Статус: Не в сети Регистрация: 02.05.2004 Откуда: Moscow
Daemon А как называется работа компьютера без сбоев и глюков?? Может не будем бросаться в крайности?? Мне Вам по почте надо свой компьютер прислаить, что бы Вы были уверены в что я не вру???
Вот вам для прикола переписка с суппортом:
aopen technical support 328
To: <support_us@aopen.com>; <support_aoa@aopen.com.tw>
> Problem description = My CPU have a default ratio = x11. On mothrboard not
> work CPU ratio lower that x9. When i set ratio lower that x9, CPU run at
Nap
the ratio should be left at default or what is auto detected, if the cpu
is not read at the correct speed you would need to change the fsb if the
chip on the motherboard to the correct speed, it should be a jumper or in
the bios
Problem description = My CPU have a default ratio = 11 (133x11=1466MHz).
On mothrboard not work CPU ratio lower that x9. For example I want
overclock my computer and set bus frequency 200MHz with ratio =7
(200x7=1400MHz). But when my computer start, CPU frequency is 2200 MHz!
When I go into BIOS I see my setting ratio =7 again, after reboot CPU
frequency again 2200MHz. Why it happen???????????????
Hello,
I am sorry to inform you but we can't help you overclock your computer. If
your cpu is running at the correct speed, then there is no problem.
Best regards,
> Hello.
> I am sorry, but I dont need help to overclock my computer. I need
correct
> work my BIOS settings! If my BIOS propose change settings of the ratio
from
> 5 to 22, I want correct work this settings, but my BIOS not work correct
> with settings of the ratio lower that 9!!! Please solve this error in next
> versions of BIOSes.
> Thanks.
It might just be your CPU. its clock ratio is locked and you cannot get a
ration below spec. Also, we will try to see what our next bios revision will
offer..
> Please, check this problem on your mothrboards. My CPU ration is not
locked.
> I check this situation with CPU Duron 800Mhz(8*100MHz) with unlocked
ratio.
> By default ratio is 8 and CPU work on 800 MHz. When I set ratio from 5 to
> 7,5 and 8,5 , CPU start on 800 MHz anyway. When I set ratio =9, then CPU
> start on 900MHz.
> Also this problem check other users of the motherboards AK79-400 in the
> forum about motherboards and they have same problem.
Hello
Aopen does not support overclocking, for the ratio it should be set at
default or what the motherboard detects it at, the fsb should be changed to
133 if the cpu has a 266 fsb
Вот Вам и все возможности для разгона.
Добавлено спустя 9 минут, 15 секунд: У меня по 12V датчику напряжение примерно 11.7, что вполне приемлемо. Я гдето читал что преобразователь питания процессора на этой плате работает от 12В. И это лучше чем от 5В, т.к. при сильной нагрузке на 5В, блок питания повышает входное напряжение, что в свою очередь увеличивает ВСЕ выходные напряжения и получается что мы имеем 4,8В и 12,7В. А повышенное напряжения по 12В ой как не любят винты - говорят горят, бывает.
Добавлено спустя 7 часов, 18 минут, 3 секунды: Несколько слов в защиту автора:
Чо вы на него накинулись как собаки. Каждый может иметь своё мнение, отличное от других. Каждый имеет право (и склонность) понимать отдельные слова и выражения по своему.
У меня тоже такая плата, и в общем доволен как питон...Помоему там на плате правда перепутали с разводкой мол CPUFan и SYSFan регулируются как один, но в общем это не ужас, если хочешь чтобы они регулировались независимо - переключаешь SYSFan на SYSFan2 и порядок.
По дефолту мой AthlonXP1700+ заработал только на 10,5*185=1943Mhz
В общем и проц попался неудачный, максимум жмёт 2000Mhz да и память моя TwinMOS3200, не хочет на 200 пахать, запускал я на 200 - сразу выкидывала гору ошибок в программе для тестирования оперативки TestMem.
А плата сама по себе мне нравиться, цевильно сделана, до этого у меня была DFI AK77PRO На KT400. ну что сказать - хуже была.
Добавлено спустя 2 минуты, 2 секунды: Evpen
Кстати, коллега, ты тестировал прогу EzRestore? Что она делает и почему есть прямо поддержка на уровне биоса?? Вроде образ делает партишена? Я прав или нет?
Добавлено спустя 3 минуты, 16 секунд: Evpen Да, вот ещё что... Какая у тебя на ней оперативка стоит? Какая марка и модель если можно, надо же поменять свою типа 400DDR-ную, которая даже не тянет на такой частоте:)
Статус: Не в сети Регистрация: 14.01.2004 Откуда: Киев, Украина
Excellent О фиговой разводке я уже говорил, правльнее будет(по стандарту положено) подключать процессорный фан к PWRFAN4. У меня стоит DDR 400 Samsung и гониться нехило.
Купил я AOpen AK79D-400VN в K-Trade (Украина г. Львов) за 75.00$. Раньше у меня была такая машина: Athlon 1700 XP+, HDD-120 GB (WD120JB 7200), RADEON 9100 SERIES 64 MB DDR, SDRAM 384 MB (PC-133), FDD, CD-ROM SAMSUNG RW 52-24-52, все это стояло на мамке GIGABATE GA-7ZXE (KT-133A) и блок питания 250 Вт. Эта конфигурация работала отлично как швейцарские часы без глюков и сбоев.
И вот что я вам скажу, поставил на AOpen все это (кроме старой материнке конечно) и еще поставил оперативку 256 MB NCP 2700 в замен старой, и поменял блок питания на 300 Вт (Super Power Codegen) .
Стали, появляются глюки: комп начал виснуть в любых программах от 1С-Бухгалтерии 7.7 и до зависания в играх NFS-5, Quake III Arena и т.д. Пришел я в сервис центр там, где брал материнку сначала они вставили свою оперативную память 256 MB NCP 3200, но это не помогло, далее были варианты отключения CD-ROM’а, флопика, вставили другую видео карту RADEON 9600 Pro 128 MB DDR, меняли блок питания, но это все так же приводило к зависанию компьютера.
На самом последнем мести поменяли другой процессор мой Athlon 1700+ XP на
Duron 1.8 GHz зависаний больше не было и конфигурация выглядит следующим образом: AOpen AK79D-400VN, HDD-120 GB (WD120JB 7200), RADEON 9100 SERIES 64 MB DDR, FDD, CD-ROM SAMSUNG RW 52-24-52, 300 Вт (Super Power Codegen). Но я тестировал свой процессор на KT133A, и он работал без глюков и зависаний значит дело не в процессоре?
После этого я поменял процессор на Athlon 1900+ XP было пару зависаний в Word 2003 и в пасьянсе косынка, а раньше было зависания в игр и т.д. но сейчас в NFS 5 их нет.
Я гонял материнку в 3D Mark 2001 SE (было выбрано 17 тестов) при Athlon 1700+ XP зависания были постоянно, даже не доходило до 5го теста. А при Athlon 1900+ XP зависаний не было ни в 3D Mark 2001 SE (прошел все 17 тестов, я повторял операцию 20 раз, зависаний не было).
Показания датчиков в БИОСе
CPU Temp. 39/102’F
SYS Temp. 31/88’F
Vcore (V) 1.73 V
CPU FAN 3214 RPM
+3.3 V 3.33 V
+5 V 4.84 V
+12 V 13.02 V -12 V 12.08 V
-5 V -5.77 V VBAT (V) 3.22 V
5VSB (V) 4.95 V
Не понятно, почему так изменяется вольтаж?
P.S. Все тесты были в Windows XP сборка 2600 (без сервис паков).
Подскажите из-за чего такая не совместимость Athlona 1700+ XP c AOpen AK79D-400VN и не особая стабильная работа с Athlon 1900+ XP. Стоит ли идти в сервис центр?
Также компьютер плохо включается при оперативной памяти 256 MB NCP 2700, то есть при выключении компьютера его сразу нельзя включить, а надо подождать минут 5-6.
Посоветуйте что делать, пожалуйста. В каких тестах ее погонять. Пишите на мыло asterix52@rambler.ru
Статус: Не в сети Регистрация: 01.03.2003
asterix52
1. не обновляли ли биос? последний от 2004/07/14 - R1.14 тут 2. напряг может скакать от глюков мониторинга или же от галимого БП, коем является и являются все БП от кодеген и им подобные...
3. протести память на "валидность" с помощью memtest_a
исправления в версиях биос..
R1.11 Fixed some DDR can't Boot. R1.09 Patch some DDR memory unstable issue.
QNX понятно твое желание помочь всем и вся на то ты и 2fast2furious*, но как человек, который являеться обладателем сего чуда, могу сказать следующие.
asterix52 в твоем случае - проблема питания. Codegen каким бы мощным не был, всеравно остаеться г... Схема питание процессора построена от 12 в, а у тебя оно из-за некачественного блока оно завышено, вот и может и глючить проц. Так что меняй бп. Плюс у этой материнки наблюдаеться потеря стабильности при работе с некоторыми множетелями. Какими - непомню.
Короче говоря помоему тут и питание и возможно битая материнка. Замена БИОСа вовсе никак не влияет на работу.
Кстате у меня Хорошо разогнаный Athlon XP 1700+. То ли из-за процессора, то ли сама мать виновата, нестабильность на частотах шины выше 185мгц.
Совет - колдуй пока все не уладиться, по моему проблема в бп
