Помогите, пожалуйста, разогнать Intel Quad Q6600@2400Mhz до 3200Mhz. У кого есть именно такие мать, проц и память...
Купил новую материнскую плату Asus P5QD Turbo и память Kingston KHX8500D2K2/4G (два модуля по 2 Гига). Корпус хорошо продувается. БП Chiefec BPS-550C. Кулер Zalman 10X Performa. В железе и ПО не лох. Но в разгоне - новичек.....хотя кучу форумов перечитал.
Ищу мнения ассов с этого сайта (здесь людям больше доверяю). За ранее спасибо!!!
AI TWEAKER Configure System Performance Settings Ai Overclock Tuner *[Manual] [Auto] CPU Ratio Setting [Auto] [0.6] - [0.9] Шаг 0.1 FSB Frequency [266] PCIE Frequency [100] FSB Strap to North Bridge [Auto] [200Mhz] [266Mhz] [333Mhz] [400Mhz] DRAM Frequency [DDR2-533Mhz] [DDR2-639Mhz] [DDR2-667Mhz] [DDR2-709Mhz] [DDR2-800Mhz] [DDR2-852Mhz] [DDR2-887Mhz] [DDR2-1066Mhz] DRAM Timing Control *[Auto] [Manual] 1st Information: 5-5-5-18-3-52-6-3 CAS# Latency [5 DRAM Clocks] (3-11) DRAM RAS# to CAS# Delay [5 DRAM Clocks] (3-18) DRAM RAS# Precharge [5 DRAM Clocks] (3-18) DRAM RAS# Activate to Precha [15 DRAM Clocks] (3-18) RAS# to RAS# Delay [Auto] (от 1 до 15 DRAM Clocks) Row Refresh Cycle Time [Auto] (20,25,30,35,40,45,50,55,60,65,70,80,85,105,132 DRAM Clocks) Write Recovery Time [Auto] (от 1 до 15 DRAM Clocks) Read to Precharge Time [Auto] (от 1 до 15 DRAM Clocks) 2nd information: 8-3-6-4-6-4-7 READ to WRITE Delay (S/D) [Auto] (от 1 до 15 DRAM Clocks) Write to Read Delay (S) [Auto] (от 1 до 15 DRAM Clocks) WRITE to READ Delay (D) [Auto] (от 1 до 15 DRAM Clocks) READ to READ Delay (S) [Auto] (от 1 до 15 DRAM Clocks) READ to READ Delay (D) [Auto] (от 1 до 15 DRAM Clocks) WRITE to WRITE Delay (S) [Auto] (от 1 до 15 DRAM Clocks) WRITE to WRITE Delay (D) [Auto] (от 1 до 15 DRAM Clocks) 3rd Information: 15-5-1-7-7 WRITE to PRE Delay [Auto] (от 1 до 15 DRAM Clocks) READ to PRE Delay [Auto] (от 1 до 15 DRAM Clocks) PRE to PRE Delay [Auto] (от 1 до 3 DRAM Clocks) ALL PRE to ACT Delay [Auto] (от 1 до 15 DRAM Clocks) ALL PRE to REF Delay [Auto] (от 1 до 15 DRAM Clocks)
DRAM Static Read Control *[Auto] [Disabled] [Enabled] DRAM Read Training *[Auto] [Disabled] [Enabled] MEM. OC Charger *[Auto] [Disabled] [Enabled] Ai Clock Twister *[Auto] [Lighter] [Light] [Moderate] [Strong] [Stronger] Ai Transaction Booster C/P: A1 A2 A3 A4 A5 I B1 B2 B3 B4 B5 LVL: 11 11 11 11 11 I 11 11 11 11 11 *[Auto] [Manual] Common Performance Level [05] (может принимать значения от 1 до 31) Pull-In of CHA PH1 *[Disabled] [Enable] Pull-In of CHA PH2 *[Disabled] [Enable] Pull-In of CHA PH3 *[Disabled] [Enable] Pull-In of CHA PH4 *[Disabled] [Enable] Pull-In of CHA PH5 *[Disabled] [Enable] Pull-In of CHB PH1 *[Disabled] [Enable] Pull-In of CHB PH2 *[Disabled] [Enable] Pull-In of CHB PH3 *[Disabled] [Enable] Pull-In of CHB PH4 *[Disabled] [Enable] Pull-In of CHB PH5 *[Disabled] [Enable] Please key in numbers directly! CPU Voltage *[Auto] (Min=0.85000V; Max=1.7V (джемпером до 2.1V)) CPU GTL Reference *[Auto] (0.65x; 0.63x; 0.61x) Опасно! CPU PLL Voltage *[Auto] (Min=1.50V; Max=2.78V; Standart=1.50V; Increment=0.02V) FSB Termination Voltage *[Auto] (Min=1.20V; Max=1.90V; Standart=1.20V; Increment=0.02V) DRAM Voltage *[Auto] (Min=1.80V; Max=3.08V; Standart=1.80V; Increment=0.02V) NB Voltage *[Auto] (Min=1.10V; Max=1.90V; Standart=1.10V; Increment=0.02V) SB Voltage *[Auto] (Min=1.10V; Max=1.40V; Standart=1.10V; Increment=0.10V) PCIE SATA Voltage *[Auto] (Min=1.50V; Max=1.80V; Standart=1.50V; Increment=0.10V) Load-Line Calibration *[Auto] [Disabled] [Enabled] CPU Spread Spectrum *[Auto] [Disabled] PCIE Spread Spectrum *[Auto] [Disabled] CPU Clock Skew *[Auto] (Min=Delay 100ps; Max=Delay 1500ps; Standart=Auto; Increment=100ps) NB Clock Skew *[Auto] (Min=Delay 100ps; Max=Delay 1500ps; Standart=Auto; Increment=100ps) CPU Margin Enhancement *[Optimized] [Compatible] [Performance Mode]
Статус: Не в сети Регистрация: 15.01.2009 Фото: 6
Шина\Память 1:1 CPU Voltage 1.4 (потом понизишь). Множитель 8. FSB Frequency 400. Затем опытным путем будешь понижать CPU Voltage. Если процессор не древний, недавно выпущеный G0, то можешь сразу выставить множитель 8, FSB Frequency 450. Либо 9*400 (что будет помедленнее). В итоге 3600. DRAM Voltage только для начала надо будет 2,0 выставить (думаю будет достаточно). А затем опытным путем его понизить (может даже до 1,8). Как называются множитель и делитель шина\память на твоем МП ищи в профильной ветке.
