Сначала он определялся как SATAFIRM S11 в нем стояло ПО 21.1....
Код:
v0.783a
Drive: 0(ATA)
OS: 10.0 build 10240
Model: SATAFIRM   S11
Fw   : SBFM21W1
P/N  : 5P1-170620001   , SBSM21.0
S11fw: SBFM21.1    , 2017May11   SBFM21.1
Original Model: GOODRAM
Bank00: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank04: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank08: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(L06B) MLC 256Gb/CE 256Gb/die
Bank12: 0x2c,0xa4,0x64,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(L06B) MLC 256Gb/CE 256Gb/die
Controller    : PS3111
Flash CE      : 4
Flash Channel : 2
Dram Size,MB  : 32
Flash CE Mask : [+---+--- +---+---]
Flash Mode/Clk: 5/7 (Set 5/7)
Block per Die : 2192
Block per CE  : 2192
Page per Block: 1024
SLC Cache     : Default
ATA: ReadParamPage18 failed! Error: 0x51
ONFI[A7]  : SPECTEK     FxxL06B256G1KDBABJ4
Page size : 18592 (16384+2208)
Page/Block: 1024
Defects All Early Later
Bank00:  61  61   0
Bank04:  52  52   0
Bank08:  97  97   0
Bank12:  69  69   0
Total : 279 279   0
Early defect list
Bank00: 96 97 98 99 107 355 611 899 901 907 1123 1131 1379 1539 1547 1555 1571 1579 1587 1595 1627 1635 1667 1691 1707 1715 1723 1731 1739 1747 1763 1771 1787 1803 1811 1819 1827 1835 1843 1851 1859 1867 1875 1891 1899 1907 1915 1920 1921 1923 1927 1928 1929 1930 1931 1932 1933 1934 1935 1939 2001
Bank04: 96 97 98 99 103 107 111 287 355 359 611 615 899 903 907 911 1015 1123 1127 1131 1135 1379 1383 1475 1491 1571 1634 1635 1639 1643 1667 1715 1751 1811 1920 1922 1923 1924 1927 1928 1929 1930 1931 1932 1933 1935 2001 2071 2079 2095 2103 2147
Bank08: 9 96 97 98 99 102 104 105 106 108 110 114 222 230 352 353 354 356 358 608 609 610 612 613 614 734 896 897 898 900 901 902 904 905 906 907 908 909 910 982 1120 1121 1122 1123 1124 1125 1126 1128 1129 1130 1131 1132 1133 1134 1135 1282 1376 1377 1378 1379 1380 1381 1382 1383 1632 1633 1634 1635 1636 1637 1638 1639 1862 1920 1921 1922 1923 1924 1925 1926 1927 1928 1929 1930 1931 1932 1933 1934 1935 2001 2046 2082 2086 2090 2094 2183 2186
Bank12: 76 96 97 98 99 100 108 116 196 212 356 611 612 613 900 901 908 909 1124 1125 1132 1133 1380 1381 1556 1564 1596 1620 1636 1637 1716 1724 1732 1748 1764 1788 1796 1812 1820 1836 1844 1860 1861 1868 1892 1917 1920 1923 1924 1925 1927 1928 1929 1930 1931 1932 1933 1934 1935 1956 1964 1988 1996 1997 2001 2028 2052 2084 2100
Later defect list
PS3111 smart configuration:
Attr Tresh Flags ValId WrstId  RawId   Description
0x01: 0x32 0x0B 0x0000 0x0000 0x0100 - Number of ECC Error
0x09: 0x00 0x12 0x0000 0x0000 0x0600 - Power on hours
0x0C: 0x00 0x12 0x0000 0x0000 0x0607 - Power on/off cycles
0xA8: 0x00 0x12 0x0000 0x0000 0x0103 - SATA PHY error count
0xAA: 0x0A 0x03 0x0102 0x0102 0x030C - Total Early Bad Block Count/Total Later Bad Block Count
0xAD: 0x00 0x12 0x0000 0x0000 0x0204 - Max Erase Cnt/Avg Erase Cnt
0xC0: 0x00 0x12 0x0000 0x0000 0x0608 - Unexpected Power Loss Count
0xC2: 0x00 0x23 0x0300 0x0300 0x0800 - Current Temp/Min Temp/Max Temp
0xDA: 0x32 0x0B 0x0000 0x0000 0x0104 - CRC Error Count
0xE7: 0x00 0x13 0x0000 0x0000 0x020A - SSD life left
0xF1: 0x00 0x12 0x0000 0x0000 0x0402 - Host Write (GB)
Нарвался на прогу repairs11 нечего не дало ...
firmware-upgrade-CX300 сказала что у вас последнее по идите лесом ...
PhisonToolBox_Complete_v1.05 не определяло диск
В итоге запустил
UpgradeFW_SBFM71.0(Reinitial)_v1.01.exe
Оно увидело диск я довольный нажал реинициализировать побежали процентики дошло до 85% долго думало и поругалось ...
в итоге диск теперь не видно даже в биосе я так понял это капут ...
___________________________________
#1 R9 5900X /ASUS TUF X570/32GB/GB RTX 5800 SFF OC/NVME 990PRO 1T/ WD 2x1TB/Enhance 850w/HeatKiller IV MORA3
Ripper_ua На Хобот к vlo. Но вообще, вроде там инструкции к использованию все приложены.
Уже настрочил =) гугл туда привел
