Статус: Не в сети Регистрация: 01.05.2006 Откуда: Питер
установил себе намедни debian etch...
всё хорошо, только иксы не запускаются я сам настроить не могу, ибо не умею, даже не знаю с чего начать
вот содержимое xorg.0.log - я очень надеюсь что по нему можно определить что не так...
заранее спасибо
X Window System Version 7.0.0 Release Date: 21 December 2005 X Protocol Version 11, Revision 0, Release 7.0 Build Operating System:Linux 2.6.12-1-686 i686 Current Operating System: Linux koi8r 2.6.16-2-686 #1 Sat Jul 15 21:59:21 UTC 2006 i686 Build Date: 16 March 2006 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Module Loader present Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 29 16:04:52 2006 (==) Using config file: "/etc/X11/xorg.conf" (==) ServerLayout "Default Layout" (**) |-->Screen "Default Screen" (0) (**) | |-->Monitor "Generic Monitor" (**) | |-->Device "NVIDIA Corporation NVIDIA Default Card" (**) |-->Input Device "Generic Keyboard" (**) |-->Input Device "Configured Mouse" (WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist. Entry deleted from font path. (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. Entry deleted from font path. (WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist. Entry deleted from font path. (WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist. Entry deleted from font path. (WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist. Entry deleted from font path. (WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist. Entry deleted from font path. (WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist. Entry deleted from font path. (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist. Entry deleted from font path. (**) FontPath set to "/usr/share/fonts/X11/misc,/usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1, /usr/X11R6/lib/X11/fonts/Type1,/usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi,/usr/share/fonts/X11/misc/, /usr/share/fonts/X11/TTF/,/usr/share/fonts/X11/OTF, /usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/CID/, /usr/share/fonts/X11/100dpi/,/usr/share/fonts/X11/75dpi/" (==) RgbPath set to "/usr/share/X11/rgb" (==) ModulePath set to "/usr/lib/xorg/modules" (II) Module ABI versions: X.Org ANSI C Emulation: 0.2 X.Org Video Driver: 0.8 X.Org XInput driver : 0.5 X.Org Server Extension : 0.2 X.Org Font Renderer : 0.4 (II) Loader running on linux (II) LoadModule: "bitmap" (II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so (II) Module bitmap: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 Module class: X.Org Font Renderer ABI class: X.Org Font Renderer, version 0.4 (II) Loading font Bitmap (II) LoadModule: "pcidata" (II) Loading /usr/lib/xorg/modules/libpcidata.so (II) Module pcidata: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org Video Driver, version 0.8 (--) using VT number 7
(II) PCI: PCI scan (all values are in hex) (II) PCI: 00:00:0: chip 8086,2770 card 1043,8178 rev 02 class 06,00,00 hdr 00 (II) PCI: 00:01:0: chip 8086,2771 card 0000,0000 rev 02 class 06,04,00 hdr 01 (II) PCI: 00:1b:0: chip 8086,27d8 card 1043,81a0 rev 01 class 04,03,00 hdr 00 (II) PCI: 00:1c:0: chip 8086,27d0 card 0000,0000 rev 01 class 06,04,00 hdr 81 (II) PCI: 00:1c:4: chip 8086,27e0 card 0000,0000 rev 01 class 06,04,00 hdr 81 (II) PCI: 00:1c:5: chip 8086,27e2 card 0000,0000 rev 01 class 06,04,00 hdr 81 (II) PCI: 00:1d:0: chip 8086,27c8 card 1043,8179 rev 01 class 0c,03,00 hdr 80 (II) PCI: 00:1d:1: chip 8086,27c9 card 1043,8179 rev 01 class 0c,03,00 hdr 00 (II) PCI: 00:1d:2: chip 8086,27ca card 1043,8179 rev 01 class 0c,03,00 hdr 00 (II) PCI: 00:1d:3: chip 8086,27cb card 1043,8179 rev 01 class 0c,03,00 hdr 00 (II) PCI: 00:1d:7: chip 8086,27cc card 1043,8179 rev 01 class 0c,03,20 hdr 00 (II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev e1 class 06,04,01 hdr 01 (II) PCI: 00:1f:0: chip 8086,27b8 card 1043,8179 rev 01 class 06,01,00 hdr 80 (II) PCI: 00:1f:1: chip 8086,27df card 1043,8179 rev 01 class 01,01,8f hdr 00 (II) PCI: 00:1f:2: chip 8086,27c0 card 1043,2601 rev 01 class 01,01,8f hdr 00 (II) PCI: 00:1f:3: chip 8086,27da card 1043,8179 rev 01 class 0c,05,00 hdr 00 (II) PCI: 01:03:0: chip 104c,8023 card 1043,808b rev 00 class 0c,00,10 hdr 00 (II) PCI: 01:04:0: chip 1283,8211 card 1043,8138 rev 11 class 01,80,00 hdr 00 (II) PCI: 02:00:0: chip 1095,3132 card 1043,819f rev 01 class 01,80,00 hdr 00 (II) PCI: 03:00:0: chip 11ab,4362 card 1043,8142 rev 19 class 02,00,00 hdr 00 (II) PCI: 05:00:0: chip 10de,0391 card 1043,81f7 rev a1 class 03,00,00 hdr 00 (II) PCI: End of PCI scan (II) Host-to-PCI bridge: (II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set) (II) Bus 0 I/O range: [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B] (II) Bus 0 non-prefetchable memory range: [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B] (II) Bus 0 prefetchable memory range: [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B] (II) PCI-to-PCI bridge: (II) Bus 5: bridge is at (0:1:0), (0,5,5), BCTRL: 0x000a (VGA_EN is set) (II) Bus 5 I/O range: [0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B] (II) Bus 5 non-prefetchable memory range: [0] -1 0 0xddf00000 - 0xdfffffff (0x2100000) MX[B] (II) Bus 5 prefetchable memory range: [0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B] (II) PCI-to-PCI bridge: (II) Bus 4: bridge is at (0:28:0), (0,4,4), BCTRL: 0x0006 (VGA_EN is cleared) (II) Bus 4 I/O range: [0] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B] [1] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B] [2] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B] [3] -1 0 0x0000dc00 - 0x0000dcff (0x100) IX[B] (II) PCI-to-PCI bridge: (II) Bus 3: bridge is at (0:28:4), (0,3,3), BCTRL: 0x0006 (VGA_EN is cleared) (II) Bus 3 I/O range: [0] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B] [1] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B] [2] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B] [3] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B] (II) Bus 3 non-prefetchable memory range: [0] -1 0 0xdde00000 - 0xddefffff (0x100000) MX[B] (II) PCI-to-PCI bridge: (II) Bus 2: bridge is at (0:28:5), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared) (II) Bus 2 I/O range: [0] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B] [1] -1 0 0x0000b400 - 0x0000b4ff (0x100) IX[B] [2] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B] [3] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B] (II) Bus 2 non-prefetchable memory range: [0] -1 0 0xddd00000 - 0xdddfffff (0x100000) MX[B] (II) Subtractive PCI-to-PCI bridge: (II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x0006 (VGA_EN is cleared) (II) Bus 1 I/O range: [0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B] [1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B] [2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B] [3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B] [4] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B] [5] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B] [6] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B] [7] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B] (II) Bus 1 non-prefetchable memory range: [0] -1 0 0xddc00000 - 0xddcfffff (0x100000) MX[B] (II) Bus 1 prefetchable memory range: [0] -1 0 0x50000000 - 0x500fffff (0x100000) MX[B] (II) PCI-to-ISA bridge: (II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set) (--) PCI:*(5:0:0) nVidia Corporation unknown chipset (0x0391) rev 161, Mem @ 0xdf000000/24, 0xe0000000/28, 0xde000000/24, I/O @ 0xe800/7, BIOS @ 0xddfe0000/17 (II) Addressable bus resource ranges are [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B] [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B] (II) OS-reported resource ranges: [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B) [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] (II) Active PCI resource ranges: [0] -1 0 0xddefc000 - 0xddefffff (0x4000) MX[B] [1] -1 0 0xdddf8000 - 0xdddfbfff (0x4000) MX[B] [2] -1 0 0xdddffc00 - 0xdddffc7f (0x80) MX[B] [3] -1 0 0xddcd8000 - 0xddcdbfff (0x4000) MX[B] [4] -1 0 0xddcdf800 - 0xddcdffff (0x800) MX[B] [5] -1 0 0xddbffc00 - 0xddbfffff (0x400) MX[B] [6] -1 0 0xddbff800 - 0xddbffbff (0x400) MX[B] [7] -1 0 0xddbf8000 - 0xddbfbfff (0x4000) MX[B] [8] -1 0 0xddfe0000 - 0xddffffff (0x20000) MX[B](B) [9] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B) [10] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B) [11] -1 0 0xdf000000 - 0xdfffffff (0x1000000) MX[B](B) [12] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B] [13] -1 0 0x0000b800 - 0x0000b87f (0x80) IX[B] [14] -1 0 0x00009400 - 0x0000940f (0x10) IX[B] [15] -1 0 0x00009800 - 0x00009803 (0x4) IX[B] [16] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B] [17] -1 0 0x0000a400 - 0x0000a403 (0x4) IX[B] [18] -1 0 0x0000a800 - 0x0000a807 (0x8) IX[B] [19] -1 0 0x00000400 - 0x0000041f (0x20) IX[B] [20] -1 0 0x00007400 - 0x0000740f (0x10) IX[B] [21] -1 0 0x00007800 - 0x00007803 (0x4) IX[B] [22] -1 0 0x00008000 - 0x00008007 (0x8) IX[B] [23] -1 0 0x00008400 - 0x00008403 (0x4) IX[B] [24] -1 0 0x00008800 - 0x00008807 (0x8) IX[B] [25] -1 0 0x00005800 - 0x0000580f (0x10) IX[B] [26] -1 0 0x00006000 - 0x00006003 (0x4) IX[B] [27] -1 0 0x00006400 - 0x00006407 (0x8) IX[B] [28] -1 0 0x00006800 - 0x00006803 (0x4) IX[B] [29] -1 0 0x00007000 - 0x00007007 (0x8) IX[B] [30] -1 0 0x00005400 - 0x0000541f (0x20) IX[B] [31] -1 0 0x00005000 - 0x0000501f (0x20) IX[B] [32] -1 0 0x00004800 - 0x0000481f (0x20) IX[B] [33] -1 0 0x00004400 - 0x0000441f (0x20) IX[B] [34] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B](B) (II) Active PCI resource ranges after removing overlaps: [0] -1 0 0xddefc000 - 0xddefffff (0x4000) MX[B] [1] -1 0 0xdddf8000 - 0xdddfbfff (0x4000) MX[B] [2] -1 0 0xdddffc00 - 0xdddffc7f (0x80) MX[B] [3] -1 0 0xddcd8000 - 0xddcdbfff (0x4000) MX[B] [4] -1 0 0xddcdf800 - 0xddcdffff (0x800) MX[B] [5] -1 0 0xddbffc00 - 0xddbfffff (0x400) MX[B] [6] -1 0 0xddbff800 - 0xddbffbff (0x400) MX[B] [7] -1 0 0xddbf8000 - 0xddbfbfff (0x4000) MX[B] [8] -1 0 0xddfe0000 - 0xddffffff (0x20000) MX[B](B) [9] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B) [10] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B) [11] -1 0 0xdf000000 - 0xdfffffff (0x1000000) MX[B](B) [12] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B] [13] -1 0 0x0000b800 - 0x0000b87f (0x80) IX[B] [14] -1 0 0x00009400 - 0x0000940f (0x10) IX[B] [15] -1 0 0x00009800 - 0x00009803 (0x4) IX[B] [16] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B] [17] -1 0 0x0000a400 - 0x0000a403 (0x4) IX[B] [18] -1 0 0x0000a800 - 0x0000a807 (0x8) IX[B] [19] -1 0 0x00000400 - 0x0000041f (0x20) IX[B] [20] -1 0 0x00007400 - 0x0000740f (0x10) IX[B] [21] -1 0 0x00007800 - 0x00007803 (0x4) IX[B] [22] -1 0 0x00008000 - 0x00008007 (0x8) IX[B] [23] -1 0 0x00008400 - 0x00008403 (0x4) IX[B] [24] -1 0 0x00008800 - 0x00008807 (0x8) IX[B] [25] -1 0 0x00005800 - 0x0000580f (0x10) IX[B] [26] -1 0 0x00006000 - 0x00006003 (0x4) IX[B] [27] -1 0 0x00006400 - 0x00006407 (0x8) IX[B] [28] -1 0 0x00006800 - 0x00006803 (0x4) IX[B] [29] -1 0 0x00007000 - 0x00007007 (0x8) IX[B] [30] -1 0 0x00005400 - 0x0000541f (0x20) IX[B] [31] -1 0 0x00005000 - 0x0000501f (0x20) IX[B] [32] -1 0 0x00004800 - 0x0000481f (0x20) IX[B] [33] -1 0 0x00004400 - 0x0000441f (0x20) IX[B] [34] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B](B) (II) OS-reported resource ranges after removing overlaps with PCI: [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B) [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] (II) All system resource ranges: [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B) [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [5] -1 0 0xddefc000 - 0xddefffff (0x4000) MX[B] [6] -1 0 0xdddf8000 - 0xdddfbfff (0x4000) MX[B] [7] -1 0 0xdddffc00 - 0xdddffc7f (0x80) MX[B] [8] -1 0 0xddcd8000 - 0xddcdbfff (0x4000) MX[B] [9] -1 0 0xddcdf800 - 0xddcdffff (0x800) MX[B] [10] -1 0 0xddbffc00 - 0xddbfffff (0x400) MX[B] [11] -1 0 0xddbff800 - 0xddbffbff (0x400) MX[B] [12] -1 0 0xddbf8000 - 0xddbfbfff (0x4000) MX[B] [13] -1 0 0xddfe0000 - 0xddffffff (0x20000) MX[B](B) [14] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B) [15] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B) [16] -1 0 0xdf000000 - 0xdfffffff (0x1000000) MX[B](B) [17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [19] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B] [20] -1 0 0x0000b800 - 0x0000b87f (0x80) IX[B] [21] -1 0 0x00009400 - 0x0000940f (0x10) IX[B] [22] -1 0 0x00009800 - 0x00009803 (0x4) IX[B] [23] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B] [24] -1 0 0x0000a400 - 0x0000a403 (0x4) IX[B] [25] -1 0 0x0000a800 - 0x0000a807 (0x8) IX[B] [26] -1 0 0x00000400 - 0x0000041f (0x20) IX[B] [27] -1 0 0x00007400 - 0x0000740f (0x10) IX[B] [28] -1 0 0x00007800 - 0x00007803 (0x4) IX[B] [29] -1 0 0x00008000 - 0x00008007 (0x8) IX[B] [30] -1 0 0x00008400 - 0x00008403 (0x4) IX[B] [31] -1 0 0x00008800 - 0x00008807 (0x8) IX[B] [32] -1 0 0x00005800 - 0x0000580f (0x10) IX[B] [33] -1 0 0x00006000 - 0x00006003 (0x4) IX[B] [34] -1 0 0x00006400 - 0x00006407 (0x8) IX[B] [35] -1 0 0x00006800 - 0x00006803 (0x4) IX[B] [36] -1 0 0x00007000 - 0x00007007 (0x8) IX[B] [37] -1 0 0x00005400 - 0x0000541f (0x20) IX[B] [38] -1 0 0x00005000 - 0x0000501f (0x20) IX[B] [39] -1 0 0x00004800 - 0x0000481f (0x20) IX[B] [40] -1 0 0x00004400 - 0x0000441f (0x20) IX[B] [41] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B](B) (II) LoadModule: "i2c" (II) Loading /usr/lib/xorg/modules/libi2c.so (II) Module i2c: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.2.0 ABI class: X.Org Video Driver, version 0.8 (II) LoadModule: "bitmap" (II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so (II) Loading font Bitmap (II) LoadModule: "ddc" (II) Loading /usr/lib/xorg/modules/libddc.so (II) Module ddc: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org Video Driver, version 0.8 (II) LoadModule: "dri" (II) Loading /usr/lib/xorg/modules/extensions/libdri.so (II) Module dri: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 0.2 (II) Loading sub module "drm" (II) LoadModule: "drm" (II) Loading /usr/lib/xorg/modules/linux/libdrm.so (II) Module drm: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 0.2 (II) Loading extension XFree86-DRI (II) LoadModule: "extmod" (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so (II) Module extmod: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 0.2 (II) Loading extension SHAPE (II) Loading extension MIT-SUNDRY-NONSTANDARD (II) Loading extension BIG-REQUESTS (II) Loading extension SYNC (II) Loading extension MIT-SCREEN-SAVER (II) Loading extension XC-MISC (II) Loading extension XFree86-VidModeExtension (II) Loading extension XFree86-Misc (II) Loading extension XFree86-DGA (II) Loading extension DPMS (II) Loading extension TOG-CUP (II) Loading extension Extended-Visual-Information (II) Loading extension XVideo (II) Loading extension XVideo-MotionCompensation (II) Loading extension X-Resource (II) LoadModule: "freetype" (II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project" compiled for 7.0.0, module version = 2.1.0 Module class: X.Org Font Renderer ABI class: X.Org Font Renderer, version 0.4 (II) Loading font FreeType (II) LoadModule: "glx" (II) Loading /usr/lib/xorg/modules/extensions/libglx.so (II) Module glx: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 0.2 (II) Loading sub module "GLcore" (II) LoadModule: "GLcore" (II) Loading /usr/lib/xorg/modules/extensions/libGLcore.so (II) Module GLcore: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 0.2 (II) Loading extension GLX (II) LoadModule: "int10" (II) Loading /usr/lib/xorg/modules/libint10.so (II) Module int10: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org Video Driver, version 0.8 (II) LoadModule: "type1" (II) Loading /usr/lib/xorg/modules/fonts/libtype1.so (II) Module type1: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.2 Module class: X.Org Font Renderer ABI class: X.Org Font Renderer, version 0.4 (II) Loading font Type1 (II) LoadModule: "vbe" (II) Loading /usr/lib/xorg/modules/libvbe.so (II) Module vbe: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.1.0 ABI class: X.Org Video Driver, version 0.8 (II) LoadModule: "nv" (II) Loading /usr/lib/xorg/modules/drivers/nv_drv.so (II) Module nv: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.1 Module class: X.Org Video Driver ABI class: X.Org Video Driver, version 0.8 (II) LoadModule: "kbd" (II) Loading /usr/lib/xorg/modules/input/kbd_drv.so (II) Module kbd: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.1 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 0.5 (II) LoadModule: "mouse" (II) Loading /usr/lib/xorg/modules/input/mouse_drv.so (II) Module mouse: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.4 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 0.5 (II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2, Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64, Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400, GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go, GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra, Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420, GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go, GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL, GeForce4 440 Go 64M, Quadro4 NVS, Quadro4 500 GoGL, GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X, GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X, GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL, Quadro4 280 NVS, Quadro4 380 XGL, Quadro NVS 50 PCI, GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3, GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600, GeForce4 Ti 4400, 0x0252, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL, Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X, GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL, Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra, GeForce FX 5800, Quadro FX 2000, Quadro FX 1000, GeForce FX 5600 Ultra, GeForce FX 5600, 0x0313, GeForce FX 5600SE, 0x0316, 0x0317, GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700, 0x031D, 0x031E, 0x031F, GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200, GeForce FX 5200SE, GeForce FX Go5200, GeForce FX Go5250, GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M, 0x0329, Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI, GeForce FX Go53xx Series, GeForce FX Go5100, 0x032F, GeForce FX 5900 Ultra, GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra, Quadro FX 700, GeForce FX 5900ZT, Quadro FX 3000, GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE, GeForce FX 5700VE, 0x0345, GeForce FX Go5700, GeForce FX Go5700, 0x0349, 0x034B, Quadro FX Go1000, Quadro FX 1100, 0x034F, GeForce 6800 Ultra, GeForce 6800, GeForce 6800 LE, 0x0043, GeForce 6800 GT, GeForce 6800 GT, GeForce 6800 XT, 0x0049, Quadro FX 4000, 0x00C0, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT, GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400, Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT, GeForce 6600, GeForce 6600 LE, 0x0143, GeForce Go 6600, GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL, GeForce Go 6600, GeForce Go 6600 GT, 0x014B, 0x014C, 0x014D, Quadro FX 540, GeForce 6200, GeForce 6500, GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM), GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400, GeForce Go 6200, GeForce Go 6400, GeForce 6250, 0x016B, 0x016C, 0x016D, 0x016E, 0x0210, GeForce 6800, GeForce 6800 LE, GeForce 6800 GT, 0x0220, GeForce 6200, 0x0222, 0x0228, 0x0090, GeForce 7800 GTX, GeForce 7800 GT, 0x0093, 0x0094, GeForce Go 7800, GeForce Go 7800 GTX, 0x009C, Quadro FX 4500, 0x009E (II) Primary Device is: PCI 05:00:0 (--) Chipset Unknown NVIDIA chip found (II) resource ranges after xf86ClaimFixedResources() call: [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B) [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [5] -1 0 0xddefc000 - 0xddefffff (0x4000) MX[B] [6] -1 0 0xdddf8000 - 0xdddfbfff (0x4000) MX[B] [7] -1 0 0xdddffc00 - 0xdddffc7f (0x80) MX[B] [8] -1 0 0xddcd8000 - 0xddcdbfff (0x4000) MX[B] [9] -1 0 0xddcdf800 - 0xddcdffff (0x800) MX[B] [10] -1 0 0xddbffc00 - 0xddbfffff (0x400) MX[B] [11] -1 0 0xddbff800 - 0xddbffbff (0x400) MX[B] [12] -1 0 0xddbf8000 - 0xddbfbfff (0x4000) MX[B] [13] -1 0 0xddfe0000 - 0xddffffff (0x20000) MX[B](B) [14] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B) [15] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B) [16] -1 0 0xdf000000 - 0xdfffffff (0x1000000) MX[B](B) [17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [19] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B] [20] -1 0 0x0000b800 - 0x0000b87f (0x80) IX[B] [21] -1 0 0x00009400 - 0x0000940f (0x10) IX[B] [22] -1 0 0x00009800 - 0x00009803 (0x4) IX[B] [23] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B] [24] -1 0 0x0000a400 - 0x0000a403 (0x4) IX[B] [25] -1 0 0x0000a800 - 0x0000a807 (0x8) IX[B] [26] -1 0 0x00000400 - 0x0000041f (0x20) IX[B] [27] -1 0 0x00007400 - 0x0000740f (0x10) IX[B] [28] -1 0 0x00007800 - 0x00007803 (0x4) IX[B] [29] -1 0 0x00008000 - 0x00008007 (0x8) IX[B] [30] -1 0 0x00008400 - 0x00008403 (0x4) IX[B] [31] -1 0 0x00008800 - 0x00008807 (0x8) IX[B] [32] -1 0 0x00005800 - 0x0000580f (0x10) IX[B] [33] -1 0 0x00006000 - 0x00006003 (0x4) IX[B] [34] -1 0 0x00006400 - 0x00006407 (0x8) IX[B] [35] -1 0 0x00006800 - 0x00006803 (0x4) IX[B] [36] -1 0 0x00007000 - 0x00007007 (0x8) IX[B] [37] -1 0 0x00005400 - 0x0000541f (0x20) IX[B] [38] -1 0 0x00005000 - 0x0000501f (0x20) IX[B] [39] -1 0 0x00004800 - 0x0000481f (0x20) IX[B] [40] -1 0 0x00004400 - 0x0000441f (0x20) IX[B] [41] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B](B) (II) resource ranges after probing: [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B) [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [5] -1 0 0xddefc000 - 0xddefffff (0x4000) MX[B] [6] -1 0 0xdddf8000 - 0xdddfbfff (0x4000) MX[B] [7] -1 0 0xdddffc00 - 0xdddffc7f (0x80) MX[B] [8] -1 0 0xddcd8000 - 0xddcdbfff (0x4000) MX[B] [9] -1 0 0xddcdf800 - 0xddcdffff (0x800) MX[B] [10] -1 0 0xddbffc00 - 0xddbfffff (0x400) MX[B] [11] -1 0 0xddbff800 - 0xddbffbff (0x400) MX[B] [12] -1 0 0xddbf8000 - 0xddbfbfff (0x4000) MX[B] [13] -1 0 0xddfe0000 - 0xddffffff (0x20000) MX[B](B) [14] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B) [15] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B) [16] -1 0 0xdf000000 - 0xdfffffff (0x1000000) MX[B](B) [17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B] [18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B] [19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B] [20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [22] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B] [23] -1 0 0x0000b800 - 0x0000b87f (0x80) IX[B] [24] -1 0 0x00009400 - 0x0000940f (0x10) IX[B] [25] -1 0 0x00009800 - 0x00009803 (0x4) IX[B] [26] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B] [27] -1 0 0x0000a400 - 0x0000a403 (0x4) IX[B] [28] -1 0 0x0000a800 - 0x0000a807 (0x8) IX[B] [29] -1 0 0x00000400 - 0x0000041f (0x20) IX[B] [30] -1 0 0x00007400 - 0x0000740f (0x10) IX[B] [31] -1 0 0x00007800 - 0x00007803 (0x4) IX[B] [32] -1 0 0x00008000 - 0x00008007 (0x8) IX[B] [33] -1 0 0x00008400 - 0x00008403 (0x4) IX[B] [34] -1 0 0x00008800 - 0x00008807 (0x8) IX[B] [35] -1 0 0x00005800 - 0x0000580f (0x10) IX[B] [36] -1 0 0x00006000 - 0x00006003 (0x4) IX[B] [37] -1 0 0x00006400 - 0x00006407 (0x8) IX[B] [38] -1 0 0x00006800 - 0x00006803 (0x4) IX[B] [39] -1 0 0x00007000 - 0x00007007 (0x8) IX[B] [40] -1 0 0x00005400 - 0x0000541f (0x20) IX[B] [41] -1 0 0x00005000 - 0x0000501f (0x20) IX[B] [42] -1 0 0x00004800 - 0x0000481f (0x20) IX[B] [43] -1 0 0x00004400 - 0x0000441f (0x20) IX[B] [44] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B](B) [45] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B] [46] 0 0 0x000003c0 - 0x000003df (0x20) IS[B] (II) Setting vga for screen 0. (II) Loading sub module "int10" (II) LoadModule: "int10" (II) Reloading /usr/lib/xorg/modules/libint10.so (II) NV(0): Initializing int10 (II) NV(0): Primary V_BIOS segment is: 0xc000 (--) NV(0): Chipset: "Unknown NVIDIA chipset" (**) NV(0): Depth 24, (--) framebuffer bpp 32 (==) NV(0): RGB weight 888 (==) NV(0): Default visual is TrueColor (II) Loading sub module "vgahw" (II) LoadModule: "vgahw" (II) Loading /usr/lib/xorg/modules/libvgahw.so (II) Module vgahw: vendor="X.Org Foundation" compiled for 7.0.0, module version = 0.1.0 ABI class: X.Org Video Driver, version 0.8 (==) NV(0): Using HW cursor (--) NV(0): Linear framebuffer at 0xE0000000 (--) NV(0): MMIO registers at 0xDF000000 (II) Loading sub module "i2c" (II) LoadModule: "i2c" (II) Reloading /usr/lib/xorg/modules/libi2c.so (II) Loading sub module "ddc" (II) LoadModule: "ddc" (II) Reloading /usr/lib/xorg/modules/libddc.so (II) NV(0): I2C bus "DDC" initialized. (II) NV(0): Probing for analog device on output A... (--) NV(0): ...found one (II) NV(0): Probing for analog device on output B... (--) NV(0): ...can't find one (II) NV(0): Probing for EDID on I2C bus A... (II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0. (II) NV(0): I2C device "DDC:ddc2" removed. (--) NV(0): DDC detected a DFP: (II) NV(0): Manufacturer: SNY Model: 1e70 Serial#: 16843009 (II) NV(0): Year: 2003 Week: 16 (II) NV(0): EDID Version: 1.3 (II) NV(0): Digital Display Input (II) NV(0): Max H-Image Size [cm]: horiz.: 34 vert.: 27 (II) NV(0): Gamma: 2.20 (II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display (II) NV(0): First detailed timing is preferred mode (II) NV(0): redX: 0.640 redY: 0.340 greenX: 0.290 greenY: 0.610 (II) NV(0): blueX: 0.140 blueY: 0.070 whiteX: 0.283 whiteY: 0.298 (II) NV(0): Supported VESA Video Modes: (II) NV(0): 720x400@70Hz (II) NV(0): 640x480@60Hz (II) NV(0): 800x600@60Hz (II) NV(0): 1024x768@60Hz (II) NV(0): Manufacturer's mask: 0 (II) NV(0): Supported Future Video Modes: (II) NV(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 (II) NV(0): Supported additional Video Mode: (II) NV(0): clock: 108.0 MHz Image Size: 338 x 270 mm (II) NV(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0 (II) NV(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0 (II) NV(0): Ranges: V min: 57 V max: 63 Hz, H min: 28 H max: 65 kHz, PixClock max 110 MHz (II) NV(0): Monitor name: SDM-X72 (II) NV(0): Serial No: 4765939 (II) NV(0): Probing for EDID on I2C bus B... (II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0. (II) NV(0): I2C device "DDC:ddc2" removed. (II) NV(0): ... none found (--) NV(0): CRTC 0 is currently programmed for DFP (II) NV(0): Using DFP on CRTC 0 (--) NV(0): Panel size is 1280 x 1024 (II) NV(0): Panel is TMDS (--) NV(0): VideoRAM: 262144 kBytes (==) NV(0): Using gamma correction (1.0, 1.0, 1.0) (WW) NV(0): config file vrefresh range 43-60Hz not within DDC vrefresh ranges. (II) NV(0): Generic Monitor: Using hsync range of 28.00-64.00 kHz (II) NV(0): Generic Monitor: Using vrefresh range of 43.00-60.00 Hz (II) NV(0): Clock range: 12.00 to 400.00 MHz (II) NV(0): Not using default mode "640x350" (vrefresh out of range) (II) NV(0): Not using default mode "320x175" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x400" (vrefresh out of range) (II) NV(0): Not using default mode "320x200" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "720x400" (vrefresh out of range) (II) NV(0): Not using default mode "360x200" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x480" (vrefresh out of range) (II) NV(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x480" (vrefresh out of range) (II) NV(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x480" (vrefresh out of range) (II) NV(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "800x600" (vrefresh out of range) (II) NV(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "800x600" (vrefresh out of range) (II) NV(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "800x600" (vrefresh out of range) (II) NV(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "1024x768" (vrefresh out of range) (II) NV(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "1024x768" (vrefresh out of range) (II) NV(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "1024x768" (hsync out of range) (II) NV(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "1152x864" (hsync out of range) (II) NV(0): Not using default mode "576x432" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x480" (bad mode clock/interlace/doublescan) (WW) (1280x960,Generic Monitor) mode clock 148.5MHz exceeds DDC maximum 110MHz (II) NV(0): Not using default mode "1280x960" (hsync out of range) (II) NV(0): Not using default mode "640x480" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x512" (bad mode clock/interlace/doublescan) (WW) (1280x1024,Generic Monitor) mode clock 135MHz exceeds DDC maximum 110MHz (II) NV(0): Not using default mode "1280x1024" (hsync out of range) (II) NV(0): Not using default mode "640x512" (bad mode clock/interlace/doublescan) (WW) (1280x1024,Generic Monitor) mode clock 157.5MHz exceeds DDC maximum 110MHz (II) NV(0): Not using default mode "1280x1024" (hsync out of range) (II) NV(0): Not using default mode "640x512" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1600x1200" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1600x1200" (unknown reason) (II) NV(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1600x1200" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1600x1200" (unknown reason) (II) NV(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1600x1200" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1600x1200" (unknown reason) (II) NV(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1600x1200" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1600x1200" (unknown reason) (II) NV(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1600x1200" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1600x1200" (unknown reason) (II) NV(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1792x1344" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1792x1344" (unknown reason) (II) NV(0): Not using default mode "896x672" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1792x1344" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1792x1344" (unknown reason) (II) NV(0): Not using default mode "896x672" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1856x1392" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1856x1392" (unknown reason) (II) NV(0): Not using default mode "928x696" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1856x1392" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1856x1392" (unknown reason) (II) NV(0): Not using default mode "928x696" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1920x1440" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1920x1440" (unknown reason) (II) NV(0): Not using default mode "960x720" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1920x1440" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1920x1440" (unknown reason) (II) NV(0): Not using default mode "960x720" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "832x624" (vrefresh out of range) (II) NV(0): Not using default mode "416x312" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x384" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "640x400" (bad mode clock/interlace/doublescan) (II) NV(0): Not using default mode "576x384" (bad mode clock/interlace/doublescan) (WW) (1152x864,Generic Monitor) mode clock 121.5MHz exceeds DDC maximum 110MHz (II) NV(0): Not using default mode "1152x864" (hsync out of range) (II) NV(0): Not using default mode "576x432" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1400x1050" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1400x1050" (unknown reason) (II) NV(0): Not using default mode "700x525" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1400x1050" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1400x1050" (unknown reason) (II) NV(0): Not using default mode "700x525" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1400x1050" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1400x1050" (unknown reason) (II) NV(0): Not using default mode "700x525" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1400x1050" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1400x1050" (unknown reason) (II) NV(0): Not using default mode "700x525" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1440x900" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1440x900" (unknown reason) (II) NV(0): Not using default mode "720x450" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1600x1024" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1600x1024" (unknown reason) (II) NV(0): Not using default mode "800x512" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1680x1050" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1680x1050" (unknown reason) (II) NV(0): Not using default mode "840x525" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1920x1200" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1920x1200" (unknown reason) (II) NV(0): Not using default mode "960x600" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1920x1200" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1920x1200" (unknown reason) (II) NV(0): Not using default mode "960x600" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "1920x1440" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "1920x1440" (unknown reason) (II) NV(0): Not using default mode "960x720" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "2048x1536" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "2048x1536" (unknown reason) (II) NV(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "2048x1536" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "2048x1536" (unknown reason) (II) NV(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan) (II) NV(0): Mode "2048x1536" is larger than BIOS programmed panel size of 1280 x 1024. Removing. (II) NV(0): Not using default mode "2048x1536" (unknown reason) (II) NV(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan) (--) NV(0): Virtual size is 1280x1024 (pitch 1280) (**) NV(0): *Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz (II) NV(0): Modeline "1280x1024" 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (**) NV(0): *Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz (II) NV(0): Modeline "1024x768" 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (**) NV(0): *Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz (II) NV(0): Modeline "640x480" 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (**) NV(0): Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz (II) NV(0): Modeline "1280x960" 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (**) NV(0): Default mode "1280x800": 83.5 MHz, 49.7 kHz, 60.0 Hz (II) NV(0): Modeline "1280x800" 83.46 1280 1344 1480 1680 800 801 804 828 (**) NV(0): Default mode "1280x768": 80.1 MHz, 47.7 kHz, 60.0 Hz (II) NV(0): Modeline "1280x768" 80.14 1280 1344 1480 1680 768 769 772 795 (**) NV(0): Default mode "1152x768": 65.0 MHz, 44.2 kHz, 54.8 Hz (II) NV(0): Modeline "1152x768" 65.00 1152 1178 1314 1472 768 771 777 806 +hsync +vsync (**) NV(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz (II) NV(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (**) NV(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz (II) NV(0): Modeline "800x600" 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (++) NV(0): DPI set to (100, 100) (II) Loading sub module "fb" (II) LoadModule: "fb" (II) Loading /usr/lib/xorg/modules/libfb.so (II) Module fb: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.0.0 ABI class: X.Org ANSI C Emulation, version 0.2 (II) Loading sub module "xaa" (II) LoadModule: "xaa" (II) Loading /usr/lib/xorg/modules/libxaa.so (II) Module xaa: vendor="X.Org Foundation" compiled for 7.0.0, module version = 1.2.0 ABI class: X.Org Video Driver, version 0.8 (II) Loading sub module "ramdac" (II) LoadModule: "ramdac" (II) Loading /usr/lib/xorg/modules/libramdac.so (II) Module ramdac: vendor="X.Org Foundation" compiled for 7.0.0, module version = 0.1.0 ABI class: X.Org Video Driver, version 0.8 (--) Depth 24 pixmap format is 32 bpp (II) do I need RAC? No, I don't. (II) resource ranges after preInit: [0] 0 0 0xde000000 - 0xdeffffff (0x1000000) MX[B] [1] 0 0 0xe0000000 - 0xefffffff (0x10000000) MX[B] [2] 0 0 0xdf000000 - 0xdfffffff (0x1000000) MX[B] [3] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B) [4] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [8] -1 0 0xddefc000 - 0xddefffff (0x4000) MX[B] [9] -1 0 0xdddf8000 - 0xdddfbfff (0x4000) MX[B] [10] -1 0 0xdddffc00 - 0xdddffc7f (0x80) MX[B] [11] -1 0 0xddcd8000 - 0xddcdbfff (0x4000) MX[B] [12] -1 0 0xddcdf800 - 0xddcdffff (0x800) MX[B] [13] -1 0 0xddbffc00 - 0xddbfffff (0x400) MX[B] [14] -1 0 0xddbff800 - 0xddbffbff (0x400) MX[B] [15] -1 0 0xddbf8000 - 0xddbfbfff (0x4000) MX[B] [16] -1 0 0xddfe0000 - 0xddffffff (0x20000) MX[B](B) [17] -1 0 0xde000000 - 0xdeffffff (0x1000000) MX[B](B) [18] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B) [19] -1 0 0xdf000000 - 0xdfffffff (0x1000000) MX[B](B) [20] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD) [21] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD) [22] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD) [23] 0 0 0x0000e800 - 0x0000e87f (0x80) IX[B] [24] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [25] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [26] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B] [27] -1 0 0x0000b800 - 0x0000b87f (0x80) IX[B] [28] -1 0 0x00009400 - 0x0000940f (0x10) IX[B] [29] -1 0 0x00009800 - 0x00009803 (0x4) IX[B] [30] -1 0 0x0000a000 - 0x0000a007 (0x8) IX[B] [31] -1 0 0x0000a400 - 0x0000a403 (0x4) IX[B] [32] -1 0 0x0000a800 - 0x0000a807 (0x8) IX[B] [33] -1 0 0x00000400 - 0x0000041f (0x20) IX[B] [34] -1 0 0x00007400 - 0x0000740f (0x10) IX[B] [35] -1 0 0x00007800 - 0x00007803 (0x4) IX[B] [36] -1 0 0x00008000 - 0x00008007 (0x8) IX[B] [37] -1 0 0x00008400 - 0x00008403 (0x4) IX[B] [38] -1 0 0x00008800 - 0x00008807 (0x8) IX[B] [39] -1 0 0x00005800 - 0x0000580f (0x10) IX[B] [40] -1 0 0x00006000 - 0x00006003 (0x4) IX[B] [41] -1 0 0x00006400 - 0x00006407 (0x8) IX[B] [42] -1 0 0x00006800 - 0x00006803 (0x4) IX[B] [43] -1 0 0x00007000 - 0x00007007 (0x8) IX[B] [44] -1 0 0x00005400 - 0x0000541f (0x20) IX[B] [45] -1 0 0x00005000 - 0x0000501f (0x20) IX[B] [46] -1 0 0x00004800 - 0x0000481f (0x20) IX[B] [47] -1 0 0x00004400 - 0x0000441f (0x20) IX[B] [48] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B](B) [49] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU) [50] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
*** If unresolved symbols were reported above, they might not *** be the reason for the server aborting.
Fatal server error: Caught signal 8. Server aborting
_________________ В технике, модератор — это устройство для уменьшения тяги в топке паровой машины на холостом ходу, что позволяет снизить расход топлива.
Последний раз редактировалось koi-8® 29.08.2006 18:18, всего редактировалось 1 раз.
lsmod | grep nvidia что показывает? покажи еще xorg.conf (подробности в теме Linux для новичка)
спасибо что откликнулся:)
ничего не показывает, вообще ни напоминания о таких модулях нету...
# /etc/X11/xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg
Последний раз редактировалось koi-8® 29.08.2006 18:35, всего редактировалось 1 раз.
чувствую себя беспросветным ламером
xserver-xorg-video-nv в системе стоит, однако modprobe его не может включить в ядро, говорит, мол, не найден.
думаю insmod'ом воткнуть, но не знаю где эти модули лежат (если есть вообще)
офф дрова с нвидии не встают, ругаются на много чего...
BusID именно 5 (lspci выдает 5:0.0)
кстати, про lspci, он мне выдает только строку с видеокартой, про дисплей как в примере ничего нету
Статус: Не в сети Регистрация: 08.03.2004 Откуда: Москва
это не дисплей, это вторая голова видеокарты.
На что родной драйвер с нвидии ругается?
установи новое ядро, 2.6.16-2 (оно же 2.6.16-18, сейчав в Etch) и header файлы к нему.
# apt-get install linux-headers-2.6.16-2-686 linux-image-2.6.16-2-686
если ядро пересобирал сам, то сорцы и так стоят.
На что родной драйвер с нвидии ругается? установи новое ядро, 2.6.16-2 (оно же 2.6.16-18, сейчав в Etch) и header файлы к нему. # apt-get install linux-headers-2.6.16-2-686 linux-image-2.6.16-2-686 если ядро пересобирал сам, то сорцы и так стоят.
ок, на 7600GT 2 головы, причем при подключении одновременно двух мониторов второй строки всеравно нет... мож у меня что с картой?
ядро установил, никаких отличий на заметил...
module assistant мне не помог, тоже на что-то ругнулся, вроде-бы на отсутствие исходных текстов модуля nvidia
дрова с офсайта говорят:
1. no precomplied interface was found, пробуем качать? (инета пока нет, тоже настраивать буду - DSL-200)
2. ругаются на версию gcc (ядро собрано gcc 4.0, в системе gcc 4.1 поэтому no warranties...)
3. инсталлер вылетает (не может включить модуль в ядро)
может мне руками ядро пересобрать с добавлением всего нужного? только как? =)
у меня рядом комп старый, но рабочий, я могу на нем поставить инет с аськой чтобы сразу всё попробовать (естессно если есть время и желание )
/usr/bin/gcc - символическая ссылка на /usr/bin/gcc-4.1 удали ссылку и сделай на gcc-4.0 (ln -s /path /path) порядок путей не помню, что первым, что вторым. Но в одном случае создаст, в другом скажет что существует. Не покалечишь ничего. Думаю и проблема с добавлением драйвера может решиться. С другой стороны lsmod еще раз попробуй, вполне возможно что драйвер то встал уже
_________________ Software is like a sex, it is better when it is free
Статус: Не в сети Регистрация: 05.01.2003 Откуда: г.Ногинск
Рабочи конфиг xorg.conf для видеокарт nvidia сдвумя мониторами (в примере это два LCD 17") отрисовка работет быстрее чем при использовании xinerama.
Конфиг работает в Debian Sid.
