Всем привет. нужна помощь. в мануале материнки написано, что можно ставить 533Mhz FSB, и даже 800Mhz (но мне нужно 533Mhz) вопрос, Rated FSB это и есть 800Mhz (вместо нужных мне 533Mhz), или это что то другое? и что такое Bus Speed, нужно ли поднимать? (если да, то как?) материнка: PCCHIPS M963GV (мануал) в cpu-z: CPU, Mainboard огромная просьба помочь чайнику)
Chapter 1 Introduction This motherboard has a Socket-478 to support Intel Pentium 4 processors with Hyper-Threading Technology and Front-Side Bus (FSB) speeds up to 800 MHz(only by overclocking) / 533 MHz. Hyper-Threading Technology, designed to take advantage of the multitasking features in Windows XP, gives you the power to do more things at once. This motherboard integrates the SiS661GX Northbridge and SiS964L Southbridge that supports the built-in USB 2.0 providing higher bandwidth, implementing Universal Serial Bus Specification Revision 2.0 and is compliant with UHCI 1.1 and EHCI 0.95. It supports two DIMM sockets for DDR400/333/266 up to 2 GB system memory, AC’ 97 Audio Codec and Ultra DMA 133/100/66 function. It has one 8X AGP, one CNR and three 32-bit PCI slots. There is a full set of I/O ports including two PS/2 ports for mouse and keyboard, one serial port, one parallel port, one LAN port(optional), one VGA port, three audio jacks for Line-in, Line-out and Microphone, and four backpanel USB2.0 ports. In addition, onboard USB headers USB2/USB3 provide extra ports by connecting the Extended USB Module to the motherboard. It is a Micro ATX motherboard and has power connectors for an ATX power supply. Key Features The key features of this motherboard include: Socket-478 Processor • Supports Intel Pentium 4 Series processors • Supports up to 800 MHz(only by overclocking) / 533 MHz Front-Side Bus Hyper-Threading technology enables the operating system into thinking it’s hooked up to two processors, allowing two threads to be run in parallel, both on separate ‘logical’ processors within the same physical processor. Users please note that this motherboard supports FSB 533 MHz only; FSB 800 MHz can be achieved by overclocking but it may be unstable! Chipset There are SiS661GX Northbridge and SiS964L in the chipsets in accordance with an innovative and scalable architecture with proven reliability and performance. • High Performance Host Interface: Supports Intel Pentium 4 processor family with FSB 533MHz
