Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 11
ребят (и девчата если есть компетентные) мож я просто где туплю но вот не работает маршрут
192.168.100.0 255.255.255.0 10.8.0.1 10.8.0.2 1
может кто что подскажет? ось вин2003
Код:
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.200     20
         10.5.0.0    255.255.255.0         10.5.2.1         10.5.2.2      1
         10.5.2.0  255.255.255.252         10.5.2.2         10.5.2.2     30
         10.5.2.2  255.255.255.255        127.0.0.1        127.0.0.1     30
         10.8.0.0  255.255.255.252         10.8.0.2         10.8.0.2     30
         10.8.0.2  255.255.255.255        127.0.0.1        127.0.0.1     30
   10.255.255.255  255.255.255.255         10.5.2.2         10.5.2.2     30
   10.255.255.255  255.255.255.255         10.8.0.2         10.8.0.2     30
        127.0.0.0        255.0.0.0        127.0.0.1        127.0.0.1      1
      192.168.0.0    255.255.255.0    192.168.0.200    192.168.0.200     20
    192.168.0.200  255.255.255.255        127.0.0.1        127.0.0.1     20
    192.168.0.255  255.255.255.255    192.168.0.200    192.168.0.200     20
     192.168.50.0    255.255.255.0     192.168.50.1     192.168.50.1     10
     192.168.50.1  255.255.255.255        127.0.0.1        127.0.0.1     10
   192.168.50.255  255.255.255.255     192.168.50.1     192.168.50.1     10
        224.0.0.0        240.0.0.0         10.5.2.2         10.5.2.2     30
        224.0.0.0        240.0.0.0         10.8.0.2         10.8.0.2     30
        224.0.0.0        240.0.0.0    192.168.0.200    192.168.0.200     20
        224.0.0.0        240.0.0.0     192.168.50.1     192.168.50.1     10
  255.255.255.255  255.255.255.255         10.5.2.2         10.5.2.2      1
  255.255.255.255  255.255.255.255         10.8.0.2         10.8.0.2      1
  255.255.255.255  255.255.255.255    192.168.0.200    192.168.0.200      1
  255.255.255.255  255.255.255.255     192.168.50.1     192.168.50.1      1
Default Gateway:       192.168.0.1
Persistent Routes:
  None
C:\Documents and Settings\admin>tracert 192.168.100.253
Tracing route to 192.168.100.253 over a maximum of 30 hops
  1     *        *        *     Request timed out.
  2  ^C
C:\Documents and Settings\admin>ping 10.8.0.1
Pinging 10.8.0.1 with 32 bytes of data:
Reply from 10.8.0.1: bytes=32 time=4ms TTL=128
Ping statistics for 10.8.0.1:
    Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 4ms, Maximum = 4ms, Average = 4ms
Control-C
^C
кароче где JDima/win-профи :)
DenisMak, сделай ipconfig /all и расскажи чего хочешь добиться.
ну если сразу не понятно то хочу чтобы пакеты ходили в сеть 192.168.100.0/24 через гейт 10.8.0.1
ipconfig /all:
Код:
C:\Documents and Settings\admin>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : (удалено)
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Unknown
   IP Routing Enabled. . . . . . . . : Yes
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter :
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Win32 Adapter V8 #2
   Physical Address. . . . . . . . . : 00-FF-99-1A-DF-53
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IP Address. . . . . . . . . . . . : 10.5.2.2
   Subnet Mask . . . . . . . . . . . : 255.255.255.252
   Default Gateway . . . . . . . . . :
   DHCP Server . . . . . . . . . . . : 10.5.2.1
   Lease Obtained. . . . . . . . . . : 24 декабря 2009 г. 12:19:16
   Lease Expires . . . . . . . . . . : 24 декабря 2010 г. 12:19:16
Ethernet adapter :
   Description . . . . . . . . . . . : Intel(R) 82566DM Gigabit Network
on
   Physical Address. . . . . . . . . : 00-18-F3-F0-0A-55
   DHCP Enabled. . . . . . . . . . . : No
   IP Address. . . . . . . . . . . . : 192.168.50.1
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   DNS Servers . . . . . . . . . . . : 192.168.0.1
Ethernet adapter :
   Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast
NIC
   Physical Address. . . . . . . . . : 00-02-44-6F-8D-B7
   IP Address. . . . . . . . . . . . : 192.168.0.200
   Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter :
   Physical Address. . . . . . . . . : 00-FF-17-18-46-EC
   IP Address. . . . . . . . . . . . : 10.8.0.2
   DHCP Server . . . . . . . . . . . : 10.8.0.1
   Lease Obtained. . . . . . . . . . : 24 декабря 2009 г. 12:34:21
   Lease Expires . . . . . . . . . . : 24 декабря 2010 г. 12:34:21
route add 192.168.100.0 mask 255.255.255.0 10.8.0.1 -p
не работает?
Добавлено спустя 9 минут 20 секунд:
Кстати, ты хочешь чтобы пакеты ходили только с этого компа или с других через него?
не работает?
нет не работает, вообще раньше так и было, ток вот работать вдруг и резко перестало, начал копать, да и потом я что то не встречал что от того persistent маршрут или нет должен по разному обруливаться, persistent это восстановление маршрута после перезагрузки и ничего более.
это уже мелочи... главное чтоб маршрут работал.
Сделай route -f и перегрузи комп. После этого покажи опять route print, перед этим добавь опять маршрут.
В предыдущем что-то так много всего..
спс, попробую, как инет дадут на том узле, удалёнка :)
Добавлено спустя 22 минуты 8 секунд:
ничего лишнего, абсолютно все правила кроме этого - автоматика (правда 10.5.2.0 там с впн серв выдаётся принудительно но нужно, хотя тоже автоматически), там интерфейсов 4 штуки 2 впн и 2 физич
Как я уже сказал, "traceroute /?". Ну и, сам то шлюз хоть пингуется?
блин, вот написать вопрос не лень, но не уж то лень посмотреть первый пост до конца, да пингуется.
Мне даже не лень написать там, тут, и еще сделать приписку в надежде, что это поможет Тебе!
DenisMak писал(а):
да пингуется.
Результат трассировки маршрута (traceroute) какой?
Добавлено спустя 1 минуту 3 секунды:
О, да-а-а-а! Помню такого...
gM
кароче tracert ping и таблица маршрутов приведены в первом посте, с тех пор ничего не изменилось. Обнаружилась другая особенность из сети 192.168.100.0/24 я могу пинговать _любой_ комп в этой (192.168.50.0/24) подсети не только этот вин2003/роутер
Добавлено спустя 8 минут 1 секунду:
причина и решение найдено:
есть такая прога Traffic Inspector и у неё есть особенность дропать пакеты при маршрутизации между контролируемым ею сетевым интерфейсом и не контролируемым. это и происходило. щас отключил... буду искать может это поведение настривается где.
всем спасибо за попытки помощи
