привет народ, ищу прогу для диагностики систем\ы. в основном что нагуглил, это 2003 года, есть ли где скачать новую версию.
спасибо.
поконкретнее, что за диагностика?
GA-P55-US3L; i5-750 + Performa @ 3.8Ghz; GTX780; 2xKVR1333D3N9K2/4G
http://www.uxd.com/wst.shtml
комплекс профессиональной диагностики системы, для выявления повреждений и стабильности.
W.S.T. is a Windows based Burn-In utility for exercising and validating the stability and reliability all core hardware, peripherals and sub-systems. Taking advantage of Microsoft Windows multi-threaded Operating System, W.S.T. Burn-In exercises PC systems to greater-than-normal usage by simultaneously testing all major core components and peripherals. This advanced user simulation stress test is intended to cause unreliable components to fail or become unstable, that can then be investigated further with QuickTech PRO to determine modifications needed to produce a more durable system.
Burn-In Stress testing is designed to find the failure limits of a PC computer by simultaneously exercising all major components of the system including:
CPU
FPU
MMX
RAM
Hard Drives
CD/DVD-ROM Drives
Floppy Drives
2D & 3D Graphics
Sound
Printers
COM & LPT Ports
Network Adapters
For System Inventory, W.S.T. can generate a complete report of the system. The list will include data on: Display, Devices, Drivers, Network configurations, APM, Media, Workstation, Operating System, CPU, Memory, Database Engines, and Printers. This information is ideal for keeping track of your systems and all installed devices. This detailed information can be used by tech support staff for problem resolutions.
With Ultra-X's extensive experience of 20-years in producing high quality PC diagnostic hardware and software tools, W.S.T. brings a much needed Windows based testing utility to computer manufacturers and service professionals for assisting in evaluating systems and performing burn-in, inventory and stress testing. W.S.T. works on the following Windows systems: 2000/XP/Vista
ап, где достать актуальную версию, если компания предоставляет софт только партнерам по сходной цене не продавая частным лицам.
асус лаборатория работает с этим софтом для диагностики.
DarkS1ayeR
www.eworld.ru/trends/pr/g:3da5819eb97e9 ... 7/p2:1673/
--- The place where gods come to die. ---
