Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 1025 • Страница 1 из 52 • 1  2  3  4  5 ... 52  >
Последняя финальная версия 5.53: :up:
http://www.overclockers.ru/softnews/28767.shtml
Последний раз редактировалось QNX 22.11.2006 3:36, всего редактировалось 18 раз(а).
Спасибо :)
http://download.nullsoft.com/winamp/cli ... 3_full.exe
http://download.nullsoft.com/winamp/cli ... 03_pro.exe
http://download.nullsoft.com/winamp/cli ... 3_lite.exe
Код:
Winamp 5.03:
* made MP4 AAC the new default ripping encoder
* fixed a crash bug when playing some AVI files in in_dshow
* added multimedia keyboard keys in global hotkeys default configuration
* added "Manual playlist advance" in Repeat button popup menu in Classic mode
* improvements in MP3 encoder configuration (added --alt-preset standard, etc...)
* made the tabs in the preferences XP correctly themed under Windows XP
* revamped the Media Library preferences a bit
* new experimental WMA9 input plugin
* gen_jumpex updates from DrO
* added "Nuke library" action in Media Library
* more upside down videos fixes
* fixed crash if a plugin generated a pledit wm_windowposchanged on shutdown
* fixed crash exploit in in_mod (thanks Peter Winter-Smith)
* fixed various crashes in in_midi when playing invalid files
* made in_midi store its settings in winamp.ini instead of the registry
* fixed error during installation on computers with chinese/oriental regional settings
* removed AOD from installer
* added Shift-R to toggle manual playlist advance
* updated VP6 video decoder to latest VP6.2 code
* fixed crash when launching winamp with very long filenames from explorer
* made registration dialog to appear in Explorer's taskbar when installing pro version
* fixed pledit/video windows showing up at startup when minimized
* modern skins updates :
  - winamp modern skin now uses a 3 state repeat button: no repeat/repeat all/repeat track
  - added appplication desktop toolbars capabilities for layouts, add
      appbar="left|top|right|bottom" to use them
  - upped maki binary version, improved stack protection
  - current skin version number is 1.2 (this should not change for a long while now, and
    of course we continue to support 0.8 to 1.1)
  - (very) limited maki debugger (for now you can bring it up with invokeDebugger(); in a
    script then use 'x' to continue and 'i' to trace into)
  - fixed obscure capture problem with dragging windows
  - fixed rectrgn being forced to 1 in xml xuiobject buttons that are originally imageless
  - fixed hilited state not on after clicking on buttons while the mouse stays in area
  - fixed scripted onEnterArea/onLeaveArea not being always correctly called while mouse
    button stays down
  - fixed getToken being passed NULL throwing guru
  - fixed clipping of painting within the background's region of a group rather than
    within the composed region (the one you can change with sysregion)
  - fixed image cache problem when using the same bitmap as a map and a button image
    parameter
А чем версия Про отличается от Full ?
Fractal
Версия Про, по-моемому, позволяет проигрывать ДВД, но для этого надо ввести регистрационный ключ, т.е. Про это тот же самый Фулл только с введенным регистрациооным ключом.
Вестник драйверостроения
Fractal
Сейчас в новость допишу отличия, потом здесь отпишусь.
Добавлено спустя 31 минуту, 1 секунду:
Fractal
Готово. Загляни еще раз в новость http://www.overclockers.ru/news/newsite ... 1080280256.
Сорри, чуть-чуть ошибся :oops:
Обновился до версии 5.03а
ссылки те же...
Только я скачал версию 5.03, уже вышла 5.03а... Подстава...
Сорри за оффтоп, обидно...
386SX -> 486DX2 -> Cel433 -> Cel533 -> Cel633 -> PIII800 -> AXP 2600+ -> A64 3000+ -> C2D E4300 -> E7200 -> Q9500
QNX
А список изменений есть? А то вроде скачал, а нигде про "а" не написано...
fin
изменился размер файлов на сервере, а изменения неизвестны :D
Блин, "а" , "б" , "в", Нулсофт свой Винамп, наверное, будет обновлять как Download Master or Nero,
т . е. не прошел и месяц :)
с первым апреля чуваки
Вылечу кривые руки топором!!!
Я тоже подумал, что "а" = апрель :)
Всем привет!
Пару дней назад ко мне приходил друган с винтом.
Ну и я загреб себе 20Гиг музыки.
Как и ожидалось, упорядоченность композиций оставляла желать лучшего.
Композиции свалены в кучу.
Вчера стал эту кучу разгребать.
Слушаю песню - если не нравиться - удаляю(через командер), но по этой методике я оч. быстро запарился.
Потому решил спросить:
Можно ли удалить с диска MP3 файл прямо из под Winamp-a?
У меня Winamp 5.03
Всем спасибо.
Да можно. Если у тебя WinAmp 5.03 руссифицированный(если английский см. в скобках): Rem-->Стереть(самая нижняя кнопка)-->Удалить выбранные файлы с диска(тоже самая последняя).
Accel Хинт: Рекомендую использовать какой-нить каталогизатор-переименовщик (я использую Tag & Rename)
Добавлено спустя 26 секунд:
Кстати, прямо в нем можно и послушать трек.
One, two, three and to the fo'
Snoop Doggy Dogg and Dr. Dre are at the do'
Мономах
Точно...
Сработало...
Спасибо... :beer:
You will find only pain living in the past
Re Disque
А можно немного подробнее о возможностях этого самого каталогизатора? Кстати существует ли прога, которая может для групы mp3 сделать одинаковый тэг. Например имеется 20штук mp3 Linkin Park "Meteora", id3 тэг не заполнен(сграблено с сд-аудио). Нужно для всех поставить Автор: Linkin Park, альбом: Meteora.
Мономах Можно!
есть, прога называется MP3 навигатор. ссылки у меня нет ... поищи..
он может и из id3 название загонять и наоборот, общего артиста, альбом ... делать
поищи.
... подумал я.
Последний раз редактировалось 4upuk 25.06.2004 10:26, всего редактировалось 1 раз.
Сейчас этот форум просматривают: LeX_6000 и гости: 16
