Приветствую. Поставлен линукс CentOS 5.2
Вопрос, как прикрутить чертову яву к браузерам Firefox и Opera?
Саму яву вроде бы как-то поставил:
Код:
[root@alik downloads]# rpm -q jre
jre-1.6.0_12-fcs
и
Код:
[root@alik downloads]# rpm -q jdk
jdk-1.6.0_12-fcs
Но браузеры по прежнему нифига не понимают и не проходят проверки на www.java.com
Помогите, плиз.
p.s. я новичек, поэтому не пинайте сильно ногами, пожалуйста.
Zander0 писал(а):
[root@alik downloads]# rpm -q jdkjdk-1.6.0_12-fcs
ну это ставилось напрасно, ибо не надо. Нужно только jre.
Ну хороше, снести - не проблема. Дальше то что делать?
По моему ваш случай
The Java plug-in is part of the Java Runtime Environment (JRE), but Opera does not use the plug-in: it uses the JRE directly. To get Java working with Opera, you must install the JRE, and configure Opera with the correct Java path.
Before proceeding, you may wish to test Java to see if Opera has been able to auto-detect your Java installation using our test applet. If Opera does not show this applet (an animated analog clock), you must install the JRE and/or configure Opera with the correct Java path:
Download the Java Runtime Environment that is suitable for your system. For systems that are older than the ones listed in System Requirements on the download page, you will need version 1.3.1. Follow the installation instructions linked from the download page.
Go to Tools > Preferences > Advanced > Content, and click the "Java options" button. If this button is dimmed, first check the "Enable Java" option.
Click the "Choose" button for the "Java path" field. The path you are looking for is the directory of your Java installation containing the files libjava.so and libawt.so, for example /usr/lib/jvm/java-6-sun-1.6.0.03/jre/lib/i386 on an Ubuntu system. The command line tools indicated above should locate the directory.
Click the "Validate Java path" button. If you get an error message, try again with a different path.
Click "OK" to save your changes and exit the Java dialog. Click "OK" to save your changes and exit the Preferences dialog.
Оригинал тут
Почему бы сначала не попользовать google, как вариант?
проблема решилась?
If ignorance is bliss, then slap the grin off my face.
Solomon Torvus
