Eset Smart Security beta 2 contains the following changes:
PROGRAM
• The graphical user interface has been rebuilt.
• Installers for Windows XP/2003/Vista x64 are now available.
• Files and folders can now be scanned from the explorer's context menu.
• Various bugs have been fixed.
UPDATE
• Creation of update mirrored files is now supported. The mirror settings are available in the advanced update setup. For update via HTTP you can now choose the desired authentication method.
ANTISPAM
• A plugin for Outlook Express and Windows Mail now enables filtering unsolicited email in these mail clients.
Сейчас этот форум просматривают: Majestic-12 [Bot] и гости: 30
