Video Compressors: WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385 WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385 MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385 DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385 MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16385 Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0030 Кодек Cinepak, изготовленный корпорацией Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385 Кодек Intel IYUV,0x00200000,1,1,qcap.dll,6.06.7600.16385 Кодек Intel IYUV,0x00200000,1,1,qcap.dll,6.06.7600.16385 Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385 Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
Midi Renderers: Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16385 Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16385
WDM Streaming Capture Devices: Realtek HD Audio CD input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385 Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385 Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385 Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385 Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385 Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385 Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16385
BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385 MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
WDM Streaming Communication Transforms: Преобразователь Tee/Sink-to-Sink,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Audio Renderers: Динамики (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7600.16385 Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16385 Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16385 DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7600.16385 DirectSound: Динамики (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7600.16385 Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7600.16385
--------------- EVR Power Information --------------- Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality) Quality Flags: 2576 Enabled: Force throttling Allow half deinterlace Allow scaling Decode Power Usage: 100 Balanced Flags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 50 PowerFlags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 0
Статус: Не в сети Регистрация: 01.12.2009 Откуда: Донецк, Украина
Ошибка паскудная, может быть вызвана очень многими причинами начиная от жестких заканчивая драйверами и криво установленными прогами, у меня тоже самое но на ХР. Сделай откат, не поможет (у меня он просто не делался, сбрасывалось и все)- переустанавливай винду, а если винда была свежая- надо грешить уже на железо. Мне кажется, что это один из жестких у меня помирает (он со старого компа) и на нем как раз и стоит винда. Сегодня везу в СЦ, потом отпишусь здесь.
У меня такая бывает, но периодически меняется на 116, или 50 вместо d1, как-то связано с тем что win 7 x64 RC отрубает и заново восстанавливает видеоадаптер (9600GT) в моем случае. т.е. либо монитор на играх уходит в дежурный режим, а потом все норм, либо БСОД с одной из ошибок,а потом на перегруз. Дрова последние 195. Перерыл по-инета, однозначного вывода нет.
