Graphic card name and driver used: NVIDIA GeForce 7800 GTX Version [6.14.10.8390]
CPU name: AMD Athlon(tm) 64 FX-55 Processor Family 7 Model 7
Video settings during benchmark:
Screen resolution: 1280 x 1024 * [32]
using shader profile: 3.0
Antialias Mode: 4x
Anisotropic Mode: 16x
Graphic & Shader settings
Texture quality: high
Shader quality: high
High quality bumpmaps: enabled
Environment map: enabled
Postprocessing: enabled
using 16bit vertex format: yes
Framerates
Scene 00 47.9 average fps 37.0 minimum fps 72.0 maximum fps
Scene 01 39.3 average fps 15.0 minimum fps 80.0 maximum fps
Scene 02 48.6 average fps 37.0 minimum fps 77.0 maximum fps
Scene 03 60.7 average fps 30.0 minimum fps 136.0 maximum fps
Статус: Не в сети Регистрация: 06.01.2005 Фото: 0
X3 - Reunion
Game version: 1.3.0.US
Graphic card name and driver used: RADEON X800 Series Version [6.14.10.6587]
CPU name: Intel(R) Pentium(R) 4 CPU 3.20GHz Family 7 Model 4
Screen resolution: 1024 x 768 * [32]
using shader profile: 2.b
Antialias Mode: NONE
Anisotropic Mode: NONE
Framerates
Scene 00 46.4 average fps 42.0 minimum fps 74.0 maximum fps
Scene 01 44.6 average fps 17.0 minimum fps 77.0 maximum fps
Scene 02 58.2 average fps 47.0 minimum fps 93.0 maximum fps
Scene 03 65.4 average fps 43.0 minimum fps 113.0 maximum fps
Статус: Не в сети Регистрация: 03.07.2003 Откуда: Выборг, ЛО Фото: 4
Kuja , у меня с твоими настройками вот чего получилось
X3 - Reunion
Framerates
Scene 00 71.7 average fps 66.0 minimum fps 103.0 maximum fps
Scene 01 39.8 average fps 16.0 minimum fps 80.0 maximum fps
Scene 02 84.7 average fps 58.0 minimum fps 119.0 maximum fps
Scene 03 83.6 average fps 52.0 minimum fps 163.0 maximum fps
Сейчас этот форум просматривают: FoxhaunD, TJS, tqran и гости: 17
