FINAL FANTASY XIV: A Realm Reborn Official Benchmark (Exploration) Tested on:23/02/2013 08:30:49 Score:5716 Average Framerate:50.762 Performance:Very High -Easily capable of running the game. Should perform exceptionally well, even at higher resolutions.
Screen Size: 1280x720 Graphics Presets: Maximum General -Improve overall graphic quality. : Enabled -Disable rendering of objects when not visible. (Occlusion Culling) : Disabled -Use low-detail models on distant objects to increase performance. (LOD) : Disabled -Cache LOD data only when necessary. (LOD Streaming) : Disabled -Smooth edges. (Anti-aliasing) : Enabled -Increase transparent lighting quality. : Enabled -Grass Quality : High Shadows -Use low-detail models on shadows to increase performance. (LOD) : Disabled -Display : All -Shadow Resolution : High: 2048 pixels -Shadow Cascading : High -Shadow Softening : High Texture Detail -Texture Filtering : High -Anisotropic Filtering : High Effects -Naturally darken the edges of the screen. (Limb Darkening) : Enabled -Blur the graphics around an object in motion. (Radial Blur) : Enabled -Effects While in Motion : Display All -Screen Space Ambient Occlusion : High -Glare : Normal Cinematic Cutscenes -Enable depth of field. : Enabled
System: Windows 7 Максимальная 32-разрядная (6.1, сборка 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431) Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz 3391.043MB NVIDIA GeForce GTX 460(VRAM 2417 MB) 9.18.0013.1407
Benchmark results do not provide any guarantee FINAL FANTASY XIV: A Realm Reborn will run on your system.
Overclocked Tester
Статус: Не в сети Регистрация: 06.01.2009 Откуда: Россия, Иваново
Razorvashka Тестировал этот бенч 21-го. Полная ерунда и просто никакая нагрузка для современных GPU. Впрочем, от сетевой игры иного ждать и не приходилось. Не тратьте время.
