Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 13
Можно ли сделать скорость быстрее?
Вот статистика
ZyXEL MODEMS LINK STATUS REPORT
Chars Sent 89079 Chars Received 935069
Octets Sent 73730 Octets Received 854408
Blocks Sent 1404 Blocks Received 6856
Blocks Resent 6 Max Outstanding 8
Max Block Size 128 Retrains Requested 0
Link Duration 11 Retrains Granted 0
FRN Requested 0 FRN Granted 0
FCS Errors 532 Round Trip Delay 4
Xmitter Underrun 0 Receiver Overrun 0
Last Speed/Protocol T26400/R31200/ARQ/V34b/V44
Disconnect Reason DTR dropped
ZyXEL MODEMS PHYSICAL LAYER STATUS REPORT
Modulation mode = V34b
Tx Carrier = 1829 Hz Rx Carrier = 1920 Hz
Tx Baud Rate = 3200 Baud Rx Baud Rate = 3200 Baud
Tx Bit Rate = 26400 bps Rx Bit Rate = 31200 bps
Tx Power = -14.00 dBm Rx Level
Phase Jitter = 0.00 degree Frequency Offset = 0.00 Hz
SNR = 35.80 dB Round Trip Delay = 4.12 ms
Near End Echo = -11.90 dB Far End Echo = -53.82 dB
Nonlinear Encoder = ON Nonlinear Decoder = ON
Tx Shaping = Exp Rx Shaping = Min
Trellis Encoder = 16 state Convolutional Decoder = 64 state
Tx Filter Index = 2 Remote Tx Filte
Tx Precoder Coefficients = FFBD 00A4 0038 FF5C FFDA 00AC
Remote Tx Precoder Coefficients = 0000 0000 0000 0000 0000 0000
-0| = = = = = = = H00:D474 H01:E053
-2| = = = = = = = = = = = = = = = = = = H02:E2D1 H03:E2F3
-4| = = = = = = = = = = = = = = = = = = = = H04:E3F2 H05:E441
-6| = = = = = = = = = = = = = = = = = = = = H06:E4B4 H07:E4E1
-8| = = = = = = = = = = = = = = = = = = = = H08:E4CF H09:E498
-10| = = = = = = = = = = = = = = = = = = = = H10:E469 H11:E481
-12| = = = = = = = = = = = = = = = = = = = = H12:E3F2 H13:E3C0
-14| = = = = = = = = = = = = = = = = = = = = H14:E3BB H15:E39E
-16| = = = = = = = = = = = = = = = = = = = = = H16:E3C0 H17:E36E
-18| = = = = = = = = = = = = = = = = = = = = = H18:E2DF H19:E24A
-20| = = = = = = = = = = = = = = = = = = = = = H20:E19A
-22| = = = = = = = = = = = = = = = = = = = = = 0000 01EE 0000 0210 0000 0210
-24| = = = = = = = = = = = = = = = = = = = =
-26| = = = = = = = = = = = = = = = = = = = = = 0001 0001 0001 0000 0001 8000
-28| = = = = = = = = = = = = = = = = = = = = = AGC: 1.66 dB/0000 /0001
-30| = = = = = = = = = = = = = = = = = = = = = IMD: 0002 /0027
dB +-------------------------------------------- Echo Pwr: -19.05/ -17.12
F 0 0 0 0 0 1 1 1 1 1 2 2 2 2 2 3 3 3 3 3 3 L1 Power: -15.05/ -13.20
R 1 3 4 6 7 0 3 5 6 9 1 2 5 7 8 0 1 3 4 6 7 L2 Power: -21.05/ -19.05
E 5 0 5 0 5 5 5 0 5 5 0 5 5 0 5 0 5 0 5 0 5
Q 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 S/E: -2.00 dB/ 0.79
ZyXEL MODEMS V.9x CAPABILITY REPORT
Local Modem V.9x Capability = V.92 / APCM
Remote Modem V.9x Capability = V.92 / DPCM
Local Modem PSTN Connection = Analogue
Remote Modem PSTN Connection = Digital
Local Modem Probing Report = V.92 / 3200
Remote Modem Probing Report = V.90 / 3200
ZyXEL MODEMS V.9x POWER MANAGEMENT REPORT
DPCM nominal tx power for phase 2 : -9.00 dBm
DPCM actual tx power for phase 2 : -15.00 dBm
Maximum DPCM tx power for phase 3 : -12.00 dBm
Maximum DPCM tx power measured at : Codec
Digital PAD loss : 0.00 dB
IMD value measured at phase 2 : 0017
DPCM tx power reduction for IMD : 0.00 dB
APCM receive power at Phase 2 : -21.02 dBm
APCM receive power at TRN1d : 0.00 dBm
APCM receive power at Data State : -35.61 dBm
DPCM Terminal tx power : -0.00 dBm
DPCM Codec tx power : -0.00 dBm
V34b T26400/R31200 RTG= 0 RTR= 0 FTG= 0 FTR= 0
OK
Кто что скажет?
http://people.overclockers.ru/Sasha
Че ты тут написал то ?
З.Ы. У меня Zyxel omni 56k NEO
Так , что тоже жду советов.......
Balmer это статистика данных о парамерах связи
Sasha Мне она ничего не говорит .....
У меня версия НЕО. Ничего особого посоветовать не могу, только строку инициализации могу дать: ATS6=10S9=40S10=200S39=2&N62*Q1 .Про все обозначения можно в мануале почитать.
Один клик на сайте www.eleanora.nm.ru и вы поможете мне.
Balmer зато некоторым она о чем то говорит
Добавлено спустя 18 минут, 53 секунды:
Re@nim@tor аппаратная ошибка при введеной строке
А можно по русски и ясно ? Для модемных ламеров , как я ........
Balmer ну я тоже не гуру!
SNR = 35.80 dB
это показатель шума линии чем показатель больше тем лучше
Retrains Granted 0
количество ретрейнов, когда модем ретрейнится то происходит небольшой простой в закачке
если график ровный то это хорошо :):)
А откуда ты взял инфо , и что хочешь добится ? Какая скорость ?
Balmer скорость 31.2кб\с, хочу добится большего,
инфа от друзей! ;)
да и почаще заходи на конфу www.ixbt.com
А бывает лучше ? Шучу у меня иногда 44
Заземли корпус, должно помочь.
зачем ?
