Комплектующие ПК: Материнская плата: Gigabyte B450M H
Процессор: Ryzen 5 3600
Оперативная память: dd4 32 GB HyperX fury
Видеокарта: RTX 3050
Накопители (HDD/SDD): CeaMere 120 ГБ
Блок питания: DeepCool 650w
Сис-ма охлаждения: AeroCool Cylon 4F
Комп иногда сам перегружается В тесте OCCT CPU+ RAM ошибки. при этом процессор не перегревается
00:00:00 - Info - Test schedule started at 2024-09-17 15:49:27 00:00:00 - Info - CPU + RAM - Initializing (Duration : 01:00:00) 00:00:00 - Info - CPU + RAM - Started (Duration : 01:00:00) 00:00:02 - Error - CPU + RAM - 1 error(s) found on physical core #3 - logical core #7 00:00:02 - Error - CPU + RAM - 5 error(s) found on physical core #3 - logical core #6 00:00:02 - Error - CPU + RAM - 5 error(s) found on physical core #3 - logical core #7 00:00:03 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #6 00:00:03 - Error - CPU + RAM - 8 error(s) found on physical core #3 - logical core #7 00:00:03 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #6 00:00:03 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #7 00:00:04 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #6 00:00:04 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #7 00:00:04 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #6 00:00:04 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #7 00:00:04 - Error - CPU + RAM - 1 error(s) found on physical core #4 - logical core #9 00:00:05 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #6 00:00:05 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #7 00:00:05 - Error - CPU + RAM - 5 error(s) found on physical core #4 - logical core #9 00:00:05 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #6 00:00:05 - Error - CPU + RAM - 10 error(s) found on physical core #3 - logical core #7 00:00:05 - Error - CPU + RAM - 5 error(s) found on physical core #4 - logical core #9 00:00:06 - Error - CPU + RAM - Test crashed (Code : -1)
CPU тест
00:00:00 - Info - Test schedule started at 2024-09-17 15:52:28 00:00:00 - Info - CPU - Initializing (Duration : 01:00:00) 00:00:00 - Info - CPU - Started (Duration : 01:00:00) 00:00:00 - Error - CPU - 16693 error(s) found on physical core #3 - logical core #6 00:00:00 - Error - CPU - 13925 error(s) found on physical core #3 - logical core #7 00:00:01 - Error - CPU - 48436 error(s) found on physical core #3 - logical core #6 00:00:01 - Error - CPU - 27723 error(s) found on physical core #3 - logical core #7 00:00:01 - Error - CPU - 37666 error(s) found on physical core #4 - logical core #9 00:00:01 - Error - CPU - Test crashed (Code : -1)
Статус: Не в сети Регистрация: 04.06.2017 Фото: 6
ealexandor с помощью ryzen master, или в биосе, поставьте Cpu core voltage (или Vcore, или VDDCR CPU VOLTAGE) в режим offset, знак плюс, значение 0,025 или 0,03 (смотря какой шаг в биосе), примените и проведите тест повторно. Если за контрольное время ошибок не возникнет, или останутся только на одном ядре, то это 100% неисправность процессора
Из материнки убрал батарейку н некоторое время. Теперь ошибки пропали
Хоть бы спойлер сделал. Сколько модулей памяти? Если 4 то попробуй с двумя, попробуй SoC voltage поставить 1.125V. а лучше выкинь эту память на авито и больше никогда не покупай кингстон фьюри. Закажи себе на али Juhor белые с аниме девочкой, там нормальная двухранговая память на чипах hynix cjr, 3600Mhz из коробки.
