Начать новую тему Новая тема / Ответить на тему Ответить  Сообщений: 2
Добрый день!
В компьютер воткнуты 4 планки оперативной памяти. Производитель corsair - 2Гб и kingston - 4Гб.
Memory Type DDR3
Memory Size 12 GBytes
Channels Dual
Memory Frequency 667.6 MHz (2:10)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 107
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CMG4GX3M2A2000C8
Manufacturing date Week 25/Year 09
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 8.0-8-8-22-30 @ 592 MHz
JEDEC #3 9.0-9-9-24-34 @ 666 MHz
XMP profile XMP-2000
Specification PC3-16000
Voltage level 1.650 Volts
Min Cycle time 1.000 ns (1000 MHz)
Max CL 8.0
Min tRP 8.00 ns
Min tRCD 8.00 ns
Min tWR 15.00 ns
Min tRAS 24.00 ns
Min tRC 50.63 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-6-6-18-38-2T @ 750 MHz (1.650 Volts)
XMP #2 8.0-8-8-24-51-2T @ 1000 MHz (1.650 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Kingston (7F98000000000000000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number KHX2133C11D3/4GX
Serial number BC27094B
Manufacturing date Week 08/Year 13
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
AMP no
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
XMP profile XMP-2132
Specification PC3-17100
Min Cycle time 0.938 ns (1066 MHz)
Max CL 11.0
Min tRP 10.31 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 28.13 ns
Min tRC 45.00 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 6.56 ns
Command Rate 1T
XMP #1 6.0-7-6-17-27-1T @ 581 MHz (1.650 Volts)
XMP #2 7.0-8-8-20-31-1T @ 678 MHz (1.650 Volts)
XMP #3 8.0-9-8-22-35-1T @ 775 MHz (1.650 Volts)
XMP #4 9.0-10-9-25-40-1T @ 872 MHz (1.650 Volts)
XMP #5 10.0-11-10-28-44-1T @ 969 MHz (1.650 Volts)
XMP #6 11.0-12-11-30-48-1T @ 1066 MHz (1.650 Volts)
XMP profile XMP-1866
Specification PC3-14900
Min Cycle time 1.071 ns (933 MHz)
Max CL 10.0
Min tRP 10.71 ns
Min tRCD 11.79 ns
Min tWR 15.00 ns
Min tRAS 32.14 ns
Min tRC 45.00 ns
Min tRFC 160.07 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP #1 7.0-8-7-22-30-2T @ 653 MHz (1.650 Volts)
XMP #2 8.0-9-9-25-34-2T @ 746 MHz (1.650 Volts)
XMP #3 9.0-10-9-28-38-2T @ 840 MHz (1.650 Volts)
При разгоне процессора xeon x3470 до 3,8 Ггц выставляю значение частоты памяти 2010 MHz - комп не грузится!
С частотой 1668 MHz - загружается без проблем. Обе оперативки поддерживаю частоту выше 2000 MHz, но
сильно отличаются в таймингах. Как правильно разогнать разные оперативки?
Характеристики компьютера:
Процессор
DMI Processor
model Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
clock speed 2933.0 MHz
Материнская плата:
vendor ASUSTeK Computer INC.
model SABERTOOTH 55i
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 05
Видеокарта:
NVIDIA GeForce GTX 1060 6GB
Блок питания:
750 Вт
не в оперативки дело!
А в контроллере Х3470 поддерживает оперативку до 1330 Mhz
у меня та-же проблема переразгон контроллера не дает поднять частоту выше 1800 с копейками.
можно повышать напряжение на контроллер
MB: p7p55d
CPU: X3470@ 4.33
RAM: 32gb 1600Mhz
VGA: GTX970
Охлаждение: СЖО CPU+VGA+MO-RA3 360)
