Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 7
Здравствуйте.
Железо почти в той же комплектации работало 2 года 24/7 на разгоне. Параметры не известны.
Сменился лишь БП и добавлены еще 3х2гб планки..
Стоковые параметры стабильны..
CPU: Intel Core i7-920
M/B: GIGABYTE GA-EX58-UD5 : F12
RAM: Crucial Ballistix BL25664TG1608 12GB (6 x 2GB)
PSU: CORSAIR GS800
Стоковые настройки стабильны.. но при подгоне под прежний XMP - БСОДы.
Advanced CPU Features:
CPU Clock Ratio ................................ [x21]
Intel(R) Turbo Boost Tech .................. [Enabled]
CPU Cores Enabled ............................ [All]
CPU Multi Threading .......................... [Enabled]
CPU Enhanced Halt (C1E) ................... [ENABLED]
C3/C6/C7 State Support .................... [DISABLED]
CPU Thermal Monitor ......................... [Enabled]
CPU EIST Function ............................ [ENABLED]
Bi-Directional PROCHOT ..................... [Enabled]
Uncore & QPI Features:
QPI Link Speed .............................. x36 (QPI frequency 5.76 GHz)
Uncore Frequency .......................... 3200 MHz (Uncore Multiplier x 20)
Isonchronous Frequency .......................... [ENAbled]
Standard Clock Control:
Base Clock (BCLK) Control ................ [Enabled]
BCLK Frequency (MHz) ..................... 160
PCI Express Frequency (MHz) ........... Auto [100]
C.I.A.2 [Disabled]
Advanced Clock Control:
CPU Clock Drive ..............................Auto [800mV]
PCI Express Clock Drive ................... Auto [900mV]
CPU Clock Skew ............................. Auto [0ps]
IOH Clock Skew ............................. Auto[0ps]
Advanced DRAM Features:
Performance Enhance ...................... [STANDARD]
Extreme Memory Profile (X.M.P) ......... [Profile1]
System Memory Multiplier (SPD) ........ x10
DRAM Timing Selectable (SPD) .......... [AUTO]
CPU Vcore .............................1.35000
QPI/Vtt .................................. 1.375
QPI PLL .................................. 1.840
IOH Core 1.100v ..................... AUTO
ICH I/O 1.500v ....................... Auto
ICH Core 1.1v ........................ Auto
DRAM
DRAM Voltage 1.500v ..............1.66 DRAM
Termination 0.750v [AUTO]
Ch-A Data VRef. 0.750v [AUTO]
Ch-B Data VRef. 0.750v [AUTO]
Ch-C Data VRef. 0.750v [AUTO]
Ch-A Address VRef. 0.750v [AUTO]
Ch-B Address VRef. 0.750v [AUTO]
Ch-C Address VRef. 0.750v [AUTO]
Это средние параметры, которых я смог достичь, когда БСОДы наиболее редки.. я менял в приблизительные положения безрезультатно.
ИТОГ: Добавив 3 планки памяти появились бсоды.. как лечить?
Проверь память на ошибки.
вольтаж на память подними...хотя мне это не помогло и пришлось оставить две планки вместо четырёх=стабильность,ошибок не было
q8200@3GHz/IH-4500/Asrock P45DE3/2x2GB+2x1GB DDR3 Samsung/MSI GTX460 Hawk@900/1800/4300;Chif 500w/GMC H80/WD Green 750+1500
Тайминги?
Video games ruined my life. Good thing I have 2 extra lives ...
cr1t1cal писал(а):
Тайминги?
8-8-8-24 1600Mhz
Ojaa, БСОДЫ могут быть из-за бэд-блоков на винте+обновления винды(Вынь7х64) - у меня так...
Ты скажи в каких приложениях вылетает? У меня только в самом виндовсе, все тесты проходит на ура...
RivaTNT2Pro|GeForce2MX200,4MX400,7600GS,8800GT|RadeonHD4890,HD5850,8970M
Duron800|Athlon645800+|C2De8200|i5-2500K,i7-4700MQ
Стабильности достиг путем:
185x19, множитель памяти опустил до х8, uncore множитель х17
слегка понизил вольтажи..
правда память теперь на частоте 1480..
