имеется Linksys WAG325N. прошивака последняя (1.00.12). Работает как модем и вайфай роутер на 3 компа. При включенном файерволе и блокировке анонимных запросов рвется коннект с провайдером. Все приблуды безопасности в данный момент отключены.
Выдержка из лога:
Sat, 2000-01-01 05:59:59 - Gateway start up
Sat, 2000-01-01 06:00:45 - Interface "nas0" created sucessfully
Sat, 2000-01-01 06:00:45 - Communicating over ATM 0.0.40, encapsulation: LLC
Sat, 2000-01-01 06:00:46 - Initialize LCP.
Sat, 2000-01-01 06:00:46 - Plugin pppoe loaded.
Sat, 2000-01-01 06:00:46 - PPPoE Plugin Initialized
Sat, 2000-01-01 06:00:46 - Plugin pppoe called.
Sat, 2000-01-01 06:00:46 - pppd 2.4.1 started by root, uid 0
Sat, 2000-01-01 06:00:46 - setting line discipline hook
Sat, 2000-01-01 06:00:46 - Sending PADI
at, 2000-01-01 06:00:46 - HOST_UNIQ successful match
Sat, 2000-01-01 06:00:46 - Unexpected packet: Ether addr: 00:1d:71:63:a4:1b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0034 (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 10 04 e1 80 PPPoE tag: type=0101 length=0000 (Service nam
Sat, 2000-01-01 06:00:46 - HOST_UNIQ successful match
Sat, 2000-01-01 06:00:46 - Unexpected packet: Ether addr: 00:1d:71:63:a8:1b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x002e (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 10 04 e1 80 PPPoE tag: type=0101 length=0000 (Service nam
Sat, 2000-01-01 06:00:46 - Got connection: 824f
Sat, 2000-01-01 06:00:46 - Connecting PPPoE socket: 00:14:6a:cf:b7:1b 824f nas0 0x1004e180
Sat, 2000-01-01 06:00:46 - using channel 1
Sat, 2000-01-01 06:00:46 - Using interface ppp0
Sat, 2000-01-01 06:00:46 - Connect: ppp0 <--> nas0
Sat, 2000-01-01 06:00:46 - Couldn't increase MTU to 1500.
Sat, 2000-01-01 06:00:46 - Couldn't increase MRU to 1500
Sat, 2000-01-01 06:00:46 - LCP is allowed to come up.
Sat, 2000-01-01 06:00:46 - CHAP authentication success
Sat, 2000-01-01 06:00:46 - local IP address 89.ххх.ххх.ххх
Sat, 2000-01-01 06:00:46 - remote IP address 212.ххх.ххх.х
Sat, 2000-01-01 06:00:46 - primary DNS address 82.200.130.232
Sat, 2000-01-01 06:00:46 - secondary DNS address 82.200.130.231
Sat, 2000-01-01 06:01:23 - Send out NTP request to time-nw.nist.gov
Thu, 2009-03-19 10:12:50 - Receive NTP Reply from time-nw.nist.gov
Thu, 2009-03-19 10:31:43 - lcp echos pending >= lcp_echo_fails! (вот это смущает)
Thu, 2009-03-19 10:31:43 - No response to 3 echo-requests
Thu, 2009-03-19 10:31:43 - Serial link appears to be disconnected.
Thu, 2009-03-19 10:31:43 - Couldn't increase MTU to 1500.
Thu, 2009-03-19 10:31:43 - Couldn't increase MRU to 1500
Thu, 2009-03-19 10:31:43 - LCP down.
Thu, 2009-03-19 10:31:49 - Connection terminated.
Thu, 2009-03-19 10:31:49 - Connect time 19.5 minutes.
Thu, 2009-03-19 10:31:49 - Sent 1008454 bytes, received 4498757 bytes.
Thu, 2009-03-19 10:31:49 - Doing disconnect
Thu, 2009-03-19 10:31:49 - Exit.
Thu, 2009-03-19 10:32:45 - Interface "nas0" created sucessfully
Thu, 2009-03-19 10:32:45 - Communicating over ATM 0.0.40, encapsulation: LLC
Thu, 2009-03-19 10:32:45 - Initialize LCP.
Thu, 2009-03-19 10:32:45 - Plugin pppoe loaded.
Thu, 2009-03-19 10:32:45 - PPPoE Plugin Initialized
Thu, 2009-03-19 10:32:45 - Plugin pppoe called.
Thu, 2009-03-19 10:32:45 - pppd 2.4.1 started by root, uid 0
Thu, 2009-03-19 10:32:45 - setting line discipline hook
Thu, 2009-03-19 10:32:45 - Sending PADI
Thu, 2009-03-19 10:33:42 - Terminating on signal 15.
Thu, 2009-03-19 10:33:42 - Failed to negotiate PPPoE connection: 127
Thu, 2009-03-19 10:33:42 - Exit.
Thu, 2009-03-19 10:33:42 - Hangup (SIGHUP)
Thu, 2009-03-19 10:33:42 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1004e180
Thu, 2009-03-19 10:33:42 - Couldn't get channel number: Transport endpoint is not connected
Thu, 2009-03-19 10:33:42 - Doing disconnect
Thu, 2009-03-19 10:33:42 - sendto returned:
Вчера вечером взял его домой с работы. Включил файервол и блокировку анонимных запросов - аптайм более 12 часов. соединение осуществлялось исключительно по вайфай. Сегодня утром включил на работе как блокировку, так и файервол - потеря коннекта в течении 5 минут. Отключил все - связь держалась порядка 1.5-2 часов, после чего модем повис намертво - вайфай канал держался, но доступа в интернет не было, как не было и доступа к самому модему.
Подскажите куда копать?
позвонить провайдеру попробовать обрисовать проблему включая домашний опыт
zveruga провайдер полдня ковырялся на месте. перепробовали уже все что можно. счас стоит какой-то роботикс (не помню модель), который стабильно держит коннект, как и простые лан-мопеды (если расшаривать вайфай с ноута).
при этом указаный выше модем работает 100% стабильно как у меня дома, так и дома у моего так сказать коллеги (друга, работающего этажом ниже).
прыгающая напруга в сети отпадает - поставили упс специально перед модемом.
