Статус: Не в сети Регистрация: 02.06.2008 Откуда: Дмитров Мос Обл
процессор е5300 мать ga-31m-es2l жеские диски на 80 и 120 гигов ide и sata на 80. при загрузке виндовс выводит сообщение a Disk Read Error Occurred. Press Ctrl+alt+del To Restart ставил win 7 на каждый из 3 дисков все тоже самое, на других компьютерах win7 с этих дисков грузиться в чем может быть проблема?
_________________ GF 4 Ti4200 64MB->Radeon 9800SE 256MB->GF 7600GS 256MB->4850 512M>7870 Вообщем иду в ногу со временем:)))))))
Статус: Не в сети Регистрация: 10.05.2007 Откуда: Санкт-Петербург
Integrated Peripherals On-Chip Primary PCI IDE > Enabled
On-Chip SATA Mode Configures the integrated SATA controller. Disabled Disables the integrated SATA controller. Auto Lets BIOS set SATA devices to Combined or Enhanced mode. If your onboard SATA controller is automatically configured to Combined mode, you can manually re-configure it to Enhanced mode as needed. (Default) Combined Sets all SATA devices to operate in PATA mode. Combined allows a maximum of 4 ATA devices to be used simultaneously: two PATA devices plus two SATA devices. Enhanced Sets all SATA devices to operate in SATA mode. Non-Combined Sets all SATA devices to operate in PATA mode and disables the integrated IDE controller. http://www.probios.ru/options/drive/ide ... -mode.html
PATA IDE Set to This item is configurable only if the On-Chip SATA Mode is set to Combined. Ch.0 Master/Slave Sets the IDE channels to Ch. 0 Master/Slave. (Default) Ch.1 Master/Slave Sets the IDE channels to Ch. 1 Master/Slave. Disabled Disables the integrated IDE controller when Non-Combined is selected. http://www.probios.ru/options/drive/ide ... et-to.html
SATA Port 0/2 Set to This value is dependent on the On-Chip SATA Mode and PATA IDE Set to settings. When PATA IDE Set to is configured to Ch. 1 Master/Slave, this option will be automatically set to Ch. 0 Master/Slave. http://www.probios.ru/options/drive/ide ... et-to.html
SATA Port 1/3 Set to This value is dependent on the On-Chip SATA Mode and PATA IDE Set to settings. When PATA IDE Set to is configured to Ch. 0 Master/Slave, this option will be automatically set to Ch. 1 Master/Slave. http://www.probios.ru/options/drive/ide ... et-to.html
Если установлен режим "Combined" то можно "отремапить" SATA порты на порты IDE контроллера. И этот режим задействует только 2 канала IDE (4 устройства). Т.е. возможна ситуация когда SATA диски будет не видны.
Для Windows 7 желательно перевести в режим On-Chip SATA Mode: "Enhanced". Сохранить настройки по F10 и "Y". После чего зайти опять в BIOS и посмотреть в разделе Standard CMOS Features видны ли все диски.
Далее: Advanced BIOS Features > Hard Disk Boot Priority Установить приоритет загрузки с HDD (с какого HDD первым грузиться). > First Boot Device Установить Hard Disk (грузиться первым с HDD)
Всем спасибо кто помогал, все оказалось просто, были неисправны одновременно и шлейф и сата кабель. поменял шлейф все прекрасно заработало))) камень оказался удачным разогнался на 50% до 3900 при напряжении в биос 1,350v (1,31 в cpu-z) тему можно закрывать.
