Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 4
Помогите как из DVD диска повырезать куски фильма чтоюы качество не упало. Пробовал DVD2AVI получается плохо особенно быстрые сцены. Что посоветуете?
если ты режешь VOB файлы...
то режь куски с помощью Mpeg2Cut
http://www.geocities.com/rocketjet4 - новая... 2...
через гугл можно найти простую.. оригинальную.. версия 1.15
41 Ищи прогу под названием vobSplitter в сети, вот её описание из ридми:
* vobSplitter Version 2.6 fixed
* (26/11/2001) Build date
* By Anastasis Chatzioglou (Anasto)
The "vobSplitter" is a program (for Windows/Linux [when available])
with the ability to extract a part of .VOB file (file of DVD disc).
Useful if you want a part of .VOB (for a collection or something)
WARNING
this is not a program for coping DVD
or violate the copyrights law use it
with your own risk.
Usage : vobsplit
(see the Help tab [tiny help for now])
* Copyright (c) 2000-01 Anastasis Chatzioglou (Anasto)
url : http://anasto.go.to
e-mail : anasto@go.to
baldycom@hotmail.com
For any comments or bugs
* Please report any bug you find, but with a small description so
I can reproduce the error
* For now the only supported platform is Win32 (GUI),
if you want the "vobSplitter" in a different platform you
have to wait for a while, until I get a compiler for Linux (Kylix)
History
Ver 1.0 27/03/2000 First Public Release
(One little thing is that, the .vob file
MUST NOT be read-only)
I have only test it with PowerDVD player
and works just fine. Enjoy!
Ver 1.0a 29/03/2000 Minor bug fixed in counter. (Never released)
Ver 1.1 30/03/2000 Changed The read method and now you can
read directly DVD (you don't have to copy .vob
to HDD and reset the read-only)
I also add the ability to copy or not the
4k-Header
Ver 1.50 05/04/2000 I added a simple GUI after requests
Ver 1.60 10/04/2000 Now with .INI file for History keeping
Ver 2.00 09/07/2001 New 32-bit version with no 2GB file limit
(64-bit file Support) and new interface (easier)
mail me for bugs
Ver 2.01 19/08/2001 New interface Linux-like, some bugfixes
(you need qtintf.dll)
Ver 2.5 29/09/2001 Several bugfixes
No need of qtinf.dll
Improve Interface, many additions
Better help (Tips@Tricks.txt) on Memo
Ver 2.6 26/11/2001 Fixes the main problem of 2.5 (starts from begging of file)
Added FileOp.DLL (plug-in) to split (to join...not yet)
More right-clicks (on process button)
new Pie progress bar, more to come.
DOOM 3 RulleZZZ Forever!!!
Guk
по сравнению с утилитой, вриведеной выше, по vobSplitter могила плачет..
+ опций мало... сакс вобщем :D
Сейчас этот форум просматривают: anta777, Din'K@.76 и гости: 31
