Статус: Не в сети Регистрация: 21.03.2004 Откуда: Ижевск
VladSoft В своё время я всё из автозагрузки убирал.
Но я пользовался функциональность только драйверов . И дополнительные примочки не ставил.
Только вот я полгода карточкой не пользовался и драйвера потерял . Забыл вобщем всё На другом компе долго работать пришлось...
Статус: Не в сети Регистрация: 26.07.2006 Откуда: Украина
Немного погуглил на эту тему:
CTDetect.exe
Auto-detect and play a DVD when using a Creative Soundblaster Audigy2 soundcard. Uses about 2.2 MB of
memory. Disable it by heading to the MediaSource DVD Audio Player, selecting Tools, then uncheck the
Auto Start box. It should not start up automatically again.
CTDVDDet.exe
Uses about 2.2 MB of memory. Disable it by heading to the MediaSource DVD Audio Player,
selecting Tools, then uncheck the Auto Start box. It should not start up automatically again.
CTHELPER.EXE
CTHELPER is a background task that is a plug-in manager for Creative drivers.
The theory is that 3rd party manufacturers can use the CTHELPER plug-in interface
to produce drivers, add-on features, and fixes that will integrate with a tighter fit
with Creative’s sound drivers and utilities. Given its purpose CTHELPER would normally
be classified as a "leave alone" background task. It also allows Creative speaker setup
to be synchronized with Windows Control Panel speaker setting. Without it running that check
box in Creative speaker setting is not functional (settings are not in sync). Unfortunately
there are often problems with CTHELPER, most notably that it can use 100% of CPU time so it's
best left disabled unless you need it
CTXFIHLP.EXE
Added by the installation of a Creative Labs X-Fi sound card.
This particular process provides the help functionality for your card.
CTXFIREG.exe
Yes you can disable this.I believe the only purpose of this prog.
is to remember you to register your Creative hardware.
UpdReg.exe
Reminder to register Creative Labs SoundBlaster Live! cards.
sbdrvdet.exe
Detects the "Easy Front-Panel Audio Connectivity Drive Internal Drive Bay"
that comes with certain Sound Blaster audio cards.
Can be disabled if you don't use the internal drive bay.
Тоесть реально возможно нужное из этого всего только CTHELPER.EXE, хотя и без него всё работает.
RINDIG, на сайте креатива и так выложен сам драйвер без софта, в комплекте с ним только аудио консоль(которая существенно не влияет на размер дистрибутива).
Статус: Не в сети Регистрация: 14.09.2004 Откуда: //Earth/Eurasia
Привет ребят.
Вопросец. Темку полистал но что то запутался... Я так понял для X-Fi вышел нормальный комплект дров, позволяющий и ЕАХ врубить, и микшер нормальный. В общем все более или менее пучком. А для 2 Аудиги что то подобное есть/предвидится? Без ЕАХа еще как то живу... Но когда даже микшера нет нормального, ни ревербов, ваще ничерта...
Спасибо.
_________________ Мой сайт www.techno-mind.ru - статьи о самоделках, технологиях, моддинге, тюнинге авто и т.д.
Main Character
Статус: В сети Регистрация: 03.12.2004
Для X-Fi есть:
более-менее приличные дрова (но пока не без ошибок, WHQL тоже нет)
весь набор софта (отдельный образ диска)
Alchemy (враппер DS3D>OpenAL, возвращающий EAX в DS3D-играх)
Для Audigy:
дрова похуже (но ничто не мешает поставить и дрова от X-Fi, правда мало что изменится)
софта нет (кое-что работает со старого диска для XP, но этого мало)
Alchemy за деньги - $10
_________________ Исследования показывают, что хранить лестницу в доме опаснее, чем ружье. Поэтому у меня 10 ружей, на случай, если какой-нибудь псих попытается протащить лестницу.
Статус: Не в сети Регистрация: 29.04.2004 Откуда: Holy Land
В факе ответа не нашел!
Объясните как можно сделать так чтоб настройки эквалайзера сохранялись после рестарта системы.
В самом Graphic Equalizer Я настроил как мне надо и сохранил, после рестарта эквалайзер просто не включается, надо зайти в ево панельку и тогда он включается уже с заранее мною сохраненным профилем (причём это слышно очень отчётливо при проигрывание музыки винэмпам, происходит щелчок и эквалайзер включается)
Помогите с проблемой.
Добавлено спустя 2 минуты, 42 секунды PS. сами дрова последние с сайта, а все программки и в частности Graphic Equalizer с диска, так как на них я понял обновлений не было.
_________________ Жизнь - игра: задумана хреново, но графика обалденная
Main Character
В FAQ ответ дан:
Q: При запуске некоторых игр эквалайзер отключается. A: Так как эквалайзер использует ресурсы, которые в играх используются для EAX, то он отключается во время запуска игр с поддержкой EAX. Повторно активировать эквалайзер можно простым его запуском, все его настройки восстанавливаются при этом сами. Решить проблему с эквалайзером совсем можно только выключив поддержку EAX в игре (аппаратное ускорение 3D звука можно оставить).
Просто от рестарта винды эквалайзер НЕ выключается (проверялось специально).
Main Character
Дубль два:
Но полюбому после каждой EAX-игры надо его запускать заново.
А вообще пора уже карту грейдить, у X-Fi этой траблы нет, наряду с другими преимуществами.
В том то и прикол что выкючается, я про Graphic Equalizer а не только Bass Treble, в любом случае ты прав надо
Добавлено спустя 3 минуты, 18 секунд Кстати посоветуй что взять.
Какая разница между X-Fi XtremeMusic и X-Fi XtremeGamer с X-Fi Xtreme Audio кроме цены в два раза.
Main Character
Вероятно мешает какая-то софтина/кодек.
В FAQ по X-Fi все уже есть. А с вопросами в тему выбора звуковух.
Привет всем. Прочитав даную статью http://www.ixbt.com/multimedia/audigy2-value.shtml и есче много чего разного, решил очередной раз поекспериментировать со своей Audigy 2 ZS и обнаружил нечто, что немогу объяснить.
У меня установлены КХ драйвера, музыку слушаю через Foobar.
Если в Foobar выбрать устройство вывода звука "DS : kx Wave 0/1" (тоесть Direct Sound) и формат вывода звука 32 или 24 (но не 16!!! об этом дальше) bit (никаких DSP плагинов как в фубаре так и в драйверах карты НЕТУ), то тестовый файл SB_test.wav (взят из FAQ по Audigy 2 ZS) воспроизводится без "сирены", без "посвистываний" и без "шума"
:eek: это что получается? карта без передискретизации сумела вывести звук 44,1кГц? :eek:
Если изменить только формат вывода звука на 16 bit, то появляэтся эфект "сирены" - тоесть карта апаратно ресемплит.
Main Character
Нечего тут объяснять. С KX ресемплер качественней, только и всего. В том, что 44.1 не поддерживается честно, легко убедиться с помощью RMAA.
4e_alex Подскажи пожалуста как с RMAA определить апаратную передискретизацию? Уже 4 дня мучаю RMAA но никак неразберусь как проверить и на что смотреть.
У меня при разных настройках как Фубара так и КХ драйва возможни следующее:
1. Четко слышно Высокий тон + нету "сирены", нету "посвистываний" и нету "шума"
2. Четко слышно Высокий тон + какойто мягкий(как сглаженый) высокочастотний "шум" (при програмном ресемплере)
3. Четко слышно Высокий тон + какойто жестокий высокочастотний "шум" (при програмном ресемплере)
4. Практически неслышен Высокий тон из-за воющей "сирены"
Отзовитесь пользователи КХ драйверов! Есть несколько вопросов...
Main Character
Выставь в дровах запись со встроенного источника. В RMAA тест IMD (интермодуляционные искажения) с переменной частотой. Если есть подъем искажений в верхней области, значит ресемплинг есть. Пример с X-Fi (в тесте использовался 24 бита/44.1, в дровах опорка на 44.1 - no res или на 48 - res):
Сейчас этот форум просматривают: HipHopSlam и гости: 13
