не могу поставить драйверы для WinFast GTX260
пробывал ставить на Ubuntu 9.04 и OpenSUSE 11.1
результат нулевой. Иксы не хотят стартвать
Ставил из репозитариев. Ставил вручную. Облазил кучу FAQ .
Ну не как не получаеться
Кратко о машине
P35,C2Duo - 8400,4Gb,WinFast GTX260
есть еще ТВ-ТЮНЕР Compro VideoMate H900 <TV Tuner, SECAM, Stereo, FM, 3D Y/C Separation, Remote Control, PCI> и веб камера
МОГУТ ОНИ ПОМЕШАТЬ УСТАНОВКЕ ДРОВ или нет?
я в отчаянии! Помогите
Xorg.0.log
Код:
X.Org X Server 1.6.0 Release Date: 2009-2-25 X Protocol Version 11, Revision 0 Build Operating System: Linux 2.6.24-23-server i686 Ubuntu Current Operating System: Linux grinnZli-ubuntu 2.6.28-11-generic #42-Ubuntu SMP Fri Apr 17 01:57:59 UTC 2009 i686 Build Date: 09 April 2009 02:10:02AM xorg-server 2:1.6.0-0ubuntu14 (buildd@rothera.buildd) Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Sat May 16 22:25:10 2009 (==) Using config file: "/etc/X11/xorg.conf" (==) No Layout section. Using the first Screen section. (**) |-->Screen "Default Screen" (0) (**) | |-->Monitor "Configured Monitor" (**) | |-->Device "Configured Video Device" (==) Automatically adding devices (==) Automatically enabling devices (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. Entry deleted from font path. (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, built-ins (==) ModulePath set to "/usr/lib/xorg/modules" (II) Cannot locate a core pointer device. (II) Cannot locate a core keyboard device. (II) The server relies on HAL to provide the list of input devices. If no devices become available, reconfigure HAL or disable AllowEmptyInput. (II) Loader magic: 0x3bc0 (II) Module ABI versions: X.Org ANSI C Emulation: 0.4 X.Org Video Driver: 5.0 X.Org XInput driver : 4.0 X.Org Server Extension : 2.0 (II) Loader running on linux (++) using VT number 7
(--) PCI:*(0@1:0:0) nVidia Corporation GT200 [GTX260-216] rev 161, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xec000000/33554432, I/O @ 0x0000a000/128, BIOS @ 0x????????/524288 (II) Open ACPI successful (/var/run/acpid.socket) (II) System resource ranges: [0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B] [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B] (II) "extmod" will be loaded by default. (II) "dbe" will be loaded by default. (II) "glx" will be loaded. This was enabled by default and also specified in the config file. (II) "record" will be loaded by default. (II) "dri" will be loaded by default. (II) "dri2" will be loaded by default. (II) LoadModule: "glx" (II) Loading /usr/lib/xorg/modules/extensions//libglx.so (II) Module glx: vendor="NVIDIA Corporation" compiled for 4.0.2, module version = 1.0.0 Module class: X.Org Server Extension (II) NVIDIA GLX Module 180.44 Mon Mar 23 15:29:02 PST 2009 (II) Loading extension GLX (II) LoadModule: "extmod" (II) Loading /usr/lib/xorg/modules/extensions//libextmod.so (II) Module extmod: vendor="X.Org Foundation" compiled for 1.6.0, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 2.0 (II) Loading extension MIT-SCREEN-SAVER (II) Loading extension XFree86-VidModeExtension (II) Loading extension XFree86-DGA (II) Loading extension DPMS (II) Loading extension XVideo (II) Loading extension XVideo-MotionCompensation (II) Loading extension X-Resource (II) LoadModule: "dbe" (II) Loading /usr/lib/xorg/modules/extensions//libdbe.so (II) Module dbe: vendor="X.Org Foundation" compiled for 1.6.0, module version = 1.0.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 2.0 (II) Loading extension DOUBLE-BUFFER (II) LoadModule: "record" (II) Loading /usr/lib/xorg/modules/extensions//librecord.so (II) Module record: vendor="X.Org Foundation" compiled for 1.6.0, module version = 1.13.0 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 2.0 (II) Loading extension RECORD (II) LoadModule: "dri" (II) Loading /usr/lib/xorg/modules/extensions//libdri.so (II) Module dri: vendor="X.Org Foundation" compiled for 1.6.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 2.0 (II) Loading extension XFree86-DRI (II) LoadModule: "dri2" (II) Loading /usr/lib/xorg/modules/extensions//libdri2.so (II) Module dri2: vendor="X.Org Foundation" compiled for 1.6.0, module version = 1.0.0 ABI class: X.Org Server Extension, version 2.0 (II) Loading extension DRI2 (II) LoadModule: "nvidia" (II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so (II) Module nvidia: vendor="NVIDIA Corporation" compiled for 4.0.2, module version = 1.0.0 Module class: X.Org Video Driver (II) NVIDIA dlloader X Driver 180.44 Mon Mar 23 15:05:32 PST 2009 (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs (II) Primary Device is: PCI 01@00:00:0 (II) Loading sub module "fb" (II) LoadModule: "fb" (II) Loading /usr/lib/xorg/modules//libfb.so (II) Module fb: vendor="X.Org Foundation" compiled for 1.6.0, module version = 1.0.0 ABI class: X.Org ANSI C Emulation, version 0.4 (II) Loading sub module "wfb" (II) LoadModule: "wfb" (II) Loading /usr/lib/xorg/modules//libwfb.so (II) Module wfb: vendor="X.Org Foundation" compiled for 1.6.0, module version = 1.0.0 ABI class: X.Org ANSI C Emulation, version 0.4 (II) Loading sub module "ramdac" (II) LoadModule: "ramdac" (II) Module "ramdac" already built-in (II) resource ranges after probing: [0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B] [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B] (II) NVIDIA(0): Creating default Display subsection in Screen section "Default Screen" for depth/fbbpp 24/32 (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32 (==) NVIDIA(0): RGB weight 888 (==) NVIDIA(0): Default visual is TrueColor (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0) (**) NVIDIA(0): Option "NoLogo" "True" (**) NVIDIA(0): Enabling RENDER acceleration (II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is (II) NVIDIA(0): enabled. (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device PCI:1:0:0. (EE) NVIDIA(0): Please see the COMMON PROBLEMS section in the README for (EE) NVIDIA(0): additional information. (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device! (II) UnloadModule: "nvidia" (II) UnloadModule: "wfb" (II) UnloadModule: "fb" (EE) Screen(s) found, but none have a usable configuration.
Fatal server error: no screens found
Please consult the The X.Org Foundation support at http://wiki.x.org for help. Please also check the log file at "/var/log/Xorg.0.log" for additional information.
