Подключиться-то он подключается, но с ошибками, и далее через putty я не могу подключиться к серверу. Драйвер стоит, брандмауэр отключен, конфиг есть. Что может быть? Помогите, пожалуйста.
Лог
Sun Mar 11 17:46:09 2018 OpenVPN 2.3.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Dec 1 2014 Sun Mar 11 17:46:09 2018 library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.08 Sun Mar 11 17:46:09 2018 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340 Sun Mar 11 17:46:09 2018 Need hold release from management interface, waiting... Sun Mar 11 17:46:10 2018 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340 Sun Mar 11 17:46:10 2018 MANAGEMENT: CMD 'state on' Sun Mar 11 17:46:10 2018 MANAGEMENT: CMD 'log all on' Sun Mar 11 17:46:10 2018 MANAGEMENT: CMD 'hold off' Sun Mar 11 17:46:10 2018 MANAGEMENT: CMD 'hold release' Sun Mar 11 17:46:15 2018 MANAGEMENT: CMD 'username "Auth" "mter"' Sun Mar 11 17:46:15 2018 MANAGEMENT: CMD 'password [...]' Sun Mar 11 17:46:15 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. Sun Mar 11 17:46:16 2018 Socket Buffers: R=[65536->65536] S=[65536->65536] Sun Mar 11 17:46:16 2018 MANAGEMENT: >STATE:1520779576,RESOLVE,,, Sun Mar 11 17:46:16 2018 UDPv4 link local: [undef] Sun Mar 11 17:46:16 2018 UDPv4 link remote: [AF_INET]195.208.245.16:1194 Sun Mar 11 17:46:16 2018 MANAGEMENT: >STATE:1520779576,WAIT,,, Sun Mar 11 17:46:16 2018 MANAGEMENT: >STATE:1520779576,AUTH,,, Sun Mar 11 17:46:16 2018 TLS: Initial packet from [AF_INET]195.208.245.16:1194, sid=e584a452 4d29854a Sun Mar 11 17:46:16 2018 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Sun Mar 11 17:46:17 2018 VERIFY OK: depth=1, C=RU, ST=Rostov Region, L=Rostov-on-Don, O=South Federal University, OU=Computer Center, CN=vpn1.r61.net, emailAddress=noc@r61.net Sun Mar 11 17:46:17 2018 VERIFY OK: depth=0, C=RU, ST=Rostov Region, L=Rostov-on-Don, O=South Federal University, OU=Computer Center, CN=vpn1.r61.net, emailAddress=noc@r61.net Sun Mar 11 17:46:22 2018 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key Sun Mar 11 17:46:22 2018 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Sun Mar 11 17:46:22 2018 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key Sun Mar 11 17:46:22 2018 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication Sun Mar 11 17:46:22 2018 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA Sun Mar 11 17:46:22 2018 [vpn1.r61.net] Peer Connection Initiated with [AF_INET]195.208.245.16:1194 Sun Mar 11 17:46:23 2018 MANAGEMENT: >STATE:1520779583,GET_CONFIG,,, Sun Mar 11 17:46:24 2018 SENT CONTROL [vpn1.r61.net]: 'PUSH_REQUEST' (status=1) Sun Mar 11 17:46:29 2018 SENT CONTROL [vpn1.r61.net]: 'PUSH_REQUEST' (status=1) Sun Mar 11 17:46:34 2018 SENT CONTROL [vpn1.r61.net]: 'PUSH_REQUEST' (status=1) Sun Mar 11 17:46:39 2018 SENT CONTROL [vpn1.r61.net]: 'PUSH_REQUEST' (status=1) Sun Mar 11 17:46:44 2018 SENT CONTROL [vpn1.r61.net]: 'PUSH_REQUEST' (status=1) Sun Mar 11 17:46:48 2018 PUSH: Received control message: 'PUSH_REPLY,route remote_host 255.255.255.255 net_gateway,dhcp-option DNS 195.208.245.203,dhcp-option DNS 195.208.245.204,route-gateway 10.132.252.1,ping 5,ping-restart 120,route 195.208.245.203 255.255.255.255,route 195.208.245.204 255.255.255.255,route 10.132.129.0 255.255.255.0,ifconfig 10.132.253.27 255.255.252.0' Sun Mar 11 17:46:48 2018 OPTIONS IMPORT: timers and/or timeouts modified Sun Mar 11 17:46:48 2018 OPTIONS IMPORT: --ifconfig/up options modified Sun Mar 11 17:46:48 2018 OPTIONS IMPORT: route options modified Sun Mar 11 17:46:48 2018 OPTIONS IMPORT: route-related options modified Sun Mar 11 17:46:48 2018 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified Sun Mar 11 17:46:48 2018 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 Sun Mar 11 17:46:48 2018 MANAGEMENT: >STATE:1520779608,ASSIGN_IP,,10.132.253.27, Sun Mar 11 17:46:48 2018 open_tun, tt->ipv6=0 Sun Mar 11 17:46:48 2018 TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{0A899639-DEBF-4C02-ABCC-96B403463D83}.tap Sun Mar 11 17:46:48 2018 TAP-Windows Driver Version 9.9 Sun Mar 11 17:46:48 2018 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.132.253.27/255.255.252.0 on interface {0A899639-DEBF-4C02-ABCC-96B403463D83} [DHCP-serv: 10.132.252.0, lease-time: 31536000] Sun Mar 11 17:46:48 2018 Successful ARP Flush on interface [2] {0A899639-DEBF-4C02-ABCC-96B403463D83} Sun Mar 11 17:46:53 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:46:53 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:46:59 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:46:59 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:00 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:00 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:01 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:01 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:02 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:02 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:04 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:04 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:05 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:05 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:06 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:06 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:07 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:07 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:08 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:08 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:10 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:10 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:11 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:11 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:12 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:12 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:13 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:13 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:14 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:14 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:16 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:16 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:17 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:17 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:18 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:18 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:19 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:19 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:20 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:20 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:21 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:21 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:22 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:22 2018 Route: Waiting for TUN/TAP interface to come up... Sun Mar 11 17:47:23 2018 TEST ROUTES: 0/0 succeeded len=4 ret=0 a=0 u/d=down Sun Mar 11 17:47:23 2018 MANAGEMENT: >STATE:1520779643,ADD_ROUTES,,, Sun Mar 11 17:47:23 2018 C:\WINDOWS\system32\route.exe ADD 195.208.245.16 MASK 255.255.255.255 192.168.1.1 Sun Mar 11 17:47:23 2018 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4 Sun Mar 11 17:47:23 2018 Route addition via IPAPI succeeded [adaptive] Sun Mar 11 17:47:23 2018 C:\WINDOWS\system32\route.exe ADD 195.208.245.203 MASK 255.255.255.255 10.132.252.1 Sun Mar 11 17:47:23 2018 Warning: route gateway is not reachable on any active network adapters: 10.132.252.1 Sun Mar 11 17:47:23 2018 Route addition via IPAPI failed [adaptive] Sun Mar 11 17:47:23 2018 Route addition fallback to route.exe Sun Mar 11 17:47:23 2018 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem Sun Mar 11 17:47:23 2018 C:\WINDOWS\system32\route.exe ADD 195.208.245.204 MASK 255.255.255.255 10.132.252.1 Sun Mar 11 17:47:24 2018 Warning: route gateway is not reachable on any active network adapters: 10.132.252.1 Sun Mar 11 17:47:24 2018 Route addition via IPAPI failed [adaptive] Sun Mar 11 17:47:24 2018 Route addition fallback to route.exe Sun Mar 11 17:47:24 2018 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem Sun Mar 11 17:47:24 2018 C:\WINDOWS\system32\route.exe ADD 10.132.129.0 MASK 255.255.255.0 10.132.252.1 Sun Mar 11 17:47:24 2018 Warning: route gateway is not reachable on any active network adapters: 10.132.252.1 Sun Mar 11 17:47:24 2018 Route addition via IPAPI failed [adaptive] Sun Mar 11 17:47:24 2018 Route addition fallback to route.exe Sun Mar 11 17:47:24 2018 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem Sun Mar 11 17:47:24 2018 SYSTEM ROUTING TABLE Sun Mar 11 17:47:24 2018 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=3 t=4 pr=3 a=717 h=0 m=55/0/0/0/0 Sun Mar 11 17:47:24 2018 10.132.129.0 255.255.255.0 10.132.252.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=56/0/0/0/0 Sun Mar 11 17:47:24 2018 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=757 h=0 m=331/0/0/0/0 Sun Mar 11 17:47:24 2018 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=757 h=0 m=331/0/0/0/0 Sun Mar 11 17:47:24 2018 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=757 h=0 m=331/0/0/0/0 Sun Mar 11 17:47:24 2018 192.168.1.0 255.255.255.0 192.168.1.113 p=0 i=3 t=3 pr=2 a=717 h=0 m=311/0/0/0/0 Sun Mar 11 17:47:24 2018 192.168.1.113 255.255.255.255 192.168.1.113 p=0 i=3 t=3 pr=2 a=717 h=0 m=311/0/0/0/0 Sun Mar 11 17:47:24 2018 192.168.1.255 255.255.255.255 192.168.1.113 p=0 i=3 t=3 pr=2 a=717 h=0 m=311/0/0/0/0 Sun Mar 11 17:47:24 2018 192.168.56.0 255.255.255.0 192.168.56.1 p=0 i=17 t=3 pr=2 a=725 h=0 m=281/0/0/0/0 Sun Mar 11 17:47:24 2018 192.168.56.1 255.255.255.255 192.168.56.1 p=0 i=17 t=3 pr=2 a=725 h=0 m=281/0/0/0/0 Sun Mar 11 17:47:24 2018 192.168.56.255 255.255.255.255 192.168.56.1 p=0 i=17 t=3 pr=2 a=725 h=0 m=281/0/0/0/0 Sun Mar 11 17:47:24 2018 195.208.245.16 255.255.255.255 192.168.1.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=55/0/0/0/0 Sun Mar 11 17:47:24 2018 195.208.245.203 255.255.255.255 10.132.252.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=56/0/0/0/0 Sun Mar 11 17:47:24 2018 195.208.245.204 255.255.255.255 10.132.252.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=56/0/0/0/0 Sun Mar 11 17:47:24 2018 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=757 h=0 m=331/0/0/0/0 Sun Mar 11 17:47:24 2018 224.0.0.0 240.0.0.0 192.168.56.1 p=0 i=17 t=3 pr=2 a=728 h=0 m=281/0/0/0/0 Sun Mar 11 17:47:24 2018 224.0.0.0 240.0.0.0 192.168.1.113 p=0 i=3 t=3 pr=2 a=728 h=0 m=311/0/0/0/0 Sun Mar 11 17:47:24 2018 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=757 h=0 m=331/0/0/0/0 Sun Mar 11 17:47:24 2018 255.255.255.255 255.255.255.255 192.168.56.1 p=0 i=17 t=3 pr=2 a=728 h=0 m=281/0/0/0/0 Sun Mar 11 17:47:24 2018 255.255.255.255 255.255.255.255 192.168.1.113 p=0 i=3 t=3 pr=2 a=728 h=0 m=311/0/0/0/0 Sun Mar 11 17:47:24 2018 SYSTEM ADAPTER LIST Sun Mar 11 17:47:24 2018 Realtek PCIe GBE Family Controller Sun Mar 11 17:47:24 2018 Index = 9 Sun Mar 11 17:47:24 2018 GUID = {63BF5A3E-09FC-4564-89C0-E43688B8CCB0} Sun Mar 11 17:47:24 2018 IP = 0.0.0.0/0.0.0.0 Sun Mar 11 17:47:24 2018 MAC = f0:76:1c:d0:52:88 Sun Mar 11 17:47:24 2018 GATEWAY = 0.0.0.0/255.255.255.255 Sun Mar 11 17:47:24 2018 DHCP SERV = Sun Mar 11 17:47:24 2018 DHCP LEASE OBTAINED = Sun Mar 11 17:47:24 2018 Sun Mar 11 17:47:24 2018 DHCP LEASE EXPIRES = Sun Mar 11 17:47:24 2018 Sun Mar 11 17:47:24 2018 DNS SERV = Sun Mar 11 17:47:24 2018 VirtualBox Host-Only Ethernet Adapter Sun Mar 11 17:47:24 2018 Index = 17 Sun Mar 11 17:47:24 2018 GUID = {D5F83F7F-EC6E-48C7-886A-BBE1B9C3F56C} Sun Mar 11 17:47:24 2018 IP = 192.168.56.1/255.255.255.0 Sun Mar 11 17:47:24 2018 MAC = 0a:00:27:00:00:11 Sun Mar 11 17:47:24 2018 GATEWAY = 0.0.0.0/255.255.255.255 Sun Mar 11 17:47:24 2018 DNS SERV = Sun Mar 11 17:47:24 2018 TAP-Windows Adapter V9 Sun Mar 11 17:47:24 2018 Index = 2 Sun Mar 11 17:47:24 2018 GUID = {0A899639-DEBF-4C02-ABCC-96B403463D83} Sun Mar 11 17:47:24 2018 IP = 0.0.0.0/0.0.0.0 Sun Mar 11 17:47:24 2018 MAC = 00:ff:0a:89:96:39 Sun Mar 11 17:47:24 2018 GATEWAY = 0.0.0.0/255.255.255.255 Sun Mar 11 17:47:24 2018 DHCP SERV = Sun Mar 11 17:47:24 2018 DHCP LEASE OBTAINED = Sun Mar 11 17:47:24 2018 Sun Mar 11 17:47:24 2018 DHCP LEASE EXPIRES = Sun Mar 11 17:47:24 2018 Sun Mar 11 17:47:24 2018 DNS SERV = Sun Mar 11 17:47:24 2018 Qualcomm Atheros AR956x Wireless Network Adapter Sun Mar 11 17:47:24 2018 Index = 3 Sun Mar 11 17:47:24 2018 GUID = {0DA4B4C5-B289-4A35-AB8A-641EAB5D0E42} Sun Mar 11 17:47:24 2018 IP = 192.168.1.113/255.255.255.0 Sun Mar 11 17:47:24 2018 MAC = 30:52:cb:1e:d5:57 Sun Mar 11 17:47:24 2018 GATEWAY = 192.168.1.1/255.255.255.255 Sun Mar 11 17:47:24 2018 DHCP SERV = 192.168.1.1/255.255.255.255 Sun Mar 11 17:47:24 2018 DHCP LEASE OBTAINED = Sun Mar 11 17:35:27 2018 Sun Mar 11 17:47:24 2018 DHCP LEASE EXPIRES = Mon Mar 12 17:35:27 2018 Sun Mar 11 17:47:24 2018 DNS SERV = 8.8.8.8/255.255.255.255 8.8.4.4/255.255.255.255 Sun Mar 11 17:47:24 2018 Microsoft Wi-Fi Direct Virtual Adapter Sun Mar 11 17:47:24 2018 Index = 14 Sun Mar 11 17:47:24 2018 GUID = {ACBC9A4B-CB03-444D-9103-7DA49E6648E0} Sun Mar 11 17:47:24 2018 IP = 0.0.0.0/0.0.0.0 Sun Mar 11 17:47:24 2018 MAC = 12:52:cb:1e:d5:57 Sun Mar 11 17:47:24 2018 GATEWAY = 0.0.0.0/255.255.255.255 Sun Mar 11 17:47:24 2018 DHCP SERV = Sun Mar 11 17:47:24 2018 DHCP LEASE OBTAINED = Sun Mar 11 17:47:24 2018 Sun Mar 11 17:47:24 2018 DHCP LEASE EXPIRES = Sun Mar 11 17:47:24 2018 Sun Mar 11 17:47:24 2018 DNS SERV = Sun Mar 11 17:47:24 2018 Microsoft Hosted Network Virtual Adapter Sun Mar 11 17:47:24 2018 Index = 11 Sun Mar 11 17:47:24 2018 GUID = {7BA3B088-005A-43E2-A327-6909EED06EFA} Sun Mar 11 17:47:24 2018 IP = 0.0.0.0/0.0.0.0 Sun Mar 11 17:47:24 2018 MAC = 52:52:cb:1e:d5:57 Sun Mar 11 17:47:24 2018 GATEWAY = 0.0.0.0/255.255.255.255 Sun Mar 11 17:47:24 2018 DNS SERV = Sun Mar 11 17:47:24 2018 Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) Sun Mar 11 17:47:24 2018 MANAGEMENT: >STATE:1520779644,CONNECTED,ERROR,10.132.253.27,195.208.245.16
