Возврат реестра из бекапа не помог. Убийство аваста, отдельно как исполняемых файлов так и всех ветвей в реестре не помогло. Виртуальных приводов нет.
setuperr.log [windeploy.exe] Failure occured during online installation. Online installation cannot complete at this time.; hr = 0x8007139f setupact.log 2016-05-05 17:11:26, Info [windeploy.exe] WinDeploy.exe launched with command-line []... 2016-05-05 17:11:26, Info [windeploy.exe] Setup has not completed, adding pending reboot. 2016-05-05 17:11:26, Warning [windeploy.exe] SetupCl has pending operations; blocking deployment process until they've been completed. 2016-05-05 17:11:26, Error [windeploy.exe] Failure occured during online installation. Online installation cannot complete at this time.; hr = 0x8007139f 2016-05-05 17:11:29, Info [windeploy.exe] Flushing registry to disk... 2016-05-05 17:11:30, Info [windeploy.exe] Flush took 1155 ms. 2016-05-05 17:11:30, Info [windeploy.exe] WinDeploy.exe exiting with code [0x8007139f]
Погуглив и применив несколько методик по удалению якобы возможно конфликтующих записей в реестре результата не дало. Печаль...
Добавлено спустя 46 минут 43 секунды: Проблема решена. Всем огромное спасибо за поддержку. Решение оказалось в следующем:
THE SOLUTION THAT WORKED
1. When the error message apears, open up a command window with SHIFT + F11 2. open the REGEDIT 3. navigate to hklm\system\setup 4. change CmdLine to blank (no value entered) (was oobe\windeploy.exe) 5. change CreateNewQueueOnFirstBoot to 0 (was 1) 6. change OOBEInProgress to 0 (was 1) (i am guessing that might be AUDITInProgress if that was your sysprep choice) 7. change SetupPhase to 0 (was 4) 8. change SetupShutdownRequired to 0 (was 1) 9. change SetupType to 0 (was 2) 10. change SystemSetupInProgress to 0 (was1)
