Доброго времени суток) Купил около месяца назад ноутбук asus k42f. И все усраивало, пока не посмотрел случайно SMART. Было превышено количество переразмеченных секторов. Повез в сервисник. Поменяли по гарантии. Пользуюсь около недели. И история начинает повторяться. Вот вывод тестирования: --------------------------------------------------------------------------------------------------------- smartctl version 5.38 [i686-pc-linux-gnu] Copyright (C) 2002-8 Bruce Allen Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION === Device Model: ST9250827AS Serial Number: 5RG8S21N Firmware Version: 3.AAA User Capacity: 250,059,350,016 bytes Device is: Not in smartctl database [for details use: -P showall] ATA Version is: 8 ATA Standard is: ATA-8-ACS revision 4 Local Time is: Sat May 29 23:16:17 2010 MSD SMART support is: Available - device has SMART capability. SMART support is: Enabled
=== START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED
General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 426) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 92) minutes. SCT capabilities: (0x0001) SCT Status supported.
SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 84 - # 2 Short offline Completed without error 00% 84 -
Параметр Hardware_ECC_Recovered растет прямо на глазах с неимоверной скоростью. Если я правильно понял, то превышена температура. Могло ли это быть причиной? Когда измерял, то специально посильнее обдувал ноутбук вентилятором - на всякий случай. А ведь еще и не жарко.
Вопросы следующие: Является ли это гарантийным случаем? Могу ли я потребовать замены ноутбука или возврата денег, поскольку даже в случае гарантийного случая есть чувство, что это не в последний раз)
