 3900.68 kb/s
encoded 1442 frames, 84.57 fps, 3900.68 kb/s
encoded 1442 frames, 85.43 fps, 3900.68 kb/s
encoded 1442 frames, 27.04 fps, 3970.68 kb/s
encoded 1442 frames, 27.26 fps, 3971.75 kb/s
encoded 1442 frames, 27.08 fps, 3971.56 kb/s
encoded 1442 frames, 27.17 fps, 3972.06 kb/s
System Details
   Codename      Lynnfield
   Core Speed      3600.0 MHz
   Temperature 0   38°C (100°F) [0x26] (TMPIN0)
   Temperature 2   76°C (168°F) [0x4C] (TMPIN2)
   Temperature 0   79°C (174°F) [0x14] (Core #0)
   Temperature 1   85°C (184°F) [0xE] (Core #1)
   Temperature 2   73°C (163°F) [0x1A] (Core #2)
   Temperature 3   79°C (174°F) [0x14] (Core #3)
Код:
encoded 1442 frames, 82.36 fps, 3905.42 kb/s
encoded 1442 frames, 82.43 fps, 3905.42 kb/s
encoded 1442 frames, 81.86 fps, 3905.42 kb/s
encoded 1442 frames, 81.69 fps, 3905.42 kb/s
encoded 1442 frames, 23.80 fps, 3952.85 kb/s
encoded 1442 frames, 23.82 fps, 3952.85 kb/s
encoded 1442 frames, 23.76 fps, 3952.85 kb/s
encoded 1442 frames, 89.06 fps, 3891.55 kb/s
encoded 1442 frames, 89.69 fps, 3891.55 kb/s
encoded 1442 frames, 85.85 fps, 3891.55 kb/s
encoded 1442 frames, 87.46 fps, 3891.55 kb/s
encoded 1442 frames, 26.70 fps, 3963.43 kb/s
encoded 1442 frames, 26.35 fps, 3963.43 kb/s
encoded 1442 frames, 26.48 fps, 3963.43 kb/s
encoded 1442 frames, 25.60 fps, 3963.43 kb/s
System Details
Codename      Yorkfield
Core Stepping
Technology      45 nm
Core Speed      4080.1 MHz (8.5 x 480.0 MHz)
Northbridge      Intel ID2E20 rev. 02
Memory Type
Memory Size      4094 MBytes
max VID         1.275 V
Voltage sensor 0   1.36 Volts [0x55] (CPU VCORE)
Number of threads   4
Temperature sensor 0   43°C (109°F) [0x2B] (TMPIN0)
Temperature sensor 1   56°C (132°F) [0x38] (TMPIN1)
Temperature sensor 2   46°C (114°F) [0x2E] (TMPIN2)
Temperature sensor 1   61°C (141°F) [0x2C] (core #1)
Temperature sensor 2   71°C (159°F) [0x22] (core #2)
Temperature sensor 3   67°C (152°F) [0x26] (core #3)
Temperature sensor 0   45°C (112°F) [0x2D] (GPU Core)
Код:
encoded 1442 frames, 81.98 fps, 3900.68 kb/s
encoded 1442 frames, 82.52 fps, 3901.21 kb/s
encoded 1442 frames, 81.74 fps, 3900.68 kb/s
encoded 1442 frames, 82.13 fps, 3900.68 kb/s
encoded 1442 frames, 27.01 fps, 3971.50 kb/s
encoded 1442 frames, 26.97 fps, 3971.55 kb/s
encoded 1442 frames, 27.10 fps, 3972.08 kb/s
encoded 1442 frames, 27.08 fps, 3971.65 kb/s
System Details
   Codename      Yorkfield
   Core Stepping      E0
   Technology      45 nm
Northbridge         Intel P45/P43/G45/G43 rev. A2
Southbridge         Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL)      5.0
RAS# to CAS# delay (tRCD)   5
RAS# Precharge (tRP)      5
Command Rate (CR)      2T
Memory Frequency      480.0 MHz (1:1)
Memory Type         DDR2
Channels         Dual, (Symmetric)
Number of threads      4
   Package (platform ID)   Socket 775 LGA (0x4)
   Temperature 0   43°C (109°F) [0x2B] (TMPIN0)
   Temperature 1   53°C (127°F) [0x35] (TMPIN1)
   Temperature 2   47°C (116°F) [0x2F] (TMPIN2)
   Temperature 0   63°C (145°F) [0x25] (Core #0)
   Temperature 1   54°C (129°F) [0x2E] (Core #1)
   Temperature 2   62°C (143°F) [0x26] (Core #2)
   Temperature 3   59°C (138°F) [0x29] (Core #3)
Фото: 41
Только что прогнал бенчмарк версии x264_Benchmark_HD_v3.01, процессор Core i7 920@4200МГц, память 3Гб 1600МГц, 7-7-7-20 - номинал, вот результаты -
encoded 1442 frames, 100.57 fps, 3901.21 kb/s
encoded 1442 frames, 100.61 fps, 3900.68 kb/s
encoded 1442 frames, 100.99 fps, 3901.21 kb/s
encoded 1442 frames, 99.58 fps, 3900.68 kb/s
encoded 1442 frames, 31.49 fps, 3971.13 kb/s
encoded 1442 frames, 31.69 fps, 3971.99 kb/s
encoded 1442 frames, 31.75 fps, 3971.12 kb/s
encoded 1442 frames, 31.69 fps, 3972.16 kb/s
System Details
Name Intel Core i7 920
product System Product Name
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 4200.0 MHz
Northbridge Intel X58 rev. 12
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Memory Frequency 800.0 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 4
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 49°C (120°F) [0x31] (SYSTIN)
Temperature 1 52°C (124°F) [0x67] (CPUTIN)
Temperature 2 2°C (34°F) [0x3] (AUXTIN)
Temperature 0 62°C (143°F) [0x26] (Core #0)
Temperature 1 66°C (150°F) [0x22] (Core #1)
Temperature 2 64°C (147°F) [0x24] (Core #2)
Temperature 3 60°C (139°F) [0x28] (Core #3)
Что скажете?
Albatron 8800GTX&MSI 8800GTS 512@пали смертью храбрых! Killer=nVidia OverGuru!
"Team Russia"
AMD Athlon(tm) II X3 435 Processor
encoded 1442 frames, 43.27 fps, 3906.89 kb/s
encoded 1442 frames, 43.93 fps, 3906.89 kb/s
encoded 1442 frames, 44.42 fps, 3906.89 kb/s
encoded 1442 frames, 44.72 fps, 3906.89 kb/s
encoded 1442 frames, 10.56 fps, 3944.00 kb/s
encoded 1442 frames, 10.59 fps, 3944.00 kb/s
encoded 1442 frames, 10.63 fps, 3944.00 kb/s
encoded 1442 frames, 46.33 fps, 3890.01 kb/s
encoded 1442 frames, 46.85 fps, 3890.01 kb/s
encoded 1442 frames, 46.47 fps, 3890.01 kb/s
encoded 1442 frames, 46.45 fps, 3890.01 kb/s
encoded 1442 frames, 11.48 fps, 3957.59 kb/s
encoded 1442 frames, 11.33 fps, 3957.59 kb/s
encoded 1442 frames, 11.41 fps, 3957.59 kb/s
encoded 1442 frames, 11.42 fps, 3957.61 kb/s
System Details
Name AMD K10
Codename
Specification AMD Athlon(tm) II X3 435 Processor
Core Stepping
Stock frequency 2900 MHz
Core Speed 2900.0 MHz (14.5 x 200.0 MHz)
FID range 5.0x - 14.5x
Northbridge AMD ID9601 rev. 00
Southbridge ATI SB700 rev. 00
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 400.0 MHz (1:2)
Memory Type DDR2
Memory Size 896 MBytes
Channels Single
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7600)
max VID 1.425 V
Voltage sensor 0 1.34 Volts [0x54] (CPU VCORE)
Number of threads 3
Package Type 0x1
Temperature sensor 0 52°C (125°F) [0x34] (TMPIN0)
Temperature sensor 1 49°C (120°F) [0x31] (TMPIN1)
Temperature sensor 0 50°C (121°F) [0x190] (core #0)
Temperature sensor 1 50°C (121°F) [0x190] (core #1)
Temperature sensor 2 50°C (121°F) [0x190] (core #2)
Добавлено спустя 2 минуты 43 секунды:
AMD Athlon(tm) II X3 435 Processor стоимостью 90 дол. с разблокированным 4 ядром и с разгоном.
encoded 1442 frames, 57.41 fps, 3905.42 kb/s
encoded 1442 frames, 57.85 fps, 3905.42 kb/s
encoded 1442 frames, 63.01 fps, 3905.42 kb/s
encoded 1442 frames, 62.37 fps, 3905.42 kb/s
encoded 1442 frames, 17.66 fps, 3952.85 kb/s
encoded 1442 frames, 17.88 fps, 3952.85 kb/s
encoded 1442 frames, 17.98 fps, 3952.85 kb/s
encoded 1442 frames, 17.87 fps, 3952.85 kb/s
encoded 1442 frames, 62.88 fps, 3891.55 kb/s
encoded 1442 frames, 63.01 fps, 3891.55 kb/s
encoded 1442 frames, 63.88 fps, 3891.55 kb/s
encoded 1442 frames, 63.70 fps, 3891.55 kb/s
encoded 1442 frames, 19.09 fps, 3963.43 kb/s
encoded 1442 frames, 19.06 fps, 3963.43 kb/s
System Details
Name AMD K10
Codename
Specification AMD Phenom(tm) II X4 B35 Processor
Core Stepping
Core Speed 3552.3 MHz (14.5 x 245.0 MHz)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 408.3 MHz (3:5)
Memory Type DDR2
Channels Single
max VID 1.425 V
Voltage sensor 0 1.47 Volts [0x5C] (CPU VCORE)
Number of threads 4
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Package Type 0x1
Temperature sensor 0 72°C (161°F) [0x48] (TMPIN0)
Temperature sensor 1 50°C (121°F) [0x32] (TMPIN1)
Temperature sensor 0 0°C (32°F) [0x0] (core #0)
Temperature sensor 1 0°C (32°F) [0x0] (core #1)
Temperature sensor 2 0°C (32°F) [0x0] (core #2)
Temperature sensor 3 0°C (32°F) [0x0] (core #3)
Попробуй изменить директорию-папку и-или задать другое имя файла , возможно у тебя файлы программы на рабочем столе - возможно путь длинноват
encoded 1442 frames, 40.14 fps, 3905.08 kb/s
encoded 1442 frames, 41.72 fps, 3905.08 kb/s
encoded 1442 frames, 41.67 fps, 3905.08 kb/s
encoded 1442 frames, 41.68 fps, 3905.08 kb/s
encoded 1442 frames, 10.64 fps, 3942.92 kb/s
encoded 1442 frames, 10.66 fps, 3942.92 kb/s
encoded 1442 frames, 10.65 fps, 3942.92 kb/s
encoded 1442 frames, 47.18 fps, 3888.52 kb/s
encoded 1442 frames, 47.18 fps, 3888.12 kb/s
encoded 1442 frames, 47.21 fps, 3889.32 kb/s
encoded 1442 frames, 11.98 fps, 3953.56 kb/s
encoded 1442 frames, 11.99 fps, 3953.45 kb/s
encoded 1442 frames, 12.00 fps, 3953.30 kb/s
encoded 1442 frames, 11.99 fps, 3953.30 kb/s
System Details
Core Stepping C0
Core Speed 3584.0 MHz
FID range 6.0x - 8.0x
Memory Frequency 560.0 MHz (4:5)
Memory Type DDR2
Memory Size 2048 MBytes
Number of threads 2
Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 35°C (94°F) [0x23] (System)
Temperature 1 42°C (107°F) [0x2A] (CPU)
Temperature 0 54°C (129°F) [0x2E] (Core #0)
Temperature 1 56°C (132°F) [0x2C] (Core #1)
Temperature 0 46°C (114°F) (GPU Core)
Fortuna non penis, in manus non recepi.
encoded 1442 frames, 72.11 fps, 3905.42 kb/s
encoded 1442 frames, 77.62 fps, 3905.42 kb/s
encoded 1442 frames, 78.12 fps, 3905.42 kb/s
encoded 1442 frames, 77.66 fps, 3905.42 kb/s
encoded 1442 frames, 19.63 fps, 3952.85 kb/s
encoded 1442 frames, 19.65 fps, 3952.85 kb/s
encoded 1442 frames, 19.67 fps, 3952.85 kb/s
encoded 1442 frames, 74.77 fps, 3891.55 kb/s
encoded 1442 frames, 77.69 fps, 3891.55 kb/s
encoded 1442 frames, 78.00 fps, 3891.55 kb/s
encoded 1442 frames, 77.70 fps, 3891.55 kb/s
encoded 1442 frames, 21.06 fps, 3963.43 kb/s
encoded 1442 frames, 21.02 fps, 3963.43 kb/s
encoded 1442 frames, 21.05 fps, 3963.43 kb/s
System Details
Name AMD Phenom
Codename Deneb
Specification AMD Phenom(tm) II X4 920 Processor
Core Stepping
Technology 45 nm
Stock frequency 2800 MHz
Core Speed 3612.3 MHz (14.0 x 258.0 MHz)
FID range 5.0x - 14.0x
Northbridge ATI RD790 rev. 00
Southbridge ATI SB600 rev. 00
CAS# 6.0
RAS# to CAS# 6
RAS# Precharge 6
Command Rate 2T
Memory Frequency 516.0 MHz (1:2)
Memory Type DDR2
Memory Size 8192 MBytes
Channels Dual (Ganged)
max VID 1.350 V
Number of threads 4
Package Type 0x1
Temperature sensor 0 48°C (118°F) [0x30] (TMPIN0)
Temperature sensor 1 35°C (94°F) [0x23] (TMPIN1)
Temperature sensor 1 51°C (122°F) [0x194] (core #1)
Temperature sensor 2 51°C (122°F) [0x194] (core #2)
Temperature sensor 3 51°C (122°F) [0x194] (core #3)
Temperature sensor 0 42°C (107°F) [0x2A] (GPU Core)
encoded 1442 frames, 42.92 fps, 3899.26 kb/s
encoded 1442 frames, 43.12 fps, 3899.26 kb/s
encoded 1442 frames, 42.98 fps, 3899.26 kb/s
encoded 1442 frames, 43.23 fps, 3899.26 kb/s
encoded 1442 frames, 10.46 fps, 3971.21 kb/s
encoded 1442 frames, 10.45 fps, 3970.65 kb/s
encoded 1442 frames, 10.14 fps, 3970.81 kb/s
encoded 1442 frames, 10.45 fps, 3970.91 kb/s
System Details
Name Intel Core 2 Duo E6550
Codename Conroe
Specification Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz
Core Stepping G0
Technology 65 nm
Manufacturer (ID) Micron Technology (2C00000000000000)
Stock frequency 2333 MHz
Core Speed 11600.1 MHz :haha:
FID range 6.0x - 7.0x
Memory Frequency 1657.2 MHz (1:1)
Memory Type DDR2
Number of threads 2
L2 cache 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Temperature 0 35°C (94°F) [0x23] (SYSTIN)
Temperature 1 48°C (118°F) [0x60] (CPUTIN)
Temperature 2 9°C (48°F) [0x12] (AUXTIN)
Temperature 1 62°C (143°F) [0x26] (Core #1)
Разгон проца не увидел ибо тогда 11,6ГГц - новый мировой рекорд. На самом деле у меня Е6550@2333МГц aka 3.22ГГц
Лучшая зашита - это нападение.
Вот мои данные.
encoded 1442 frames, 68.52 fps, 3904.94 kb/s
encoded 1442 frames, 69.45 fps, 3904.94 kb/s
encoded 1442 frames, 69.14 fps, 3904.94 kb/s
encoded 1442 frames, 68.37 fps, 3904.94 kb/s
encoded 1442 frames, 23.89 fps, 3974.08 kb/s
encoded 1442 frames, 23.93 fps, 3974.08 kb/s
encoded 1442 frames, 24.02 fps, 3974.08 kb/s
encoded 1442 frames, 24.00 fps, 3974.08 kb/s
encoded 1442 frames, 71.93 fps, 3894.31 kb/s
encoded 1442 frames, 73.13 fps, 3894.31 kb/s
encoded 1442 frames, 73.71 fps, 3894.31 kb/s
encoded 1442 frames, 72.56 fps, 3895.56 kb/s
encoded 1442 frames, 26.86 fps, 3981.71 kb/s
encoded 1442 frames, 26.80 fps, 3981.71 kb/s
encoded 1442 frames, 26.82 fps, 3981.71 kb/s
encoded 1442 frames, 26.83 fps, 3981.30 kb/s
System Details
Name Intel Core 2
Codename Nehalem
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Engineering Sample) :?:
Core Stepping
Technology 45 nm
Core Speed 2803.5 MHz (21.0 x 133.5 MHz)
Northbridge Intel ID3405 rev. 13
Memory Type
Memory Size 4088 MBytes
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition х64 (Build 7600)
max VID 0.825 V
Voltage sensor 0 1.24 Volts [0x9B] (CPU VCORE)
Number of threads 8
Temperature sensor 1 63°C (145°F) [0x7E] (CPUTIN)
Temperature sensor 2 43°C (108°F) [0x55] (AUXTIN)
Temperature sensor 0 76°C (168°F) [0x1D] (core #0)
Temperature sensor 0 54°C (129°F) [0x36] (GPU Core)
