Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 95 • Страница 3 из 5<  1  2  3  4  5  >
vbif писал(а):
finexТебе надо решить проблему или пописАть ??? если первое то давай то что тебя просят, а не прерикайся
я щас на работе с дома скину
finex
Производитель - ASUS :oops:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us,ru"
Option "XkbVariant" ",winkeys"
Option "XkbOptions" "grp:alt_shift_toggle,grp_led:scroll"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV350 AP [Radeon 9600]"
Driver "ati"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Универсальный монитор"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV350 AP [Radeon 9600]"
Monitor "Универсальный монитор"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
Option "AIGLX" "true"
#InputDevice "stylus" "SendCoreEvents"
#InputDevice "cursor" "SendCoreEvents"
#InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
finex
У тебя просто прописан один монитор , надо прописать второй, с максимальным разрешением 800Х600, BusID для второго выхода можно посмотреть командой lspci.
Все настройки детально описаны в man xorg.conf, если будет что не понятно пиши.
ps.И выкинь ввод стилусом из конфига, и вообще откуда он взялся ???
они в убунте по умолчанию прописаны, видимо в ЮАР все вакумами пользуются =) Они у него и так выкинуты, в Server Layout комментарии стоят.
Software is like a sex, it is better when it is free
vbif спасиб попробую
У меня Мандрива 2007.0 x86. При установке выбирается только vesa. При остальных дровах запускается только консольный вид. Скачал драйвер ati-driver-installer-8.36.5-x86.x86_64.run. Ставлю все по инструкции:
1. пишу sh ./ati-driver-installer-8.36.5-x86.x86_64.run.
2. он начинает устанавливать.
3. далее в инструкции написано, что в папке /usr/X11R6/bin будет aticonfig. Там я его не обнаруживаю, хотя нахожу его в /usr/bin/.
4. пишу /usr/bin/aticonfig --initial. Он выдает что файл отсутствует в /etc/X11/. Я пишу /usr/bin/aticonfig --initial --input=/etc/X11/xorg.conf.original-0 (т.к. xorg.conf у меня вообще отсутствует).
5. у меня пишет, типо все нормально вписалось в xorg.conf.original-0.
6. перезагружаю - не входит в графическую оболочку, запускается только консольный вид.
p.s. Контрол Панель появляется, но не запуускается.
Что делать!?!?
Enzo1988
Вот в том и проблема :)
/usr/bin/aticonfig --initial --input=/etc/X11/xorg.conf и должно работать , если не будет то сюда вывод конвига и логов каких я писал выше ...
ооо в который раз в который раз :)))) если после просмотра гуру конфигов и логов ниче не работает то следует :1) у тебя кривые руки; 2)не тот дистр; 3) и то и другое вместе; 4)Ати отстой выкинь видяху купи нвидиа; 5)А у меня все работает а у тебя карма плохая; 6) луна не в той фазе завтра попробуй.
поставил, но после ввода логина и пароля - зависает, а комп чето грузит, тока мышка и синий экран
Enzo1988
сюда /etc/X11/xorg.conf
/var/log/Xorg.0.log
поставил. разобрался седня. просто луна в другую фазу перешла) и все получилось. теперь не могу поставить DirectRendening. В xorg.conf прописал DirectRendening on в секции Device, но все равно не пашет.
Enzo1988
Фазы луны на линуксойдов не влияют, в отличии от виндузятников они знают чего делают :)
А вывод лога /var/log/Xorg.0.log можеш дать ???
vbif
давай я дам тебе логи и xorg.conf и ты сделаешь, плиз.
http://www.rapidshare.ru/280089 - log
http://www.rapidshare.ru/280094 - config
Еще я читал что в ядре надо DRI отключать.
Вообще мне нужна конфигурация для игр. Какую лучше конфигурацию сделать?
Enzo1988
Выдежка из твоего лога.
Код:
(EE) fglrx(0): GART is not initialized, disabling DRI
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed!                                             *
(WW) fglrx(0): * (maybe driver kernel module missing or bad)             *
(WW) fglrx(0): * 2D acceleraton available (MMIO)                                *
(WW) fglrx(0): * no 3D acceleration available                                      *
(WW) fglrx(0): *********************************************   *
так что ты правильно читал :)
и что делать? мне нужно DRI. как попасть в настройку ядра? или что вообще делать, чтобы DRI работал???
Enzo1988
тут куча статей про настройку ядра, там решится и твоя проблема с DRI и с SATA контроллером.
ps.Хотя если ты задаеш такие вопросы то проще поставить Ubuntu-Kubintu, там такого головняка нет.
make xconfig
make menuconfig
make config
make oldconfig
ниче из этого не пашет
Enzo1988
если не пашет нет сырцов ядра, поставь с диска или репозитария , в директории /usr/src/linux должны быть файлы ...
vbif ты предлагаешь человеку, который не может поставить драйвер для видео, пересобирать ядро!? А нафига? в мандриве каррент!!! 2.6.17 а он даже про 965ый еще не знает. А ваниллу ставить на мандриву - это самоубийство!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 62
