Здравствуйте.
У меня в журнале событий постоянно повторяется эта ошибка. К ней даётся описание: "Не удалось открыть службу сервера. Данные производительности сервера не будут возвращены. В данных находится возвращенный код ошибки - в DWORD 0."
Что это такое? Нигде не могу нарыть инфы про неё. Может быть, знаете?
ASUS P8Z77-V PRO, i7 3770K@4,2Ghz, 4x4GB Hynix DDR3@1600Mhz, Palit 1070 GR@GRP, Chieftec 750W
Посмотри по ошибке Event ID и поищи по нему на сайте www.eventid.net
savelyy спасибо тебе. Проблему решил.
Вот, что нашёл на сайте www.eventid.net:
Anonymous (Last update 2/12/2004):
Based on the other comments related to this Event ID, it seemed that this event has something to do with File & Print Sharing. Therefore, I uninstalled and then reinstalled this service and now all is well.
Adrian Grigorof
Run exctrlst.exe (Extensible Counter Listing Tool) from the resource kit (see the link below for download) and disable the counter if you don't use it.
As per Microsoft: "The extensible counter list utility (EXCTRLST.EXE) is used to obtain information about the extensible performance counter dynamic-link libraries (DLLs) on a computer running Windows NT/Windows 2000. This utility lists the applications, drivers, and services that are registered to provide performance data through the performance registry. You can use this utility for finding information and for troubleshooting"
A. Unikowski
To fix this error, I had previously used the EXCTRLST.EXE utility and disabled the performance counters. This stopped the error message appearing in the event viewer, but I still did not have a server service in Services and I got an error message when clicking on shares in computer Management.Not a big deal I suppose, but I wanted to find out what was wrong. As I have a stand alone machine, I did not have File and Printer Sharing for Microsoft Networks installed. So, I went to dial up properties for my Dial up connection, Under Networking, installed the service File and Printer Sharing for Microsoft Networks Left the check box for this service blank (as I don't want to use it) This immediately enabled the server service and I have since re-enabled the performance counters without any problems or error messages. A sharing tab now also appears under folder properties.
Сейчас этот форум просматривают: Prophy2000, Гжегорж, WhiteRatify и гости: 17
