Не могу разогнать свой проц,после изменений в биосе он перезагружается до лого материнки и опять перезагружается,раньше он уже был разогнан и я по тупости взял и сбросил настройки,помогите Процессор Processor 1 ID = 0 Number of cores 2 (max 2) Number of threads 2 (max 2) Name Intel Pentium E2180 Codename Conroe Specification Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz Package (platform ID) Socket 775 LGA (0x0) CPUID 6.F.D Extended CPUID 6.F Core Stepping M0 Technology 65 nm Core Speed 1999.9 MHz Multiplier x Bus Speed 10.0 x 200.0 MHz Rated Bus speed 800.0 MHz Stock frequency 2000 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 1024 KBytes, 4-way set associative, 64-byte line size FID/VID Control yes FID range 6.0x - 10.0x Max VID 1.225 V Temperature 0 35°C (94°F) [0x32] (Core #0) Мать Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IB (ICH9) rev. 02 Graphic Interface PCI-Express PCI-E Link Width x16 PCI-E Max Link Width x16 Memory Type DDR2 Memory Size 3 GBytes Channels Dual, (Symmetric) Memory Frequency 400.0 MHz (1:2) CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Row Refresh Cycle Time (tRFC) 52 Command Rate (CR) 2T Host Bridge 0x29C0 MCHBAR I/O Base address 0x0FED14000 MCHBAR I/O Size 4096 Оперативка DIMM # 1 SMBus address 0x50 Memory type DDR2 Module format Regular UDIMM Manufacturer (ID) Transcend Information (7F4F0000000000000000) Size 2048 MBytes Max bandwidth PC2-6400 (400 MHz) Part number JM800QLU-2G Serial number 00096BF2 Manufacturing date Week 21/Year 12 Number of banks 2 Data width 64 bits Correction None Nominal Voltage 1.80 Volts EPP no XMP no AMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 4.0-4-4-12-16 @ 266 MHz JEDEC #2 5.0-5-5-15-20 @ 333 MHz JEDEC #3 6.0-6-6-18-24 @ 400 MHz
DIMM # 2 SMBus address 0x53 Memory type DDR2 Module format Regular UDIMM Manufacturer (ID) (00000000000000000000) Size 1024 MBytes Max bandwidth PC2-6400 (400 MHz) Part number Number of banks 1 Data width 64 bits Correction None Nominal Voltage 1.80 Volts EPP no XMP no AMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 4.0-4-4-12-16 @ 266 MHz JEDEC #2 5.0-5-5-15-20 @ 333 MHz JEDEC #3 6.0-6-6-18-24 @ 400 MHz Вольтаж(вдруг понадобится) Hardware monitor ITE IT87 Voltage 0 1.12 Volts [0x46] (CPU VCORE) Voltage 1 1.94 Volts [0x79] (VIN1) Voltage 2 3.39 Volts [0xD4] (+3.3V) Voltage 3 5.00 Volts [0xBA] (+5V) Voltage 4 12.42 Volts [0xC2] (+12V) Voltage 6 -4.80 Volts [0x4B] (-5V) Voltage 8 3.20 Volts [0xC8] (VBAT) Temperature 0 34°C (93°F) [0x22] (TMPIN0) Temperature 1 -1°C (28°F) [0xFE] (TMPIN1) Temperature 2 39°C (102°F) [0x27] (TMPIN2) Fan 3 3000 RPM [0xE1] (FANIN3) Fan PWM 0 99 pc [0x7F] (FANPWM0) Fan PWM 1 0 pc [0x0] (FANPWM1) Fan PWM 2 0 pc [0x0] (FANPWM2) Register space LPC, base address = 0x0290
Заблокирован Статус: Не в сети Регистрация: 15.06.2010 Откуда: Калуга Фото: 18
Вот и найди тему здесь с такой матерью. 100500 раз рассказывать старые сказки тоскливо. P35 должна вполне нормально гнаться. Твой камень может и до 3ГГц потянуть, если получится. Судя по скорости ответа, ты и правда клоун.
_________________ Лужу, паяю, не шалю, никого не трогаю, починяю примус (ЭВМ). Я не фанат INTEL, я просто не люблю AMD.
